1 Flash-Turtle Китай Весь мир | |
Buzzers Transducer, Externally Driven Piezo Through Hole PC Pins | запрос 7 дней склад 33612 шт |
6 Position Circular Connector Receptacle, Male Pins Solder Cup | запрос 7 дней склад 35985 шт |
53 Position Circular Connector Receptacle, Male Pins Crimp | запрос 7 дней склад 7322 шт |
Еще 1 строка | |
53 Position Circular Connector Receptacle, Male Pins Crimp | запрос 7 дней склад 10861 шт |
2 Akcel Китай Весь мир | |
Oscillator MEMS 40MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BI-23-25N-40.00 0000Oscillator MEMS 40MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.5V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 100MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BI-23-18N-100.0 00000Oscillator MEMS 100MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 1.8V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 19.6608MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008BI-23-18S-19.66 0800Oscillator MEMS 19.6608MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 1.8V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Еще 692 строки | |
Oscillator MEMS 1.8432MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008BI-23-30N-1.843 200Oscillator MEMS 1.8432MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 8MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BI-23-30N-8.000 000Oscillator MEMS 8MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 31.25MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008BC-23-25N-31.25 0000Oscillator MEMS 31.25MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.5V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 27MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BC-23-28N-27.00 0000Oscillator MEMS 27MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.8V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 48MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BC-23-30S-48.00 0000Oscillator MEMS 48MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 19.6608MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008BC-23-33S-19.66 0800Oscillator MEMS 19.6608MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 3.3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 20MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BC-23-XXE-20.00 0000Oscillator MEMS 20MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.5V/2.8V/3V/3.3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 52MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BI-23-33N-52.00 0000Oscillator MEMS 52MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 3.3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 16.384MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008BI-23-33N-16.38 4000Oscillator MEMS 16.384MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 3.3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 18.432MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008AI-23-XXE-18.43 2000Oscillator MEMS 18.432MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.5V/2.8V/3V/3.3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 12.288MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008AI-23-28S-12.28 8000Oscillator MEMS 12.288MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.8V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 40MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BI-23-28E-40.00 0000Oscillator MEMS 40MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.8V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 3.6864MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008BI-23-30S-3.686 400Oscillator MEMS 3.6864MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 52MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% ... Далее SIT8008BI-23-28E-52.00 0000Oscillator MEMS 52MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.8V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 19.2MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55 ... Далее SIT8008AC-23-XXS-19.20 0000Oscillator MEMS 19.2MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.5V/2.8V/3V/3.3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 19.6608MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008AC-23-XXS-19.66 0800Oscillator MEMS 19.6608MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 2.5V/2.8V/3V/3.3V 4-Pin QFN SMD Bulk | запрос от 1 шт |
Oscillator MEMS 31.25MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS ... Далее SIT8008AC-23-18E-31.25 0000Oscillator MEMS 31.25MHz ±50ppm (Stability) 15pF HCMOS/LVCMOS 55% 1.8V 4-Pin QFN SMD Bulk | запрос от 1 шт |
3 Utmel Китай Весь мир | |
IC & Component Sockets STRIP LINE SOCKETS 23 PINS GOLD | запрос от 1 шт 5-7 дней склад 3423 шт |
IC & Component Sockets SINGLE ROW COLLET SOLDER TAIL 23 PINS | запрос от 1 шт 5-7 дней склад 3999 шт |
Rectangular Contact Inserts, Pin, Pin, 30 Pole Configuration, Crimp, ... Далее DMC-MR 30-23 PCRectangular Contact Inserts, Pin, Pin, 30 Pole Configuration, Crimp, Wire-to-Wire, 30 Position, Sealable, 26 - 22 AWG Wire Size | запрос от 1 шт 5-7 дней склад 8583 шт |
Еще 24 строки | |
Rectangular Contact Inserts, Pin, Pin, 30 Pole Configuration, Crimp, ... Далее DMC-MR 30-23 PBRectangular Contact Inserts, Pin, Pin, 30 Pole Configuration, Crimp, Wire-to-Wire, 30 Position, Sealable, 26 - 22 AWG Wire Size | запрос от 1 шт 5-7 дней склад 1318 шт |
Circular MIL Spec Connector 6P Sz 23 Pin Jam Nut Rcpt | 38 383 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 32 227 ₽ | |
36 210 ₽ от 10 шт 5-7 дней склад 1 шт | |
34 161 ₽ от 100 шт 5-7 дней склад 1 шт | |
32 227 ₽ от 1000 шт 5-7 дней склад 1 шт | |
Conn MIL-DTL-38999 Circular PIN 6 POS Crimp ST Cable Mount 6 Terminal ... Далее TV06RW-23-6PB-LCConn MIL-DTL-38999 Circular PIN 6 POS Crimp ST Cable Mount 6 Terminal 1 Port | 14 557 ₽ от 1 шт 5-7 дней склад 23 шт |
Еще 3 цен: … 12 222 ₽ | |
13 733 ₽ от 10 шт 5-7 дней склад 23 шт | |
12 956 ₽ от 100 шт 5-7 дней склад 23 шт | |
12 222 ₽ от 1000 шт 5-7 дней склад 23 шт | |
TV 6C 6#8(TWINAX) PIN PLUG | 32 303 ₽ от 1 шт 5-7 дней склад 23 шт |
Еще 3 цен: … 27 122 ₽ | |
30 475 ₽ от 10 шт 5-7 дней склад 23 шт | |
28 750 ₽ от 100 шт 5-7 дней склад 23 шт | |
27 122 ₽ от 1000 шт 5-7 дней склад 23 шт | |
AMPHENOL TV06RGQF-23-6PC-LC CIRCULAR, SIZE 23, 6WAYS, PIN (L/C) | запрос от 1 шт 5-7 дней склад 3483 шт |
AMPHENOL TV06RQW-23-6PA-LC CIRCULAR, SIZE 23, 6WAYS, PIN (L/C) | 28 480 ₽ от 1 шт 5-7 дней склад 52 шт |
Еще 3 цен: … 23 913 ₽ | |
26 868 ₽ от 10 шт 5-7 дней склад 52 шт | |
