1 Flash-Turtle Китай Весь мир | |
320 Position Connector Array, Male Pins Surface Mount Gold | запрос 7 дней склад 35161 шт |
Adapter Coaxial Connector SMA Plug, Male Pin To N Plug, Male Pin 50Ohm | запрос 7 дней склад 10749 шт |
Adapter Coaxial Connector SMA Plug, Male Pin To SMA Plug, Male Pin ... Далее HRM-502 (40)Adapter Coaxial Connector SMA Plug, Male Pin To SMA Plug, Male Pin 50Ohm | запрос 7 дней склад 46151 шт |
Еще 12 строк | |
Coaxial Connector Plug, Male Pin 75Ohm Free Hanging (In-Line), Right ... Далее PL71-LP-1.5C (40)Coaxial Connector Plug, Male Pin 75Ohm Free Hanging (In-Line), Right Angle Solder | запрос 7 дней склад 6966 шт |
MMCX Connector Plug, Male Pin 50Ohm Free Hanging (In-Line), Right ... Далее MMCX-LP-FHSB-1 (40)MMCX Connector Plug, Male Pin 50Ohm Free Hanging (In-Line), Right Angle Solder | запрос 7 дней склад 46734 шт |
BNC Connector Plug, Male Pin 50Ohm Free Hanging (In-Line) Solder | запрос 7 дней склад 14841 шт |
Adapter Coaxial Connector N Jack, Female Socket To N Plug, Male Pin ... Далее UG-27C/U (40)Adapter Coaxial Connector N Jack, Female Socket To N Plug, Male Pin 50Ohm | запрос 7 дней склад 34968 шт |
N Type Connector Plug, Male Pin 50Ohm Free Hanging (In-Line) Solder | запрос 7 дней склад 22042 шт |
N Type Connector Plug, Male Pin 50Ohm Free Hanging (In-Line) Solder | запрос 7 дней склад 35876 шт |
Adapter Coaxial Connector SMA Jack, Female Socket To SMA Plug, Male ... Далее HRM-PA-PJ (F)-1 (40)Adapter Coaxial Connector SMA Jack, Female Socket To SMA Plug, Male Pin 50Ohm | запрос 7 дней склад 15780 шт |
SMA Connector Plug, Male Pin 50Ohm Free Hanging (In-Line), Right Angle ... Далее HRM-208S (40)SMA Connector Plug, Male Pin 50Ohm Free Hanging (In-Line), Right Angle Solder | запрос 7 дней склад 32489 шт |
SMA Connector Plug, Male Pin 50Ohm Free Hanging (In-Line) Solder | запрос 7 дней склад 27170 шт |
SMA Connector Plug, Male Pin 50Ohm Free Hanging (In-Line) Solder | запрос 7 дней склад 6757 шт |
SMA Connector Plug, Male Pin 50Ohm Free Hanging (In-Line), Right Angle ... Далее HRM-104 (40)SMA Connector Plug, Male Pin 50Ohm Free Hanging (In-Line), Right Angle Solder | запрос 7 дней склад 28106 шт |
9 Position D-Sub Plug, Male Pins Connector | запрос 7 дней склад 21073 шт |
2 ChipWorker Китай Весь мир | |
4 330 ₽ 2-7 дней отгрузка со склада в Китае склад 16 шт | |
3 AiPCBA Китай Весь мир | |
4 Akcel Китай Весь мир | |
Crystal 40MHz ±10ppm (Tol) ±15ppm (Stability) 10pF FUND ... Далее SXT11410FE38-40.000MCrystal 40MHz ±10ppm (Tol) ±15ppm (Stability) 10pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±10ppm (Tol) ±25ppm (Stability) 10pF FUND ... Далее SXT11410FC48-40.000MCrystal 40MHz ±10ppm (Tol) ±25ppm (Stability) 10pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±30ppm (Tol) ±50ppm (Stability) 11pF FUND ... Далее SXT32411BA48-40.000MCrystal 40MHz ±30ppm (Tol) ±50ppm (Stability) 11pF FUND 40Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Еще 283 строки | |
Crystal 40MHz ±10ppm (Tol) ±50ppm (Stability) 12pF FUND ... Далее SXT32412FA17-40.000MCrystal 40MHz ±10ppm (Tol) ±50ppm (Stability) 12pF FUND 40Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±30ppm (Tol) ±50ppm (Stability) 13pF FUND ... Далее SXT22413BA38-40.000MCrystal 40MHz ±30ppm (Tol) ±50ppm (Stability) 13pF FUND 50Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±10ppm (Tol) ±30ppm (Stability) 12pF FUND ... Далее SXT22412FB07-40.000MCrystal 40MHz ±10ppm (Tol) ±30ppm (Stability) 12pF FUND 50Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±30ppm (Tol) ±30ppm (Stability) 11pF FUND ... Далее SXT22411BB17-40.000MCrystal 40MHz ±30ppm (Tol) ±30ppm (Stability) 11pF FUND 50Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±25ppm (Tol) ±30ppm (Stability) 10pF FUND ... Далее SXT22410CB27-40.000MCrystal 40MHz ±25ppm (Tol) ±30ppm (Stability) 10pF FUND 50Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±20ppm (Tol) ±50ppm (Stability) 12pF FUND ... Далее SXT22412DA27-40.000MCrystal 40MHz ±20ppm (Tol) ±50ppm (Stability) 12pF FUND 50Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±15ppm (Tol) ±15ppm (Stability) 8pF FUND ... Далее SXT2148EE38-40.000MCrystal 40MHz ±15ppm (Tol) ±15ppm (Stability) 8pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±50ppm (Tol) ±50ppm (Stability) 22pF FUND ... Далее SXT21422AA38-40.000MCrystal 40MHz ±50ppm (Tol) ±50ppm (Stability) 22pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±10ppm (Tol) ±50ppm (Stability) 18pF FUND ... Далее SXT21418FA17-40.000MCrystal 40MHz ±10ppm (Tol) ±50ppm (Stability) 18pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±10ppm (Tol) ±50ppm (Stability) 18pF FUND ... Далее SXT21418FA38-40.000MCrystal 40MHz ±10ppm (Tol) ±50ppm (Stability) 18pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±50ppm (Tol) ±50ppm (Stability) 20pF FUND ... Далее SXT21420AA38-40.000MCrystal 40MHz ±50ppm (Tol) ±50ppm (Stability) 20pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±30ppm (Tol) ±30ppm (Stability) 18pF FUND ... Далее SXT21418BB48-40.000MCrystal 40MHz ±30ppm (Tol) ±30ppm (Stability) 18pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±30ppm (Tol) ±50ppm (Stability) 18pF FUND ... Далее SXT21418BA48-40.000MCrystal 40MHz ±30ppm (Tol) ±50ppm (Stability) 18pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±30ppm (Tol) ±30ppm (Stability) 16pF FUND ... Далее SXT21416BB17-40.000MCrystal 40MHz ±30ppm (Tol) ±30ppm (Stability) 16pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±50ppm (Tol) ±50ppm (Stability) 18pF FUND ... Далее SXT21418AA48-40.000MCrystal 40MHz ±50ppm (Tol) ±50ppm (Stability) 18pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±30ppm (Tol) ±50ppm (Stability) 17pF FUND ... Далее SXT21417BA38-40.000MCrystal 40MHz ±30ppm (Tol) ±50ppm (Stability) 17pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
Crystal 40MHz ±10ppm (Tol) ±15ppm (Stability) 10pF FUND ... Далее SXT21410FE07-40.000MCrystal 40MHz ±10ppm (Tol) ±15ppm (Stability) 10pF FUND 100Ohm Medical 4-Pin Ultra Mini-CSMD T/R | запрос от 1 шт |
5 Utmel Китай Весь мир | |
40-PIN TEST CLIP GOLD DIP .60 | 9 196 ₽ от 1 шт 5-7 дней склад 6 шт |
Еще 3 цен: … 7 721 ₽ | |
8 675 ₽ от 10 шт 5-7 дней склад 6 шт | |
8 184 ₽ от 100 шт 5-7 дней склад 6 шт | |
7 721 ₽ от 1000 шт 5-7 дней склад 6 шт | |
40-PIN TEST CLIP GOLD DIP .60 | 8 667 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 7 277 ₽ | |
8 176 ₽ от 10 шт 5-7 дней склад 1 шт | |
7 713 ₽ от 100 шт 5-7 дней склад 1 шт | |
7 277 ₽ от 1000 шт 5-7 дней склад 1 шт | |
... Suppressor Diode, 600W, 40.2V V(RWM), Unidirectional ... DO-15, 2 PIN Далее BZW06-40Trans Voltage Suppressor Diode, 600W, 40.2V V(RWM), Unidirectional, 1 Element, Silicon, DO-204AC, ROHS COMPLIANT, PLASTIC, DO-15, 2 PIN | запрос от 1 шт 5-7 дней склад 4197 шт |
Еще 40 строк | |
Rectifier Diode Schottky 40V 0.03A 2-Pin SOD-523 T/R | 13.8 ₽ от 1 шт 5-7 дней склад 13720 шт |
Еще 3 цен: … 11.6 ₽ | |
13.0 ₽ от 10 шт 5-7 дней склад 13720 шт | |
12.3 ₽ от 100 шт 5-7 дней склад 13720 шт | |
11.6 ₽ от 1000 шт 5-7 дней склад 13720 шт | |
Diode Schottky 40V 1A Automotive 2-Pin Mini-MELF T/R | 28.2 ₽ от 1 шт 5-7 дней склад 903 шт |
Еще 3 цен: … 23.7 ₽ | |
26.6 ₽ от 10 шт 5-7 дней склад 903 шт | |
25.1 ₽ от 100 шт 5-7 дней склад 903 шт | |
23.7 ₽ от 1000 шт 5-7 дней склад 903 шт | |
Rectifier Diode Schottky 40V 0.03A 2-Pin SOD-323 Tape and Box | 2.51 ₽ от 1 шт 5-7 дней склад 9745 шт |
Еще 3 цен: … 1.41 ₽ | |
1.84 ₽ от 10 шт 5-7 дней склад 9745 шт | |
1.54 ₽ от 100 шт 5-7 дней склад 9745 шт | |
1.41 ₽ от 1000 шт 5-7 дней склад 9745 шт | |
Dual ADC Pipelined 40Msps 10-bit Parallel 48-Pin LQFP Tray | 1 744 ₽ от 1 шт 5-7 дней склад 7483 шт |
Еще 3 цен: … 1 464 ₽ | |
1 645 ₽ от 10 шт 5-7 дней склад 7483 шт | |
1 552 ₽ от 100 шт 5-7 дней склад 7483 шт | |
1 464 ₽ от 1000 шт 5-7 дней склад 7483 шт | |
Single ADC Pipelined 40Msps 14-bit Parallel 52-Pin LQFP Tray | 6 213 ₽ от 1 шт 5-7 дней склад 10113 шт |
Еще 3 цен: … 5 216 ₽ | |
5 861 ₽ от 10 шт 5-7 дней склад 10113 шт | |
5 529 ₽ от 100 шт 5-7 дней склад 10113 шт | |
5 216 ₽ от 1000 шт 5-7 дней склад 10113 шт | |
Single ADC Pipelined 40Msps 14-bit Parallel 48-Pin LQFP Tray | запрос от 1 шт 5-7 дней склад 1 шт |
Dual Channel Dual ADC Pipelined 40Msps 12-bit Parallel/Serial 64-Pin ... Далее AD9231BCPZ-40Dual Channel Dual ADC Pipelined 40Msps 12-bit Parallel/Serial 64-Pin LFCSP EP Tray | 5 723 ₽ от 1 шт 5-7 дней склад 7 шт |
Еще 3 цен: … 4 805 ₽ | |
5 399 ₽ от 10 шт 5-7 дней склад 7 шт | |
5 094 ₽ от 100 шт 5-7 дней склад 7 шт | |
4 805 ₽ от 1000 шт 5-7 дней склад 7 шт | |
Quad ADC Pipelined 40Msps 10-bit Serial 48-Pin LFCSP EP Tray | 3 361 ₽ от 1 шт 5-7 дней склад 2 шт |
Еще 3 цен: … 2 822 ₽ | |
3 171 ₽ от 10 шт 5-7 дней склад 2 шт | |
2 991 ₽ от 100 шт 5-7 дней склад 2 шт | |
2 822 ₽ от 1000 шт 5-7 дней склад 2 шт | |
Quad ADC Pipelined 40Msps 10-bit Serial 48-Pin LFCSP EP T/R | запрос от 1 шт 5-7 дней склад 5598 шт |
Quad ADC Pipelined 40Msps 12-bit Serial 48-Pin LFCSP EP T/R | запрос от 1 шт 5-7 дней склад 3482 шт |
AFE General Purpose 8ADC 12bit 1.8V/3.3V 100-Pin TQFP EP T/R | запрос от 1 шт 5-7 дней склад 2025 шт |
Dual ADC Pipelined 40Msps 10-bit Parallel/Serial 64-Pin LFCSP EP T/R | запрос от 1 шт 5-7 дней склад 1141 шт |
Dual ADC Pipelined 40Msps 12-bit Parallel 64-Pin LQFP Tray | 3 419 ₽ от 1 шт 5-7 дней склад 434 шт |
Еще 3 цен: … 2 871 ₽ | |
3 225 ₽ от 10 шт 5-7 дней склад 434 шт | |
3 043 ₽ от 100 шт 5-7 дней склад 434 шт | |
2 871 ₽ от 1000 шт 5-7 дней склад 434 шт | |
TOOL INSERTER CMOS-SAFE 36-40PIN | запрос от 1 шт 5-7 дней склад 2 шт |
EXAR XR88C681CP/40-F UART Interface, 2, 1 ... V, 5.25 V, DIP, 40 Pins | 460 ₽ от 1 шт 5-7 дней склад 2511 шт |
Еще 3 цен: … 386 ₽ | |
434 ₽ от 10 шт 5-7 дней склад 2511 шт | |
409 ₽ от 100 шт 5-7 дней склад 2511 шт | |
386 ₽ от 1000 шт 5-7 дней склад 2511 шт | |
CONNECTOR DIP 40 PIN TIN IDC | 461 ₽ от 1 шт 5-7 дней склад 181 шт |
Еще 3 цен: … 387 ₽ | |
435 ₽ от 10 шт 5-7 дней склад 181 шт | |
410 ₽ от 100 шт 5-7 дней склад 181 шт | |
