1 Flash-Turtle Китай Весь мир | |
Buzzers Transducer, Externally Driven Piezo 10 V 10mA 80dB @ 10V, 10cm ... Далее CUI Devices CPE-6080Buzzers Transducer, Externally Driven Piezo 10 V 10mA 80dB @ 10V, 10cm Panel Mount, Flange Wire Leads | запрос 7 дней склад 28682 шт |
12 μF Hermetically Sealed Tantalum Capacitors 20 V Axial | запрос 7 дней склад 37636 шт |
40.608 MHz XO (Standard) CMOS Oscillator 1.8V ~ 3.3V Standby (Power ... Далее DSC1001AE2-040.608040.608 MHz XO (Standard) CMOS Oscillator 1.8V ~ 3.3V Standby (Power Down) 4-SMD, No Lead Exposed Pad | запрос 7 дней склад 6052 шт |
Еще 8 строк | |
40.608 MHz XO (Standard) CMOS Oscillator 1.8V ~ 3.3V Standby (Power ... Далее DSC1001AE5-040.608040.608 MHz XO (Standard) CMOS Oscillator 1.8V ~ 3.3V Standby (Power Down) 4-SMD, No Lead Exposed Pad | запрос 7 дней склад 16181 шт |
Dot Matrix Display Module 5 x 8 Common Cathode Row, Common Anode ... Далее TBA24-11EGWADot Matrix Display Module 5 x 8 Common Cathode Row, Common Anode Column Green, Red 2.2V Green, 2V Red 1.50 L x 2.39 W x 0.34 H (38.10mm x 60 ... | запрос 7 дней склад 24532 шт |
Dot Matrix Display Module 5 x 8 Common Cathode Row, Common Anode ... Далее TBA24-22EGWADot Matrix Display Module 5 x 8 Common Cathode Row, Common Anode Column Green, Red 2.2V Green, 2V Red 1.50 L x 2.39 W x 0.35 H (38.10mm x 60 ... | запрос 7 дней склад 6971 шт |
Dot Matrix Display Module 5 x 8 Common Anode Row, Common Cathode ... Далее TBC24-11EGWADot Matrix Display Module 5 x 8 Common Anode Row, Common Cathode Column Green, Red 2.2V Green, 2V Red 1.52 L x 2.39 W x 0.34 H (38.50mm x 60 ... | запрос 7 дней склад 47620 шт |
Dot Matrix Display Module 5 x 8 Common Anode Row, Common Cathode ... Далее TBC24-22EGWADot Matrix Display Module 5 x 8 Common Anode Row, Common Cathode Column Green, Red 2.2V Green, 2V Red 1.50 L x 2.39 W x 0.35 H (38.10mm x 60 ... | запрос 7 дней склад 39132 шт |
Dot Matrix Display Module 5 x 8 Common Anode Row, Common Cathode ... Далее LTP-2158AEDot Matrix Display Module 5 x 8 Common Anode Row, Common Cathode Column Orange-Red 2V 1.49 L x 2.39 W x 0.35 H (37.90mm x 60.80mm x 8.90mm) | запрос 7 дней склад 49321 шт |
Dot Matrix Display Module 5 x 8 Common Cathode Row, Common Anode ... Далее LTP-2458AADot Matrix Display Module 5 x 8 Common Cathode Row, Common Anode Column Green, Orange-Red 2.1V Green, 2V Orange-Red 1.49 L x 2.39 W x 0.35 H ... | запрос 7 дней склад 19069 шт |
Dot Matrix Display Module 5 x 8 Common Anode Row, Common Cathode ... Далее LTP-2558AADot Matrix Display Module 5 x 8 Common Anode Row, Common Cathode Column Green, Orange-Red 2.1V Green, 2V Orange-Red 1.49 L x 2.39 W x 0.35 H ... | запрос 7 дней склад 45997 шт |
2 FAV Technology Китай Весь мир | |
запрос Оплата в рублях, USD и юанях In Stock | |
3 EIS Components Китай Весь мир | |
new in stock for immediate delivery | 535 ₽ От 1 шт Оплата рубли, юани,... Далее От 1 шт Оплата рубли, юани, USD. 5-7 дней склад 15610 шт |
new in stock for immediate delivery | 506 ₽ От 1 шт Оплата рубли, юани,... Далее От 1 шт Оплата рубли, юани, USD. 5-7 дней склад 17410 шт |
new in stock for immediate delivery | 446 ₽ От 1 шт Оплата рубли, юани,... Далее От 1 шт Оплата рубли, юани, USD. 5-7 дней склад 15010 шт |
4 Akcel Китай Весь мир | |
Replacement for Tennant 6080 St | запрос от 1 шт |
Test Plugs & Test Jacks RED BANANA PLUG | запрос от 1 шт |
BANANA PLUG, SOLDER, RED, Gender:Plug, Connector Mounting:Cable Mount, ... Далее 6080BANANA PLUG, SOLDER, RED, Gender:Plug, Connector Mounting:Cable Mount, Current Rating:-, Voltage Rating:-, Contact Plating:Nickel Plated ... | запрос от 1 шт |
Еще 25 строк | |
PWR ENT MOD RCPT IEC320-C14 PNL | запрос от 1 шт |
Board Connector | запрос от 1 шт |
RF Connectors / Coaxial Connectors | запрос от 1 шт |
KK 156 HEADER ASSY FRLK BREAK | запрос от 1 шт |
MEMS OSC XO 40.6080MHZ CMOS SMD | запрос от 1 шт |
Board Connector, 8 Contact(s), 1 Row(s), Male, Right Angle, 0.1 inch ... Далее 22-28-6080Board Connector, 8 Contact(s), 1 Row(s), Male, Right Angle, 0.1 inch Pitch, Solder Terminal, Locking, Black Insulator, Receptacle, | 250 ₽ от 1 шт 5-7 дней склад 10152 шт |
Еще 3 цен: … 210 ₽ | |
235 ₽ от 10 шт 5-7 дней склад 10152 шт | |
222 ₽ от 100 шт 5-7 дней склад 10152 шт | |
210 ₽ от 1000 шт 5-7 дней склад 10152 шт | |
CONN PLUG 5POS IDC 18AWG GOLD | запрос от 1 шт |
запрос от 1 шт 5-7 дней | |
Photoelectric Proximity Switches, Size 65x83, Through-beam sensor - ... Далее LLT-6080-002 (R)Photoelectric Proximity Switches, Size 65x83, Through-beam sensor - operating distance 50000 mm, Screw Terminal version | запрос от 1 шт |
PIM 60-80KW Q0BOOST-L57 1200V, 1 | 7 882 ₽ от 1 шт 5-7 дней склад 24 шт |
Еще 3 цен: … 6 618 ₽ | |
7 436 ₽ от 10 шт 5-7 дней склад 24 шт | |
7 015 ₽ от 100 шт 5-7 дней склад 24 шт | |
6 618 ₽ от 1000 шт 5-7 дней склад 24 шт | |
Schneider Electric MGE GALAXY 5000 IN/OUT XFMR CAB 60-80 KV | запрос от 1 шт |
Schneider Electric MGE GALAXY 5000 XFMR CABINET 60-80 KVA | запрос от 1 шт |
Schneider Electric MGE GALAXY 5000 IN/BYP XFMR CAB 60-80KVA | запрос от 1 шт |
Hard Metric Connectors PREALIGN CMP PIN-PWR 6.0-8.0mm base reqd | запрос от 1 шт |
Full-range Speaker White 4Ohm 60/80W 60-15000Hz D180x50 IP65 FR 16 WP/ ... Далее FR 16 WP/4 WHFull-range Speaker White 4Ohm 60/80W 60-15000Hz D180x50 IP65 FR 16 WP/4 WH | запрос от 1 шт |
Sanding Discs 3 Inch 34 PieceKit 60/80/120 Grit For RS Pro# 1370898 / ... Далее 1370959Sanding Discs 3 Inch 34 PieceKit 60/80/120 Grit For RS Pro# 1370898 / RS PRO 1370959 | запрос от 1 шт |
Combination Starter, A63, Non-Reversing Three Phase Motor Circuit ... Далее 81M1-BFZ6JCombination Starter, A63, Non-Reversing Three Phase Motor Circuit Protection, Enclosure NEMA/UL Type 1, Voltage 240V, Overload Relay Setting ... | запрос от 1 шт |
5 ChipWorker Китай Весь мир | |
26.3 ₽ 2-7 дней отгрузка со склада в Китае склад 258 шт | |
203 ₽ 2-7 дней отгрузка со склада в Китае склад 774 шт | |
12 671 ₽ 2-7 дней отгрузка со склада в Китае склад 290 шт | |
Еще 19 строк | |
667 ₽ 2-7 дней отгрузка со склада в Китае склад 10 шт | |
106 ₽ 2-7 дней отгрузка со склада в Китае склад 280 шт | |
109 ₽ 2-7 дней отгрузка со склада в Китае склад 208 шт | |
525 ₽ 2-7 дней отгрузка со склада в Китае склад 103 шт | |
479 ₽ 2-7 дней отгрузка со склада в Китае склад 12 шт | |
475 ₽ 2-7 дней отгрузка со склада в Китае склад 81 шт | |
373 ₽ 2-7 дней отгрузка со склада в Китае склад 287 шт | |
850 ₽ 2-7 дней отгрузка со склада в Китае склад 64 шт | |
631 ₽ 2-7 дней отгрузка со склада в Китае склад 83 шт | |
300 ₽ 2-7 дней отгрузка со склада в Китае склад 260 шт | |
31 396 ₽ 2-7 дней отгрузка со склада в Китае склад 235 шт | |
5 545 ₽ 2-7 дней отгрузка со склада в Китае склад 273 шт | |
908 ₽ 2-7 дней отгрузка со склада в Китае склад 1000 шт | |
1 244 ₽ 2-7 дней отгрузка со склада в Китае склад 237 шт | |
1 000 ₽ 2-7 дней отгрузка со склада в Китае склад 238 шт | |
425 ₽ 2-7 дней отгрузка со склада в Китае склад 176 шт | |
860 ₽ 2-7 дней отгрузка со склада в Китае склад 80 шт | |
6 AiPCBA Китай Весь мир | |
102 ₽ 2-7 дней отгрузка со склада в Китае склад 1435 шт | |
259 ₽ 2-7 дней отгрузка со склада в Китае склад 776 шт | |
294 ₽ 2-7 дней отгрузка со склада в Китае склад 249 шт | |
Еще 21 строка | |
6 341 ₽ 2-7 дней отгрузка со склада в Китае склад 100 шт | |
5 782 ₽ 2-7 дней отгрузка со склада в Китае склад 98 шт | |