25 347 ₽ от 100 шт 5-7 дней склад 52 шт | |
23 913 ₽ от 1000 шт 5-7 дней склад 52 шт | |
AMPHENOL TV06RQW-23-6P-LC CIRCULAR, SIZE 23, 6WAYS, PIN (L/C) | 33 681 ₽ от 1 шт 5-7 дней склад 52 шт |
Еще 3 цен: … 28 279 ₽ | |
31 775 ₽ от 10 шт 5-7 дней склад 52 шт | |
29 976 ₽ от 100 шт 5-7 дней склад 52 шт | |
28 279 ₽ от 1000 шт 5-7 дней склад 52 шт | |
AMPHENOL TV06RW-23-54PA-LC CIRCULAR, SIZE 23, 53WAYS, PIN (L/C) | 12 418 ₽ от 1 шт 5-7 дней склад 397 шт |
Еще 3 цен: … 10 426 ₽ | |
11 715 ₽ от 10 шт 5-7 дней склад 397 шт | |
11 052 ₽ от 100 шт 5-7 дней склад 397 шт | |
10 426 ₽ от 1000 шт 5-7 дней склад 397 шт | |
AMPHENOL TV06RW-23-53P-LC CIRCULAR, SIZE 23, 53WAYS, PIN (L/C) | 52 781 ₽ от 1 шт 5-7 дней склад 89 шт |
Еще 3 цен: … 44 316 ₽ | |
49 794 ₽ от 10 шт 5-7 дней склад 89 шт | |
46 975 ₽ от 100 шт 5-7 дней склад 89 шт | |
44 316 ₽ от 1000 шт 5-7 дней склад 89 шт | |
AMPHENOL TVP00RW-23-53P-LC CIRCULAR, SIZE 23, 53WAYS, PIN (L/C) | 47 779 ₽ от 1 шт 5-7 дней склад 56 шт |
Еще 3 цен: … 40 116 ₽ | |
45 074 ₽ от 10 шт 5-7 дней склад 56 шт | |
42 523 ₽ от 100 шт 5-7 дней склад 56 шт | |
40 116 ₽ от 1000 шт 5-7 дней склад 56 шт | |
AMPHENOL TVPS00RF-23-21PD CIRCULAR, SIZE 23, 21WAYS, PIN | 47 390 ₽ от 1 шт 5-7 дней склад 36 шт |
Еще 3 цен: … 39 790 ₽ | |
44 708 ₽ от 10 шт 5-7 дней склад 36 шт | |
42 177 ₽ от 100 шт 5-7 дней склад 36 шт | |
39 790 ₽ от 1000 шт 5-7 дней склад 36 шт | |
AMPHENOL CTVS07RF-23-54PA CIRCULAR, SIZE 23, 53WAYS, PIN | 25 947 ₽ от 1 шт 5-7 дней склад 12 шт |
Еще 3 цен: … 21 786 ₽ | |
24 478 ₽ от 10 шт 5-7 дней склад 12 шт | |
23 093 ₽ от 100 шт 5-7 дней склад 12 шт | |
21 786 ₽ от 1000 шт 5-7 дней склад 12 шт | |
AMPHENOL TV06RQW-23-6PA CIRCULAR, SIZE 23, 6WAYS, PIN | 108 304 ₽ от 1 шт 5-7 дней склад 52 шт |
Еще 3 цен: … 103 291 ₽ | |
104 742 ₽ от 10 шт 5-7 дней склад 52 шт | |
104 014 ₽ от 100 шт 5-7 дней склад 52 шт | |
103 291 ₽ от 1000 шт 5-7 дней склад 52 шт | |
CIRCULAR, SIZE 23, 55WAYS, PIN (L/C) | 49 506 ₽ от 1 шт 5-7 дней склад 49 шт |
Еще 3 цен: … 41 566 ₽ | |
46 704 ₽ от 10 шт 5-7 дней склад 49 шт | |
44 060 ₽ от 100 шт 5-7 дней склад 49 шт | |
41 566 ₽ от 1000 шт 5-7 дней склад 49 шт | |
CIRCULAR, SIZE 23, 100WAY, PIN (L/C) | 49 503 ₽ от 1 шт 5-7 дней склад 49 шт |
Еще 3 цен: … 41 563 ₽ | |
46 701 ₽ от 10 шт 5-7 дней склад 49 шт | |
44 057 ₽ от 100 шт 5-7 дней склад 49 шт | |
41 563 ₽ от 1000 шт 5-7 дней склад 49 шт | |
... 6355-0002-23 D-SUB pin strip set ... ° Number of pins (num): 25 Solder ... Далее 6355-0002-23encitech DTZK25-DMP-K 6355-0002-23 D-SUB pin strip set 180 ° Number of pins (num): 25 Solder bucket 1 Set | запрос от 1 шт 5-7 дней склад 9196 шт |
CIRCULAR, SIZE 23, 100WAYS, PIN (L/C) | 47 779 ₽ от 1 шт 5-7 дней склад 49 шт |
45 074 ₽ от 10 шт 5-7 дней склад 49 шт | |
42 523 ₽ от 100 шт 5-7 дней склад 49 шт | |
40 116 ₽ от 1000 шт 5-7 дней склад 49 шт | |
4 ТМ Электроникс Санкт-Петербург Россия | |
Converter; D-Sub 15pin HD socket,HDMI plug,Jack 3.5mm socket | 2 762 ₽ от 1 шт 5-10 дней склад 10 шт |
Еще 3 цен: … 1 847 ₽ | |
2 372 ₽ от 5 шт 5-10 дней склад 10 шт | |
2 106 ₽ от 10 шт 5-10 дней склад 10 шт | |
1 847 ₽ от 20 шт 5-10 дней склад 10 шт | |
Рефлектор; круглая; металл; H: 23,9мм; Ø: 50мм | 1 279 ₽ от 1 шт 5-10 дней склад 23 шт |
Еще 4 цен: … 832 ₽ | |
905 ₽ от 10 шт 5-10 дней склад 23 шт | |
863 ₽ от 28 шт 5-10 дней склад 23 шт | |
845 ₽ от 112 шт 5-10 дней склад 23 шт | |
832 ₽ от 252 шт 5-10 дней склад 23 шт | |
Гнездо; RJ45; PIN: 8; экранированный,PoE+,с LED; Конф: 8p8c; THT | 3 029 ₽ от 1 шт 5-10 дней склад 23 шт |
Еще 3 цен: … 2 119 ₽ | |
2 731 ₽ от 3 шт 5-10 дней склад 23 шт | |
2 430 ₽ от 10 шт 5-10 дней склад 23 шт | |
2 119 ₽ от 40 шт 5-10 дней склад 23 шт | |
Еще 7 строк | |
Разъем: FFC/FPC; горизонтальный; PIN: 23; SMT; 0,3мм; позолота; 30В | 458 ₽ от 1 шт 5-10 дней склад 15902 шт |
Еще 4 цен: … 355 ₽ | |
397 ₽ от 10 шт 5-10 дней склад 15902 шт | |
380 ₽ от 25 шт 5-10 дней склад 15902 шт | |
372 ₽ от 50 шт 5-10 дней склад 15902 шт | |
355 ₽ от 100 шт 5-10 дней склад 15902 шт | |
... ;папа"; вилка; на провод; PIN: 23 Далее HD 36-24-23 PN-059Разъем: провод-провод; HD30; "папа"; вилка; на провод; PIN: 23 | 38 488 ₽ от 1 шт 5-10 дней склад 2 шт |
Еще 3 цен: … 26 942 ₽ | |
34 556 ₽ от 5 шт 5-10 дней склад 2 шт | |
30 905 ₽ от 10 шт 5-10 дней склад 2 шт | |
26 942 ₽ от 50 шт 5-10 дней склад 2 шт | |
Socket; RJ45; PIN: 8; shielded,with LED; Layout: 8p8c; THT; angled | 2 111 ₽ от 1 шт 5-10 дней склад 166 шт |
Еще 4 цен: … 1 344 ₽ | |
1 920 ₽ от 5 шт 5-10 дней склад 166 шт | |
1 729 ₽ от 15 шт 5-10 дней склад 166 шт | |
1 535 ₽ от 30 шт 5-10 дней склад 166 шт | |
1 344 ₽ от 50 шт 5-10 дней склад 166 шт | |
Socket; RJ45; PIN: 8; shielded,with LED; Layout: 8p8c; THT; angled | 1 991 ₽ от 1 шт 5-10 дней склад 2440 шт |
Еще 4 цен: … 1 576 ₽ | |
1 800 ₽ от 10 шт 5-10 дней склад 2440 шт | |
1 701 ₽ от 25 шт 5-10 дней склад 2440 шт | |
1 659 ₽ от 40 шт 5-10 дней склад 2440 шт | |
1 576 ₽ от 80 шт 5-10 дней склад 2440 шт | |
Реле времени; 0,1с÷100ч; 4PDT; 250ВAC/6А; 12ВDC; -20÷60°C; PIN: 14 | 8 431 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 2 цен: … 7 277 ₽ | |
7 905 ₽ от 5 шт 5-10 дней склад 1 шт | |
7 277 ₽ от 10 шт 5-10 дней склад 1 шт | |
D-Sub; PIN: 25; вилка; "мама"; пайка; на провод; черный | 1 399 ₽ от 1 шт 5-10 дней склад 8 шт |
Еще 3 цен: … 981 ₽ | |
1 261 ₽ от 5 шт 5-10 дней склад 8 шт | |
1 120 ₽ от 25 шт 5-10 дней склад 8 шт | |
981 ₽ от 100 шт 5-10 дней склад 8 шт | |
D-Sub; PIN: 25; вилка; "папа"; пайка; на провод; черный | 3 304 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 3 цен: … 2 294 ₽ | |
2 940 ₽ от 5 шт 5-10 дней склад 1 шт | |
2 621 ₽ от 25 шт 5-10 дней склад 1 шт | |
2 294 ₽ от 100 шт 5-10 дней склад 1 шт | |
5 Acme Chip Китай Весь мир | |
Rectifier Diode, 1 Phase, 1 Element, 5A, 400V V(RRM), Silicon, ROHS ... Далее EGP50G-E3/23Rectifier Diode, 1 Phase, 1 Element, 5A, 400V V(RRM), Silicon, ROHS COMPLIANT, PLASTIC, GP20, 2 PIN | запрос 7 дней склад 2721 шт |
6 Онлайн Компоненты Москва Россия | |
Реле питания, 3PCO, 230 В, 10 А, REPOL 11-Pin R15 Series, DIN-рейка, ... Далее R15-2013-23-5230-WTLРеле питания, 3PCO, 230 В, 10 А, REPOL 11-Pin R15 Series, DIN-рейка, AC | 2 096 ₽ от 1 шт |
Еще 3 цен: … 1 510 ₽ | |
1 797 ₽ от 5 шт | |
1 645 ₽ от 25 шт | |
1 510 ₽ от 100 шт | |
Pin Header, Board-to-Board, 2.54 мм, 2 ряд(-ов), 2 контакт(-ов), ... Далее TSW-101-23-L-DPin Header, Board-to-Board, 2.54 мм, 2 ряд(-ов), 2 контакт(-ов), Through Hole Straight | 63.3 ₽ от 10 шт 5-12 дней склад 880 шт |