387 ₽ от 1000 шт 5-7 дней склад 181 шт | |
CONNECTOR DIP 40 PIN GOLD IDC | 665 ₽ от 1 шт 5-7 дней склад 11 шт |
Еще 3 цен: … 559 ₽ | |
628 ₽ от 10 шт 5-7 дней склад 11 шт | |
592 ₽ от 100 шт 5-7 дней склад 11 шт | |
559 ₽ от 1000 шт 5-7 дней склад 11 шт | |
6 Acme Chip Китай Весь мир | |
Dual ADC Pipelined 40Msps 12-bit Parallel 64-Pin LQFP Tray | запрос 7 дней склад 379 шт |
Single Channel Single ADC Pipelined 40Msps 12-bit Parallel 32-Pin ... Далее AD9235BCPZ-40Single Channel Single ADC Pipelined 40Msps 12-bit Parallel 32-Pin LFCSP EP Tray | запрос 7 дней склад 2996 шт |
Single ADC Flash 40Msps 8-bit Parallel 20-Pin SSOP Tube | запрос 7 дней склад 700 шт |
Еще 13 строк | |
Quad ADC Pipelined 40Msps 10-bit Serial 48-Pin LFCSP EP Tray | запрос 7 дней склад 483 шт |
Dual ADC Pipelined 40Msps 8-bit Parallel 48-Pin LQFP T/R | запрос 7 дней склад 413 шт |
AFE General Purpose 8ADC 12bit 1.8V/3V 100-Pin TQFP EP Tray | запрос 7 дней склад 214 шт |
Rectifier Diode Schottky 40V 1A Automotive 2-Pin Mini-MELF T/R | запрос 7 дней склад 195 шт |
Diode Schottky 45V 20A Automotive 3-Pin(3+Tab) TO-220FN Bulk | запрос 7 дней склад 4386 шт |
Diode Schottky 45V 10A Automotive 3-Pin(3+Tab) TO-220FN Bulk | запрос 7 дней склад 4415 шт |
Diode Schottky 45V 15A Automotive 3-Pin(3+Tab) TO-220FN Bulk | запрос 7 дней склад 4320 шт |
... , 2 Mbit, 256K x 8bit, 40 MHz, 4 Wire, Serial, SPI ... Далее SST25WF020-40-5I-SAFMICROCHIP SST25WF020-40-5I-SAFFlash Memory, 2 Mbit, 256K x 8bit, 40 MHz, 4 Wire, Serial, SPI, SOIC, 8 Pins | запрос 7 дней склад 2187 шт |
... , 4 Mbit, 512K x 8bit, 40 MHz, 4 Wire, Serial, SPI ... Далее SST25WF040-40-5I-SAFMICROCHIP SST25WF040-40-5I-SAFFlash Memory, 4 Mbit, 512K x 8bit, 40 MHz, 4 Wire, Serial, SPI, SOIC, 8 Pins | запрос 7 дней склад 7853 шт |
Rectifier Diode Switching 4KV 0.25A 2000ns 2-Pin DO-41 T/R / DIODE GEN ... Далее GP02-40-E3/54Rectifier Diode Switching 4KV 0.25A 2000ns 2-Pin DO-41 T/R / DIODE GEN PURP 4KV 250MA DO204 | запрос 7 дней склад 533 шт |
Rectifier Diode Schottky 0.2A 2-Pin SOD-523 T/R | запрос 7 дней склад 5021 шт |
MCU 8-bit PIC16 PIC RISC 896byte EPROM 3.3V/5V 18-Pin SOIC W Tube | запрос 7 дней склад 8113 шт |
MCU 8-bit PIC RISC 512B EPROM 3.3V/5V Automotive 18-Pin SOIC W Tube | запрос 7 дней склад 2686 шт |
7 Онлайн Компоненты Москва Россия | |
Pin Header, Wire-to-Board, 2.54 мм, 2 ряд(-ов), 40 контакт ... Далее SL11 SMD 062.40SPin Header, Wire-to-Board, 2.54 мм, 2 ряд(-ов), 40 контакт(-ов), Поверхностный Монтаж, Серия SL | 1 018 ₽ от 1 шт 5-12 дней склад 585 шт |
Еще 5 цен: … 490 ₽ | |
749 ₽ от 10 шт 5-12 дней склад 585 шт | |
606 ₽ от 100 шт 5-12 дней склад 585 шт | |
554 ₽ от 250 шт 5-12 дней склад 585 шт | |
499 ₽ от 500 шт 5-12 дней склад 585 шт | |
490 ₽ от 1000 шт 5-12 дней склад 585 шт | |
Pin Header, угловой, Board-to-Board, 2 мм, 2 ряд(-ов), 40 контакт ... Далее SLY 4/ 35/ 40/GPin Header, угловой, Board-to-Board, 2 мм, 2 ряд(-ов), 40 контакт(-ов), Through Hole Right Angle | 1 132 ₽ от 1 шт |
Еще 5 цен: … 544 ₽ | |
834 ₽ от 10 шт | |
674 ₽ от 100 шт | |
615 ₽ от 250 шт | |
556 ₽ от 500 шт | |
544 ₽ от 1000 шт | |
Pin Header, Wire-to-Board, 1.27 мм, 2 ряд(-ов), 40 контакт ... Далее FP 1, 27/ 40-MHPin Header, Wire-to-Board, 1.27 мм, 2 ряд(-ов), 40 контакт(-ов), Surface Mount Right Angle | 1 018 ₽ от 1 шт 5-12 дней склад 734 шт |
Еще 2 строки | |
Pin Header, Wire-to-Board, 1.27 мм, 2 ряд(-ов), 40 контакт ... Далее FP 1, 27/ 40-MV 1, 75Pin Header, Wire-to-Board, 1.27 мм, 2 ряд(-ов), 40 контакт(-ов), Surface Mount Straight | 1 171 ₽ от 1 шт 5-12 дней склад 101 шт |
Еще 4 цен: … 964 ₽ | |
1 121 ₽ от 7 шт 5-12 дней склад 101 шт | |
1 066 ₽ от 21 шт 5-12 дней склад 101 шт | |
1 018 ₽ от 56 шт 5-12 дней склад 101 шт | |
964 ₽ от 140 шт 5-12 дней склад 101 шт | |
Pin Header, Wire-to-Board, 1.27 мм, 2 ряд(-ов), 40 контакт ... Далее FP 1, 27/ 40-MV 3, 25Pin Header, Wire-to-Board, 1.27 мм, 2 ряд(-ов), 40 контакт(-ов), Surface Mount Straight | 982 ₽ от 1 шт 5-12 дней склад 276 шт |
8 ТМ Электроникс Санкт-Петербург Россия | |
Разъем; PIN: 40; ZIF FFC; 0,5мм; Версия: ... Далее EA WF050-40SРазъем; PIN: 40; ZIF FFC; 0,5мм; Версия: нижний ряд контактов | 1 805 ₽ от 1 шт 5-10 дней склад 8 шт |
Еще 4 цен: … 1 034 ₽ | |
1 311 ₽ от 10 шт 5-10 дней склад 8 шт | |
1 207 ₽ от 25 шт 5-10 дней склад 8 шт | |
1 082 ₽ от 100 шт 5-10 дней склад 8 шт | |
1 034 ₽ от 250 шт 5-10 дней склад 8 шт | |
Шлейф FFC; PIN: 40; Ш.контактов: 0,5мм; L: 51мм | 3 074 ₽ от 1 шт 5-10 дней склад 4 шт |
Еще 4 цен: … 1 526 ₽ | |
2 230 ₽ от 10 шт 5-10 дней склад 4 шт | |
1 842 ₽ от 100 шт 5-10 дней склад 4 шт | |
1 614 ₽ от 500 шт 5-10 дней склад 4 шт | |
1 526 ₽ от 1000 шт 5-10 дней склад 4 шт | |
... ;мама"/"папа"; PIN: 40; без контактов Далее NSR-40Вилка; штыревой; NSR/NDR; "мама"/"папа"; PIN: 40; без контактов | 287 ₽ от 2 шт 5-10 дней склад 1471 шт |
Еще 4 цен: … 104 ₽ | |
229 ₽ от 10 шт 5-10 дней склад 1471 шт | |
172 ₽ от 50 шт 5-10 дней склад 1471 шт | |
126 ₽ от 250 шт 5-10 дней склад 1471 шт | |
104 ₽ от 1000 шт 5-10 дней склад 1471 шт | |
Еще 15 строк | |
... планка; штыревой; "папа"; PIN: 40; двухуровневый; прямой Далее ZL2038-40Штыревая планка; штыревой; "папа"; PIN: 40; двухуровневый; прямой | 1 069 ₽ от 1 шт 5-10 дней склад 1714 шт |
Еще 4 цен: … 348 ₽ | |
776 ₽ от 5 шт 5-10 дней склад 1714 шт | |
582 ₽ от 20 шт 5-10 дней склад 1714 шт | |
428 ₽ от 100 шт 5-10 дней склад 1714 шт | |
348 ₽ от 500 шт 5-10 дней склад 1714 шт | |
Вилка; IDC; "мама"; PIN: 40; с зажимом шлейфа; IDC; на ... Далее AWP-40Вилка; IDC; "мама"; PIN: 40; с зажимом шлейфа; IDC; на шлейф; 1,27мм | 173 ₽ от 2 шт 5-10 дней склад 2593 шт |
Еще 4 цен: … 62.2 ₽ | |
138 ₽ от 10 шт 5-10 дней склад 2593 шт | |
104 ₽ от 70 шт 5-10 дней склад 2593 шт | |
76.0 ₽ от 700 шт 5-10 дней склад 2593 шт | |
62.2 ₽ от 2800 шт 5-10 дней склад 2593 шт | |
Разъем: M16; гнездо; "мама"; пайка; PIN: 4; 5А; 250В; IP40; ... Далее KFV 40Разъем: M16; гнездо; "мама"; пайка; PIN: 4; 5А; 250В; IP40; 0,75мм2 | 1 071 ₽ от 1 шт 5-10 дней склад 3 шт |
Еще 3 цен: … 747 ₽ | |
957 ₽ от 10 шт 5-10 дней склад 3 шт | |
856 ₽ от 25 шт 5-10 дней склад 3 шт | |
747 ₽ от 50 шт 5-10 дней склад 3 шт | |
Разъем: M16; гнездо; "мама"; пайка; PIN: 4; 5А; 250В; IP40; ... Далее KGV 40Разъем: M16; гнездо; "мама"; пайка; PIN: 4; 5А; 250В; IP40; 0,75мм2 | 1 109 ₽ от 1 шт 5-10 дней склад 236 шт |
Еще 3 цен: … 768 ₽ | |
992 ₽ от 10 шт 5-10 дней склад 236 шт | |
877 ₽ от 25 шт 5-10 дней склад 236 шт | |
768 ₽ от 50 шт 5-10 дней склад 236 шт | |
Разъем: M16; вилка; "мама"; пайка; на провод; PIN: 4; 5А; ... Далее KV 40Разъем: M16; вилка; "мама"; пайка; на провод; PIN: 4; 5А; 250В; прямой | 1 678 ₽ от 1 шт 5-10 дней склад 33 шт |
Еще 3 цен: … 1 175 ₽ | |
1 508 ₽ от 10 шт 5-10 дней склад 33 шт | |
1 343 ₽ от 25 шт 5-10 дней склад 33 шт | |
1 175 ₽ от 50 шт 5-10 дней склад 33 шт | |
Разъем: M16; гнездо; "папа"; пайка; PIN: 4; 5А; 250В; IP40; ... Далее SFV 40Разъем: M16; гнездо; "папа"; пайка; PIN: 4; 5А; 250В; IP40; 0,75мм2 | 1 340 ₽ от 1 шт 5-10 дней склад 90 шт |
Еще 3 цен: … 944 ₽ | |
1 196 ₽ от 10 шт 5-10 дней склад 90 шт | |
1 085 ₽ от 25 шт 5-10 дней склад 90 шт | |
944 ₽ от 50 шт 5-10 дней склад 90 шт | |
Разъем: M16; гнездо; "папа"; пайка; PIN: 4; 5А; 250В; IP40; ... Далее SGV 40Разъем: M16; гнездо; "папа"; пайка; PIN: 4; 5А; 250В; IP40; 0,75мм2 | 1 313 ₽ от 1 шт 5-10 дней склад 138 шт |
Еще 3 цен: … 920 ₽ | |
1 188 ₽ от 10 шт 5-10 дней склад 138 шт | |
1 050 ₽ от 25 шт 5-10 дней склад 138 шт | |
920 ₽ от 50 шт 5-10 дней склад 138 шт | |
Разъем: M16; вилка; "папа"; пайка; на провод; PIN: 4; 5А; ... Далее SV 40Разъем: M16; вилка; "папа"; пайка; на провод; PIN: 4; 5А; 250В; прямой | 1 508 ₽ от 1 шт 5-10 дней склад 638 шт |
Еще 3 цен: … 1 056 ₽ | |
1 351 ₽ от 10 шт 5-10 дней склад 638 шт | |
1 210 ₽ от 25 шт 5-10 дней склад 638 шт | |
1 056 ₽ от 50 шт 5-10 дней склад 638 шт | |
Разъем: M16; вилка; "мама"; пайка; на провод; PIN: 4; 5А; ... Далее WKV 40Разъем: M16; вилка; "мама"; пайка; на провод; PIN: 4; 5А; 250В; IP40 | 2 178 ₽ от 1 шт 5-10 дней склад 58 шт |
Еще 3 цен: … 1 523 ₽ | |
1 960 ₽ от 10 шт 5-10 дней склад 58 шт | |
1 741 ₽ от 25 шт 5-10 дней склад 58 шт | |
1 523 ₽ от 50 шт 5-10 дней склад 58 шт | |
Разъем: M16; вилка; "папа"; пайка; на провод; PIN: 4; 5А; ... Далее WSV 40Разъем: M16; вилка; "папа"; пайка; на провод; PIN: 4; 5А; 250В; IP40 | 1 800 ₽ от 1 шт 5-10 дней склад 221 шт |
Еще 3 цен: … 1 260 ₽ | |
1 619 ₽ от 10 шт 5-10 дней склад 221 шт | |
1 438 ₽ от 25 шт 5-10 дней склад 221 шт | |
1 260 ₽ от 50 шт 5-10 дней склад 221 шт | |
Разъем: питания AC; "папа"; вилка; 2P+PE; 250ВAC; 16А; белый ... Далее WT-40 BIРазъем: питания AC; "папа"; вилка; 2P+PE; 250ВAC; 16А; белый; PIN: 3 | 417 ₽ от 1 шт 5-10 дней склад 89 шт |
Еще 3 цен: … 292 ₽ | |
375 ₽ от 5 шт 5-10 дней склад 89 шт | |
335 ₽ от 20 шт 5-10 дней склад 89 шт | |
292 ₽ от 100 шт 5-10 дней склад 89 шт | |
Разъем: питания AC; "папа"; вилка; 2P+PE; 250ВAC; 16А; ... Далее WT-40 CZРазъем: питания AC; "папа"; вилка; 2P+PE; 250ВAC; 16А; черный; PIN: 3 | 436 ₽ от 1 шт 5-10 дней склад 80 шт |
Еще 3 цен: … 306 ₽ | |
394 ₽ от 5 шт 5-10 дней склад 80 шт | |
348 ₽ от 20 шт 5-10 дней склад 80 шт | |
306 ₽ от 100 шт 5-10 дней склад 80 шт | |
Разъем: питания AC; "папа"; вилка; 2P; 250ВAC; 16А; черный; ... Далее WT-40 K2 CZРазъем: питания AC; "папа"; вилка; 2P; 250ВAC; 16А; черный; PIN: 2 | 399 ₽ от 1 шт 5-10 дней склад 120 шт |
Еще 3 цен: … 253 ₽ | |
327 ₽ от 5 шт 5-10 дней склад 120 шт | |
290 ₽ от 20 шт 5-10 дней склад 120 шт | |
253 ₽ от 100 шт 5-10 дней склад 120 шт | |
Вилка; DIN; "мама"; PIN: 4; Конф: 216°; прямой; на ... Далее 930150517 MAK 40Вилка; DIN; "мама"; PIN: 4; Конф: 216°; прямой; на провод; пайка | 1 170 ₽ от 1 шт 5-10 дней склад 290 шт |
Еще 3 цен: … 822 ₽ | |
1 056 ₽ от 5 шт 5-10 дней склад 290 шт | |
933 ₽ от 20 шт 5-10 дней склад 290 шт | |
822 ₽ от 100 шт 5-10 дней склад 290 шт | |
Разъем: провод-провод/плата; DRC; "мама"; вилка; на провод; ... Далее DRC16-40SРазъем: провод-провод/плата; DRC; "мама"; вилка; на провод; PIN: 70 | 8 601 ₽ от 1 шт 5-10 дней склад 97 шт |