108 ₽ 2-7 дней отгрузка со склада в Китае склад 208 шт | |
43.6 ₽ 2-7 дней отгрузка со склада в Китае склад 289 шт | |
40.9 ₽ 2-7 дней отгрузка со склада в Китае склад 1070 шт | |
521 ₽ 2-7 дней отгрузка со склада в Китае склад 103 шт | |
628 ₽ 2-7 дней отгрузка со склада в Китае склад 83 шт | |
656 ₽ 2-7 дней отгрузка со склада в Китае склад 10 шт | |
540 ₽ 2-7 дней отгрузка со склада в Китае склад 293 шт | |
456 ₽ 2-7 дней отгрузка со склада в Китае склад 235 шт | |
118 ₽ 2-7 дней отгрузка со склада в Китае склад 204 шт | |
424 ₽ 2-7 дней отгрузка со склада в Китае склад 176 шт | |
184 ₽ 2-7 дней отгрузка со склада в Китае склад 8 шт | |
1 867 ₽ 2-7 дней отгрузка со склада в Китае склад 272 шт | |
7 Utmel Китай Весь мир | |
Test Plugs & Test Jacks RED BANANA PLUG | 586 ₽ от 1 шт 5-7 дней склад 363 шт |
Еще 3 цен: … 492 ₽ | |
552 ₽ от 10 шт 5-7 дней склад 363 шт | |
521 ₽ от 100 шт 5-7 дней склад 363 шт | |
492 ₽ от 1000 шт 5-7 дней склад 363 шт | |
AUDIO PIEZO TRANSDUCER 50V CHAS | 156 ₽ от 1 шт 5-7 дней склад 441 шт |
Еще 3 цен: … 131 ₽ | |
147 ₽ от 10 шт 5-7 дней склад 441 шт | |
139 ₽ от 100 шт 5-7 дней склад 441 шт | |
131 ₽ от 1000 шт 5-7 дней склад 441 шт | |
CONN SOCKET 5POS IDC 18AWG GOLD | 769 ₽ от 1 шт 5-7 дней склад 98 шт |
Еще 3 цен: … 646 ₽ | |
726 ₽ от 10 шт 5-7 дней склад 98 шт | |
685 ₽ от 100 шт 5-7 дней склад 98 шт | |
646 ₽ от 1000 шт 5-7 дней склад 98 шт | |
Еще 19 строк | |
CONN PLUG 5POS IDC 18AWG GOLD | 654 ₽ от 1 шт 5-7 дней склад 91 шт |
Еще 3 цен: … 549 ₽ | |
617 ₽ от 10 шт 5-7 дней склад 91 шт | |
582 ₽ от 100 шт 5-7 дней склад 91 шт | |
549 ₽ от 1000 шт 5-7 дней склад 91 шт | |
CONN PLUG 5POS IDC 18AWG GOLD | 654 ₽ от 1 шт 5-7 дней склад 11 шт |
617 ₽ от 10 шт 5-7 дней склад 11 шт | |
582 ₽ от 100 шт 5-7 дней склад 11 шт | |
549 ₽ от 1000 шт 5-7 дней склад 11 шт | |
Board Connector, 8 Contact(s), 2 Row(s), Male, Straight, Surface Mount ... Далее 15-91-6080Board Connector, 8 Contact(s), 2 Row(s), Male, Straight, Surface Mount Terminal, | запрос от 1 шт 5-7 дней склад 4721 шт |
Board Connector, 8 Contact(s), 1 Row(s), Male, Right Angle, 0.1 inch ... Далее 22-28-6080Board Connector, 8 Contact(s), 1 Row(s), Male, Right Angle, 0.1 inch Pitch, Solder Terminal, Locking, Black Insulator, Receptacle, | 253 ₽ от 1 шт 5-7 дней склад 8764 шт |
Еще 3 цен: … 213 ₽ | |
239 ₽ от 10 шт 5-7 дней склад 8764 шт | |
226 ₽ от 100 шт 5-7 дней склад 8764 шт | |
213 ₽ от 1000 шт 5-7 дней склад 8764 шт | |
MEMS OSC XO 40.6080MHZ CMOS SMD | запрос от 1 шт 5-7 дней склад 4438 шт |
Schottky Diodes & Rectifiers 80V - 60A Schottky Rectifier | запрос от 1 шт 5-7 дней склад 9904 шт |
TRANS 3NPN/3PNP DARL 60V 12SIP | 671 ₽ от 1 шт 5-7 дней склад 142 шт |
Еще 3 цен: … 563 ₽ | |
633 ₽ от 10 шт 5-7 дней склад 142 шт | |
597 ₽ от 100 шт 5-7 дней склад 142 шт | |
563 ₽ от 1000 шт 5-7 дней склад 142 шт | |
Rectifier Diode, Schottky, 1 Phase, 1 Element, 10A, 60V V(RRM), ... Далее NTE6080Rectifier Diode, Schottky, 1 Phase, 1 Element, 10A, 60V V(RRM), Silicon, | 176 ₽ от 1 шт 5-7 дней склад 2313 шт |
Еще 3 цен: … 148 ₽ | |
166 ₽ от 10 шт 5-7 дней склад 2313 шт | |
157 ₽ от 100 шт 5-7 дней склад 2313 шт | |
148 ₽ от 1000 шт 5-7 дней склад 2313 шт | |
AC Power Cords 6080 Connector Inlet 10A C14, with ... Далее 3-137-753AC Power Cords 6080 Connector Inlet 10A C14, with sealing IP20, PC I, white | 339 ₽ от 1 шт 5-7 дней склад 17 шт |
Еще 3 цен: … 284 ₽ | |
319 ₽ от 10 шт 5-7 дней склад 17 шт | |
301 ₽ от 100 шт 5-7 дней склад 17 шт | |
284 ₽ от 1000 шт 5-7 дней склад 17 шт | |
AC Power Cords 6080 Connector Inlet 10A C18, with ... Далее 3-137-754AC Power Cords 6080 Connector Inlet 10A C18, with sealing IP20, PC II, white | 251 ₽ от 1 шт 5-7 дней склад 13 шт |
Еще 3 цен: … 211 ₽ | |
237 ₽ от 10 шт 5-7 дней склад 13 шт | |
223 ₽ от 100 шт 5-7 дней склад 13 шт | |
211 ₽ от 1000 шт 5-7 дней склад 13 шт | |
AC Power Cords 6080 Connector Inlet 10A C18, with ... Далее 3-134-881AC Power Cords 6080 Connector Inlet 10A C18, with sealing IP54/IP67, PC II, black | 921 ₽ от 1 шт 5-7 дней склад 16 шт |
Еще 3 цен: … 774 ₽ | |
869 ₽ от 10 шт 5-7 дней склад 16 шт | |
820 ₽ от 100 шт 5-7 дней склад 16 шт | |
774 ₽ от 1000 шт 5-7 дней склад 16 шт | |
AC Power Cords 6080 Connector Inlet 10A C18, with ... Далее 3-134-903AC Power Cords 6080 Connector Inlet 10A C18, with sealing IP54/IP67, PC II, white | 1 100 ₽ от 1 шт 5-7 дней склад 20 шт |
Еще 3 цен: … 924 ₽ | |
1 038 ₽ от 10 шт 5-7 дней склад 20 шт | |
979 ₽ от 100 шт 5-7 дней склад 20 шт | |
924 ₽ от 1000 шт 5-7 дней склад 20 шт | |
AC Power Cords 6080 Connector Inlet 10A C14, with ... Далее 3-134-902AC Power Cords 6080 Connector Inlet 10A C14, with sealing IP54/IP67, PC I, white | 1 109 ₽ от 1 шт 5-7 дней склад 10 шт |
Еще 3 цен: … 931 ₽ | |
1 046 ₽ от 10 шт 5-7 дней склад 10 шт | |
987 ₽ от 100 шт 5-7 дней склад 10 шт | |
931 ₽ от 1000 шт 5-7 дней склад 10 шт | |
AC Power Cords 6080 Connector Inlet 10A C14, with ... Далее 3-134-880AC Power Cords 6080 Connector Inlet 10A C14, with sealing IP54/IP67, PC I, black | запрос от 1 шт 5-7 дней склад 2140 шт |
BOARD EVAL FOR GS6080 | запрос от 1 шт 5-7 дней склад 1741 шт |
PIM 60-80KW Q0BOOST-L57 1200V, 1 | 8 007 ₽ от 1 шт 5-7 дней склад 20 шт |
Еще 3 цен: … 6 723 ₽ | |
7 553 ₽ от 10 шт 5-7 дней склад 20 шт | |
7 126 ₽ от 100 шт 5-7 дней склад 20 шт | |
6 723 ₽ от 1000 шт 5-7 дней склад 20 шт | |
PIM 60-80KW Q0BOOST-L57 1200V, 1 | 8 007 ₽ от 1 шт 5-7 дней склад 24 шт |
7 553 ₽ от 10 шт 5-7 дней склад 24 шт | |
7 126 ₽ от 100 шт 5-7 дней склад 24 шт | |
6 723 ₽ от 1000 шт 5-7 дней склад 24 шт | |
8 Онлайн Компоненты Москва Россия | |
Автомобильный разъем, Mini50 34912 Series, Угловой Штекер, 8 контакт(- ... Далее 34912-6080Автомобильный разъем, Mini50 34912 Series, Угловой Штекер, 8 контакт(-ов) | 706 ₽ от 1 шт 5-12 дней склад 5 шт |
Еще 4 цен: … 424 ₽ | |
617 ₽ от 6 шт 5-12 дней склад 5 шт | |
513 ₽ от 18 шт 5-12 дней склад 5 шт | |
458 ₽ от 50 шт 5-12 дней склад 5 шт | |
424 ₽ от 125 шт 5-12 дней склад 5 шт | |
Rivet, Snap, Black, Nylon, 6.2 mm Hole Dia, 3.5 mm - 5.5 mm Grip, 12 ... Далее SR 6080BRivet, Snap, Black, Nylon, 6.2 mm Hole Dia, 3.5 mm - 5.5 mm Grip, 12 mm Dia, 3 mm Depth | 3 241 ₽ от 1 шт 5-12 дней склад 4 шт |
Еще 2 цен: … 2 096 ₽ | |
2 139 ₽ от 25 шт 5-12 дней склад 4 шт | |
2 096 ₽ от 50 шт 5-12 дней склад 4 шт | |
Rivet, Snap, White, Nylon, 6.2 mm Hole Dia, 3.5 mm - 5.5 mm Grip, 12 ... Далее SR 6080WRivet, Snap, White, Nylon, 6.2 mm Hole Dia, 3.5 mm - 5.5 mm Grip, 12 mm Dia, 3 mm Depth | 3 419 ₽ от 1 шт 5-12 дней склад 2 шт |
Еще 2 цен: … 2 212 ₽ | |
2 257 ₽ от 25 шт 5-12 дней склад 2 шт | |
2 212 ₽ от 50 шт 5-12 дней склад 2 шт | |
9 Acme Chip Китай Весь мир | |
запрос 7 дней склад 37 шт | |
standard | запрос 7 дней склад 7329 шт |
TO220 | запрос 7 дней склад 3719 шт |
Еще 9 строк | |
SOPDIP | запрос 7 дней склад 4288 шт |
Schottky Diodes & Rectifiers 80V - 60A Schottky Rectifier | запрос 7 дней склад 4521 шт |
запрос 7 дней склад 7406 шт | |
SOP-8 | запрос 7 дней склад 5620 шт |
MODULE | запрос 7 дней склад 7265 шт |
SIP | запрос 7 дней склад 4640 шт |
ZIP18 | запрос 7 дней склад 6213 шт |
запрос 7 дней склад 680 шт | |
SSOP-24 | запрос 7 дней склад 115 шт |
10 ТМ Электроникс Санкт-Петербург Россия | |
Блок питания: лабораторный; одноканальный,регулируемый; 0÷15ВDC | 19 611 ₽ от 1 шт 5-10 дней склад 11 шт |
18 303 ₽ от 3 шт 5-10 дней склад 11 шт | |