Еще 5 цен: … 23.0 ₽ | |
34.6 ₽ от 100 шт 5-12 дней склад 880 шт | |
29.6 ₽ от 500 шт 5-12 дней склад 880 шт | |
27.3 ₽ от 1000 шт 5-12 дней склад 880 шт | |
25.3 ₽ от 2500 шт 5-12 дней склад 880 шт | |
23.0 ₽ от 5000 шт 5-12 дней склад 880 шт | |
Pin Header, Board-to-Board, 2.54 мм, 1 ряд(-ов), 50 контакт(-ов), ... Далее TSW-150-23-T-SPin Header, Board-to-Board, 2.54 мм, 1 ряд(-ов), 50 контакт(-ов), Сквозное Отверстие, TSW Series | 526 ₽ от 1 шт 5-12 дней склад 71 шт |
Еще 5 цен: … 296 ₽ | |
405 ₽ от 10 шт 5-12 дней склад 71 шт | |
351 ₽ от 100 шт 5-12 дней склад 71 шт | |
328 ₽ от 250 шт 5-12 дней склад 71 шт | |
305 ₽ от 500 шт 5-12 дней склад 71 шт | |
296 ₽ от 1000 шт 5-12 дней склад 71 шт | |
7 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
Разъём 23 pin, шаг 1mm 02 Май 2024 04:23 разъем под гибкий шлейф | 39.0 ₽ Доставка: есть Самовывоз: есть на складе |
... Chip 1, Package Type SOT-23, Pin Count 3, Zener Type Voltage ... Далее BZX84C24V SOT-23 T&R RoHS Hottech стаб-диод Зенера ... Voltage Number of Elements per Chip 1, Package Type SOT-23, Pin Count 3, Zener Type Voltage Regulator. | 1 249 ₽ Доставка: есть Самовывоз: есть на складе |
Герметичные разъемы.Длина в сборе, мм: 2 x 200 ± 10Вес брутто: ... Далее BLHK16-8PB 8 pinГерметичные разъемы.Длина в сборе, мм: 2 x 200 ± 10Вес брутто: 51.80Транспортная упаковка: размер/кол-во: 42*28*23.5/250Количество ... | 316 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 8 строк | |
Кнопка 6*6, ручка 1,5мм(2pin)/6*6*5 | 6.00 ₽ Доставка: есть Самовывоз: есть на складе |
Выключатели DIP | 72.0 ₽ Доставка: есть Самовывоз: есть на складе |
39.0 ₽ Доставка: есть Самовывоз: есть на складе | |
44.0 ₽ Доставка: есть Самовывоз: есть на складе | |
Пусковые конденсаторы.Тип: CBB61Тип разъёма: 4 клеммыНоминальная ... Далее CBB61 1.5 uF 450V 4 PIN (SAIFU)Пусковые конденсаторы.Тип: CBB61Тип разъёма: 4 клеммыНоминальная емкость: 1,5 мкФДопуск номинальной емкости: ± 5 %Рабочее напряжение: ... | 42.0 ₽ Доставка: есть Самовывоз: есть на складе |
Пусковые конденсаторы.Тип: CBB61Тип разъёма: 4 клеммыНоминальная ... Далее CBB61 1.2 uF 450V 4 PIN (SAIFU)Пусковые конденсаторы.Тип: CBB61Тип разъёма: 4 клеммыНоминальная емкость: 1,2 мкФДопуск номинальной емкости: ± 5 %Рабочее напряжение: ... | 40.0 ₽ Доставка: есть Самовывоз: есть на складе |
Пусковые конденсаторы.Тип: CBB61Тип разъёма: 4 клеммыНоминальная ... Далее CBB61 1 uF 450V 4 PIN (SAIFU)Пусковые конденсаторы.Тип: CBB61Тип разъёма: 4 клеммыНоминальная емкость: 1 мкФДопуск номинальной емкости: ± 5 %Рабочее напряжение: ... | 28.0 ₽ Доставка: есть Самовывоз: есть на складе |
10,374.92 | 13 620 ₽ Доставка: есть Самовывоз: есть на складе |
8 ЕКОМП Санкт-Петербург Россия | |
Штыри 2x3 конт. шаг 2.54 мм, верт. на плату (3.0/ 6.1 мм) (ан. PLD-6/ PLD-06) Connfly DS1021-2*3 SF11 - DS1021-2*3 SF11 Connfly 03 Май 2024 01:50 Штыри двухрядные 2x3 конт. шаг 2.54 мм, вертик. на плату (3.0 мм/ 6.1 ... Далее Штыри 2x3 конт. шаг 2.54 мм, верт. на плату (3.0/ 6.1 мм) (ан. PLD-6/ PLD-06) Connfly DS1021-2*3 SF11 - DS1021-2*3 SF11Штыри двухрядные 2x3 конт. шаг 2.54 мм, вертик. на плату (3.0 мм/ 6.1 мм), позол. (DS1021-2*3SF11-B) | 1.60 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
9 ЭК ЗИП Москва Россия | |
Цилиндрические малогабаритные | 198 ₽ от 1 шт 4-5 недель |
Еще 2 цен: … 130 ₽ | |
137 ₽ от 8 шт 4-5 недель | |
130 ₽ от 74 шт 4-5 недель | |
Цилиндрические малогабаритные | 310 ₽ от 1 шт 4-5 недель |
Еще 2 цен: … 203 ₽ | |
214 ₽ от 5 шт 4-5 недель | |
203 ₽ от 47 шт 4-5 недель | |
Еще 1 строка | |
10 ЗУМ-СМД Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 600 руб. | |
CBB65 (2+3+4PINS) ALUMINUM 03 Фев 2024 16:47 | запрос от 600 ₽ от 7 дней |
запрос от 600 ₽ от 7 дней 0, 005 | |
запрос от 600 ₽ от 7 дней 0, 01 | |
Еще 12 строк | |
запрос от 600 ₽ от 7 дней 0, 095 | |
запрос от 600 ₽ от 7 дней 0, 09 | |
запрос от 600 ₽ от 7 дней 0, 025 | |
запрос от 600 ₽ от 7 дней 0, 04 | |
запрос от 600 ₽ от 7 дней 0, 105 | |
запрос от 600 ₽ от 7 дней 0, 02 | |
запрос от 600 ₽ от 7 дней 0, 045 | |
запрос от 600 ₽ от 7 дней 0, 03 | |
11 ЭФО Санкт-Петербург Россия Филиалы: Москва Казань Екатеринбург Ростов-на-Дону Пермь Нижний Новгород Новосибирск | |
206151-1 КОРПУС CPC size 23/37 PIN фланец Стандартный цилиндрический ... Далее 206151-1206151-1 КОРПУС CPC size 23/37 PIN фланец Стандартный цилиндрический соединитель | запрос Цена рассчитана по курсу ЦБ РФ. Точную цену уточняйте у поставщика |
12 Industrial Module Москва Россия | |
Current supply cable, M12, 5-pin cable box, shielded cable, 10 m, open ... Далее CMX-23Current supply cable, M12, 5-pin cable box, shielded cable, 10 m, open end, IP 65 | 6 604 ₽ 7-28 дней на складе |
13 T-electron Раменское, Московская обл. Россия и страны СНГ | |
запрос да | |
6.10 ₽ до 5 дней | |
10.0 ₽ до 5 дней | |
Еще 4 строки | |
Шлейф 0, 5mm 30pin 23/1, 5cm 20 Ноя 2023 00:56 | 50.0 ₽ да |
Шлейф 1mm 16pin 23/1, 7cm 20 Ноя 2023 00:56 | 50.0 ₽ да |
Шлейф 1mm 24pin 23/2, 5cm 20 Ноя 2023 00:56 | 50.0 ₽ да |
28.0 ₽ до 5 дней | |
14 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
Плоская круглая батарея 3V 20 X 3.2 MM 200mA | запрос 7-14 дней |
... панели для ИС и компонентов PIN LINE COLLET SCKT SOLDER TAIL 23 PINS Далее 23-0513-11HУстановочные панели для ИС и компонентов PIN LINE COLLET SCKT SOLDER TAIL 23 PINS | запрос 7-14 дней |
... и компонентов ELEVATOR STRIP LINE 23 PINS Далее 23-7400-10Установочные панели для ИС и компонентов ELEVATOR STRIP LINE 23 PINS | запрос 7-14 дней |
Еще 10 строк | |
... клеммы и зажимы .100/.295 23 PIN HDR STR Далее 929400-01-23-RKПроводные клеммы и зажимы .100/.295 23 PIN HDR STR | запрос 7-14 дней |
... клеммы и зажимы .100/.295 23 PIN HDR RT ANG Далее 929550-01-23-IПроводные клеммы и зажимы .100/.295 23 PIN HDR RT ANG | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.410 Далее 929647-03-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.410 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.510 Далее 929665-04-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.510 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.310 Далее 929836-08-23Проводные клеммы и зажимы .100 STR 23 PIN .235-.310 | запрос 7-14 дней |
... / технические характеристики соединителя 53P SIZE 23 PIN TRI-START Далее TV06RW-23-54PКруговой мил / технические характеристики соединителя 53P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... характеристики соединителя 53 P SIZE 23 PIN TRI-START Далее TV07RW-23-54PN-W52Круговой мил / технические характеристики соединителя 53 P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... / технические характеристики соединителя 100P SZ 23 PIN CABLE MOUNT Далее TVS06RF-23-35PBКруговой мил / технические характеристики соединителя 100P SZ 23 PIN CABLE MOUNT | запрос 7-14 дней |