Еще 4 цен: … 6 741 ₽ | |
7 531 ₽ от 10 шт 5-10 дней склад 97 шт | |
7 206 ₽ от 25 шт 5-10 дней склад 97 шт | |
6 974 ₽ от 50 шт 5-10 дней склад 97 шт | |
6 741 ₽ от 125 шт 5-10 дней склад 97 шт | |
9 ЕКОМП Санкт-Петербург Россия | |
Разъем "вилка" 40 конт. (2x20) шаг 2.54 мм, пр.уг. на пл. (ан. BH-40R/ IDC-40MR) Connfly DS1013-40 RSIB - DS1013-40 RSIB Connfly 26 Апр 2024 01:50 Разъем "вилка" 40 конт.(2x20) шаг 2.54 мм, прямой угол на ... Далее Разъем "вилка" 40 конт. (2x20) шаг 2.54 мм, пр.уг. на пл. (ан. BH-40R/ IDC-40MR) Connfly DS1013-40 RSIB - DS1013-40 RSIBРазъем "вилка" 40 конт.(2x20) шаг 2.54 мм, прямой угол на плату (ответн. часть к IDC) (DS1013-40RSIB-B-0) | 11.9 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Разъем "вилка" 40 к. (2x20) ш. 2.54мм, с фикс., верт. (ан. SCM-40/ IDCC-40MS) Connfly DS1011-40 SBSIB7 - DS1011-40 SBSIB7 Connfly 26 Апр 2024 01:50 Разъем "вилка" 40 конт.(2x20) шаг 2.54 мм, с боковыми ... Далее Разъем "вилка" 40 к. (2x20) ш. 2.54мм, с фикс., верт. (ан. SCM-40/ IDCC-40MS) Connfly DS1011-40 SBSIB7 - DS1011-40 SBSIB7Разъем "вилка" 40 конт.(2x20) шаг 2.54 мм, с боковыми фиксаторами (H = 7.9мм), вертик. на плату (ответн. часть к IDC) | 23.5 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Разъем "вилка" 40 к. (2x20) шаг 2.00 мм, пр. уг. на пл. (ан. BH2-40R/ IDC2-40MR) Connfly DS1014-40 RF1B - DS1014-40 RF1B Connfly 26 Апр 2024 01:50 Разъем "вилка" 40 конт.(2x20) шаг 2.00 мм, прямой угол на ... Далее Разъем "вилка" 40 к. (2x20) шаг 2.00 мм, пр. уг. на пл. (ан. BH2-40R/ IDC2-40MR) Connfly DS1014-40 RF1B - DS1014-40 RF1BРазъем "вилка" 40 конт.(2x20) шаг 2.00 мм, прямой угол на плату (ответн. часть к IDC) | 21.4 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Еще 3 строки | |
Штыри 2x20 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-40) Connfly DS1025-05-2*20 P8BV1 - DS1025-05-2*20 P8BV1 Connfly 26 Апр 2024 01:50 Штыри двухрядные 2x20 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x20 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-40) Connfly DS1025-05-2*20 P8BV1 - DS1025-05-2*20 P8BV1Штыри двухрядные 2x20 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 10.1 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x40 конт. шаг 2.00 мм, межплатн. (3.0/ 9.0/ 4.0 мм) (ан. PLHD2-80*) Connfly DS1030-02-2*40 P8BVB7 - DS1030-02-2*40 P8BVB7 Connfly 26 Апр 2024 01:50 Штыри двухрядные 2x40 конт. шаг 2.00 мм, межплатные вертик. (3.0/ 9.0/ ... Далее Штыри 2x40 конт. шаг 2.00 мм, межплатн. (3.0/ 9.0/ 4.0 мм) (ан. PLHD2-80*) Connfly DS1030-02-2*40 P8BVB7 - DS1030-02-2*40 P8BVB7Штыри двухрядные 2x40 конт. шаг 2.00 мм, межплатные вертик. (3.0/ 9.0/ 4.0 мм), позол., изолят. тип V2 | 19.6 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 1x40 конт. шаг 2.00 мм, межплатн. (3.0/ 9.0/ 4.0 мм) (ан. PLH2-40*) Connfly DS1030-01-1*40 P8BV4 - DS1030-01-1*40 P8BV4 Connfly 26 Апр 2024 01:50 Штыри однорядные 1x40 конт. шаг 2.00 мм, межплатные вертик. (3.0/ 9.0/ ... Далее Штыри 1x40 конт. шаг 2.00 мм, межплатн. (3.0/ 9.0/ 4.0 мм) (ан. PLH2-40*) Connfly DS1030-01-1*40 P8BV4 - DS1030-01-1*40 P8BV4Штыри однорядные 1x40 конт. шаг 2.00 мм, межплатные вертик. (3.0/ 9.0/ 4.0 мм), позол. | 12.9 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
10 ЭК ЗИП Москва Россия | |
Герметичные разъемы | 178 ₽ от 1 шт склад 1226 шт |
Еще 2 цен: … 116 ₽ | |
123 ₽ от 9 шт склад 1226 шт | |
116 ₽ от 82 шт склад 1226 шт | |
Герметичные разъемы | 162 ₽ от 1 шт склад 500 шт |
Еще 2 цен: … 106 ₽ | |
112 ₽ от 9 шт склад 500 шт | |
106 ₽ от 90 шт склад 500 шт | |
Герметичные разъемы | 139 ₽ от 1 шт склад 811 шт |
Еще 2 цен: … 90.9 ₽ | |
95.7 ₽ от 11 шт склад 811 шт | |
90.9 ₽ от 105 шт склад 811 шт | |
Еще 3 строки | |
Герметичные разъемы | 198 ₽ от 1 шт склад 760 шт |
Еще 2 цен: … 130 ₽ | |
137 ₽ от 8 шт склад 760 шт | |
130 ₽ от 74 шт склад 760 шт | |
Герметичные разъемы | 91.2 ₽ от 1 шт склад 5788 шт |
Еще 2 цен: … 59.7 ₽ | |
62.9 ₽ от 16 шт склад 5788 шт | |
59.7 ₽ от 160 шт склад 5788 шт | |
11 ЗУМ-СМД Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 600 руб. | |
Конденсатор FUJI CBB60 (2+2PINS) 40 uF 450v 45x93 (min 50) SAND 03 Фев 2024 16:47 | запрос от 600 ₽ от 7 дней >0.500 |
Конденсатор FUJI CBB65 (2+2PIN) 40 uF 450v 45x102 (min 25) ALUMINIUM 03 Фев 2024 16:47 | запрос от 600 ₽ от 7 дней 0, 184 |
Конденсатор FUJI CBB65 (2+2PIN) 40 uF 450v 50x102 (min 25) ALUMINIUM 03 Фев 2024 16:47 | запрос от 600 ₽ от 7 дней >0.500 |
Еще 1 строка | |
запрос от 600 ₽ от 7 дней 0, 025 | |
12 PL-1 Москва Россия | |
Вилка штыревая угловая PLS-40R, 1х40, шаг 2, 54мм (Однорядный угловой штырьковый разъем 40 pin) 26 Апр 2024 02:49 Разъем для печатной платы на 40 контактов.Угловой. | 26.0 ₽ от 1 шт нет |
Еще 2 цен: … 23.5 ₽ | |
24.6 ₽ от 3000 ₽ нет | |
23.5 ₽ от 6000 ₽ нет | |
Вилка штыревая прямая PLS-40, 1х40, шаг 2, 54мм (Однорядный прямой штырьковый разъем 40 pin) 26 Апр 2024 02:49 Разъем для печатной платы на 40 контактов. | 28.0 ₽ от 1 шт нет |
Еще 2 цен: … 25.3 ₽ | |
26.5 ₽ от 3000 ₽ нет | |
25.3 ₽ от 6000 ₽ нет | |
LED подсветка TV SAMSUNG 40 комплект из 2-х линеек (56+56) LED, 3V, алюминий, (L/56+R/56), 2D, 6pin, 2012SVS40 7032NNB RIGHT56/LEFT56 2D REV1.1 120317 26 Апр 2024 02:49 Samsung UE40ES6307U UE40ES6727U UE40ES6100W UE40ES5507KКомплекты ... Далее LED подсветка TV SAMSUNG 40 комплект из 2-х линеек (56+56) LED, 3V, алюминий, (L/56+R/56), 2D, 6pin, 2012SVS40 7032NNB RIGHT56/LEFT56 2D REV1.1 120317Samsung UE40ES6307U UE40ES6727U UE40ES6100W UE40ES5507KКомплекты подсветки подходят для разных серий телевизоров Samsung: UE40ES6307U ... | 2 450 ₽ от 1 шт да |
Еще 2 цен: … 2 288 ₽ | |
2 376 ₽ от 2 шт да | |
2 288 ₽ от 4 шт да | |
Еще 1 строка | |
LED подсветка TV SAMSUNG 40 комплект из 2-х линеек (56+56) LED, 3V, алюминий, (L/56+R/56), 3D, 10pin, 2012SVS40 7032NNB Right/left 56 3D REV1.1 120317 26 Апр 2024 02:49 Samsung UE40ES6100WКомплекты подсветки подходят для разных серий ... Далее LED подсветка TV SAMSUNG 40 комплект из 2-х линеек (56+56) LED, 3V, алюминий, (L/56+R/56), 3D, 10pin, 2012SVS40 7032NNB Right/left 56 3D REV1.1 120317Samsung UE40ES6100WКомплекты подсветки подходят для разных серий телевизоров Samsung, например: Samsung UE40ES6100W Название линеeк: ... | 2 540 ₽ от 1 шт да |
Еще 2 цен: … 2 376 ₽ | |
2 464 ₽ от 2 шт да | |
2 376 ₽ от 4 шт да | |
13 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
Сокеты под микросхемы | 33.0 ₽ Доставка: есть Самовывоз: есть на складе |
Сокеты под микросхемы | 8.00 ₽ Доставка: есть Самовывоз: есть на складе |
Линейка 12 шт | 17.0 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 85 строк | |
Коннектор для Arduino 40 контактов, шаг 2.54 мм (Однорядный штырьковый разъем 40 pin) - - 25 Апр 2024 04:18 Разъем для печатной платы на 40 контактов. | 27.0 ₽ Доставка: есть Самовывоз: есть на складе |
40-0100 | 622 ₽ Доставка: есть Самовывоз: есть на складе |
Преобразователь DC-DC на печатную плату 24В на входе 2-канальный 15В/- ... Далее TEN 40-2423WIRПреобразователь DC-DC на печатную плату 24В на входе 2-канальный 15В/-15В 1.333A/-1.333A 40Вт 6-Pin DIP модуль | 8 562 ₽ Доставка: есть Самовывоз: есть на складе |
Преобразователь DC-DC на печатную плату 24В на входе 1-канальный 24В 1 ... Далее TEN 40-2415NПреобразователь DC-DC на печатную плату 24В на входе 1-канальный 24В 1.67A 40Вт 6-Pin | 6 828 ₽ Доставка: есть Самовывоз: есть на складе |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход ... Далее TEN 40-2412Преобразователь DC-DC на печатную плату вход 24В однополярный выход 12В 3.3A 40Вт 9-Pin | 8 120 ₽ Доставка: есть Самовывоз: есть на складе |
591 ₽ Доставка: есть Самовывоз: есть на складе | |
45.0 ₽ Доставка: есть Самовывоз: есть на складе | |
пара герм., IP68, 2A, DC 0-24В (AC110-220В), D=21,5мм, 5*0.2мм2, L= ... Далее 5PIN WP L = 40 D = 21.5MM 5*0.2MM2пара герм., IP68, 2A, DC 0-24В (AC110-220В), D=21,5мм, 5*0.2мм2, L=40см, -20...80 C | 237 ₽ Доставка: есть Самовывоз: есть на складе |
пара герм., IP68, 6A, DC 0-24В (AC110-220В), D=21,5мм, 2*0.75мм2, L= ... Далее 2PIN WP L = 40 D = 21.5MM 2*0.75MM2пара герм., IP68, 6A, DC 0-24В (AC110-220В), D=21,5мм, 2*0.75мм2, L=40см, -20...80 C | 137 ₽ Доставка: есть Самовывоз: есть на складе |
LED подсветка TV SAMSUNG 40" комплект из 2-х линеек (56+56) LED, 3V, алюминий, (L/56+R/56), 2D, 6pin, 2012SVS40 7032NNB RIGHT56/LEFT56 2D REV1.1 120317 - - 25 Апр 2024 04:18 Samsung UE40ES6307U UE40ES6727U UE40ES6100W UE40ES5507K | 3 822 ₽ Доставка: есть Самовывоз: есть на складе |
LED подсветка TV SAMSUNG 40" комплект из 2-х линеек (56+56) LED, 3V, алюминий, (L/56+R/56), 3D, 10pin, 2012SVS40 7032NNB Right/left 56 3D REV1.1 120317 - - 25 Апр 2024 04:18 Samsung UE40ES6100W | 3 963 ₽ Доставка: есть Самовывоз: есть на складе |
DIP-панель под микросхему 40pin, шаг 2.54мм, ширина 15.24мм | 16.0 ₽ Доставка: есть Самовывоз: есть на складе |
DIP-панель под микросхему 40pin, шаг 1.778мм, ширина 15.24мм | 16.0 ₽ Доставка: есть Самовывоз: есть на складе |
Гнезда цанговые однорядные для монтажа в отверстия 40pin, шаг 2.54мм | 102 ₽ Доставка: есть Самовывоз: есть на складе |
Rs40 SMD-выводы,пригоден как Pin | 15.0 ₽ Доставка: есть Самовывоз: есть на складе |
0.50mm Pitch FFC/FPC Connector SMT Pin,Full pack,H=2.0mm | 21.0 ₽ Доставка: есть Самовывоз: есть на складе |
Линза для светодиода LG Innotek серии LG LEMWA33X (Oslon/Cree XP-G), ... Далее FP13025_LISA2-W-PINЛинза для светодиода LG Innotek серии LG LEMWA33X (Oslon/Cree XP-G), эфф=88, 40° | 246 ₽ Доставка: есть Самовывоз: есть на складе |
14 Элитан Ижевск Россия Безнал. расчет Филиалы: Москва Санкт-Петербург Екатеринбург Новосибирск | |
40 pin 26 Апр 2024 02:24 | 1 591 ₽ |
SCZP-40 pin 26 Апр 2024 02:24 | 1 206 ₽ |
260 ₽ | |
Еще 2 строки | |
248 ₽ | |
113 ₽ | |
15 DIP8.RU Москва Россия и страны ТС | |
Штыревая планка, штыревой, папа, PIN 40, двухуровневый, прямой | 840 ₽ от 1 шт 42 дня склад 1714 шт Внешний |
Еще 9 цен: … 253 ₽ | |