Монтажная панель; сталь | 26 456 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 2 цен: … 22 199 ₽ | |
24 469 ₽ от 5 шт 5-10 дней склад 1 шт | |
22 199 ₽ от 10 шт 5-10 дней склад 1 шт | |
Клавиша; круглая; Ø21мм; черный; 09 | 1 874 ₽ от 1 шт 5-10 дней склад 10 шт |
Еще 2 цен: … 1 499 ₽ | |
1 689 ₽ от 10 шт 5-10 дней склад 10 шт | |
1 499 ₽ от 50 шт 5-10 дней склад 10 шт | |
Еще 17 строк | |
Диод: выпрямительный Шоттки; THT; 60В; 10А; TO220; Ufmax: 800мВ | 507 ₽ от 1 шт 5-10 дней склад 2313 шт |
Еще 4 цен: … 421 ₽ | |
483 ₽ от 10 шт 5-10 дней склад 2313 шт | |
456 ₽ от 20 шт 5-10 дней склад 2313 шт | |
432 ₽ от 50 шт 5-10 дней склад 2313 шт | |
421 ₽ от 100 шт 5-10 дней склад 2313 шт | |
Корпус: настенный; Х: 800мм; Y: 600мм; Z: 300мм; SOLID GSX; сталь | 69 245 ₽ от 1 шт 5-10 дней склад 3 шт |
Еще 2 цен: … 60 011 ₽ | |
64 628 ₽ от 3 шт 5-10 дней склад 3 шт | |
60 011 ₽ от 5 шт 5-10 дней склад 3 шт | |
Симистор; 1,2кВ; 30А; TO247-3; Igt: 60/80мА; Ifsm: 325А | 1 845 ₽ от 1 шт 5-10 дней склад 270 шт |
Еще 3 цен: … 1 367 ₽ | |
1 633 ₽ от 3 шт 5-10 дней склад 270 шт | |
1 467 ₽ от 10 шт 5-10 дней склад 270 шт | |
1 367 ₽ от 30 шт 5-10 дней склад 270 шт | |
Симистор; 1,2кВ; 30А; D3PAK; Igt: 60/80мА; Ifsm: 325А | 2 113 ₽ от 1 шт 5-10 дней склад 32 шт |
Еще 3 цен: … 1 563 ₽ | |
1 866 ₽ от 3 шт 5-10 дней склад 32 шт | |
1 678 ₽ от 10 шт 5-10 дней склад 32 шт | |
1 563 ₽ от 30 шт 5-10 дней склад 32 шт | |
Симистор; 1,2кВ; 30А; ISO247TM; Igt: ... Далее CLA60MT1200NHRСимистор; 1,2кВ; 30А; ISO247TM; Igt: 60/80мА; Ifsm: 325А | 1 933 ₽ от 1 шт 5-10 дней склад 27 шт |
Еще 3 цен: … 1 432 ₽ | |
1 708 ₽ от 3 шт 5-10 дней склад 27 шт | |
1 534 ₽ от 10 шт 5-10 дней склад 27 шт | |
1 432 ₽ от 30 шт 5-10 дней склад 27 шт | |
LED; красный; 120°; 700мА; λd: 620÷630нм; 60÷80лм; 3,5x3,5x2мм; ... Далее OSR53535C1H-700MALED; красный; 120°; 700мА; λd: 620÷630нм; 60÷80лм; 3,5x3,5x2мм; SMD | 214 ₽ от 1 шт 5-10 дней склад 1796 шт |
Еще 4 цен: … 85.8 ₽ | |
142 ₽ от 10 шт 5-10 дней склад 1796 шт | |
107 ₽ от 100 шт 5-10 дней склад 1796 шт | |
96.5 ₽ от 500 шт 5-10 дней склад 1796 шт | |
85.8 ₽ от 2000 шт 5-10 дней склад 1796 шт | |
Блок питания: импульсный; 12Вт; 24ВDC; 500мА; 43÷52ВAC; 60÷80ВDC | 19 751 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 3 цен: … 15 999 ₽ | |
18 172 ₽ от 10 шт 5-10 дней склад 1 шт | |
16 789 ₽ от 50 шт 5-10 дней склад 1 шт | |
15 999 ₽ от 100 шт 5-10 дней склад 1 шт | |
Хомуты для труб; W: 9мм; Захват: 60÷80мм; D; W2; DIN: 3017 | 231 ₽ от 1 шт 5-10 дней склад 247 шт |
Еще 3 цен: … 80.4 ₽ | |
104 ₽ от 50 шт 5-10 дней склад 247 шт | |
95.2 ₽ от 250 шт 5-10 дней склад 247 шт | |
80.4 ₽ от 1000 шт 5-10 дней склад 247 шт | |
Хомуты для труб; W: 12мм; Захват: 60÷80мм; DD; W2; DIN: 3017 | 325 ₽ от 1 шт 5-10 дней склад 180 шт |
Еще 3 цен: … 113 ₽ | |
146 ₽ от 50 шт 5-10 дней склад 180 шт | |
134 ₽ от 250 шт 5-10 дней склад 180 шт | |
113 ₽ от 1000 шт 5-10 дней склад 180 шт | |
Хомуты для труб; W: 9мм; Захват: 60÷80мм; D; W4; DIN: 3017 | 360 ₽ от 1 шт 5-10 дней склад 150 шт |
Еще 3 цен: … 126 ₽ | |
162 ₽ от 10 шт 5-10 дней склад 150 шт | |
148 ₽ от 50 шт 5-10 дней склад 150 шт | |
126 ₽ от 250 шт 5-10 дней склад 150 шт | |
Filament: PET-G; 1.75mm; black; 220÷250°C; 3kg; Table temp: 60÷80& ... Далее 5907753130020Filament: PET-G; 1.75mm; black; 220÷250°C; 3kg; Table temp: 60÷80°C | 17 105 ₽ от 1 шт 5-10 дней склад 6 шт |
Еще 2 цен: … 13 303 ₽ | |
15 204 ₽ от 5 шт 5-10 дней склад 6 шт | |
13 303 ₽ от 25 шт 5-10 дней склад 6 шт | |
Filament: PET-G; 1.75mm; white; 220÷250°C; 1kg; Table temp: 60÷80& ... Далее 5907753131997Filament: PET-G; 1.75mm; white; 220÷250°C; 1kg; Table temp: 60÷80°C | 6 174 ₽ от 1 шт 5-10 дней склад 40 шт |
Еще 2 цен: … 4 802 ₽ | |
5 488 ₽ от 6 шт 5-10 дней склад 40 шт | |
4 802 ₽ от 30 шт 5-10 дней склад 40 шт | |
Filament: PET-G; 1.75mm; black; 220÷250°C; 1kg; Table temp: 60÷80& ... Далее 5907753131980Filament: PET-G; 1.75mm; black; 220÷250°C; 1kg; Table temp: 60÷80°C | 6 174 ₽ от 1 шт 5-10 дней склад 93 шт |
5 488 ₽ от 6 шт 5-10 дней склад 93 шт | |
4 802 ₽ от 30 шт 5-10 дней склад 93 шт | |
Filament: PET-G; 1.75mm; grey; 220÷250°C; 1kg; Table temp: 60÷80& ... Далее 5907753134325Filament: PET-G; 1.75mm; grey; 220÷250°C; 1kg; Table temp: 60÷80°C | 6 174 ₽ от 1 шт 5-10 дней склад 55 шт |
5 488 ₽ от 6 шт 5-10 дней склад 55 шт | |
4 802 ₽ от 30 шт 5-10 дней склад 55 шт | |
Filament: PCTG; 1.75mm; black; 240÷270°C; 1kg; Table temp: 60÷80& ... Далее 5907753133892Filament: PCTG; 1.75mm; black; 240÷270°C; 1kg; Table temp: 60÷80°C | 6 799 ₽ от 1 шт 5-10 дней склад 9 шт |
Еще 2 цен: … 5 290 ₽ | |
6 043 ₽ от 7 шт 5-10 дней склад 9 шт | |
5 290 ₽ от 35 шт 5-10 дней склад 9 шт | |
Filament: PCTG; 1.75mm; grey; 240÷270°C; 1kg; Table temp: 60÷80& ... Далее 5907753134806Filament: PCTG; 1.75mm; grey; 240÷270°C; 1kg; Table temp: 60÷80°C | 6 799 ₽ от 1 шт 5-10 дней склад 3 шт |
6 043 ₽ от 7 шт 5-10 дней склад 3 шт | |
5 290 ₽ от 35 шт 5-10 дней склад 3 шт | |
Кабельная стяжка; Ø: 60÷80мм; W: 9мм | 389 ₽ от 1 шт 5-10 дней склад 10 шт |
Еще 2 цен: … 340 ₽ | |
365 ₽ от 5 шт 5-10 дней склад 10 шт | |
340 ₽ от 10 шт 5-10 дней склад 10 шт | |
11 ЧипСити Москва Россия | |
MOLEX 34691-6080 Rectangular Power Connector, Stac64 34691 ... Далее 34691-6080MOLEX 34691-6080 Rectangular Power Connector, Stac64 34691 Series, Through Hole, Header, 8Contacts, 2.54mm, Pin | 113 ₽ 3-7 дней склад 5929 шт |
Board Connector | 246 ₽ 3-7 дней склад 3306 шт |
Earth Fault Ct 3.1 Id (80mm) | 11 884 ₽ 3-7 дней склад 1250 шт |
Еще 19 строк | |
CONN HEADER 8POS 2.5MM VERT TIN | 41.0 ₽ 3-7 дней склад 1246 шт |
Conn Unshrouded Header HDR 8POS 2.54mm Solder RA Thru-Hole KK® Bag | 66.4 ₽ 3-7 дней склад 4998 шт |
Conn IDC Connector SKT 5POS 3mm IDT ST Cable Mount | 405 ₽ 3-7 дней склад 988 шт |
MOUNT.PLATEXSEPAR.CELL 600X800MM(HXW) | 29 484 ₽ 3-7 дней склад 1018 шт |
SLIDING FLOOR CLOSING PLATE 600X800MM | 5 208 ₽ 3-7 дней склад 1178 шт |
Diode Schottky 60V 10A 2Pin(2+Tab) TO-220 | 173 ₽ 3-7 дней склад 164 шт |
SP-NO Reed Switch, 5A 250V AC-DC | 3 204 ₽ 3-7 дней склад 903 шт |
SP-NO Reed Switch, 1.3A 250V AC-DC | 1 053 ₽ 3-7 дней склад 201 шт |
Switch Reed N.O./N.C. 0.5A 350VAC 500VDC 30VA 4.5ms 125mOhm Automotive | 854 ₽ 3-7 дней склад 4253 шт |
Switch Reed N.O./N.C. 1.5A 350VAC 500VDC 50VA 5.5ms 500mOhm Automotive | 1 168 ₽ 3-7 дней склад 1026 шт |
SWITCH REED SPDT | 938 ₽ 3-7 дней склад 1030 шт |
Accessory; Hand Polishing Film; 60-80; 8.5in. x 11in.; Green ( ... Далее 228433-7Accessory; Hand Polishing Film; 60-80; 8.5in. x 11in.; Green (Polishing Film) | 193 ₽ 3-7 дней склад 666 шт |
Accessory; Hand Polishing Film; 60-80; 8.5in. x 11in.; Aluminum Oxide | 138 ₽ 3-7 дней склад 389 шт |
Accessory; Hand Polishing Film; 60-80; 8.5in. x 11in.; White ( ... Далее 228433-5Accessory; Hand Polishing Film; 60-80; 8.5in. x 11in.; White (Polishing Film) | 220 ₽ 3-7 дней склад 404 шт |
GS6080 Evaluation Board | 28 676 ₽ 3-7 дней склад 1280 шт |
Thermal Overload Relay; Type TA; Class 10; 60-80A; for Contactor A110 | 13 470 ₽ 3-7 дней склад 963 шт |
Thermal Overload Relay; Type TA; Class 10; 60-80A; for Contactor A50- ... Далее TA75DU80Thermal Overload Relay; Type TA; Class 10; 60-80A; for Contactor A50-A75 | 8 379 ₽ 3-7 дней склад 497 шт |
12 Industrial Module Москва Россия | |