... характеристики соединителя Plug 5P SZ:23 PIN;TRI-START Далее TVS06RF-23-54PAКруговой мил / технические характеристики соединителя Plug 5P SZ:23 PIN;TRI-START | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3100-160-23-L104INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
15 Десси Москва Россия | |
... Type:SMD; Case Style:SOT-23; Pins, No. of:3; Capacitance, Total ... Далее PIN диод HSMP-3820-TR1G ... SWITCHING; Diode Type:RF; Termination Type:SMD; Case Style:SOT-23; Pins, No. of:3; Capacitance, Total Ct Max:1pF; Current, If ... | 79.0 ₽ |
16 МосЧип Москва Россия | |
... панели для ИС и компонентов PIN LINE HEAD 23 PIN SCREW MACHINE CONT Далее 23-0625-70Установочные панели для ИС и компонентов PIN LINE HEAD 23 PIN SCREW MACHINE CONT | запрос 7-14 дней |
... клеммы и зажимы .100/.295 23 PIN HDR RT ANG Далее 929500-01-23Проводные клеммы и зажимы .100/.295 23 PIN HDR RT ANG | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.410 Далее 929665-03-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.410 | запрос 7-14 дней |
Еще 38 строк | |
... клеммы и зажимы .100 STR 23 PIN .318-.410 Далее 929715-03-23-IПроводные клеммы и зажимы .100 STR 23 PIN .318-.410 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.410 Далее 929834-03-23Проводные клеммы и зажимы .100 STR 23 PIN .235-.410 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.510 Далее 929834-04-23Проводные клеммы и зажимы .100 STR 23 PIN .235-.510 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.610 Далее 929834-05-23Проводные клеммы и зажимы .100 STR 23 PIN .235-.610 | запрос 7-14 дней |
... и зажимы .100 RT ANG 23 PIN .235-.110 Далее 929835-01-23-RKПроводные клеммы и зажимы .100 RT ANG 23 PIN .235-.110 | запрос 7-14 дней |
... и зажимы .100 RT ANG 23 PIN .235-.145 Далее 929838-04-23-RKПроводные клеммы и зажимы .100 RT ANG 23 PIN .235-.145 | запрос 7-14 дней |
Проводные клеммы и зажимы 23P PIN STRP HDR SR DUAL INSUL BD STCKNG | запрос 7-14 дней |
CONN RECEPT PIN .045-.065 .293 | запрос 7-14 дней |
Bulk Metal Foil Technology 4 Pin Transistor Outline Hermetic Resistor ... Далее 14030-H-A-.277-23Bulk Metal Foil Technology 4 Pin Transistor Outline Hermetic Resistor Network | запрос 7-14 дней |
Круговой мил / технические характеристики соединителя WALL RCPT TAP ... Далее 180-060XWS7-23-21PNКруговой мил / технические характеристики соединителя WALL RCPT TAP HOLE 21CH PIN INSRT NORM | запрос 7-14 дней |
CONN RECEPT PIN .117D .100L | запрос 7-14 дней |
CONN RECEPT PIN | запрос 7-14 дней |
Проводные клеммы и зажимы 46P PIN STRP HDR DR DUAL INSUL BD STCKNG | запрос 7-14 дней |
Оборудование для печатных плат - PCB PIN RCPT PRESS FIT | запрос 7-14 дней |
17 Аудиомания Москва Россия, Беларусь, Казахстан | |
Всенаправленный головной микрофон с фиксированным разъемом 4-pin мини- ... Далее MU-23 BeigeВсенаправленный головной микрофон с фиксированным разъемом 4-pin мини-XLR. Миниатюрный капсюль диаметром 3 мм. Штангу микрофона можно носить ... | 15 985 ₽ Доставка: есть Самовывоз: есть на складе |
18 ЧипСити Москва Россия | |
0625 Pin-Line Hdr Scrw Mach Cont | 672 ₽ 3-7 дней склад 1073 шт |
0625 Pin-Line Hdr Scrw Mach Cont | 841 ₽ 3-7 дней склад 1098 шт |
0625 Pin-Line Hdr Scrw Mach Cont | 854 ₽ 3-7 дней склад 882 шт |
Еще 39 строк | |
IC & Component Sockets PIN LINE HEAD 23Pin SCREW MACHINE CONT | 951 ₽ 3-7 дней склад 920 шт |
0625 Pin-Line Hdr Scrw Mach Cont | 1 000 ₽ 3-7 дней склад 1221 шт |
0625 Pin-Line Hdr Scrw Mach Cont | 1 362 ₽ 3-7 дней склад 1030 шт |
0625 Pin-Line Hdr Scrw Mach Cont | 1 350 ₽ 3-7 дней склад 891 шт |
ar PIN 23POS ST Jam Nut 23 Terminal 1Port /search.html?q = D38999%2F24FE99AN& utm_source = rlocman&utm_medium = s242 - 28 Апр 2024 02:15 | запрос 3-7 дней |
IC & Component Sockets STRIP LINE 23Pins COINED CONTACT | 304 ₽ 3-7 дней склад 1263 шт |
IC & Component Sockets STRIP LINE 23Pins COINED CONTACT | 437 ₽ 3-7 дней склад 1102 шт |
Conn Fiber Optic Test Adapter PIN/PIN 21POS ST 21 Terminal 1Port | 113 851 ₽ 3-7 дней склад 314 шт |
Conn Fiber Optic Test Adapter PIN/PIN 21POS ST 21 Terminal 1Port | 133 317 ₽ 3-7 дней склад 182 шт |
Conn MIL-DTL-38999 Circular PIN 53POS Crimp ST Wall Mount 53 Terminal ... Далее TVPS00RF-23-54PAConn MIL-DTL-38999 Circular PIN 53POS Crimp ST Wall Mount 53 Terminal 1Port | 8 863 ₽ 3-7 дней склад 332 шт |
Conn MIL-DTL-38999 Circular PIN 100POS Crimp ST Cable Mount 100 ... Далее LJT06RE-23-35PConn MIL-DTL-38999 Circular PIN 100POS Crimp ST Cable Mount 100 Terminal 1Port | 9 459 ₽ 3-7 дней склад 282 шт |
Conn Subminiature Cylindrical PIN 100POS Crimp ST Jam Nut 100 Terminal ... Далее CTVS07RF-23-35PConn Subminiature Cylindrical PIN 100POS Crimp ST Jam Nut 100 Terminal 1Port | 12 449 ₽ 3-7 дней склад 104 шт |
Conn MIL-DTL-38999 Circular PIN 100POS Crimp ST Cable Mount 100 ... Далее CTV06RW-23-35PBConn MIL-DTL-38999 Circular PIN 100POS Crimp ST Cable Mount 100 Terminal 1Port | 9 985 ₽ 3-7 дней склад 363 шт |
Conn Subminiature Cylindrical PIN 6POS Crimp ST Wall Mount 6 Terminal ... Далее TVP00RQW-23-6P-LCConn Subminiature Cylindrical PIN 6POS Crimp ST Wall Mount 6 Terminal 1Port | 19 516 ₽ 3-7 дней склад 150 шт |
Conn MIL-DTL-38999 Circular PIN 100POS Crimp ST Cable Mount 100 ... Далее TVS06RF-23-35PConn MIL-DTL-38999 Circular PIN 100POS Crimp ST Cable Mount 100 Terminal 1Port | 7 361 ₽ 3-7 дней склад 760 шт |
Conn MIL-DTL-38999 Circular PIN 55POS Crimp ST Cable Mount 55 Terminal ... Далее TV06RW-23-55PConn MIL-DTL-38999 Circular PIN 55POS Crimp ST Cable Mount 55 Terminal 1Port | 8 457 ₽ 3-7 дней склад 501 шт |
Conn MIL-DTL-38999 Circular PIN 100POS Crimp ST Cable Mount 100 ... Далее TV06RW-23-35PConn MIL-DTL-38999 Circular PIN 100POS Crimp ST Cable Mount 100 Terminal 1Port | 6 738 ₽ 3-7 дней склад 468 шт |
19 Элитан Ижевск Россия Безнал. расчет Филиалы: Москва Санкт-Петербург Екатеринбург Новосибирск | |
FWB091-G WO pins 2, 3, 6, 7 03 Май 2024 02:24 | 32.5 ₽ |
20 LifeElectronics Санкт-Петербург Россия | |
... панели для ИС и компонентов PIN LINE COLLET SCKT WIRE WRAP 23 PINS Далее 23-0503-30Установочные панели для ИС и компонентов PIN LINE COLLET SCKT WIRE WRAP 23 PINS | запрос 7-14 дней |
... панели для ИС и компонентов PIN LINE COLLET SCKT SOLDER TAIL 23 PINS Далее 23-0513-10Установочные панели для ИС и компонентов PIN LINE COLLET SCKT SOLDER TAIL 23 PINS | запрос 7-14 дней |