840 ₽ от 1 шт от 1 дня склад 67 шт Москва | |
599 ₽ от 5 шт 42 дня склад 1714 шт Внешний | |
599 ₽ от 5 шт от 1 дня склад 67 шт Москва | |
443 ₽ от 20 шт 42 дня склад 1714 шт Внешний | |
443 ₽ от 20 шт от 1 дня склад 67 шт Москва | |
317 ₽ от 100 шт 42 дня склад 1714 шт Внешний | |
317 ₽ от 100 шт от 1 дня склад 67 шт Москва | |
253 ₽ от 500 шт 42 дня склад 1714 шт Внешний | |
253 ₽ от 500 шт от 1 дня склад 67 шт Москва | |
Штыревой, IDC, папа, PIN 40, прямой, 2,54мм, THT, 1x40, ... Далее PH1-40-UAШтыревой, IDC, папа, PIN 40, прямой, 2,54мм, THT, 1x40, позолота | 90.0 ₽ от 1 шт 42 дня склад 1355 шт Внешний |
Еще 9 цен: … 38.6 ₽ | |
90.0 ₽ от 1 шт от 1 дня склад 30 шт Москва | |
63.5 ₽ от 20 шт 42 дня склад 1355 шт Внешний | |
63.5 ₽ от 20 шт от 1 дня склад 30 шт Москва | |
51.6 ₽ от 100 шт 42 дня склад 1355 шт Внешний | |
51.6 ₽ от 100 шт от 1 дня склад 30 шт Москва | |
44.9 ₽ от 400 шт 42 дня склад 1355 шт Внешний | |
44.9 ₽ от 400 шт от 1 дня склад 30 шт Москва | |
38.6 ₽ от 2000 шт 42 дня склад 1355 шт Внешний | |
38.6 ₽ от 2000 шт от 1 дня склад 30 шт Москва | |
16 РИВ Электроникс Москва Россия | |
2pin WP L = 40 D = 13mm 2*0.3mm2 05 Апр 2024 09:38 | 105 ₽ от 10 шт мин заказ 10 шт Да |
Еще 4 цен: | |
75.4 ₽ от 20 шт мин заказ 10 шт Да | |
55.7 ₽ от 600 шт мин заказ 10 шт Да | |
54.9 ₽ от 1120 шт мин заказ 10 шт Да | |
запрос от 0 шт мин заказ 10 шт Да | |
17 T-electron Раменское, Московская обл. Россия и страны СНГ | |
запрос | |
запрос | |
запрос да | |
Еще 8 строк | |
запрос да | |
19.0 ₽ до 5 дней | |
запрос склад 1 шт | |
запрос | |
запрос | |
запрос да | |
Кнопка TS-40 4.3мм 2pin 20 Ноя 2023 00:56 | 5.00 ₽ до 5 дней |
Шлейф 0, 5mm 50pin 40/2.5cm 20 Ноя 2023 00:56 | 90.0 ₽ да |
18 ЧипСити Москва Россия | |
Pin; Cable; 40dB; Male; 1; H.D | 645 ₽ 3-7 дней склад 692 шт |
HEAVYCON pin insert, BBB 40 series, 40POS., crimp connection | 3 632 ₽ 3-7 дней склад 1043 шт |
Conn DIP Test Clip PIN 40POS Solder ST Thru-Hole 1Port | 4 508 ₽ 3-7 дней склад 211 шт |
Еще 90 строк | |
Conn DIP Test Clip PIN 40POS Solder ST Thru-Hole 1Port | 5 711 ₽ 3-7 дней склад 107 шт |
The VARIOFACE feed-through module implements a 1:1 connection between ... Далее DFLK 40The VARIOFACE feed-through module implements a 1:1 connection between screw connection terminal blocks and an IDC/FLK pin strip (2.54mm, ... | 11 028 ₽ 3-7 дней склад 396 шт |
VARIOFACE module, with screw connection and flat-ribbon cable ... Далее FLKM 40VARIOFACE module, with screw connection and flat-ribbon cable connector, for mounting on NS 32 or NS 35/7.5, with pin strip and short and ... | 21 206 ₽ 3-7 дней склад 1259 шт |
VARIOFACE module, with screw connection and flat-ribbon cable ... Далее FLKMS 40VARIOFACE module, with screw connection and flat-ribbon cable connector, for mounting on NS 32 or NS 35/7.5, with pin strip ... | 31 986 ₽ 3-7 дней склад 924 шт |
connector, adapter, 9Pin cont d-sub to 8cont modular jack, 2-piece ... Далее 40-9528Mconnector, adapter, 9Pin cont d-sub to 8cont modular jack, 2-piece black hood | 285 ₽ 3-7 дней склад 121 шт |
Alphanumeric Display Controller 40Pin PDIP | 267 ₽ 3-7 дней склад 823 шт |
X55X Series 40Pin 2.54mm Pitch Through Hole DIP Test Socket | 1 394 ₽ 3-7 дней склад 1132 шт |
DIP/SIP Sockets LO-PRO FILE COLLET SOLDER TAIL 40Pins | 550 ₽ 3-7 дней склад 142 шт |
DIP/SIP Sockets 40Pin ZIF SOCKET | 2 085 ₽ 3-7 дней склад 315 шт |
Dip Header Cover 40Pin .270 | 381 ₽ 3-7 дней склад 331 шт |
IC & Component Sockets DIP HEADERS 40Pins SCREW MACHINE CONT | 1 003 ₽ 3-7 дней склад 214 шт |
IC & Component Sockets DIP HEADERS 40Pins SCREW MACHINE CONT | 1 133 ₽ 3-7 дней склад 903 шт |
IC & Component Sockets DIP HEADERS 40Pins SCREW MACHINE CONT | 945 ₽ 3-7 дней склад 1276 шт |
IC & Component Sockets DIP HEADERS 40Pins SCREW MACHINE CONT | 975 ₽ 3-7 дней склад 1111 шт |
IC & Component Sockets DIP HEADERS 40Pins SCREW MACHINE CONT | 1 024 ₽ 3-7 дней склад 1144 шт |
IC & Component Sockets DIP HEADERS 40Pins SCREW MACHINE CONT | 1 357 ₽ 3-7 дней склад 1233 шт |
IC & Component Sockets DIP HEADERS 40Pins SCREW MACHINE CONT | 1 061 ₽ 3-7 дней склад 1128 шт |
19 Умные Модули Санкт-Петербург Россия | |
Модуль датчика горючих газов MQ-6.Применяется для детектирования ... Далее Датчик газа MQ-6 (Gas Sensor V2) 3PIN DFRobotМодуль датчика горючих газов MQ-6.Применяется для детектирования горючих газов в измерительных приборах.Характеристики датчика дыма и ... | 135 ₽ Наличный, безнал расчет.... Далее Наличный, безнал расчет. Отгрузка в день заказа! 1-10 дней на складе |
Модуль датчика паров спирта MQ-3. Применяется для детектирования паров ... Далее Датчик газа MQ-3 модуль 4PIN YwRobotМодуль датчика паров спирта MQ-3. Применяется для детектирования паров спирта в измерительных приборах.Характеристики датчика паров спирта ... | 160 ₽ Наличный, безнал расчет.... Далее Наличный, безнал расчет. Отгрузка в день заказа! 1-10 дней - |
20 Industrial Module Москва Россия | |
Trigger cable, M12, 5-pin cable box, shielded cable, 1.5 m, open end, ... Далее CMX-40Trigger cable, M12, 5-pin cable box, shielded cable, 1.5 m, open end, IP 65 | 3 455 ₽ 7-28 дней на складе |
21 СЭлКом Москва Россия и страны СНГ | |
Акция! / | 91.6 ₽ розница 1-7 дней склад 584 шт |
117 ₽ розница 1-7 дней склад 16 шт | |
Еще 3 цен: … 106 ₽ | |
110 ₽ мелкий опт 1-7 дней склад 16 шт | |
107 ₽ опт 1-7 дней склад 16 шт | |
106 ₽ крупный опт 1-7 дней склад 16 шт | |
22 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
Интерфейсный 40-контактный разъем ZIF для монтажа на плату (для модуля ... Далее CON 40-pin ZIF connectorИнтерфейсный 40-контактный разъем ZIF для монтажа на плату (для модуля TC35i) | 22.5 ₽ от 5000 ₽ |
Соединительные провода и разъемы | 322 ₽ от 5000 ₽ |
23 Океан Электроники Санкт-Петербург Россия | |
36/40-PIN 26 Апр 2024 22:57 | запрос 7-14 дней |
... компонентов DIP TEST SCKT TIN 40 PINS Далее 40-6551-10*Установочные панели для ИС и компонентов DIP TEST SCKT TIN 40 PINS | запрос 7-14 дней |
... и компонентов VERTISOCKETS HORIZ COLLET 40 PINS Далее 40-6822-90CУстановочные панели для ИС и компонентов VERTISOCKETS HORIZ COLLET 40 PINS | запрос 7-14 дней |
Еще 13 строк | |
... ELEV. SCKT .3 CENTER COLLET 40 PINS Далее 40-811Установочные панели для ИС и компонентов ELEV. SCKT .3 CENTER COLLET 40 PINS | запрос 7-14 дней |
CONNECTOR DIP 40 PIN TIN IDC | запрос 7-14 дней |
CONN SOCKET 40 PIN TIN W/STR REL | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3101-4064-40INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.030?€? dia.) Pins, Solderless Press-Fit ... Далее 800-40-001-62-001000INTERCONNECTS .100?€? Grid (.030?€? dia.) Pins, Solderless Press-Fit Single Row | запрос 7-14 дней |
CONN RCPT 85POS STRGHT W/PINS | запрос 7-14 дней |
CONN RCPT 85POS BOX MNT W/PINS | запрос 7-14 дней |
CONN RCPT 62POS BOX MNT W/PINS | запрос 7-14 дней |
CONN PLUG 60POS RT ANG W/PINS | запрос 7-14 дней |
CONN PLUG 62POS RT ANG W/PINS | запрос 7-14 дней |
CONN HSG RCPT 60POS BOX MT PINS | запрос 7-14 дней |
CONN RCPT 4POS BOX MNT W/PINS | запрос 7-14 дней |
CONN PLUG 85POS STRAIGHT W/PINS | запрос 7-14 дней |
24 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
... и компонентов DIP ADAPTER SOCKETS 40 PINS Далее 1107254-40Установочные панели для ИС и компонентов DIP ADAPTER SOCKETS 40 PINS | запрос 7-14 дней |
... SINGLE ROW COLLET WIRE WRAP 40 PINS Далее 40-050Установочные панели для ИС и компонентов SINGLE ROW COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... SINGLE ROW COLLET WIRE WRAP 40 PINS Далее 40-0508-30Установочные панели для ИС и компонентов SINGLE ROW COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
Еще 37 строк | |
... SINGLE ROW COLLET SOLDER TAIL 40 PINS Далее 40-0518-10HУстановочные панели для ИС и компонентов SINGLE ROW COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... DUAL ROW COLLET SOLDER TAIL 40 PINS Далее 40-1518-10Установочные панели для ИС и компонентов DUAL ROW COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... компонентов DIP TEST SCKT GOLD 40 PINS Далее 40-3554-11Установочные панели для ИС и компонентов DIP TEST SCKT GOLD 40 PINS | запрос 7-14 дней |
... ИС и компонентов DIP HEADERS 40 PINS SCREW MACHINE CONT Далее 40-3625-10Установочные панели для ИС и компонентов DIP HEADERS 40 PINS SCREW MACHINE CONT | запрос 7-14 дней |
... для ИС и компонентов HEADER 40 PINS COINED CONTACT Далее 40-600-11Установочные панели для ИС и компонентов HEADER 40 PINS COINED CONTACT | запрос 7-14 дней |
... OPEN FRAME CAPACITOR WIRE WRAP 40 PINS Далее 40-6508-201Установочные панели для ИС и компонентов OPEN FRAME CAPACITOR WIRE WRAP 40 PINS | запрос 7-14 дней |
... OPEN FRAME CAPACITOR SOLDER TAIL 40 PINS Далее 40-6518-111Установочные панели для ИС и компонентов OPEN FRAME CAPACITOR SOLDER TAIL 40 PINS | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN GOLD Далее 40-3571-11Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN GOLD | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN GOLD Далее 40-3573-11Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN GOLD | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN NICKEL Далее 40-3575-16Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN NICKEL | запрос 7-14 дней |
... панели для ИС и компонентов 40-PIN ZIF SOCKET Далее 40-516-11MУстановочные панели для ИС и компонентов 40-PIN ZIF SOCKET | запрос 7-14 дней |
40 PIN ZIF SOCKET HT | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN NICKEL Далее 40-6570-16Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN NICKEL | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3101-40INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 350-40-102-00-107000INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
25 МосЧип Москва Россия | |
... для ИС и компонентов COLLET PIN CARRIERS 40 PINS Далее 40-6540-10Установочные панели для ИС и компонентов COLLET PIN CARRIERS 40 PINS | запрос 7-14 дней |