... INTERNAL SOLID STATE DRIVE ( 342-6080) WITH TRAY FOR DELL POWEREDGE ... Далее 342-6080342-6080 - DELL - 800GB SATA READ INTENSIVE MLC 3GBPS FORM FACTOR INTERNAL SOLID STATE DRIVE ( 342-6080) WITH TRAY FOR DELL POWEREDGE SERVER ... | запрос 7-28 дней на складе |
... INTERNAL SOLID STATE DRIVE ( 342-6080) WITH TRAY FOR DELL POWEREDGE ... Далее 342-6080342-6080 - DELL - 800GB SATA READ INTENSIVE MLC 3GBPS FORM FACTOR INTERNAL SOLID STATE DRIVE ( 342-6080) WITH TRAY FOR DELL POWEREDGE SERVER ... | 93.3 ₽ 7-28 дней на складе |
342-6080 Dell 800-GB 3G 2.5 SATA SSD w/G176J | запрос 7-28 дней на складе |
Еще 24 строки | |
Входной модуль счетчиков и частоты | 27 136 ₽ 7-28 дней на складе |
342-6080 Dell 800-GB 3G 2.5 SATA SSD w/G176J [ 5 Pack ] | запрос 7-28 дней на складе |
342-6080 Dell 800-GB 3G 2.5 SATA SSD w/G176J [ 2 Pack ] | запрос 7-28 дней на складе |
342-6080 Dell 800-GB 3G 2.5 SATA SSD w/G176J [ 10 Pack ] | запрос 7-28 дней на складе |
Модуль Cisco CCX-UPG-AQM-60-80 | запрос 7-28 дней на складе |
Модуль Cisco CCX-UPG-QM-60-80 | запрос 7-28 дней на складе |
Модуль Cisco CCX-UPG-P-60-80 | запрос 7-28 дней на складе |
Модуль Cisco CCX-UPG-E-60-80 | запрос 7-28 дней на складе |
Модуль Cisco CCX-UPG-EHA-60-80 | запрос 7-28 дней на складе |
Модуль Cisco CCX-UPG-S-60-80 | запрос 7-28 дней на складе |
Модуль Cisco CCX-UPG-PHA-60-80 | запрос 7-28 дней на складе |
Модуль Cisco CCX-UPG-WFM-60-80 | запрос 7-28 дней на складе |
Модуль памяти EtherCAT 128 кБайт - EL6080 Beckhoff | запрос 7-28 дней на складе |
Модуль Beckhoff | запрос 7-28 дней на складе |
УКОРОЧЕННАЯ МОНТАЖНАЯ ПЛАТА 597x705 | запрос 7-28 дней на складе |
ПЕРФ. МОНТАЖНАЯ ПЛАТА 600х800 | запрос 7-28 дней на складе |
Реле перегрузки тепловое TA75DU-80M диапазон уставки 60...80А для ... Далее 1SAZ321201R2006Реле перегрузки тепловое TA75DU-80M диапазон уставки 60...80А для контакторов AX50…AX80|1SAZ321201R2006| ABB 1SAZ321201R2006 | запрос 7-28 дней на складе |
13 Оптулс Москва Россия | |
330.6080 KS TOOLS Сверло укороченное, цилиндрический ... Далее 330.6080 KS TOOLS330.6080 KS TOOLS Сверло укороченное, цилиндрический хвостовик, кобальт, 10 шт. в ... | 7 860 ₽ Розница, Скидки для Дилеров - |
143192 Захват для стекловолоконных прутков 60-80 мм Haupa | 13 960 ₽ Розница, Скидки для Дилеров - |
Губка для шлифования, 100 х 70 х 25 мм, мягкая, 3 шт., P 60/80, P 60/100, P 80/120 MATRIX 75705 Matrix 28 Фев 2024 17:35 Губка для шлифования, 100 х 70 х 25 мм, мягкая, 3 шт., P 60/80, P 60/ ... Далее Губка для шлифования, 100 х 70 х 25 мм, мягкая, 3 шт., P 60/80, P 60/100, P 80/120 MATRIX 75705Губка для шлифования, 100 х 70 х 25 мм, мягкая, 3 шт., P 60/80, P 60/100, P 80/120 MATRIX | 247 ₽ Розница, Скидки для Дилеров - |
Еще 28 строк | |
Губка для шлифования, 100 х 70 х 25 мм, средняя жестк., 3 шт., P 60/80, P 60/100, P 80/120 MATRIX 75710 Matrix 28 Фев 2024 17:35 Губка для шлифования, 100 х 70 х 25 мм, средняя жестк., 3 шт., P 60/80 ... Далее Губка для шлифования, 100 х 70 х 25 мм, средняя жестк., 3 шт., P 60/80, P 60/100, P 80/120 MATRIX 75710Губка для шлифования, 100 х 70 х 25 мм, средняя жестк., 3 шт., P 60/80, P 60/100, P 80/120 MATRIX | 231 ₽ Розница, Скидки для Дилеров - |
Губка для шлифования, 125 х 100 х 10 мм, мягкая, 3 шт., P 60/80, P 60/100, P 80/120 MATRIX 75715 Matrix 28 Фев 2024 17:35 Губка для шлифования, 125 х 100 х 10 мм, мягкая, 3 шт., P 60/80, P 60/ ... Далее Губка для шлифования, 125 х 100 х 10 мм, мягкая, 3 шт., P 60/80, P 60/100, P 80/120 MATRIX 75715Губка для шлифования, 125 х 100 х 10 мм, мягкая, 3 шт., P 60/80, P 60/100, P 80/120 MATRIX | 192 ₽ Розница, Скидки для Дилеров - |
Хомуты нержав. сталь, стандартное болтовое крепление 60-80мм, 50шт/уп, ширина 9мм СИБРТЕХ 47585 СИБРТЕХ - 28 Фев 2024 17:35 Хомуты нержав. сталь, стандартное болтовое крепление 60-80мм, 50шт/уп, ... Далее Хомуты нержав. сталь, стандартное болтовое крепление 60-80мм, 50шт/уп, ширина 9мм СИБРТЕХ 47585Хомуты нержав. сталь, стандартное болтовое крепление 60-80мм, 50шт/уп,ширина 9мм СИБРТЕХ | 938 ₽ Розница, Скидки для Дилеров - |
Набор шпателей 40-60-80 мм, белая резина, 3 шт. СИБРТЕХ/ Россия | 38.8 ₽ Розница, Скидки для Дилеров - |
Набор шпателей 40-60-80 мм, белая резина, 3 шт. Россия | 44.5 ₽ Розница, Скидки для Дилеров - |
Набор шпателей 40-60-80 мм, черная резина, 3 шт. Россия | 45.4 ₽ Розница, Скидки для Дилеров - |
Набор шпателей 40-60-80 мм, ПВХ, 3 шт. СИБРТЕХ/ Россия | 38.9 ₽ Розница, Скидки для Дилеров - |
L-образный прямой реактивный рычаг для модели DVV60-80, 1.1/2" GEDORE RL-DVV60-80 2654091 GEDORE - 28 Фев 2024 17:35 L-образный прямой реактивный рычаг для модели DVV60-80, 1.1/2" | 478 651 ₽ Розница, Скидки для Дилеров - |
Панель монтажная 550х754х2мм оцинк. сталь ENSTO NMP6080 | 3 287 ₽ Розница, Скидки для Дилеров - |
Хомут червячный PL-9 (60-80 )/W1 (Fortisflex) | 13.1 ₽ Розница, Скидки для Дилеров - |
Вакуумный пакет для упаковки и хранения вещей 60*80 см ELFE | 91.4 ₽ Розница, Скидки для Дилеров - |
AI050076 Фильтросъемник 60-80мм | 4 888 ₽ Розница, Скидки для Дилеров - |
1253350510 KEIL Набор SDS-plus TURBOKEIL 5.0-6.0x110, 6.0-8.0-10, ... Далее 1253350510 KEIL1253350510 KEIL Набор SDS-plus TURBOKEIL 5.0-6.0x110, 6.0-8.0-10,0х160мм | 2 332 ₽ Розница, Скидки для Дилеров - |
Хомуты металлические Стандартное болтовое крепление 60-80мм, 50шт/уп, ... Далее 47564 СИБРТЕХХомуты металлические Стандартное болтовое крепление 60-80мм, 50шт/уп,ширина 9мм СИБРТЕХ | 808 ₽ Розница, Скидки для Дилеров - |
45623 Хомуты металлические Стандартное болтовое крепление 60-80мм, ... Далее 45623 ШУРУПЬ45623 Хомуты металлические Стандартное болтовое крепление 60-80мм, 50шт/уп,ширина 9мм ШУРУПЬ | 274 ₽ Розница, Скидки для Дилеров - |
9AE52 KING TONY Съемник масляных фильтров 1/2", 60-80 мм, ... Далее Съемник масляных фильтров KING TONY 9AE529AE52 KING TONY Съемник масляных фильтров 1/2", 60-80 мм, двухзахватный | 6 240 ₽ Розница, Скидки для Дилеров - |
Хомуты, нерж. сталь, накатная лента 12 мм, 60-80 мм, 50 шт, ЗУБР ... Далее Хомуты из нержавеющей стали ЗУБР ПРОФЕССИОНАЛ 37822-60-80-50Хомуты, нерж. сталь, накатная лента 12 мм, 60-80 мм, 50 шт, ЗУБР Профессионал 37822-60-80-50 | 1 568 ₽ Розница, Скидки для Дилеров - |
14 AMANA Москва Россия и страны СНГ | |
... -шпилька Laserweld Rotor 6080 одинарная с 18-ю ... Laserweld Rotor 6080 Далее Rotor 6080Тележка-шпилька Laserweld Rotor 6080 одинарная с 18-ю уровнями. Применяется в ... ; Для использования с ротационной печью Laserweld Rotor 6080 | 43 792 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Расстоечный шкаф Kumkaya EF 6080 MO Y предназначен для использования ... Далее EF 6080 MO Y ... Y предназначен для использования вместе с модульными печами EF 6080, обеспечивая оптимальную подготовку тестовых заготовок. Он идеален для ... | 400 199 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня на складе |
Стиральная машина Miele PW 6080 Vario с фронтальной загрузкой ... Далее PW 6080 Vario EL AV EDСтиральная машина Miele PW 6080 Vario с фронтальной загрузкой используется в отелях, ресторанах, прачечных, химчистках, ... | 475 738 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Еще 55 строк | |