... SINGLE ROW COLLET SOLDER TAIL 23 PINS Далее 23-0518-10TУстановочные панели для ИС и компонентов SINGLE ROW COLLET SOLDER TAIL 23 PINS | запрос 7-14 дней |
Еще 13 строк | |
... ИС и компонентов STRIP LINE 23 PINS COINED CONTACT Далее 23-0600-10Установочные панели для ИС и компонентов STRIP LINE 23 PINS COINED CONTACT | запрос 7-14 дней |
... панели для ИС и компонентов PIN LINE HEAD 23 PIN SCREW MACHINE CONT Далее 23-0625-31Установочные панели для ИС и компонентов PIN LINE HEAD 23 PIN SCREW MACHINE CONT | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.210 Далее 929834-02-23Проводные клеммы и зажимы .100 STR 23 PIN .235-.210 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.610 Далее 929836-05-23-RKПроводные клеммы и зажимы .100 STR 23 PIN .235-.610 | запрос 7-14 дней |
... и зажимы .100 RT ANG 23 PIN .235-.405 Далее 929838-02-23Проводные клеммы и зажимы .100 RT ANG 23 PIN .235-.405 | запрос 7-14 дней |
... соединителя 100P STRT PLUG SZ 23 PIN CRMP NO REAR ACC Далее LJT06RT-23-35P (023)Круговой мил / технические характеристики соединителя 100P STRT PLUG SZ 23 PIN CRMP NO REAR ACC | запрос 7-14 дней |
... / технические характеристики соединителя 100P SIZE 23 PIN TRI-START Далее TV06RW-23-35PNКруговой мил / технические характеристики соединителя 100P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... / технические характеристики соединителя 53P SIZE 23 PIN TRI-START Далее TV06RW-23-54PDКруговой мил / технические характеристики соединителя 53P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... / технические характеристики соединителя 6P SIZ 23 PIN TRI-START Далее TV06RW-23-6PA-LCКруговой мил / технические характеристики соединителя 6P SIZ 23 PIN TRI-START | запрос 7-14 дней |
... характеристики соединителя 14P Sz 23 Pin Recept Back Panel Wall ... Далее TVP00RGF-23-14P-LCКруговой мил / технические характеристики соединителя 14P Sz 23 Pin Recept Back Panel Wall Mt | запрос 7-14 дней |
... характеристики соединителя Plug 21P SZ:23 PIN;TRI-START Далее TVS06RF-23-21PAКруговой мил / технические характеристики соединителя Plug 21P SZ:23 PIN;TRI-START | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3100-39-23INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3100-74-23INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
21 ТаймЧипс Санкт-Петербург Россия | |
... панели для ИС и компонентов PIN LINE COLLET SCKT WIRE WRAP 23 PINS Далее 23-0503-21Установочные панели для ИС и компонентов PIN LINE COLLET SCKT WIRE WRAP 23 PINS | запрос 7-14 дней |
... панели для ИС и компонентов PIN LINE HEAD 23 PIN SCREW MACHINE CONT Далее 23-0625-21Установочные панели для ИС и компонентов PIN LINE HEAD 23 PIN SCREW MACHINE CONT | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.910 Далее 929647-07-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.910 | запрос 7-14 дней |
Еще 11 строк | |
... клеммы и зажимы .100 STR 23 PIN .235-.145 Далее 929647-09-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.145 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.210 Далее 929665-02-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.210 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .318-.410 Далее 929710-03-23-RKПроводные клеммы и зажимы .100 STR 23 PIN .318-.410 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .318-.175 Далее 929710-10-23-RKПроводные клеммы и зажимы .100 STR 23 PIN .318-.175 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.410 Далее 929836-03-23-RKПроводные клеммы и зажимы .100 STR 23 PIN .235-.410 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.610 Далее 929836-05-23Проводные клеммы и зажимы .100 STR 23 PIN .235-.610 | запрос 7-14 дней |
... характеристики соединителя 100P Sz 23 Pin Recpt Inline Tri-Start ... Далее TV01RW-23-35PAКруговой мил / технические характеристики соединителя 100P Sz 23 Pin Recpt Inline Tri-Start III | запрос 7-14 дней |
... / технические характеристики соединителя 100P SIZE 23 PIN TRI-START Далее TV06RW-23-35PDКруговой мил / технические характеристики соединителя 100P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... характеристики соединителя 53 P SIZE 23 PIN TRI-START Далее TV07RW-23-54PКруговой мил / технические характеристики соединителя 53 P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... / технические характеристики соединителя 55P SIZE 23 PIN TRI-START Далее TV07RW-23-55PN-W52Круговой мил / технические характеристики соединителя 55P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... характеристики соединителя Plug 21P SZ:23 PIN;TRI-START Далее TVS06RF-23-21P-LCКруговой мил / технические характеристики соединителя Plug 21P SZ:23 PIN;TRI-START | запрос 7-14 дней |
22 DIP8.RU Москва Россия и страны ТС | |
Вилка, провод-плата, мама, Mega-Fit, 5,7мм, PIN: 4, Конф: 2x2, 23А | 120 ₽ от 1 шт 42 дня склад 4098 шт Внешний |
Еще 7 цен: … 70.7 ₽ | |
120 ₽ от 1 шт от 1 дня склад 23 шт Москва | |
94.2 ₽ от 3 шт 42 дня склад 4098 шт Внешний | |
94.2 ₽ от 3 шт от 1 дня склад 23 шт Москва | |
83.2 ₽ от 9 шт от 1 дня склад 23 шт Москва | |
83.2 ₽ от 9 шт 42 дня склад 4098 шт Внешний | |
70.7 ₽ от 27 шт 42 дня склад 4098 шт Внешний | |
70.7 ₽ от 27 шт от 1 дня склад 23 шт Москва | |
... RT360, гнездо, вилка, мама, обжим, PIN: 23, поставляется с контактами Далее RT071823SNH-KРазъем: круглый, Серия: RT360, гнездо, вилка, мама, обжим, PIN: 23, поставляется с контактами | 6 070 ₽ от 1 шт 42 дня склад 21 шт Внешний |
Еще 5 цен: … 4 396 ₽ | |
6 070 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
5 168 ₽ от 5 шт 42 дня склад 21 шт Внешний | |
5 168 ₽ от 5 шт от 1 дня склад 3 шт Москва | |
4 396 ₽ от 20 шт 42 дня склад 21 шт Внешний | |
4 396 ₽ от 20 шт от 1 дня склад 3 шт Москва | |
Вилка, провод-плата, мама, Mega-Fit, 5,7мм, PIN: 2, Конф: 2x1, 23А | 160 ₽ от 1 шт 42 дня склад 1141 шт Внешний |
Еще 7 цен: … 54.3 ₽ | |
160 ₽ от 1 шт от 1 дня склад 9 шт Москва | |
96.1 ₽ от 10 шт 42 дня склад 1141 шт Внешний | |
96.1 ₽ от 10 шт от 1 дня склад 9 шт Москва | |
70.6 ₽ от 100 шт от 1 дня склад 9 шт Москва | |
70.6 ₽ от 100 шт 42 дня склад 1141 шт Внешний | |
54.3 ₽ от 500 шт 42 дня склад 1141 шт Внешний | |
54.3 ₽ от 500 шт от 1 дня склад 9 шт Москва | |
Еще 1 строка | |
Вилка, провод-плата, мама, Mega-Fit, 5,7мм, PIN: 8, Конф: 2x4, 23А | 300 ₽ от 1 шт от 1 дня склад 9 шт Москва |
Еще 3 цен: … 136 ₽ | |
243 ₽ от 10 шт от 1 дня склад 9 шт Москва | |
174 ₽ от 80 шт от 1 дня склад 9 шт Москва | |