... SINGLE ROW COLLET WIRE WRAP 40 PINS Далее 40-0508-20Установочные панели для ИС и компонентов SINGLE ROW COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... панели для ИС и компонентов 40-PIN ZIF SOCKET Далее 40-516-10TLУстановочные панели для ИС и компонентов 40-PIN ZIF SOCKET | запрос 7-14 дней |
Еще 77 строк | |
... для ИС и компонентов HEADER 40 PINS COINED CONTACT Далее 40-600-1Установочные панели для ИС и компонентов HEADER 40 PINS COINED CONTACT | запрос 7-14 дней |
... -PRO FILE COLLET WIRE WRAP 40 PINS Далее 40-6503-31HУстановочные панели для ИС и компонентов LO-PRO FILE COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... ИС и компонентов SURFACE MOUNT 40 PIN Далее 40-6518-00Установочные панели для ИС и компонентов SURFACE MOUNT 40 PIN | запрос 7-14 дней |
... OPEN FRAME COLLET SOLDER TAIL 40 PINS Далее 40-6518-10TУстановочные панели для ИС и компонентов OPEN FRAME COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN TIN Далее 40-6570-10Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN TIN | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN NICKEL Далее 40-6574-16Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN NICKEL | запрос 7-14 дней |
... и компонентов VERTISOCKETS HORIZ COLLET 40 PINS Далее 40-823Установочные панели для ИС и компонентов VERTISOCKETS HORIZ COLLET 40 PINS | запрос 7-14 дней |
... ELEV. SCKT .3 CENTER COLLET 40 PINS Далее 40-8785-610CУстановочные панели для ИС и компонентов ELEV. SCKT .3 CENTER COLLET 40 PINS | запрос 7-14 дней |
Проводные клеммы и зажимы .045 x .750 Rd Pin Brass Tin | запрос 7-14 дней |
Контакты D-Sub CONTACT CRIMP PIN PKG./100 | запрос 7-14 дней |
Принадлежности для автоматических выключателей Busbar,2Phase+1/2pole, ... Далее 2P25U3H/40Принадлежности для автоматических выключателей Busbar,2Phase+1/2pole,25sqmm,;PIN Type,40Lugs,UL/cUL listed | запрос 7-14 дней |
... панели для ИС и компонентов 40 PIN W/HANDLE Далее 40-526-10-RУстановочные панели для ИС и компонентов 40 PIN W/HANDLE | запрос 7-14 дней |
Установочные панели для ИС и компонентов PIN GRID ARRAY SOLDER TAIL ... Далее 120-PGM13015-40*Установочные панели для ИС и компонентов PIN GRID ARRAY SOLDER TAIL 120 PINS | запрос 7-14 дней |
Bulk Metal Foil Technology 3 Pin Transistor Outline Hermetic Resistor ... Далее 1401828-31-40Bulk Metal Foil Technology 3 Pin Transistor Outline Hermetic Resistor Network | запрос 7-14 дней |
INTERCONNECTS 2,54 Grid (0,46 dia.) Pins, Straight and Right Angle ... Далее 350-40-101-00-006000INTERCONNECTS 2,54 Grid (0,46 dia.) Pins, Straight and Right Angle Single Row | запрос 7-14 дней |
Проводные клеммы и зажимы 64P STRAIGHT PIN HDR | запрос 7-14 дней |
Проводные клеммы и зажимы 32P R/A Pin Header | запрос 7-14 дней |
26 Десси Москва Россия | |
... :100mA; Device Marking:BC337-40; Pin Configuration:d; Pins, No. of:3 ... Далее Транзистор биполярный BC337-40 ... Max:800mA; Current, Ic hFE:100mA; Device Marking:BC337-40; Pin Configuration:d; Pins, No. of:3; Power, Ptot:625mW; Transistors, No. of ... | 12.0 ₽ |
Прямой штыревой соединитель жёлтого цвета. Однорядный. Один ряд в 40 ... Далее Разъём PLS-40. Штыревой соединитель прямой 1х40 pin 2, 54 мм. ЖЁЛТЫЙ 10 штукПрямой штыревой соединитель жёлтого цвета. Однорядный. Один ряд в 40 пинов. Шаг разъёмов 2,54 мм. В упаковке 10 штук. | 170 ₽ |
Разъем PLS-40 (вилка штыревая 140pin 2.54мм) (уп. 10шт) | 80.0 ₽ |
Еще 12 строк | |
Прямой штыревой соединитель белого цвета. Однорядный. Один ряд в 40 ... Далее Разъём PLS-40. Штыревой соединитель прямой 1х40 pin 2, 54 мм. БЕЛЫЙ 10 штукПрямой штыревой соединитель белого цвета. Однорядный. Один ряд в 40 пинов. Шаг разъёмов 2,54 мм. В упаковке 10 штук. | 170 ₽ |
Прямой штыревой соединитель красного цвета. Однорядный. Один ряд в 40 ... Далее Разъём PLS-40. Штыревой соединитель прямой 1х40 pin 2, 54 мм. КРАСНЫЙ 10 штукПрямой штыревой соединитель красного цвета. Однорядный. Один ряд в 40 пинов. Шаг разъёмов 2,54 мм. В упаковке 10 штук. | 210 ₽ |
Разъем PBS-40 (гнездо на плату 140pin 2.54mm) (уп. 10шт) 02 Апр 2024 09:03 Разъем PBS-40 (гнездо на плату 140pin 2.54mm) (уп. 10шт) | 180 ₽ |
Конденсатор электролитический алюминиевый: 680 мкФ, 400 В, ф 40x51, - ... Далее Электролитический конденсатор ECAP 680 мкФ 400 Вольт 4051 HP3 4-pinКонденсатор электролитический алюминиевый: 680 мкФ, 400 В, ф 40x51, -40...85, Snap In, HP32G681MSB. Исполнение: FC-TIP-KNDNSTR-LCTRLT-680MF | 743 ₽ |
Прямой штыревой соединитель красного цвета. Двухрядный. Два ряда по 40 ... Далее Разъём PLD-80. Штыревой соединитель прямой 2х40 pin 2, 54 мм. КРАСНЫЙПрямой штыревой соединитель красного цвета. Двухрядный. Два ряда по 40 пинов. Шаг разъёмов 2,54 мм. | 35.0 ₽ |
Прямой штыревой соединитель чёрного цвета. Двухрядный. Два ряда по 40 ... Далее Разъём PLD-80. Штыревой соединитель прямой 2х40 pin 2, 54 мм. ЧЁРНЫЙПрямой штыревой соединитель чёрного цвета. Двухрядный. Два ряда по 40 пинов. Шаг разъёмов 2,54 мм. | 33.0 ₽ |
Прямой штыревой соединитель жёлтого цвета. Двухрядный. Два ряда по 40 ... Далее Разъём PLD-80. Штыревой соединитель прямой 2х40 pin 2, 54 мм. ЖЁЛТЫЙПрямой штыревой соединитель жёлтого цвета. Двухрядный. Два ряда по 40 пинов. Шаг разъёмов 2,54 мм. | 35.0 ₽ |
Разъём PLS-40R SMD. Штыревой соединитель угловой SMD 1х40 pin 2, 54 мм. ЧЁРНЫЙ 2 штуки 02 Апр 2024 09:03 Прямой штыревой соединитель чёрного цвета. Однорядный. Один ряд в 40 ... Далее Разъём PLS-40R SMD. Штыревой соединитель угловой SMD 1х40 pin 2, 54 мм. ЧЁРНЫЙ 2 штукиПрямой штыревой соединитель чёрного цвета. Однорядный. Один ряд в 40 пинов. Шаг разъёмов 2,54 мм. В упаковке 2 штуки. | 120 ₽ |
71.0 ₽ | |
Гнездо на плату, шаг 2.54мм, двухрядное Разъем 2х20(м) для пайки на ... Далее Разъём PBD-40. Гнездо прямое на плату 2х20 pin 2, 54 мм. 2 штукиГнездо на плату, шаг 2.54мм, двухрядное Разъем 2х20(м) для пайки на плату, шаг 2,54мм | 200 ₽ |
LED подсветка TV SAMSUNG 40 комплект из 2-х линеек /56+56/ LED, 3V, алюминий, /L/56+R/56/, 2D, 6pin, 2012SVS40 7032NNB RIGHT56/LEFT56 2D REV1.1 120317 02 Апр 2024 09:03 Samsung UE40ES6307U UE40ES6727U UE40ES6100W UE40ES5507K | 3 234 ₽ |
3 350 ₽ | |
27 ЭИК Санкт-Петербург Россия | |
DIP HEADER COVER 40 PIN .270 | 1 011 ₽ от 1 шт 21-42 дня склад 33 шт |
Еще 3 цен: … 586 ₽ | |
918 ₽ от 10 шт 21-42 дня склад 33 шт | |
809 ₽ от 100 шт 21-42 дня склад 33 шт | |
586 ₽ от 1000 шт 21-42 дня склад 33 шт | |
CONN D-SUB PIN CRIMP GOLD 1=100 | 2 101 ₽ от 1 шт 21-42 дня склад 659 шт |
Еще 4 цен: … 1 690 ₽ | |
1 891 ₽ от 10 шт 21-42 дня склад 659 шт | |
1 782 ₽ от 25 шт 21-42 дня склад 659 шт | |
1 736 ₽ от 50 шт 21-42 дня склад 659 шт | |
1 690 ₽ от 100 шт 21-42 дня склад 659 шт | |
CONN D-SUB PIN CRIMP GOLD 1=100 | 2 101 ₽ от 1 шт 21-42 дня склад 28 шт |
1 891 ₽ от 10 шт 21-42 дня склад 28 шт | |
1 782 ₽ от 25 шт 21-42 дня склад 28 шт | |
1 736 ₽ от 50 шт 21-42 дня склад 28 шт | |
1 690 ₽ от 100 шт 21-42 дня склад 28 шт | |
Еще 20 строк | |
40 PIN INTRA-SWITCH | 23 825 ₽ от 1 шт 21-42 дня склад 5 шт |
TECHNOPOLYMER HINGE, S.S. PIN | 1 104 ₽ от 1 шт 21-42 дня склад 34 шт |
CONN HDR DIP MALE PIN 40POS GOLD | 753 ₽ от 1 шт 21-42 дня склад 899 шт |
Еще 4 цен: … 603 ₽ | |
685 ₽ от 12 шт 21-42 дня склад 899 шт | |
649 ₽ от 36 шт 21-42 дня склад 899 шт | |
633 ₽ от 60 шт 21-42 дня склад 899 шт | |
603 ₽ от 108 шт 21-42 дня склад 899 шт | |
CONN PIN RCPT .025-.037 SMD | 104 ₽ от 1 шт 21-42 дня склад 4384 шт |
Еще 2 цен: … 47.0 ₽ | |
75.0 ₽ от 100 шт 21-42 дня склад 4384 шт | |
47.0 ₽ от 5000 шт 21-42 дня склад 4384 шт | |
CONN PIN RCPT .022-.034 SOLDER | 229 ₽ от 1 шт 21-42 дня склад 45005 шт |
Еще 4 цен: … 127 ₽ | |
194 ₽ от 10 шт 21-42 дня склад 45005 шт | |
182 ₽ от 50 шт 21-42 дня склад 45005 шт | |
158 ₽ от 250 шт 21-42 дня склад 45005 шт | |
127 ₽ от 1000 шт 21-42 дня склад 45005 шт | |
HEATSINK 40X40X23MM PIN | 2 464 ₽ от 1 шт 21-42 дня склад 94 шт |
Еще 3 цен: … 1 834 ₽ | |
2 317 ₽ от 10 шт 21-42 дня склад 94 шт | |
1 965 ₽ от 50 шт 21-42 дня склад 94 шт | |
1 834 ₽ от 100 шт 21-42 дня склад 94 шт | |
CONN PIN RCPT .025-.037 PRESSFIT | 268 ₽ от 1 шт 21-42 дня склад 705 шт |
Еще 3 цен: … 129 ₽ | |
227 ₽ от 10 шт 21-42 дня склад 705 шт | |
203 ₽ от 100 шт 21-42 дня склад 705 шт | |
129 ₽ от 5000 шт 21-42 дня склад 705 шт | |
DIODE,PIN SWITCH,2615 | 4 374 ₽ от 1 шт 21-42 дня склад 1816 шт |
Еще 4 цен: … 3 229 ₽ | |
4 020 ₽ от 10 шт 21-42 дня склад 1816 шт | |
3 854 ₽ от 25 шт 21-42 дня склад 1816 шт | |
3 395 ₽ от 100 шт 21-42 дня склад 1816 шт | |
3 229 ₽ от 250 шт 21-42 дня склад 1816 шт | |
.90" COVER 16 PIN | 65.0 ₽ от 1 шт 21-42 дня склад 37403 шт |
Еще 4 цен: … 35.4 ₽ | |
56.0 ₽ от 25 шт 21-42 дня склад 37403 шт | |
51.0 ₽ от 100 шт 21-42 дня склад 37403 шт | |
39.0 ₽ от 500 шт 21-42 дня склад 37403 шт | |
35.4 ₽ от 2500 шт 21-42 дня склад 37403 шт | |
HEATSINK 40X40X12MM PIN | 2 290 ₽ от 1 шт 21-42 дня склад 481 шт |
Еще 4 цен: … 1 856 ₽ | |
2 227 ₽ от 10 шт 21-42 дня склад 481 шт | |
2 103 ₽ от 25 шт 21-42 дня склад 481 шт | |
1 979 ₽ от 50 шт 21-42 дня склад 481 шт | |
1 856 ₽ от 100 шт 21-42 дня склад 481 шт | |
HEAT SINK PIN FIN 40X40MM CLIP | 1 980 ₽ от 1 шт 21-42 дня склад 104 шт |
Еще 4 цен: … 1 624 ₽ | |
1 879 ₽ от 5 шт 21-42 дня склад 104 шт | |
1 802 ₽ от 10 шт 21-42 дня склад 104 шт | |
1 725 ₽ от 30 шт 21-42 дня склад 104 шт | |
1 624 ₽ от 64 шт 21-42 дня склад 104 шт | |
CONN OFP PIN RCPT .022/.034" DIA | 580 ₽ от 1 шт 21-42 дня склад 999 шт |
Еще 4 цен: … 286 ₽ | |
505 ₽ от 10 шт 21-42 дня склад 999 шт | |
451 ₽ от 100 шт 21-42 дня склад 999 шт | |
322 ₽ от 1000 шт 21-42 дня склад 999 шт | |
286 ₽ от 5000 шт 21-42 дня склад 999 шт | |
HEAVY DUTY BALL LOCK PIN | 851 ₽ от 5 шт 21-42 дня склад 100 шт |
Еще 3 цен: … 628 ₽ | |
766 ₽ от 25 шт 21-42 дня склад 100 шт | |
673 ₽ от 50 шт 21-42 дня склад 100 шт | |
628 ₽ от 100 шт 21-42 дня склад 100 шт | |
QUICK RELEASE PIN, PLASTIC | 6 497 ₽ от 1 шт 21-42 дня склад 20 шт |
ALUMINUM PRESS-FIT THRUST PIN | 985 ₽ от 1 шт 21-42 дня склад 20 шт |
ALUMINUM PRESS-FIT THRUST PIN | 1 398 ₽ от 1 шт 21-42 дня склад 32 шт |
ALUMINUM PRESS-FIT THRUST PIN | 1 545 ₽ от 1 шт 21-42 дня склад 50 шт |
28 Оптулс Москва Россия | |