Стиральная машина Miele PW 6080 Vario с фронтальной загрузкой ... Далее PW 6080 Vario EL AV LWСтиральная машина Miele PW 6080 Vario с фронтальной загрузкой используется в отелях, ресторанах, прачечных, химчистках, ... | 469 375 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Стиральная машина Miele PW 6080 Vario с фронтальной загрузкой ... Далее PW 6080 Vario EL LP EDСтиральная машина Miele PW 6080 Vario с фронтальной загрузкой используется в отелях, ресторанах, прачечных, химчистках, ... | 463 035 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Стиральная машина Miele PW 6080 Vario с фронтальной загрузкой ... Далее PW 6080 Vario EL AV OBСтиральная машина Miele PW 6080 Vario с фронтальной загрузкой используется в отелях, ресторанах, прачечных, химчистках, ... | 455 910 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Стиральная машина Miele PW 6080 Vario с фронтальной загрузкой ... Далее PW 6080 Vario EL LP LWСтиральная машина Miele PW 6080 Vario с фронтальной загрузкой используется в отелях, ресторанах, прачечных, химчистках, ... | 446 903 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Стиральная машина Miele PW 6080 Vario с фронтальной загрузкой ... Далее PW 6080 Vario EL LP OBСтиральная машина Miele PW 6080 Vario с фронтальной загрузкой используется в отелях, ресторанах, прачечных, химчистках, ... | 446 212 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Адаптер __ FC 6080 предназначен для монтажа трубопроводных систем. ... Далее FC 6080, 3/4" НР для Н-образного узла , FАдаптер __ FC 6080 предназначен для монтажа трубопроводных систем. Корпус выполнен из горяче-штампованной ... | 168 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Печь ротационная Laserweld Rotor 6080 платформа однокамерная с 15-тью, ... Далее Rotor 6080 платформаПечь ротационная Laserweld Rotor 6080 платформа однокамерная с 15-тью, 18-тью уровнями. Предназначена для ... | 1 693 993 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Камера расстоечная Laserweld PF 2/6080/1 (без пола) - вмещает две ... Далее 1/6080/2Камера расстоечная Laserweld PF 2/6080/1 (без пола) - вмещает две тележки с противнями размером 600х800 ... | 550 688 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Камера расстоечная Laserweld 2/6080/2 (без пола) - вмещает две ... Далее 2/6080/2Камера расстоечная Laserweld 2/6080/2 (без пола) - вмещает две тележки с противнями размером 600х800 ... | 591 670 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Камера расстоечная Laserweld 2/6080/4 (без пола) - вмещает четыре ... Далее 2/6080/4Камера расстоечная Laserweld 2/6080/4 (без пола) - вмещает четыре тележки с противнями размером 600х800 ... | 657 555 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Камера расстоечная Laserweld 2/6080/6 (без пола) - вмещает шесть ... Далее 2/6080/6Камера расстоечная Laserweld 2/6080/6 (без пола) - вмещает шесть тележек с противнями размером 600х800 ... | 737 618 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Расстоечная камера WLBake PF 4/6080/2 используется на предприятиях ... Далее PF 4/6080/2Расстоечная камера WLBake PF 4/6080/2 используется на предприятиях пищевой промышленности и в пекарнях для ... | 956 584 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Камера отложенной расстойки POLAIR СRP1.6080.Т1L серии Bakery CRP ... Далее СRP1.6080.Т1LКамера отложенной расстойки POLAIR СRP1.6080.Т1L серии Bakery CRP предназначена для отложенной расстойки на предприятиях ... | 408 850 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Камера отложенной расстойки POLAIR CRP2.6080.T2 серии Bakery CRP ... Далее CRP2.6080.T2LКамера отложенной расстойки POLAIR CRP2.6080.T2 серии Bakery CRP предназначена для отложенной расстойки на предприятиях ... | 463 165 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Камера отложенной расстойки POLAIR СRP1.6080.Т2 серии Bakery CRP ... Далее СRP1.6080.Т2LКамера отложенной расстойки POLAIR СRP1.6080.Т2 серии Bakery CRP предназначена для отложенной расстойки на предприятиях ... | 444 975 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Камера окончательной расстойки POLAIR CR1.6080.Т1L серии Bakery CR ... Далее CR1.6080.Т1LКамера окончательной расстойки POLAIR CR1.6080.Т1L серии Bakery CR предназначена для расстойки изделий хлебопекарного и ... | 339 150 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Соковыжималка для цитрусовых электрическая Zumoval Top+self service ... Далее Top+self service tapСоковыжималка для цитрусовых электрическая Zumoval Top+self service tap с автоматической подачей и дозатором для самообслуживания оснащена ... | 446 228 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
15 Whitegoods Москва Россия | |
... загрузкой 8 кг Octoplus PW 6080 Vario со сливным насосом (цвет ... Далее PW 6080 со сливным насосом, белыйСтиральная машина с загрузкой 8 кг Octoplus PW 6080 Vario со сливным насосом (цвет белый) Производительность Загрузка (кг): 8 ... | 496 000 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
... загрузкой 8 кг Octoplus PW 6080 Vario со сливным насосом (цвет ... Далее PW 6080 со сливным насосом, стальСтиральная машина с загрузкой 8 кг Octoplus PW 6080 Vario со сливным насосом (цвет нержавеющая сталь) Производительность Загрузка (кг): ... | 500 000 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Печь ротационная Laserweld Rotor 6080 подходит для выпечки широкого ... Далее Rotor 6080Печь ротационная Laserweld Rotor 6080 подходит для выпечки широкого ассортимента хлебобулочных и кондитерских изделий: Формовой ... | 1 403 095 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Еще 51 строка | |
... предназначена для печи Rotor 6080 Вместимость: 18 уровней ... Далее Rotor 6080Технические характеристики Тележка-шпилька предназначена для печи Rotor 6080 Вместимость: 18 уровней 600х800 мм Материал: нержавеющая ... | 47 845 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Весы товарные SCALE СКЕ 300-6080 RS предназначены для взвешивания ... Далее СКЕ 300-6080 RSВесы товарные SCALE СКЕ 300-6080 RS предназначены для взвешивания материалов, полуфабрикатов, готовой сельскохозяйственной или промышленной ... | 28 328 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
... выпечкой. Шкаф расстоечный PF 2/6080/2 имеет прочную конструкцию и ... Далее PF 2/6080/2 (без пола) - 00000255133 ... из дрожжевого теста перед выпечкой. Шкаф расстоечный PF 2/6080/2 имеет прочную конструкцию и износоустойчивые внутренние компоненты, что ... | 701 408 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Весы товарные SCALE СКЕ-500-6080 предназначены для определения веса ... Далее СКЕ-500-6080Весы товарные SCALE СКЕ-500-6080 предназначены для определения веса разнообразных пищевых и непищевых объектов взвешивания, ... | 17 521 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
... весы SCALE СКЕ-Н-300-6080 (300 КГ) предназначены для взвешивания ... Далее СКЕ-Н-300-6080Напольные весы SCALE СКЕ-Н-300-6080 (300 КГ) предназначены для взвешивания материалов, полуфабрикатов, готовой сельскохозяйственной или ... | 85 604 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