136 ₽ от 400 шт от 1 дня склад 9 шт Москва | |
23 TradeElectronics Москва Россия | |
... панели для ИС и компонентов PIN LINE HEAD 23 PIN SCREW MACHINE CONT Далее 23-0625-51Установочные панели для ИС и компонентов PIN LINE HEAD 23 PIN SCREW MACHINE CONT | запрос 7-14 дней |
... клеммы и зажимы .100/.295 23 PIN HDR STR Далее 929450-01-23-IПроводные клеммы и зажимы .100/.295 23 PIN HDR STR | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.610 Далее 929647-05-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.610 | запрос 7-14 дней |
Еще 11 строк | |
... клеммы и зажимы .100 STR 23 PIN .235-.310 Далее 929665-08-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.310 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.145 Далее 929665-09-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.145 | запрос 7-14 дней |
... и зажимы .100 RT ANG 23 PIN .235-.145 Далее 929667-04-23-IПроводные клеммы и зажимы .100 RT ANG 23 PIN .235-.145 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .318-.175 Далее 929715-10-23-IПроводные клеммы и зажимы .100 STR 23 PIN .318-.175 | запрос 7-14 дней |
... и зажимы .100 RT ANG 23 PIN .235-.110 Далее 929835-01-23Проводные клеммы и зажимы .100 RT ANG 23 PIN .235-.110 | запрос 7-14 дней |
... и зажимы .100 RT ANG 23 PIN .235-.405 Далее 929838-02-23-RKПроводные клеммы и зажимы .100 RT ANG 23 PIN .235-.405 | запрос 7-14 дней |
... и зажимы .100 RT ANG 23 PIN .235-.145 Далее 929838-04-23Проводные клеммы и зажимы .100 RT ANG 23 PIN .235-.145 | запрос 7-14 дней |
... / технические характеристики соединителя 6P SIZE 23 PIN TRI-START Далее TV06RQW-23-6P-LCКруговой мил / технические характеристики соединителя 6P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... характеристики соединителя 53 P SIZE 23 PIN TRI-START Далее TV07RW-23-54PAКруговой мил / технические характеристики соединителя 53 P SIZE 23 PIN TRI-START | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3101E/A20-23S (EMCT0870INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
A6D-8103 (EMB:23) 04 Май 2024 18:03 DIP-переключатели / SIP-переключатели 8 Pins Sealed Raised Actuator | запрос 7-14 дней |
24 ICdarom.ru Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
Преобразователь DC-DC повышающий одноканальный вход 2.6....16В выход ... Далее AP3012KTR-E1 DIODES SOT-23-5Преобразователь DC-DC повышающий одноканальный вход 2.6....16В выход 29В 0.5А 5-Pin | 15.4 ₽ розница 3-4 рабочих дня склад 692 шт |
Еще 3 цен: … 10.0 ₽ | |
12.7 ₽ мелкий опт 3-4 рабочих дня склад 692 шт | |
11.2 ₽ средний опт 3-4 рабочих дня склад 692 шт | |
10.0 ₽ крупный опт 3-4 рабочих дня склад 692 шт | |
25 Берёзка Электронные Компоненты Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
Преобразователь DC-DC повышающий одноканальный вход 2.6....16В выход ... Далее AP3012KTR-E1 DIODES SOT-23-5Преобразователь DC-DC повышающий одноканальный вход 2.6....16В выход 29В 0.5А 5-Pin | 16.0 ₽ розница 3-4 рабочих дня склад 692 шт |
Еще 3 цен: … 10.5 ₽ | |
13.3 ₽ мелкий опт 3-4 рабочих дня склад 692 шт | |
11.6 ₽ средний опт 3-4 рабочих дня склад 692 шт | |
10.5 ₽ крупный опт 3-4 рабочих дня склад 692 шт | |
26 ЭИК Санкт-Петербург Россия | |
HEATSINK 35X35X23MM PIN | 2 132 ₽ от 1 шт 21-42 дня склад 127 шт |
Еще 4 цен: … 1 729 ₽ | |
2 075 ₽ от 10 шт 21-42 дня склад 127 шт | |
1 959 ₽ от 25 шт 21-42 дня склад 127 шт | |
1 844 ₽ от 40 шт 21-42 дня склад 127 шт | |
1 729 ₽ от 90 шт 21-42 дня склад 127 шт | |
CONN PIN RCPT .045-.065 SOLDER | 157 ₽ от 1 шт 21-42 дня склад 18163 шт |
Еще 4 цен: … 73.0 ₽ | |
125 ₽ от 25 шт 21-42 дня склад 18163 шт | |
112 ₽ от 100 шт 21-42 дня склад 18163 шт | |
98.0 ₽ от 500 шт 21-42 дня склад 18163 шт | |
73.0 ₽ от 2500 шт 21-42 дня склад 18163 шт | |
CONN PIN RCPT .045-.065 PRESSFIT | 180 ₽ от 1 шт 21-42 дня склад 5071 шт |
Еще 2 цен: … 87.0 ₽ | |
136 ₽ от 100 шт 21-42 дня склад 5071 шт | |
87.0 ₽ от 5000 шт 21-42 дня склад 5071 шт | |
Еще 53 строки | |
CONN PIN RCPT .045-.065 SOLDER | 125 ₽ от 1 шт 21-42 дня склад 2560 шт |
Еще 2 цен: … 57.0 ₽ | |
90.0 ₽ от 100 шт 21-42 дня склад 2560 шт | |
57.0 ₽ от 5000 шт 21-42 дня склад 2560 шт | |
CONN PIN RCPT .045-.065 SOLDER | 169 ₽ от 1 шт 21-42 дня склад 2639 шт |
Еще 2 цен: … 82.0 ₽ | |
129 ₽ от 100 шт 21-42 дня склад 2639 шт | |
82.0 ₽ от 5000 шт 21-42 дня склад 2639 шт | |
CONN PIN RCPT .045-.065 SOLDER | 159 ₽ от 1 шт 21-42 дня склад 18187 шт |
Еще 4 цен: … 75.0 ₽ | |
127 ₽ от 25 шт 21-42 дня склад 18187 шт | |
114 ₽ от 100 шт 21-42 дня склад 18187 шт | |
99.0 ₽ от 500 шт 21-42 дня склад 18187 шт | |
75.0 ₽ от 2500 шт 21-42 дня склад 18187 шт | |
CONN PIN RCPT .045-.065 PRESSFIT | 210 ₽ от 1 шт 21-42 дня склад 2945 шт |
Еще 2 цен: … 101 ₽ | |
159 ₽ от 100 шт 21-42 дня склад 2945 шт | |
101 ₽ от 5000 шт 21-42 дня склад 2945 шт | |
CONN PIN RCPT .045-.065 SOLDER | 193 ₽ от 1 шт 21-42 дня склад 11746 шт |
Еще 4 цен: … 97.0 ₽ | |
157 ₽ от 25 шт 21-42 дня склад 11746 шт | |
147 ₽ от 100 шт 21-42 дня склад 11746 шт | |
120 ₽ от 500 шт 21-42 дня склад 11746 шт | |
97.0 ₽ от 2500 шт 21-42 дня склад 11746 шт | |
CONN PIN RCPT .045-.065 HEX | 290 ₽ от 1 шт 21-42 дня склад 20205 шт |
Еще 4 цен: … 140 ₽ | |
253 ₽ от 10 шт 21-42 дня склад 20205 шт | |
226 ₽ от 100 шт 21-42 дня склад 20205 шт | |
162 ₽ от 1000 шт 21-42 дня склад 20205 шт | |
140 ₽ от 10000 шт 21-42 дня склад 20205 шт | |
HEATSINK 40X40X23MM PIN | 2 410 ₽ от 1 шт 21-42 дня склад 94 шт |
Еще 3 цен: … 1 794 ₽ | |
2 267 ₽ от 10 шт 21-42 дня склад 94 шт | |
1 922 ₽ от 50 шт 21-42 дня склад 94 шт | |
1 794 ₽ от 100 шт 21-42 дня склад 94 шт | |
HEATSINK 19X19X23MM PIN | 1 516 ₽ от 1 шт 21-42 дня склад 464 шт |
Еще 4 цен: … 1 147 ₽ | |
1 474 ₽ от 10 шт 21-42 дня склад 464 шт | |
1 392 ₽ от 25 шт 21-42 дня склад 464 шт | |
1 229 ₽ от 90 шт 21-42 дня склад 464 шт | |
1 147 ₽ от 270 шт 21-42 дня склад 464 шт | |
CONN PIN RCPT .045-.065 PRESSFIT | 421 ₽ от 1 шт 21-42 дня склад 999 шт |
Еще 4 цен: … 208 ₽ | |
367 ₽ от 10 шт 21-42 дня склад 999 шт | |
328 ₽ от 100 шт 21-42 дня склад 999 шт | |
234 ₽ от 1000 шт 21-42 дня склад 999 шт | |
208 ₽ от 5000 шт 21-42 дня склад 999 шт | |
CONN PIN RCPT .045-.065 PRESSFIT | 544 ₽ от 1 шт 21-42 дня склад 1000 шт |
Еще 4 цен: … 283 ₽ | |
494 ₽ от 10 шт 21-42 дня склад 1000 шт | |
435 ₽ от 100 шт 21-42 дня склад 1000 шт | |
316 ₽ от 1000 шт 21-42 дня склад 1000 шт | |
283 ₽ от 5000 шт 21-42 дня склад 1000 шт | |
CONN PC PIN CIRC 0.072DIA GOLD | 227 ₽ от 1 шт 21-42 дня склад 999 шт |
Еще 3 цен: … 104 ₽ | |
191 ₽ от 10 шт 21-42 дня склад 999 шт | |
125 ₽ от 1000 шт 21-42 дня склад 999 шт | |