Инструмент для резки Turned Pin контактов Pressmaster PHC-40 | 23 567 ₽ Розница, Скидки для Дилеров - |
1788210000 WEIDMULLER Корпус для вилки 4-pin, 1хМ25, типа HB-16/HBD-40 TOVU Weidmuller 28 Фев 2024 17:35 ... WEIDMULLER Корпус для вилки 4-pin, 1хМ25, типа HB-16/HBD ... Далее 1788210000 WEIDMULLER Корпус для вилки 4-pin, 1хМ25, типа HB-16/HBD-40 TOVU1788210000 WEIDMULLER Корпус для вилки 4-pin, 1хМ25, типа HB-16/HBD-40 TOVU | 1 711 ₽ Розница, Скидки для Дилеров - |
1788240000 WEIDMULLER Корпус для вилки 4-pin, 1хМ25, типа HB-16/HBD-40 TOVU Weidmuller 28 Фев 2024 17:35 ... WEIDMULLER Корпус для вилки 4-pin, 1хМ25, типа HB-16/HBD ... Далее 1788240000 WEIDMULLER Корпус для вилки 4-pin, 1хМ25, типа HB-16/HBD-40 TOVU1788240000 WEIDMULLER Корпус для вилки 4-pin, 1хМ25, типа HB-16/HBD-40 TOVU | 2 850 ₽ Розница, Скидки для Дилеров - |
Еще 3 строки | |
Пресс-клещи Pressmaster KPB-0140L для обжима Turned Pin контактов 0.14 - 4.0 мм2 (AWG 26-12) PRESSMASTER - 28 Фев 2024 17:35 Пресс-клещи Pressmaster KPB-0140L для обжима Turned Pin контактов 0.14 ... Далее Пресс-клещи Pressmaster KPB-0140L для обжима Turned Pin контактов 0.14 - 4.0 мм2 (AWG 26-12)Пресс-клещи Pressmaster KPB-0140L для обжима Turned Pin контактов 0.14 - 4.0 мм2 (AWG 26-12) | 41 013 ₽ Розница, Скидки для Дилеров - |
Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8) PRESSMASTER - 28 Фев 2024 17:35 Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 ... Далее Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8)Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8) | 41 013 ₽ Розница, Скидки для Дилеров - |
Изолированный цилиндрический PIN коннектор 4, 0-6, 0 мм2, "папа", диам. 5мм, изол. ПВХ (желтый) Safak BE-5050 Safak - 28 Фев 2024 17:35 BE-5050 SAFAK Изолированный цилиндрический PIN коннектор 4,0-6,0 мм2, ... Далее Изолированный цилиндрический PIN коннектор 4, 0-6, 0 мм2, "папа", диам. 5мм, изол. ПВХ (желтый) Safak BE-5050BE-5050 SAFAK Изолированный цилиндрический PIN коннектор 4,0-6,0 мм2, "папа", диам. 5мм, изол. ПВХ (желтый) | 19.7 ₽ Розница, Скидки для Дилеров - |
29 Аудиомания Москва Россия, Беларусь, Казахстан | |
Моноусилитель мощности гибридного типа, юбилейная серия, мощность 1000 ... Далее М 40 HV SilverМоноусилитель мощности гибридного типа, юбилейная серия, мощность 1000 Вт (4 Ом), класс А/АВ, входы: RCA, XLR 3 pin, XLR 4 pin, выходы: 4 ... | 3 150 000 ₽ Доставка: есть Самовывоз: есть - |
30 Берёзка Электронные Компоненты Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
Разъем герметичный 3pin WP L=40 D=21.5 мм 3*0.3 мм2, 3 контакта | 156 ₽ розница 3-4 рабочих дня склад 40 шт |
Еще 3 цен: … 134 ₽ | |
147 ₽ мелкий опт 3-4 рабочих дня склад 40 шт | |
140 ₽ средний опт 3-4 рабочих дня склад 40 шт | |
134 ₽ крупный опт 3-4 рабочих дня склад 40 шт | |
Биполярный транзистор PNP 45В 0.8A 625мВт автомобильного применения 3- ... Далее BC327-40Биполярный транзистор PNP 45В 0.8A 625мВт автомобильного применения 3-Pin TO-92 лента в коробке | 3.24 ₽ розница 3-4 рабочих дня склад 1790 шт |
Еще 3 цен: … 1.98 ₽ | |
2.58 ₽ мелкий опт 3-4 рабочих дня склад 1790 шт | |
2.22 ₽ средний опт 3-4 рабочих дня склад 1790 шт | |
1.98 ₽ крупный опт 3-4 рабочих дня склад 1790 шт | |
Биполярный транзистор NPN 45В 0.5A автомобильного применения 3-Pin SOT ... Далее BC817-40Биполярный транзистор NPN 45В 0.5A автомобильного применения 3-Pin SOT-23 лента на катушке | 3.84 ₽ розница 3-4 рабочих дня склад 3000 шт |
Еще 3 цен: … 1.92 ₽ | |
2.82 ₽ мелкий опт 3-4 рабочих дня склад 3000 шт | |
2.28 ₽ средний опт 3-4 рабочих дня склад 3000 шт | |
1.92 ₽ крупный опт 3-4 рабочих дня склад 3000 шт | |
Еще 9 строк | |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход ... Далее TEN 40-2415WIRПреобразователь DC-DC на печатную плату вход 24В однополярный выход 24В 1.666A 40Вт 6-Pin | 11 729 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 9 731 ₽ | |
10 753 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
10 149 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
9 731 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Разъём герметичный 2 контакта L=40мм D=21.5 мм | 171 ₽ розница 3-4 рабочих дня склад 37 шт |
Еще 3 цен: … 148 ₽ | |
161 ₽ мелкий опт 3-4 рабочих дня склад 37 шт | |
154 ₽ средний опт 3-4 рабочих дня склад 37 шт | |
148 ₽ крупный опт 3-4 рабочих дня склад 37 шт | |
Разъём герметичный 2 контакта L=40мм D=13 мм | 104 ₽ розница 3-4 рабочих дня склад 150 шт |
Еще 3 цен: … 78.7 ₽ | |
92.2 ₽ мелкий опт 3-4 рабочих дня склад 150 шт | |
84.2 ₽ средний опт 3-4 рабочих дня склад 150 шт | |
78.7 ₽ крупный опт 3-4 рабочих дня склад 150 шт | |
Разъём герметичный 2 контакта L=40мм D=19 мм | 107 ₽ розница 3-4 рабочих дня склад 57 шт |
Еще 3 цен: … 90.8 ₽ | |
99.8 ₽ мелкий опт 3-4 рабочих дня склад 57 шт | |
95.2 ₽ средний опт 3-4 рабочих дня склад 57 шт | |
90.8 ₽ крупный опт 3-4 рабочих дня склад 57 шт | |
пара герм., IP68, 6A, DC 0-24В (AC110-220В), D=21,5мм, 2*0.75мм2, L= ... Далее 2PIN WP L = 40 D = 21.5MM 2*0.75MM2пара герм., IP68, 6A, DC 0-24В (AC110-220В), D=21,5мм, 2*0.75мм2, L=40см, -20...80 C | 135 ₽ розница 3-4 рабочих дня склад 50 шт |
Еще 3 цен: … 116 ₽ | |
127 ₽ мелкий опт 3-4 рабочих дня склад 50 шт | |
121 ₽ средний опт 3-4 рабочих дня склад 50 шт | |
116 ₽ крупный опт 3-4 рабочих дня склад 50 шт | |
пара герм., IP68, 2A, DC 0-24В (AC110-220В), D=21,5мм, 5*0.2мм2, L= ... Далее 5PIN WP L = 40 D = 21.5MM 5*0.2MM2пара герм., IP68, 2A, DC 0-24В (AC110-220В), D=21,5мм, 5*0.2мм2, L=40см, -20...80 C | 235 ₽ розница 3-4 рабочих дня склад 25 шт |
Еще 3 цен: … 203 ₽ | |
221 ₽ мелкий опт 3-4 рабочих дня склад 25 шт | |
212 ₽ средний опт 3-4 рабочих дня склад 25 шт | |
203 ₽ крупный опт 3-4 рабочих дня склад 25 шт | |
DIP-панель цанговая под микросхему 40pin, шаг 2.54мм, ширина 15.24мм | 57.2 ₽ розница 3-4 рабочих дня склад 228 шт |
Еще 3 цен: … 42.1 ₽ | |
50.1 ₽ мелкий опт 3-4 рабочих дня склад 228 шт | |
45.4 ₽ средний опт 3-4 рабочих дня склад 228 шт | |
42.1 ₽ крупный опт 3-4 рабочих дня склад 228 шт | |
Плоский кабель шлейф 40pin, шаг 1.27мм, бухта 30,5 м. | 4 256 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 492 ₽ | |
3 885 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 653 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 492 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
DIP-панель под микросхему 40pin, шаг 1.778мм, ширина 15.24мм | 16.0 ₽ розница 3-4 рабочих дня склад 160 шт |
14.0 ₽ мелкий опт 3-4 рабочих дня склад 160 шт | |
12.7 ₽ средний опт 3-4 рабочих дня склад 160 шт | |
11.6 ₽ крупный опт 3-4 рабочих дня склад 160 шт | |
31 Промэлектроника Екатеринбург Россия и страны СНГ | |
Разъем герметичный 3pin WP L=40 D=21.5 мм 3*0.3 мм2, 3 контакта | 135 ₽ от 1 шт от 2-10 дней склад 46 шт |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход ... Далее TEN 40-2415WIRПреобразователь DC-DC на печатную плату вход 24В однополярный выход 24В 1.666A 40Вт 6-Pin | 12 016 ₽ от 1 шт от 2-10 дней склад 20 шт |
Преобразователь DC-DC на печатную плату вход 48В однополярный выход 5В ... Далее TEN 40-4811Преобразователь DC-DC на печатную плату вход 48В однополярный выход 5В 8A 40Вт 9-Pin | 12 228 ₽ от 1 шт от 2-10 дней склад 5 шт |
Еще 4 строки | |
пара герм., IP68, 6A, DC 0-24В (AC110-220В), D=21,5мм, 2*0.75мм2, L= ... Далее 2PIN WP L = 40 D = 21.5MM 2*0.75MM2пара герм., IP68, 6A, DC 0-24В (AC110-220В), D=21,5мм, 2*0.75мм2, L=40см, -20...80 C | 117 ₽ от 1 шт от 2-10 дней склад 34 шт |
пара герм., IP68, 2A, DC 0-24В (AC110-220В), D=21,5мм, 5*0.2мм2, L= ... Далее 5PIN WP L = 40 D = 21.5MM 5*0.2MM2пара герм., IP68, 2A, DC 0-24В (AC110-220В), D=21,5мм, 5*0.2мм2, L=40см, -20...80 C | 203 ₽ от 1 шт от 2-10 дней склад 29 шт |
Разъём герметичный 2 контакта L=40мм D=13 мм | 96.6 ₽ от 1 шт от 2-10 дней склад 370 шт |
Разъём герметичный 2 контакта L=40мм D=19 мм | 93.2 ₽ от 1 шт от 2-10 дней склад 9 шт |
32 ICdarom.ru Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
Биполярный транзистор PNP 45В 0.8A 625мВт автомобильного применения 3- ... Далее BC327-40Биполярный транзистор PNP 45В 0.8A 625мВт автомобильного применения 3-Pin TO-92 лента в коробке | 3.12 ₽ розница 3-4 рабочих дня склад 1790 шт |
2.46 ₽ мелкий опт 3-4 рабочих дня склад 1790 шт | |
2.16 ₽ средний опт 3-4 рабочих дня склад 1790 шт | |
1.92 ₽ крупный опт 3-4 рабочих дня склад 1790 шт | |
Биполярный транзистор NPN 45В 0.5A автомобильного применения 3-Pin SOT ... Далее BC817-40Биполярный транзистор NPN 45В 0.5A автомобильного применения 3-Pin SOT-23 лента на катушке | 3.72 ₽ розница 3-4 рабочих дня склад 3000 шт |
Еще 3 цен: … 1.80 ₽ | |
2.76 ₽ мелкий опт 3-4 рабочих дня склад 3000 шт | |
2.16 ₽ средний опт 3-4 рабочих дня склад 3000 шт | |
1.80 ₽ крупный опт 3-4 рабочих дня склад 3000 шт | |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход ... Далее TEN 40-2415WIRПреобразователь DC-DC на печатную плату вход 24В однополярный выход 24В 1.666A 40Вт 6-Pin | 11 264 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 9 345 ₽ | |
10 327 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
9 747 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
9 345 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Еще 8 строк | |
Разъём герметичный 2 контакта L=40мм D=21.5 мм | 165 ₽ розница 3-4 рабочих дня склад 37 шт |
Еще 3 цен: … 142 ₽ | |
155 ₽ мелкий опт 3-4 рабочих дня склад 37 шт | |
148 ₽ средний опт 3-4 рабочих дня склад 37 шт | |
142 ₽ крупный опт 3-4 рабочих дня склад 37 шт | |
Разъём герметичный 2 контакта L=40мм D=13 мм | 100 ₽ розница 3-4 рабочих дня склад 150 шт |
Еще 3 цен: … 75.6 ₽ | |
88.5 ₽ мелкий опт 3-4 рабочих дня склад 150 шт | |
80.9 ₽ средний опт 3-4 рабочих дня склад 150 шт | |
75.6 ₽ крупный опт 3-4 рабочих дня склад 150 шт | |
Разъём герметичный 2 контакта L=40мм D=19 мм | 102 ₽ розница 3-4 рабочих дня склад 57 шт |
Еще 3 цен: … 87.2 ₽ | |
95.9 ₽ мелкий опт 3-4 рабочих дня склад 57 шт | |
91.4 ₽ средний опт 3-4 рабочих дня склад 57 шт | |
87.2 ₽ крупный опт 3-4 рабочих дня склад 57 шт | |