... весы SCALE СКЕ-Н-500-6080 (500 КГ) предназначены для взвешивания ... Далее СКЕ-Н-500-6080Напольные весы SCALE СКЕ-Н-500-6080 (500 КГ) предназначены для взвешивания материалов, полуфабрикатов, готовой сельскохозяйственной или ... | 85 604 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Расстоечная камера используется на предприятиях пищевой промышленности ... Далее PF 2/6080/1 (без пола) - 00000255132Расстоечная камера используется на предприятиях пищевой промышленности, общественного питания и в пекарнях для расстойки тестовых заготовок ... | 631 640 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Зонт вытяжной пристенный Кобор ЗПВ-60/80 предназначен для очистки ... Далее ЗПВ-60/80Зонт вытяжной пристенный Кобор ЗПВ-60/80 предназначен для очистки воздуха на кухне от жира, масла, дыма и водяного пара на предприятиях ... | 16 435 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Зонт приточно-вытяжной пристенный Кобор ЗППВ-60/80 предназначен для ... Далее ЗППВ-60/80Зонт приточно-вытяжной пристенный Кобор ЗППВ-60/80 предназначен для очистки воздуха на кухне от жира, масла, дыма и водяного пара на ... | 20 683 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Винный шкаф монотемпературный Cold Vine C192-KBF2 - роскошная модель в ... Далее C192-KBF2Винный шкаф монотемпературный Cold Vine C192-KBF2 - роскошная модель в сфере качественного хранения и дозревания вин! Благодаря современному ... | 137 390 ₽ Самовывоз: есть - |
Винный шкаф монотемпературный Cold Vine C192-KBF2 - роскошная модель в ... Далее C192-KBF2Винный шкаф монотемпературный Cold Vine C192-KBF2 - роскошная модель в сфере качественного хранения и дозревания вин! Благодаря современному ... | 137 390 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Винный шкаф Cold Vine C21-TBF2 - роскошная модель в сфере ... Далее C21-TBF2Винный шкаф Cold Vine C21-TBF2 - роскошная модель в сфере качественного хранения и дозревания вин! Благодаря современному продуманному ... | 27 599 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Винный шкаф Cold Vine C24-KBF2 - роскошная модель в сфере ... Далее C24-KBF2Винный шкаф Cold Vine C24-KBF2 - роскошная модель в сфере качественного хранения и дозревания вин! Благодаря современному продуманному ... | 34 999 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Винный шкаф монотемпературный Cold Vine C12-KBF1 - роскошная модель в ... Далее C12-KBF1Винный шкаф монотемпературный Cold Vine C12-KBF1 - роскошная модель в сфере качественного хранения и дозревания вин! Благодаря современному ... | 46 499 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Винный шкаф монотемпературный Cold Vine C12-KSF1 - роскошная модель в ... Далее C12-KSF1Винный шкаф монотемпературный Cold Vine C12-KSF1 - роскошная модель в сфере качественного хранения и дозревания вин! Благодаря современному ... | 46 499 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Винный шкаф монотемпературный Cold Vine C18-KBB1 - роскошная модель в ... Далее C18-KBB1Винный шкаф монотемпературный Cold Vine C18-KBB1 - роскошная модель в сфере качественного хранения и дозревания вин! Благодаря современному ... | 67 299 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
Винный шкаф монотемпературный Cold Vine C18-KBT1 - роскошная модель в ... Далее C18-KBT1Винный шкаф монотемпературный Cold Vine C18-KBT1 - роскошная модель в сфере качественного хранения и дозревания вин! Благодаря современному ... | 42 999 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
16 Энтеро Москва Россия, Белоруссия, Казахстан | |
Стиральная машина Miele PW 6080 Vario XL EL LP с ... Далее PW 6080 Vario XL EL LP белыйСтиральная машина Miele PW 6080 Vario XL EL LP с фронтальной загрузкой используется в отелях, ... | 600 000 ₽ Доставка: есть |
Стиральная машина Miele PW 6080 Vario XL EL LP с ... Далее PW 6080 Vario XL EL LP стальСтиральная машина Miele PW 6080 Vario XL EL LP с фронтальной загрузкой используется в отелях, ... | 600 000 ₽ Доставка: есть |
Стиральная машина Miele PW 6080 Vario XL EL LP с ... Далее PW 6080 Vario XL EL LP синийСтиральная машина Miele PW 6080 Vario XL EL LP с фронтальной загрузкой используется в отелях, ... | 570 000 ₽ Доставка: есть |
Еще 79 строк | |
Стиральная машина Miele PW 6080 Vario XL EL AV с ... Далее PW 6080 Vario XL EL AV белыйСтиральная машина Miele PW 6080 Vario XL EL AV с фронтальной загрузкой используется в отелях, ... | 600 000 ₽ Доставка: есть |
Стиральная машина Miele PW 6080 Vario XL EL AV с ... Далее PW 6080 Vario XL EL AV стальСтиральная машина Miele PW 6080 Vario XL EL AV с фронтальной загрузкой используется в отелях, ... | 600 000 ₽ Доставка: есть |
Стиральная машина Miele PW 6080 Vario XL EL AV с ... Далее PW 6080 Vario XL EL AV синийСтиральная машина Miele PW 6080 Vario XL EL AV с фронтальной загрузкой используется в отелях, ... | 570 000 ₽ Доставка: есть |
600 000 ₽ Доставка: есть | |
Расстоечная камера WLBake PF 2/6080/1 используется на предприятиях ... Далее PF 2/6080/1 (без пола)Расстоечная камера WLBake PF 2/6080/1 используется на предприятиях пищевой промышленности, общественного питания и в ... | 837 051 ₽ Доставка: есть |
Расстоечная камера WLBake PF 2/6080/2 используется на предприятиях ... Далее PF 2/6080/2 (без пола)Расстоечная камера WLBake PF 2/6080/2 используется на предприятиях пищевой промышленности и в пекарнях для ... | 883 516 ₽ Доставка: есть |
Камера отложенной расстойки POLAIR CRP2.6080.T2 inox серии Bakery CRP ... Далее CRP2.6080.T2 inoxКамера отложенной расстойки POLAIR CRP2.6080.T2 inox серии Bakery CRP предназначена для отложенной расстойки на ... | 525 190 ₽ Доставка: есть |
Камера отложенной расстойки POLAIR CRP2.6080.T4 серии Bakery CRP ... Далее СRP2.6080.T4Камера отложенной расстойки POLAIR CRP2.6080.T4 серии Bakery CRP предназначена для отложенной расстойки на предприятиях ... | 687 055 ₽ Доставка: есть |
Камера отложенной расстойки POLAIR CRP2.6080.T4 inox серии Bakery CRP ... Далее CRP2.6080.T4 inoxКамера отложенной расстойки POLAIR CRP2.6080.T4 inox серии Bakery CRP предназначена для отложенной расстойки на ... | 787 279 ₽ Доставка: есть |
Камера отложенной расстойки POLAIR CRP2.6080.T6 серии Bakery CRP ... Далее СRP2.6080.T6Камера отложенной расстойки POLAIR CRP2.6080.T6 серии Bakery CRP предназначена для отложенной расстойки на предприятиях ... | 1 003 425 ₽ Доставка: есть |
Камера отложенной расстойки POLAIR CRP2.6080.T6 серии Bakery CRP ... Далее CRP2.6080.T6 inoxКамера отложенной расстойки POLAIR CRP2.6080.T6 серии Bakery CRP предназначена для отложенной расстойки на предприятиях ... | 1 042 270 ₽ Доставка: есть |
Камера окончательной расстойки POLAIR CR1.6080.Т1L серии Bakery CR ... Далее CR1.6080.Т1LКамера окончательной расстойки POLAIR CR1.6080.Т1L серии Bakery CR предназначена для расстойки изделий хлебопекарного и ... | 339 150 ₽ Доставка: есть |
Камера окончательной расстойки POLAIR CR1.6080.Т2L серии Bakery CR ... Далее CR1.6080.Т2LКамера окончательной расстойки POLAIR CR1.6080.Т2L серии Bakery CR предназначена для расстойки изделий хлебопекарного и ... | 357 000 ₽ Доставка: есть |
Камера окончательной расстойки POLAIR CR2.6080.Т2L серии Bakery CR ... Далее CR2.6080.Т2LКамера окончательной расстойки POLAIR CR2.6080.Т2L серии Bakery CR предназначена для расстойки изделий хлебопекарного и ... | 378 250 ₽ Доставка: есть |
Камера окончательной расстойки POLAIR CR2.6080.Т2S серии Bakery CR ... Далее CR2.6080.Т2SКамера окончательной расстойки POLAIR CR2.6080.Т2S серии Bakery CR предназначена для расстойки изделий хлебопекарного и ... | запрос Доставка: есть |
Камера окончательной расстойки POLAIR CR2.6080.Т4L серии Bakery CR ... Далее CR2.6080.Т4LКамера окончательной расстойки POLAIR CR2.6080.Т4L серии Bakery CR предназначена для расстойки изделий хлебопекарного и ... | запрос Доставка: есть |
... дозирующих насосов стиральных машин PW 6080, PW 5082 в отелях ... Далее ASK ... для подключения до 6 дозирующих насосов стиральных машин PW 6080, PW 5082 в отелях, ресторанах, прачечных, химчистках, больницах, спортивных ... | 50 900 ₽ Доставка: есть |