104 ₽ от 10000 шт 21-42 дня склад 999 шт | |
CONN PC PIN CIRC 0.072DIA GOLD | 241 ₽ от 1 шт 21-42 дня склад 974 шт |
Еще 4 цен: … 133 ₽ | |
203 ₽ от 10 шт 21-42 дня склад 974 шт | |
191 ₽ от 50 шт 21-42 дня склад 974 шт | |
166 ₽ от 250 шт 21-42 дня склад 974 шт | |
133 ₽ от 1000 шт 21-42 дня склад 974 шт | |
CONN PC PIN CIRC 0.072DIA GOLD | 252 ₽ от 1 шт 21-42 дня склад 999 шт |
Еще 3 цен: … 121 ₽ | |
213 ₽ от 10 шт 21-42 дня склад 999 шт | |
191 ₽ от 100 шт 21-42 дня склад 999 шт | |
121 ₽ от 5000 шт 21-42 дня склад 999 шт | |
CONN PC PIN CIRC 0.072DIA GOLD | 258 ₽ от 1 шт 21-42 дня склад 999 шт |
Еще 3 цен: … 125 ₽ | |
219 ₽ от 10 шт 21-42 дня склад 999 шт | |
197 ₽ от 100 шт 21-42 дня склад 999 шт | |
125 ₽ от 5000 шт 21-42 дня склад 999 шт | |
HEATSINK 21X21X23MM PIN | 1 590 ₽ от 1 шт 21-42 дня склад 156 шт |
Еще 4 цен: … 1 203 ₽ | |
1 547 ₽ от 10 шт 21-42 дня склад 156 шт | |
1 461 ₽ от 25 шт 21-42 дня склад 156 шт | |
1 289 ₽ от 90 шт 21-42 дня склад 156 шт | |
1 203 ₽ от 270 шт 21-42 дня склад 156 шт | |
HEATSINK 27X27X23MM PIN | 1 858 ₽ от 1 шт 21-42 дня склад 180 шт |
Еще 4 цен: … 1 531 ₽ | |
1 790 ₽ от 10 шт 21-42 дня склад 180 шт | |
1 683 ₽ от 20 шт 21-42 дня склад 180 шт | |
1 602 ₽ от 45 шт 21-42 дня склад 180 шт | |
1 531 ₽ от 90 шт 21-42 дня склад 180 шт | |
HEATSINK 31X31X23MM PIN | 1 935 ₽ от 1 шт 21-42 дня склад 229 шт |
Еще 4 цен: … 1 464 ₽ | |
1 882 ₽ от 10 шт 21-42 дня склад 229 шт | |
1 778 ₽ от 25 шт 21-42 дня склад 229 шт | |
1 569 ₽ от 90 шт 21-42 дня склад 229 шт | |
1 464 ₽ от 270 шт 21-42 дня склад 229 шт | |
27 ЭлектроПласт Санкт-Петербург Россия | |
... клеммы и зажимы .100 STR 23 PIN .235-.210 Далее 929647-02-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.210 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.610 Далее 929665-05-23-IПроводные клеммы и зажимы .100 STR 23 PIN .235-.610 | запрос 7-14 дней |
... и зажимы .100 RT ANG 23 PIN .235-.405 Далее 929667-02-23-IПроводные клеммы и зажимы .100 RT ANG 23 PIN .235-.405 | запрос 7-14 дней |
Еще 5 строк | |
... клеммы и зажимы .100 STR 23 PIN .235-.210 Далее 929836-02-23-RKПроводные клеммы и зажимы .100 STR 23 PIN .235-.210 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.145 Далее 929836-09-23-RKПроводные клеммы и зажимы .100 STR 23 PIN .235-.145 | запрос 7-14 дней |
... / технические характеристики соединителя 55P SIZE 23 PIN TRI-START Далее TV07RW-23-55PAКруговой мил / технические характеристики соединителя 55P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... / технические характеристики соединителя 100P SZ 23 PIN CABLE MOUNT Далее TVS06RF-23-35PCКруговой мил / технические характеристики соединителя 100P SZ 23 PIN CABLE MOUNT | запрос 7-14 дней |
INTERCONNECTS 2,54 Grid (0,46 dia.) Pins, Straight and Right Angle ... Далее 3017-23INTERCONNECTS 2,54 Grid (0,46 dia.) Pins, Straight and Right Angle Single Row | запрос 7-14 дней |
28 Океан Электроники Санкт-Петербург Россия | |
... плат - PCB PC SKT FOR #23 PIN 10Au CNT SnPb SHELL Далее 0365-0-15-01-23-14-10- 0Оборудование для печатных плат - PCB PC SKT FOR #23 PIN 10Au CNT SnPb SHELL | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .318-.175 Далее 929710-10-23Проводные клеммы и зажимы .100 STR 23 PIN .318-.175 | запрос 7-14 дней |
... клеммы и зажимы .100 STR 23 PIN .235-.910 Далее 929834-07-23Проводные клеммы и зажимы .100 STR 23 PIN .235-.910 | запрос 7-14 дней |
Еще 6 строк | |
... характеристики соединителя 100P Sz 23 Pin Recpt Inline Tri-Start ... Далее TV01RW-23-35PКруговой мил / технические характеристики соединителя 100P Sz 23 Pin Recpt Inline Tri-Start III | запрос 7-14 дней |
... / технические характеристики соединителя 100P SIZE 23 PIN TRI-START Далее TV06RW-23-35PBКруговой мил / технические характеристики соединителя 100P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... / технические характеристики соединителя 6P SIZ 23 PIN TRI-START Далее TV06RW-23-6P-LCКруговой мил / технические характеристики соединителя 6P SIZ 23 PIN TRI-START | запрос 7-14 дней |
... / технические характеристики соединителя 55P SIZE 23 PIN TRI-START Далее TV07RW-23-55PBКруговой мил / технические характеристики соединителя 55P SIZE 23 PIN TRI-START | запрос 7-14 дней |
... характеристики соединителя Plug 21P SZ:23 PIN;TRI-START Далее TVS06RF-23-21PКруговой мил / технические характеристики соединителя Plug 21P SZ:23 PIN;TRI-START | запрос 7-14 дней |
... / технические характеристики соединителя 100P SZ 23 PIN CABLE MOUNT Далее TVS06RF-23-35PC-453-LCКруговой мил / технические характеристики соединителя 100P SZ 23 PIN CABLE MOUNT | запрос 7-14 дней |
29 Зенер Москва Россия и страны ТС | |
HD 38999 151C 151#23 PIN PLUG | 45 765 ₽ от 5 шт |
HD 38999 151C 151#23 PIN RECP | запрос 5-15 дней |
Еще 12 строк | |
30 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
Транзисторы полевые (MOSFET) | 1.93 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-H Далее T93YA101KT20Cermet Trimmer 100 Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-H | 23.8 ₽ от 5000 ₽ |
DIODE PIN ATTENUATOR HF SOT-23 | 23.3 ₽ от 5000 ₽ |
Еще 58 строк | |
... .5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9 ... X 5 X 11.1mm) Pin Thru- Далее T93YA204KT20Cermet Trimmer 200K Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9.7 X 5 X 11.1mm) Pin Thru- | 23.9 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turn 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-Ho Далее T93YA473KT20Cermet Trimmer 47K Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turn 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-Ho | 23.4 ₽ от 5000 ₽ |
Ultra Small Temp Switch with Pin-Selectable Hysteresis,SOT-23-5 | 30.3 ₽ от 5000 ₽ |
Charge Pump INV/STPUP/STPDN -1.6V to -5.25V 60mA 5-Pin SOT-23 T/R | 15.2 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-H Далее T93YA501KT20Cermet Trimmer 500 Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-H | 14.5 ₽ от 5000 ₽ |
DIODE PIN GP 50V 1A SOT-23 | 20.0 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-H Далее T93YA203KT20Cermet Trimmer 20K Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-H | 24.6 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-H Далее T93YA471KT20Cermet Trimmer 470 Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-H | 24.3 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turn 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-Hol Далее T93YA100KT20Cermet Trimmer 10 Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turn 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-Hol | 27.5 ₽ от 5000 ₽ |