пара герм., IP68, 6A, DC 0-24В (AC110-220В), D=21,5мм, 2*0.75мм2, L= ... Далее 2PIN WP L = 40 D = 21.5MM 2*0.75MM2пара герм., IP68, 6A, DC 0-24В (AC110-220В), D=21,5мм, 2*0.75мм2, L=40см, -20...80 C | 133 ₽ розница 3-4 рабочих дня склад 50 шт |
Еще 3 цен: … 111 ₽ | |
122 ₽ мелкий опт 3-4 рабочих дня склад 50 шт | |
116 ₽ средний опт 3-4 рабочих дня склад 50 шт | |
111 ₽ крупный опт 3-4 рабочих дня склад 50 шт | |
пара герм., IP68, 2A, DC 0-24В (AC110-220В), D=21,5мм, 5*0.2мм2, L= ... Далее 5PIN WP L = 40 D = 21.5MM 5*0.2MM2пара герм., IP68, 2A, DC 0-24В (AC110-220В), D=21,5мм, 5*0.2мм2, L=40см, -20...80 C | 226 ₽ розница 3-4 рабочих дня склад 25 шт |
Еще 3 цен: … 195 ₽ | |
212 ₽ мелкий опт 3-4 рабочих дня склад 25 шт | |
203 ₽ средний опт 3-4 рабочих дня склад 25 шт | |
195 ₽ крупный опт 3-4 рабочих дня склад 25 шт | |
DIP-панель цанговая под микросхему 40pin, шаг 2.54мм, ширина 15.24мм | 55.0 ₽ розница 3-4 рабочих дня склад 228 шт |
Еще 3 цен: … 40.4 ₽ | |
48.1 ₽ мелкий опт 3-4 рабочих дня склад 228 шт | |
43.6 ₽ средний опт 3-4 рабочих дня склад 228 шт | |
40.4 ₽ крупный опт 3-4 рабочих дня склад 228 шт | |
Плоский кабель шлейф 40pin, шаг 1.27мм, бухта 30,5 м. | 4 088 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 353 ₽ | |
3 731 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 508 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 353 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
DIP-панель под микросхему 40pin, шаг 1.778мм, ширина 15.24мм | 15.4 ₽ розница 3-4 рабочих дня склад 160 шт |
Еще 3 цен: … 11.2 ₽ | |
13.4 ₽ мелкий опт 3-4 рабочих дня склад 160 шт | |
12.2 ₽ средний опт 3-4 рабочих дня склад 160 шт | |
11.2 ₽ крупный опт 3-4 рабочих дня склад 160 шт | |
33 Romstore Москва Россия, Беларусь | |
Мак. плата QFP 0.5 40-208pin 25 Апр 2024 02:14 | 1 190 ₽ розница |
950 ₽ опт | |
34 Кремний Санкт-Петербург Россия и страны СНГ | |
IC SOCKET 40 PIN 26 Апр 2024 22:57 | запрос 7-14 дней |
IC SOCKET 40 PIN D/C99 26 Апр 2024 22:57 | запрос 7-14 дней |
запрос 2 недели | |
Еще 3 строки | |
запрос 2 недели | |
запрос 2 недели | |
запрос 2 недели | |
35 ЭлектроПласт Санкт-Петербург Россия | |
... для ИС и компонентов COLLET PIN CARRIERS 40 PINS Далее 40-0540-10Установочные панели для ИС и компонентов COLLET PIN CARRIERS 40 PINS | запрос 7-14 дней |
... DUAL ROW COLLET WIRE WRAP 40 PINS Далее 40-1508-21Установочные панели для ИС и компонентов DUAL ROW COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... и компонентов WIRE WRAP BIFURCATED 40 PINS GOLD Далее 40-501Установочные панели для ИС и компонентов WIRE WRAP BIFURCATED 40 PINS GOLD | запрос 7-14 дней |
Еще 6 строк | |
... ИС и компонентов SOLDER TAIL 40 PINS TIN Далее 40-511-1Установочные панели для ИС и компонентов SOLDER TAIL 40 PINS TIN | запрос 7-14 дней |
... и компонентов ELEVATOR STRIP LINE 40 PINS Далее 40-7350-10Установочные панели для ИС и компонентов ELEVATOR STRIP LINE 40 PINS | запрос 7-14 дней |
Установочные панели для ИС и компонентов PIN GRID ARRAY SOLDER TAIL ... Далее 145-PGM15024-40*Установочные панели для ИС и компонентов PIN GRID ARRAY SOLDER TAIL 145 PINS | запрос 7-14 дней |
CONN PLUG 61POS RT ANG W/PINS | запрос 7-14 дней |
CONN RCPT 35POS BOX MNT W/PINS | запрос 7-14 дней |
36 TradeElectronics Москва Россия | |
... и компонентов WIRE WRAP BIFURCATED 40 PINS GOLD Далее 40-501-31Установочные панели для ИС и компонентов WIRE WRAP BIFURCATED 40 PINS GOLD | запрос 7-14 дней |
... для ИС и компонентов HEADER 40 PINS COINED CONTACT Далее 40-600Установочные панели для ИС и компонентов HEADER 40 PINS COINED CONTACT | запрос 7-14 дней |
... -PRO FILE COLLET WIRE WRAP 40 PINS Далее 40-6503-31Установочные панели для ИС и компонентов LO-PRO FILE COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
Еще 20 строк | |
... OPEN FRAME CAPACITOR WIRE WRAP 40 PINS Далее 40-6508-301Установочные панели для ИС и компонентов OPEN FRAME CAPACITOR WIRE WRAP 40 PINS | запрос 7-14 дней |
... -PRO FILE COLLET SOLDER TAIL 40 PINS Далее 40-6513-11HУстановочные панели для ИС и компонентов LO-PRO FILE COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... OPEN FRAME COLLET SOLDER TAIL 40 PINS Далее 40-6518-10MУстановочные панели для ИС и компонентов OPEN FRAME COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... компонентов DIP TEST SCKT GOLD 40 PINS Далее 40-6552-11*Установочные панели для ИС и компонентов DIP TEST SCKT GOLD 40 PINS | запрос 7-14 дней |
... /EJECT DIP SCKT WIRE WRAP 40 PINS Далее 40-C182-20Установочные панели для ИС и компонентов LOCK/EJECT DIP SCKT WIRE WRAP 40 PINS | запрос 7-14 дней |
... панели для ИС и компонентов 40 PIN TIN SHORT LEVER Далее 40-516-10SУстановочные панели для ИС и компонентов 40 PIN TIN SHORT LEVER | запрос 7-14 дней |
... панели для ИС и компонентов 40 PIN W/HANDLE Далее 40-526-10Установочные панели для ИС и компонентов 40 PIN W/HANDLE | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN HI TEMP Далее 40-657Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN HI TEMP | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN TIN Далее 40-6572-10Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN TIN | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN GOLD Далее 40-6574-11Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN GOLD | запрос 7-14 дней |
40-PIN TEST CLIP ALLOY DIP .60 | запрос 7-14 дней |
... зажимы SHRD HDR .100X.100 40 PIN GLD W/ TIN TL Далее 925320-01-40-RAПроводные клеммы и зажимы SHRD HDR .100X.100 40 PIN GLD W/ TIN TL | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3101-4021-40INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.030?€? dia.) Pins, Straight and Right ... Далее 802-40-002-10-001000INTERCONNECTS .100?€? Grid (.030?€? dia.) Pins, Straight and Right Angle Double Row | запрос 7-14 дней |
CONN RCPT 21POS IN LINE W/PINS | запрос 7-14 дней |
CONN RCPT 60POS BOX MNT W/PINS | запрос 7-14 дней |
CONN RCPT 7POS BOX MNT W/PINS | запрос 7-14 дней |
37 ТаймЧипс Санкт-Петербург Россия | |
... DUAL ROW COLLET WIRE WRAP 40 PINS Далее 40-1508-31Установочные панели для ИС и компонентов DUAL ROW COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... DUAL ROW COLLET SOLDER TAIL 40 PINS Далее 40-1518-11HУстановочные панели для ИС и компонентов DUAL ROW COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... компонентов DIP TEST SCKT NICKEL 40 PINS Далее 40-3553-16*Установочные панели для ИС и компонентов DIP TEST SCKT NICKEL 40 PINS | запрос 7-14 дней |
Еще 26 строк | |
... и компонентов WIRE WRAP BIFURCATED 40 PINS GOLD Далее 40-501-21Установочные панели для ИС и компонентов WIRE WRAP BIFURCATED 40 PINS GOLD | запрос 7-14 дней |
... ИС и компонентов SOLDER TAIL 40 PINS GOLD Далее 40-511-11Установочные панели для ИС и компонентов SOLDER TAIL 40 PINS GOLD | запрос 7-14 дней |
... -PRO FILE COLLET WIRE WRAP 40 PINS Далее 40-6503-21Установочные панели для ИС и компонентов LO-PRO FILE COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... OPEN FRAME CAPACITOR WIRE WRAP 40 PINS Далее 40-6508-212Установочные панели для ИС и компонентов OPEN FRAME CAPACITOR WIRE WRAP 40 PINS | запрос 7-14 дней |
... -PRO FILE COLLET SOLDER TAIL 40 PINS Далее 40-6513-10TУстановочные панели для ИС и компонентов LO-PRO FILE COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... OPEN FRAME COLLET SOLDER TAIL 40 PINS Далее 40-6518-10EУстановочные панели для ИС и компонентов OPEN FRAME COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... и компонентов VERTISOCKETS HORIZ COLLET 40 PINS Далее 40-820-90CУстановочные панели для ИС и компонентов VERTISOCKETS HORIZ COLLET 40 PINS | запрос 7-14 дней |
... ELEV. SCKT .3 CENTER COLLET 40 PINS Далее 40-8600-610CУстановочные панели для ИС и компонентов ELEV. SCKT .3 CENTER COLLET 40 PINS | запрос 7-14 дней |
... ELEV. SCKT .3 CENTER COLLET 40 PINS Далее 40-8770-610CУстановочные панели для ИС и компонентов ELEV. SCKT .3 CENTER COLLET 40 PINS | запрос 7-14 дней |
... /EJECT DIP SCKT SOLDER TAIL 40 PINS Далее 40-C212-11Установочные панели для ИС и компонентов LOCK/EJECT DIP SCKT SOLDER TAIL 40 PINS | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN GOLD Далее 40-3572-11Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN GOLD | запрос 7-14 дней |
... панели для ИС и компонентов 40 PIN GOLD SHORT LEVER Далее 40-516-1Установочные панели для ИС и компонентов 40 PIN GOLD SHORT LEVER | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3100-8-102-40INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 31002-403-40INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3101-4069-40INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & ... Далее 3104-5098-02-86-40INTERCONNECTS .100?€? Grid (.018?€? dia.) Pins SMT Gull Wing Headers & Sockets Single and Double Row | запрос 7-14 дней |
INTERCONNECTS .100?€? Grid (.030?€? dia.) Pins, Straight and Right ... Далее 800-40-002-20-001000INTERCONNECTS .100?€? Grid (.030?€? dia.) Pins, Straight and Right Angle Single Row | запрос 7-14 дней |
38 LifeElectronics Санкт-Петербург Россия | |
... и компонентов STRIP LINE BIFURCATE 40 PINS TIN Далее 40-0501-20Установочные панели для ИС и компонентов STRIP LINE BIFURCATE 40 PINS TIN | запрос 7-14 дней |
... и компонентов STRIP LINE SOCKETS 40 PINS GOLD Далее 40-0511-11Установочные панели для ИС и компонентов STRIP LINE SOCKETS 40 PINS GOLD | запрос 7-14 дней |
... DUAL ROW COLLET WIRE WRAP 40 PINS Далее 40-150Установочные панели для ИС и компонентов DUAL ROW COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
Еще 36 строк | |
... -PRO FILE COLLET WIRE WRAP 40 PINS Далее 40-3503-21Установочные панели для ИС и компонентов LO-PRO FILE COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... ИС и компонентов DIP HEADERS 40 PINS SCREW MACHINE CONT Далее 40-3625-31Установочные панели для ИС и компонентов DIP HEADERS 40 PINS SCREW MACHINE CONT | запрос 7-14 дней |
... и компонентов WIRE WRAP BIFURCATED 40 PINS TIN Далее 40-501-30Установочные панели для ИС и компонентов WIRE WRAP BIFURCATED 40 PINS TIN | запрос 7-14 дней |