17 ВсеИнструменты.ру Москва Россия | |
... 0602 600х800 4 Г 00602-6080 Далее Полотенцесушитель Стилье - 00602-6080Полотенцесушитель Стилье Минор 0602 600х800 4 Г 00602-6080 | 10 200 ₽ на складе |
Металлическая перфопанель ООО Металекс Metalex 600x800 зелёная с ... Далее Металлическая перфопанель ООО Металекс - PRZA6080Металлическая перфопанель ООО Металекс Metalex 600x800 зелёная с комплектом аксессуаров PRZA6080 | 2 600 ₽ на складе |
Хомут с пружинной вставкой KALE WD IS 60-80/12 W3 уп. 10 шт. 60-80 ... Далее Хомут KALE CLAMP - 60-80 WD1273ISХомут с пружинной вставкой KALE WD IS 60-80/12 W3 уп. 10 шт. 60-80 WD1273IS | 1 356 ₽ на складе |
Еще 134 строки | |
Металлическая перфопанель ООО Металекс Metalex 600x800 чёрная с ... Далее Металлическая перфопанель ООО Металекс - PRCHA6080Металлическая перфопанель ООО Металекс Metalex 600x800 чёрная с комплектом аксессуаров PRCHA6080 | 2 600 ₽ на складе |
Цилиндр СК 80 мм, латунь СК 6080 СЦ (30+10+40) | 762 ₽ на складе |
... прижима 270 кг DIN5117 FCB-6080 Далее F-образная струбцина WOODWORKF-образная струбцина WOODWORK 600x80 мм, усилие прижима 270 кг DIN5117 FCB-6080 | 757 ₽ на складе |
Зеркало с LED-подсветкой MELANA 6080 MLN-LED018 | 12 180 ₽ на складе |
Напольные весы СКЕЙЛ СКЕ-500-6080 RS 88-00000145 | 25 055 ₽ на складе |
Червячный хомут FORTISFLEX PL-9/W2 60-80 мм 68968 | 425 ₽ на складе |
Скрытый ревизионный люк под плитку ЛСИС 600x800 алюминиевый, нажимной, ... Далее Скрытый ревизионный люк под плитку ЛСИССкрытый ревизионный люк под плитку ЛСИС 600x800 алюминиевый, нажимной, регулируемый АРРЗ6080 | 7 110 ₽ на складе |
Набор резиновых шпателей ON 40-60-80 мм, белые 02-04-300 | 71.0 ₽ на складе |
Червячный хомут FORTISFLEX PL-12/W2 60-80 мм 69016 | 592 ₽ на складе |
Червячный хомут STARFIX 60-80 мм, цинк, DIN 3017, 25 шт. в пакете SM- ... Далее Червячный хомут STARFIXЧервячный хомут STARFIX 60-80 мм, цинк, DIN 3017, 25 шт. в пакете SM-82344-25 | 567 ₽ на складе |
Червячный хомут NORMA TORRO нержавеющая сталь 100 шт. 60-80/9C7W2 | 5 889 ₽ на складе |
Губка для шлифования Matrix 125x100x10 мм мягкая 3 шт. P 60/80 P 60/ ... Далее Мягкая губка для шлифования MATRIXГубка для шлифования Matrix 125x100x10 мм мягкая 3 шт. P 60/80 P 60/100 P 80/120 75715 | 221 ₽ на складе |
Червячный хомут ZIP 60-80/9W2 50279 | 51.0 ₽ на складе |
Обжимной хомут FIT IT нержавеющая сталь 60-80 мм 64287 | 55.0 ₽ на складе |
Набор губок для шлифования (3 шт; 100х70х25 мм; Р60/80; Р60/100; Р80/ ... Далее Набор губок для шлифования РемоКолорНабор губок для шлифования (3 шт; 100х70х25 мм; Р60/80; Р60/100; Р80/120; карбид кремния) РемоКолор 32-1-201 | 235 ₽ на складе |
Чашка для резки и шлифовки Super Wood Cup (125 мм; 60/80) Hilberg ... Далее Чашка для резки и шлифовки Hilberg - 533125Чашка для резки и шлифовки Super Wood Cup (125 мм; 60/80) Hilberg 533125 | 1 205 ₽ на складе |
Нижняя направляющая ARMADILLO Comfort 60/80/1000 bottom track 46703 | 324 ₽ на складе |
18 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
Короб перф. пл., 1 шт - 2 метра. короб 60.0 мм х 80.0 мм, окно ... Далее 6080S-2Короб перф. пл., 1 шт - 2 метра. короб 60.0 мм х 80.0 мм, окно перфорации 5.0 мм, мтериал ПВХ (UL 94V-0) не поддерж. горение, цвет: серый | 552 ₽ от 5000 ₽ |
Заклепка пластиковая, 1 уп. - 1000 шт. Заклепки: марериал нейлон 66 ( ... Далее PR-6080-KЗаклепка пластиковая, 1 уп. - 1000 шт. Заклепки: марериал нейлон 66 ( UL-94V-2), цвет черный | 4 846 ₽ от 5000 ₽ |
компьютерные переходники | 34.5 ₽ от 5000 ₽ |
Еще 8 строк | |
Короб перф. пл., 1 шт - 2 метра. короб 60.0 мм х 80.0 мм, окно ... Далее 6080L-2Короб перф. пл., 1 шт - 2 метра. короб 60.0 мм х 80.0 мм, окно перфорации 8.0 мм, мтериал ПВХ (UL 94V-0) не поддерж. горение, цвет: серый | 552 ₽ от 5000 ₽ |
... /5300/5500/6020/6060/6070/6080/7260/7360/N80/N90 Далее СОТ Акк. Nokia 3220/3230/3500/5140/60 60CRAFTMANN / LI-ION 800 mAh / (BL-5B) Nokia 3220/3230/3500/5070/5140/5200/5300/5500/6020/6060/6070/6080/7260/7360/N80/N90 | 273 ₽ от 5000 ₽ |
... /5300/5500/6020/6060/6070/6080/7260/7360/N80/N90 Далее СОТ Акк. Nokia 3220/3230/3500/5140/60 60PRONTO / LI-ION 800 mAh / (BL-5B) Nokia 3220/3230/3500/5070/5140/5200/5300/5500/6020/6060/6070/6080/7260/7360/N80/N90 | 162 ₽ от 5000 ₽ |
7.6x7.6 / Green / Water clear / 520nm / 2600 mcd / 60°-80° | 5.74 ₽ от 5000 ₽ |
AC-DC led, 40Вт, выход 60..80В/ 500mA, стаб. тока, IP20, вход 100... ... Далее ELP040C0500LXAC-DC led, 40Вт, выход 60..80В/ 500mA, стаб. тока, IP20, вход 100...240В AC, PFC, в кожухе, 157х50х34 мм, -5..+50 °C, клеммы | 399 ₽ от 5000 ₽ |
Кабельный ввод, 1 шт. Кабельный ввод Progress® EMC Rapid с ... Далее 1081.17.080Кабельный ввод, 1 шт. Кабельный ввод Progress® EMC Rapid с контактным стальным диском; М20x1,5; мат.: никелированная латунь; -40 +100С; ... | 210 ₽ от 5000 ₽ |
Кабельный ввод, 1 шт.. Никелированный латунный кабельный ввод ... Далее 1100.20.080Кабельный ввод, 1 шт.. Никелированный латунный кабельный ввод компрессионного типа, М20*1,5. -40 +100С, IP68, IP69K, Ключ=24, H=21, L=10, ... | 145 ₽ от 5000 ₽ |
Кабельный ввод, 1 шт.. Никелированный латунный кабельный ввод ... Далее 1100.17.080Кабельный ввод, 1 шт.. Никелированный латунный кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, ... | 113 ₽ от 5000 ₽ |
19 ForOffice Москва Россия, Белорусь, Казахстан | |
Тип станка полуавтоматический Печать по цилиндру нет Вакуумный стол да ... Далее t TS-6080Тип станка полуавтоматический Печать по цилиндру нет Вакуумный стол да Максимальная длина отпечатка 900 мм Максимальная ширина отпечатка 600 ... | 986 415 ₽ на складе |
Цвет на выбор по каталогу Размер поверхности 600 х 800 Вес 8 кг | 9 000 ₽ на складе |
20 РЕФРО Москва Россия | |
Печь ротационная электрическая Danzi Forni Prisma S1 6080Модель: ... Далее Печь ротационная электрическая Danzi Forni Prisma S1 6080Печь ротационная электрическая Danzi Forni Prisma S1 6080Модель: Prisma S1 6080Страна: ИталияВес без упаковки, кг: 950Ширина, мм: 2 ... | 2 129 304 ₽ - |
... расстоечная WLBake PF 4/6080/2Модель: PF 4/6080/2Страна: ИталияВес без ... Далее Камера расстоечная WLBake PF 4/6080/2Камера расстоечная WLBake PF 4/6080/2Модель: PF 4/6080/2Страна: ИталияВес без упаковки, кг: 320Ширина, мм: 1 900Глубина, мм: ... | 721 505 ₽ - |
Камера расстоечная WLBake PF 2/6080/2 (без пола) позиционируется как ... Далее Камера расстоечная WLBake PF 2/6080/2 (без пола)Камера расстоечная WLBake PF 2/6080/2 (без пола) позиционируется как производительная модель с большим эксплуатационным ... | 883 527 ₽ - |
Еще 13 строк | |
Камера расстоечная WLBake PF 2/6080/1 (без пола) обеспечивает ... Далее Камера расстоечная WLBake PF 2/6080/1 (без пола)Камера расстоечная WLBake PF 2/6080/1 (без пола) обеспечивает необходимый режим температуры/влажности для окончательной ... | 631 347 ₽ - |
Весы напольные MAS PM1E-300-6080Модель: PM1E-300-6080Страна: РоссияВес ... Далее Весы напольные MAS PM1E-300-6080Весы напольные MAS PM1E-300-6080Модель: PM1E-300-6080Страна: РоссияВес без упаковки, кг: 32Ширина, мм: 600Глубина, мм: 980Высота, мм: ... | 23 986 ₽ - |
Весы напольные MAS PM1B-300-6080Модель: PM1B-300-6080Страна: РоссияВес ... Далее Весы напольные MAS PM1B-300-6080Весы напольные MAS PM1B-300-6080Модель: PM1B-300-6080Страна: РоссияВес без упаковки, кг: 32Ширина, мм: 600Глубина, мм: 980Высота, мм: ... | 25 315 ₽ - |