... 10% 0.28W 21(Elec)/23(Mech)Turn 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-Hole T Далее T93YA224KT20Cermet Trimmer 220K Ohm 10% 0.28W 21(Elec)/23(Mech)Turn 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-Hole T | 24.9 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9 ... X 5 X 11.1mm) Pin Thru- Далее T93YA104KT20Cermet Trimmer 100K Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9.7 X 5 X 11.1mm) Pin Thru- | 29.3 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9 ... X 5 X 11.1mm) Pin Thru- Далее T93YA504KT20Cermet Trimmer 500K Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9.7 X 5 X 11.1mm) Pin Thru- | 24.8 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-H Далее T93YA201KT20Cermet Trimmer 200 Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turns 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-H | 24.8 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turn 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-Hol Далее T93YA202KT20Cermet Trimmer 2K Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turn 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-Hol | 24.3 ₽ от 5000 ₽ |
... .5W(1/2W) 21(Elec)/23(Mech)Turn 2.2mm (9 ... X 5 X 11.1mm) Pin Thru-Ho Далее T93YA221KT20Cermet Trimmer 220 Ohm 10% 0.5W(1/2W) 21(Elec)/23(Mech)Turn 2.2mm (9.7 X 5 X 11.1mm) Pin Thru-Ho | 24.8 ₽ от 5000 ₽ |
31 PL-1 Москва Россия | |
Размеры: 75x8_Шлейф для автомагнитолы | 129 ₽ от 1 шт да |
Еще 3 цен: … 108 ₽ | |
123 ₽ от 3000 ₽ да | |
117 ₽ от 6000 ₽ да | |
108 ₽ от 4 шт да | |
32 Промэлектроника Екатеринбург Россия и страны СНГ | |
Соединитель автомобильный 23 pin, 4мм белый | 603 ₽ от 1 шт от 2-10 дней склад 499 шт |
... .5A 1-выход неинвертирующий 5-Pin SOT-23 лента на катушке Далее IRS44273LTRPBFДрайвер нижнего плеча 1.5A 1-выход неинвертирующий 5-Pin SOT-23 лента на катушке | 49.3 ₽ от 1 шт от 2-10 дней склад 7671 шт |
... 0.12A автомобильного применения 3-Pin SOT-23 лента на катушке Далее BAS4004E6327Диод Шоттки сборка 40В 0.12A автомобильного применения 3-Pin SOT-23 лента на катушке | 3.83 ₽ от 1 шт от 2-10 дней склад 1783 шт |
Еще 10 строк | |
... 1.5A Aвтомобильного применения 3-Pin SOT-23 лента на катушке Далее BSS315PH6327Транзистор полевой P-канальный 30В 1.5A Aвтомобильного применения 3-Pin SOT-23 лента на катушке | 19.3 ₽ от 1 шт от 2-10 дней склад 1441 шт |
... 2.3A Aвтомобильного применения 3-Pin SOT-23 лента на катушке Далее BSS806NEH6327XTSA1Транзистор полевой N-канальный 20В 2.3A Aвтомобильного применения 3-Pin SOT-23 лента на катушке | 34.7 ₽ от 1 шт от 2-10 дней склад 51 шт |
... 0.23A Aвтомобильного применения 3-Pin SOT-23 лента на катушке Далее BSS159NH6327Транзистор полевой N-канальный 60В 0.23A Aвтомобильного применения 3-Pin SOT-23 лента на катушке | 38.0 ₽ от 1 шт от 2-10 дней склад 50 шт |
... -канальный 30В 2.6A 3-Pin SOT-23 лента на катушке Далее AO3403Транзистор полевой P-канальный 30В 2.6A 3-Pin SOT-23 лента на катушке | 8.30 ₽ от 1 шт от 2-10 дней склад 26656 шт |
... -канальный 55В 2.1A 3-Pin SOT-23 Далее AO3422Транзистор полевой N-канальный 55В 2.1A 3-Pin SOT-23 | 9.64 ₽ от 1 шт от 2-10 дней склад 44896 шт |
... низкий уровень/открытый сток 3-Pin SOT-23 лента на катушке Далее STM1816SWX7FСупервизор процессора 2.88В активный низкий уровень/открытый сток 3-Pin SOT-23 лента на катушке | 71.4 ₽ от 1 шт от 2-10 дней склад 11 шт |
... .02А 175мВт автомобильного применения 3-Pin SOT-23 лента на катушке Далее BFR181E6327HTSA1Транзистор биполярный NPN 12В 0.02А 175мВт автомобильного применения 3-Pin SOT-23 лента на катушке | 19.5 ₽ от 1 шт от 2-10 дней склад 1960 шт |
... .5В 15мА автомобильного применения 3-Pin SOT-23 лента на катушке Далее TPR6040F25-S3TRИсточник опорного напряжения прецизионный 2.5В 15мА автомобильного применения 3-Pin SOT-23 лента на катушке | 37.2 ₽ от 1 шт от 2-10 дней склад 45 шт |
... 5В 15мА автомобильного применения 3-Pin SOT-23 лента на катушке Далее TPR6040F50-S3TRИсточник опорного напряжения прецизионый 5В 15мА автомобильного применения 3-Pin SOT-23 лента на катушке | 113 ₽ от 1 шт от 2-10 дней склад 236 шт |
... прецизионный 3.0В 15мА 3-Pin SOT-23 лента на катушке Далее TPR6040F30-S3TRИсточник опорного напряжения прецизионный 3.0В 15мА 3-Pin SOT-23 лента на катушке | 32.1 ₽ от 1 шт от 2-10 дней склад 1075 шт |
33 Холодильник.ру Москва Россия | |
Видеокарта MSI GeForce RTX 4060 TI GAMING X SLIM 8G (RTX 4060 TI GAMING X SLIM 8G) MSI 04 Май 2024 02:06 Объем памяти (Гб): 8
Разрядность шины памяти (бит): 128
Длина ... Далее Видеокарта MSI GeForce RTX 4060 TI GAMING X SLIM 8G (RTX 4060 TI GAMING X SLIM 8G)Объем памяти (Гб): 8
Длина видеокарты (мм): 307
Разъем дополнительного питания: 8 pin
Количество слотов ... | 57 590 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Длина ... Далее Видеокарта MSI GeForce RTX 4060 Ti GAMING SLIM WHITE 8GОбъем памяти (Гб): 8
Количество слотов ... | 52 890 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Видеокарта ASUS GeForce GTX 1650 TUF Gaming V2 4GB (TUF-GTX1650-4GD6-P-V2 GAMING) ASUS 04 Май 2024 02:06 Объем памяти (Гб): 4
Длина ... Далее Видеокарта ASUS GeForce GTX 1650 TUF Gaming V2 4GB (TUF-GTX1650-4GD6-P-V2 GAMING)Объем памяти (Гб): 4
Длина видеокарты (мм): 205
Разъем дополнительного питания: 6 pin
Количество слотов ... | 22 490 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
34 Оптулс Москва Россия | |
1715099 MKDS 1/ 2-3,5 HT BK PIN1,65 Клеммы Phoenix Contact | 64.5 ₽ Розница, Скидки для Дилеров - |
35 Контест Москва Россия | |
HSMP-4820-BLKG 02 Май 2024 02:09 ... PIN RF PWR LIMITER SOT-23 - Avago Technologies US Inc. SOT-23 Bulk ... Далее HSMP-4820-BLKG ... (последоват. соедин., DIODE PIN RF PWR LIMITER SOT-23 - Avago Technologies US Inc. SOT-23 Bulk 1A 1pF @ 0V, 1MHz PIN - Single 600 mOhm ... | запрос склад 4 шт |
DIODE PIN 200V 250MW SOT-23 | запрос склад 37518 шт |
DIODE PIN 50V 250MW SOT-23 | запрос склад 44259 шт |
Еще 4 строки | |
DIODE PIN 200V 250MW SOT-23 | запрос склад 12 шт |
DIODE PIN SWITCH 50V 1A SOT-23 | 19.0 ₽ склад 2282 шт |
DIODE RF PIN 200V 250MW SOT23 | запрос склад 1438 шт |
COIL CHOKE 10MH 2.3A PIN | 316 ₽ склад 284 шт |
36 AliExpress Китай Весь мир | |
1 488 ₽ от 1 шт от 21 дня | |
139 ₽ от 21 дня | |
139 ₽ от 21 дня | |
Еще 5 строк | |
139 ₽ от 21 дня | |
1 065 ₽ от 21 дня | |
10.4 ₽ от 50 шт 50 шт/лот от 21 дня | |
107 ₽ от 21 дня | |
107 ₽ от 21 дня |
Искать "23-pin" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 91.6918 |
EUR | 98.5602 |