... -PRO FILE COLLET WIRE WRAP 40 PINS Далее 40-6503-30Установочные панели для ИС и компонентов LO-PRO FILE COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... OPEN FRAME COLLET WIRE WRAP 40 PINS Далее 40-6508-30Установочные панели для ИС и компонентов OPEN FRAME COLLET WIRE WRAP 40 PINS | запрос 7-14 дней |
... -PRO FILE COLLET SOLDER TAIL 40 PINS Далее 40-6513-11Установочные панели для ИС и компонентов LO-PRO FILE COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... OPEN FRAME COLLET SOLDER TAIL 40 PINS Далее 40-6518-10HУстановочные панели для ИС и компонентов OPEN FRAME COLLET SOLDER TAIL 40 PINS | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN GOLD Далее 40-3570-11Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN GOLD | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN NICKEL Далее 40-3572-16Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN NICKEL | запрос 7-14 дней |
... ИС и компонентов QUICK RELEASE 40 PIN NICKEL Далее 40-3574-16Установочные панели для ИС и компонентов QUICK RELEASE 40 PIN NICKEL | запрос 7-14 дней |
... панели для ИС и компонентов 40-PIN ZIF SOCKET Далее 40-516-10Установочные панели для ИС и компонентов 40-PIN ZIF SOCKET | запрос 7-14 дней |
40 PIN ZIF SOCKET,GOLD | запрос 7-14 дней |
INTERCONNECTS 2,54 Grid (0,46 dia.) Pins, Straight and Right Angle ... Далее 399-40-102-00-009000INTERCONNECTS 2,54 Grid (0,46 dia.) Pins, Straight and Right Angle Single Row | запрос 7-14 дней |
39 Зенер Москва Россия и страны ТС | |
CONN PLUG W/PINS | 11 446 ₽ от 5 шт |
Еще 2 цен: … 9 045 ₽ | |
9 728 ₽ от 10 шт | |
9 045 ₽ от 25 шт | |
CONN PLUG W/PINS | 23 257 ₽ от 5 шт |
Еще 2 цен: … 20 174 ₽ | |
21 445 ₽ от 10 шт | |
20 174 ₽ от 25 шт | |
CONN PLUG W/PINS | запрос 5-15 дней |
Еще 31 строка | |
CONN PLUG W/PINS | 50 593 ₽ от 5 шт |
Еще 2 цен: … 45 849 ₽ | |
47 328 ₽ от 10 шт | |
45 849 ₽ от 25 шт | |
CONN PLUG W/PINS | 78 034 ₽ от 5 шт |
Еще 2 цен: … 70 719 ₽ | |
73 000 ₽ от 10 шт | |
70 719 ₽ от 25 шт | |
CONN PLUG W/PINS | 118 095 ₽ от 5 шт |
Еще 2 цен: … 107 024 ₽ | |
110 477 ₽ от 10 шт | |
107 024 ₽ от 25 шт | |
CONN PLUG W/PINS | 64 642 ₽ от 5 шт |
Еще 2 цен: … 58 583 ₽ | |
60 473 ₽ от 10 шт | |
58 583 ₽ от 25 шт | |
CONN PLUG W/PINS | 54 667 ₽ от 5 шт |
Еще 2 цен: … 49 543 ₽ | |
51 141 ₽ от 10 шт | |
49 543 ₽ от 25 шт | |
CONN PLUG W/PINS | 62 792 ₽ от 5 шт |
Еще 2 цен: … 56 905 ₽ | |
58 741 ₽ от 10 шт | |
56 905 ₽ от 25 шт | |
CONN PLUG W/PINS | 77 111 ₽ от 5 шт |
Еще 2 цен: … 69 881 ₽ | |
72 135 ₽ от 10 шт | |
69 881 ₽ от 25 шт | |
CONN PLUG W/PINS | 69 936 ₽ от 5 шт |
Еще 2 цен: … 63 378 ₽ | |
65 423 ₽ от 10 шт | |
63 378 ₽ от 25 шт | |
CONN PLUG W/PINS | 88 126 ₽ от 5 шт |
Еще 2 цен: … 79 864 ₽ | |
82 440 ₽ от 10 шт | |
79 864 ₽ от 25 шт | |
40 Onber.ru Москва Россия и страны СНГ | |
COM 1-4 cable 40-pin, 9-pin male DSUB x 4 | 327 ₽ 100% предоплата. Минимальная... Далее 100% предоплата. Минимальная сумма заказа 5000 р. Самовывоз: есть под заказ |
41 Whitegoods Москва Россия | |
Аппарат пончиковый Сиком ПРФ-11/300АD (D40) используется на ... Далее ПРФ-11/300AD (D40) - 212138Аппарат пончиковый Сиком ПРФ-11/300АD (D40) используется на предприятиях общественного питания и торговли для формирования и приготовления в ... | 111 314 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Аппарат пончиковый Сиком ПРФ-11/900D (D40) используется на ... Далее ПРФ-11/900D (D40) - 212141Аппарат пончиковый Сиком ПРФ-11/900D (D40) используется на предприятиях общественного питания и торговли для формирования и приготовления в ... | 266 957 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Аппарат пончиковый автоматический СИКОМ ПРФ-11/1200D (D40) ... Далее ПРФ-11/1200D (D40)Аппарат пончиковый автоматический СИКОМ ПРФ-11/1200D (D40) используется на предприятиях общественного питания и торговли для формирования и ... | 214 320 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
42 Холодильник.ру Москва Россия | |
Объем памяти (Гб): 4
Разрядность шины памяти (бит): 128
Длина ... Далее Видеокарта Gigabyte GeForce GTX 1650 D6 OC 4.0 4GB (GV-N1656OC-4GD 4.0)Объем памяти (Гб): 4
Длина видеокарты (мм): 170
Разъем дополнительного питания: 8 pin
Количество слотов ... | 20 490 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
43 Контест Москва Россия | |
AT24C02BN-SH-T 25 Апр 2024 02:08 ... bytes, write protect pin, Vcc=1.8-5.5V, -40 to +85C) Далее AT24C02BN-SH-T ... interface, 100 kHz, 32 pages of 8 bytes, write protect pin, Vcc=1.8-5.5V, -40 to +85C) | 40.8 ₽ |
AT24C64AN-10SI-2.7 25 Апр 2024 02:08 ... bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C) Далее AT24C64AN-10SI-2.7 ... interface, 400 kHz, 256 pages of 32 bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C) | 25.8 ₽ |
AT24C64AN-10SU-2.7 25 Апр 2024 02:08 ... bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C ... Далее AT24C64AN-10SU-2.7 ... interface, 400 kHz, 256 pages of 32 bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C), Pb-free. | 36.0 ₽ |
Еще 122 строки | |
AT25160A-10PI-1.8 25 Апр 2024 02:08 ... @5V, write protect pin, Vcc=1.8-5.5V, -40 to +85C) Далее AT25160A-10PI-1.8 ... , 1M циклов, SPI compatible interface, 3.0MHz@5V, write protect pin, Vcc=1.8-5.5V, -40 to +85C) | 34.8 ₽ |
AT24C256-10PU-2.7 25 Апр 2024 02:08 ... bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C ... Далее AT24C256-10PU-2.7 ... interface, 400 kHz, 512 pages of 64 bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C), Pb-free | 216 ₽ склад 1 шт |
... bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C ... Далее AT24C256-10PU-2.7 ... interface, 400 kHz, 512 pages of 64 bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C), Pb-free | запрос склад 22 шт |
... @5V, write protect pin, Vcc=2.7-5.5V, -40 to +85C ... Далее AT25160AN-10SU-2.7 ... , 1M циклов, SPI compatible interface, 3.0MHz@5V, write protect pin, Vcc=2.7-5.5V, -40 to +85C), Pb-free | 37.8 ₽ склад 1 шт |
AT25160AN-10SU-2.7 25 Апр 2024 02:08 ... @5V, write protect pin, Vcc=2.7-5.5V, -40 to +85C ... Далее AT25160AN-10SU-2.7 ... , 1M циклов, SPI compatible interface, 3.0MHz@5V, write protect pin, Vcc=2.7-5.5V, -40 to +85C), Pb-free | 67.9 ₽ |
... @5V, write protect pin, Vcc=2.7-5.5V, -40 to +85C ... Далее AT25160AN-10SU-2.7 ... , 1M циклов, SPI compatible interface, 3.0MHz@5V, write protect pin, Vcc=2.7-5.5V, -40 to +85C), Pb-free | запрос склад 68 шт |
AT25256AN-10SU-2.7 25 Апр 2024 02:08 ... @5V, write protect pin, Vcc=2.7-5.5V, -40 to +85C ... Далее AT25256AN-10SU-2.7 ... , 100K циклов, SPI compatible interface, 20 MHz@5V, write protect pin, Vcc=2.7-5.5V, -40 to +85C), Pb-free. | 202 ₽ |
... bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C ... Далее AT24C256B-10PU-1.8 ... interface, 400 kHz, 512 pages of 64 bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C), Pb-free. | запрос склад 48 шт |
... bytes, write protect pin, Vcc=1.8-3.6V, -40 to +85C ... Далее AT24C256BN-SH-T ... kHz (1.8V), 512 pages of 64 bytes, write protect pin, Vcc=1.8-3.6V, -40 to +85C) покр. выв. NiPdAu | запрос склад 31 шт |
AT24C256BN-SH-T 25 Апр 2024 02:08 ... bytes, write protect pin, Vcc=1.8-3.6V, -40 to +85C ... Далее AT24C256BN-SH-T ... kHz (1.8V), 512 pages of 64 bytes, write protect pin, Vcc=1.8-3.6V, -40 to +85C) покр. выв. NiPdAu | 152 ₽ |
... bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C) Далее AT24C256N-10SI-2.7 ... interface, 400 kHz, 512 pages of 64 bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C) | запрос склад 123 шт |
AT24C256N-10SI-2.7 25 Апр 2024 02:08 ... bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C) Далее AT24C256N-10SI-2.7 ... interface, 400 kHz, 512 pages of 64 bytes, write protect pin, Vcc=2.7-5.5V, -40 to +85C) | 1 103 ₽ |
... @5V, write protect pin, Vcc=2.7-5.5V, -40 to +125C) Далее AT25080A-10TU-2.7 ... , 1M циклов, SPI compatible interface, 5.0MHz@5V, write protect pin, Vcc=2.7-5.5V, -40 to +125C) | запрос склад 3148 шт |
... bytes, write protect pin, Vcc=1.8-5.5V, -40 to +85C) Далее AT24C02BN-SH-T ... interface, 100 kHz, 32 pages of 8 bytes, write protect pin, Vcc=1.8-5.5V, -40 to +85C) | 18.3 ₽ склад 3 шт |
... bytes, write protect pin, Vcc=1.8-5.5V, -40 to +85C) Далее AT24C02BN-SH-T ... interface, 100 kHz, 32 pages of 8 bytes, write protect pin, Vcc=1.8-5.5V, -40 to +85C) | запрос склад 3030 шт |
25LC640-I/SN 25 Апр 2024 02:08 ... @5V, write protect pin, Vcc=2.5-5.5V, -40 to +85C) Далее 25LC640-I/SN ... , 10 M циклов, SPI interface, 2.0MHz@5V, write protect pin, Vcc=2.5-5.5V, -40 to +85C) | 107 ₽ |
... bytes, write protect pin, Vcc=1.8-5.5V, -40 to +85C) Далее AT24C02BN-10SU-1.8 ... interface, 100 kHz, 32 pages of 8 bytes, write protect pin, Vcc=1.8-5.5V, -40 to +85C) | запрос склад 1165 шт |
44 ВсеИнструменты.ру Москва Россия | |
... Gembird 120x120x38, подшипник, 3 pin, провод 40 см, D12038BM-3 Далее Вентилятор GembirdВентилятор Gembird 120x120x38, подшипник, 3 pin, провод 40 см, D12038BM-3 | 440 ₽ на складе |
Вентилятор Gembird 120x120x38, втулка, 4 pin, провод 40 см, D12038SM-4 | 462 ₽ на складе |
... вентилятор Gembird 120x120x38, 4 pin, провод 40 см, D12038HM-4 Далее Гидродинамический вентилятор GembirdГидродинамический вентилятор Gembird 120x120x38, 4 pin, провод 40 см, D12038HM-4 | 474 ₽ на складе |
Еще 1 строка | |
Вентилятор Gembird 120x120x38, втулка, 3 pin, провод 40 см, D12038SM-3 | 385 ₽ на складе |
45 AliExpress Китай Весь мир | |
1 075 ₽ от 21 дня | |
516 ₽ от 21 дня | |
1.41 ₽ от 10 шт 10 шт/лот от 21 дня | |
Еще 35 строк | |
22.7 ₽ от 21 дня | |
410 ₽ от 21 дня | |
108 ₽ от 5 шт 5 шт/лот от 21 дня | |
27.0 ₽ от 21 дня | |
3.03 ₽ от 5 шт 5 шт/лот от 21 дня | |
3.24 ₽ от 5 шт 5 шт/лот от 21 дня | |
899 ₽ от 5 шт 5 шт/лот от 21 дня | |
527 ₽ от 21 дня | |
2 864 ₽ от 21 дня | |
190 ₽ от 21 дня | |
189 ₽ от 21 дня | |
44.3 ₽ от 21 дня | |
213 ₽ от 2 шт 2 шт/лот от 21 дня | |
139 ₽ от 10 шт 10 шт/лот от 21 дня | |
2.56 ₽ от 460 шт 460 шт/лот от 21 дня |
Искать "40-pin" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 92.1314 |
EUR | 98.7079 |