Весы напольные MAS PM1E-500-6080Модель: PM1E-500-6080Страна: РоссияВес ... Далее Весы напольные MAS PM1E-500-6080Весы напольные MAS PM1E-500-6080Модель: PM1E-500-6080Страна: РоссияВес без упаковки, кг: 32Ширина, мм: 600Глубина, мм: 980Высота, мм: ... | 23 986 ₽ - |
Весы напольные MAS PM1H-300-6080Модель: PM1H-300-6080Страна: РоссияВес ... Далее Весы напольные MAS PM1H-300-6080Весы напольные MAS PM1H-300-6080Модель: PM1H-300-6080Страна: РоссияВес без упаковки, кг: 32Ширина, мм: 600Глубина, мм: 980Высота, мм: ... | 36 132 ₽ - |
Весы напольные MAS PM1H-500-6080Модель: PM1H-500-6080Страна: ... Далее Весы напольные MAS PM1H-500-6080Весы напольные MAS PM1H-500-6080Модель: PM1H-500-6080Страна: РоссияГарантия, мес: 12 | 36 132 ₽ - |
Весы напольные MAS PM1B-500-6080Модель: PM1B-500-6080Страна: РоссияВес ... Далее Весы напольные MAS PM1B-500-6080Весы напольные MAS PM1B-500-6080Модель: PM1B-500-6080Страна: РоссияВес без упаковки, кг: 32Ширина, мм: 600Глубина, мм: 980Высота, мм: ... | 25 315 ₽ - |
Вытяжной пристенный зонт КОБОР ЗПВ -60/80 предназначен для очистки ... Далее Зонт вытяжной пристенный КОБОР ЗПВ-60/80Вытяжной пристенный зонт КОБОР ЗПВ -60/80 предназначен для очистки воздуха от аэрозолей жира, масла, водяного пара и устанавливаются в ... | 16 693 ₽ - |
Приточно-вытяжной зонт КОБОР ЗППВ -60/80 предназначен для очистки ... Далее Зонт приточно-вытяжной КОБОР ЗППВ -60/80Приточно-вытяжной зонт КОБОР ЗППВ -60/80 предназначен для очистки воздуха от аэрозолей жира, масла, водяного пара и устанавливаются в ... | 21 606 ₽ - |
Плита индукционная Iterma ПКИ-800/700М-4/3 - настольная модель с 4 ... Далее Плита индукционная Iterma ПКИ-800/700М-4/3Плита индукционная Iterma ПКИ-800/700М-4/3 - настольная модель с 4 плоскими прямоугольными конфорками под наплитную посуду с ферромагнитным ... | 200 247 ₽ на складе |
Шкаф расстоечный Abat ШРТ-18М черный дизайн используется для расстойки ... Далее Расстоечный шкаф Abat ШРТ-18М черный дизайнШкаф расстоечный Abat ШРТ-18М черный дизайн используется для расстойки хлебобулочных и кондитерских изделий на предприятиях пищевого ... | 265 283 ₽ - |
HURAKAN HKN-MA230 представляет собой вместительный шкаф для вызревания ... Далее Шкаф для вызревания мяса HURAKAN HKN-MA230HURAKAN HKN-MA230 представляет собой вместительный шкаф для вызревания колбас. Модель подходит для охлаждения и организации процесса ... | 197 250 ₽ - |
Шкаф винный Dunavox DAUF-9.22SS отлично сочетается с интерьером кухни ... Далее Шкаф винный Dunavox DAUF-9.22SSШкаф винный Dunavox DAUF-9.22SS отлично сочетается с интерьером кухни или бара. Двойное стекло с защитой от прямых ультрафиолетовых лучей. ... | 32 699 ₽ - |
21 Холодильник.ру Москва Россия | |
Габариты (ВxШxГ) (см): 81.5x59.8x55
Тип панели: закрытая
Тип ... Далее Встраиваемая посудомоечная машина Kuppersberg GLM 6080Габариты (ВxШxГ) (см): 81.5x59.8x55
Тип управления: электронный
Вместимость (комплекты): 14
Третья корзина: да
Класс ... | 52 731 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 1500 ₽ на складе |
Вид мебели: шкаф
Установка: подвесная
Материал: МДФ
Тип фасада: МДФ
... Далее Шкаф СаНта Верона, 60*80 над стиральной машиной (710011)Вид мебели: шкаф
Материал: МДФ
Тип фасада: МДФ
Возможность установки над стиральной машиной: да
Цвет: белый
Страна- ... | 8 950 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Вид мебели: шкаф подвесной
Материал: влагостойкое ... Далее Шкаф подвесной СаНта Дублин 60*80, над стиральной машиной (423001)Вид мебели: шкаф подвесной
Материал: влагостойкое ЛДСП, МДФ, пленка
Тип фасада: МДФ, пленка
Возможность установки над ... | 7 627 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 1500 ₽ - |
Еще 3 строки | |
Тип: тактильные мячики
Материал: ПВХ
Цвет: разноцветный
Страна- ... Далее Тактильные мячики Юнландия развивающие ЭКО 6 штук d 60-80 мм 664702Тип: тактильные мячики
Материал: ПВХ
Цвет: разноцветный
Страна-производитель: Китай | 409 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Назначение: для силовых тренировок
Максимальный вес пользователя (кг): ... Далее Турник треххватный Atemi ATD3 в дверной проем 60-80 смНазначение: для силовых тренировок
Максимальный вес пользователя (кг): 100
Цвет: черный/оранжевый
Страна-производитель: Китай | 3 149 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Максимальный вес пользователя (кг): ... Далее Турник треххватный Atemi ATD1 в дверной проем 60-80 смНазначение: для силовых тренировок
Страна-производитель: Китай | 1 899 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
22 LifeElectronics Санкт-Петербург Россия | |
2K-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
6765 POWER ENTRY MODUL 10A 70C | запрос 7-14 дней |
Тестеры DMM TEST PROBE | запрос 7-14 дней |
Еще 18 строк | |
15-49-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
Проводные клеммы и зажимы CGrid SMT Bkwy Hdr T kwy Hdr Tin 8Ckt T&R | запрос 7-14 дней |
3M?„? Power Clamp Wiremount Plug | запрос 7-14 дней |
6080B 24 Апр 2024 00:53 | запрос 7-14 дней |
6080JX 24 Апр 2024 00:53 | запрос 7-14 дней |
6080WB 24 Апр 2024 00:53 | запрос 7-14 дней |
Schottky Powermod | запрос 7-14 дней |
MFC6080 24 Апр 2024 00:53 | запрос 7-14 дней |
10 AMPERES COMPLEMENTARY SILICON POWER TRANSISTORS 60,80 VOLTS | запрос 7-14 дней |
3-Electrode 6.08.0 mm Type | запрос 7-14 дней |
23 TradeElectronics Москва Россия | |
Соединения кабелей MICRO-C EXT DEVICE cable 80' | запрос 7-14 дней |
BUZZER PIEZO 10V 44MM CHASSIS | запрос 7-14 дней |
Еще 18 строк | |
Проводные клеммы и зажимы KK 156 Header Assy F rLk Break 08 Ckt Gol | запрос 7-14 дней |
Insulated Minigator Clip To Pin Tip Jack | запрос 7-14 дней |
6080WC 24 Апр 2024 00:53 | запрос 7-14 дней |
SILICON BRIDGE RECTIFIER 6.0 AMPS, 100 THRU 1000 VOLTS | запрос 7-14 дней |
Dual Enhancement Mode Field Effect Transistor (N and P Channel) | запрос 7-14 дней |
LAN DISCRETE TRANSFORMER MODULES | запрос 7-14 дней |
10 AMPERE DARLINGTON POWER TRANSISTORS COMPLEMENTARY SILICON 60.80 ... Далее MJ2500TO-3PULLS10 AMPERE DARLINGTON POWER TRANSISTORS COMPLEMENTARY SILICON 60.80 VOLTS 150 WATTS | запрос 7-14 дней |
24 Элитан Ижевск Россия Безнал. расчет Филиалы: Москва Санкт-Петербург Екатеринбург Новосибирск | |
940 ₽ | |
195 ₽ | |
233 ₽ | |
Еще 16 строк | |
223 ₽ | |
562 ₽ | |
709 ₽ | |
103 ₽ | |
1 388 ₽ | |
1 673 ₽ | |
722 ₽ | |
1 476 ₽ | |
27.8 ₽ | |
4 430 ₽ | |
89.0 ₽ | |
Плата макетная 60*80 19 Апр 2024 02:31 | 237 ₽ |
Плата макетная 60*80 PCB BLACK EDITION 19 Апр 2024 02:31 | 386 ₽ |
Плата макетная 60*80 PCB BLACK EDITION 19 Апр 2024 02:31 | 449 ₽ |
SRP6080 19 Апр 2024 02:31 | 503 ₽ |
303 ₽ | |
25 ЭИК Санкт-Петербург Россия | |
BUZZER PIEZO 10V 44MM FLANGE | 361 ₽ от 1 шт 21-42 дня склад 500 шт |
Еще 4 цен: … 245 ₽ | |
300 ₽ от 10 шт 21-42 дня склад 500 шт | |
278 ₽ от 25 шт 21-42 дня склад 500 шт | |
261 ₽ от 50 шт 21-42 дня склад 500 шт | |
245 ₽ от 100 шт 21-42 дня склад 500 шт | |
CONN BANANA PLUG STACK SLDR RED | 1 359 ₽ от 1 шт 21-42 дня склад 362 шт |
Еще 4 цен: … 961 ₽ | |
1 189 ₽ от 25 шт 21-42 дня склад 362 шт | |
1 076 ₽ от 100 шт 21-42 дня склад 362 шт | |
1 028 ₽ от 250 шт 21-42 дня склад 362 шт | |
961 ₽ от 500 шт 21-42 дня склад 362 шт | |
2.92MM MALE TO SMP MALE ADAPTER, | 37 039 ₽ от 1 шт 21-42 дня склад 8 шт |
Еще 3 цен: … 31 592 ₽ | |
33 989 ₽ от 10 шт 21-42 дня склад 8 шт | |
32 682 ₽ от 25 шт 21-42 дня склад 8 шт | |
31 592 ₽ от 50 шт 21-42 дня склад 8 шт | |
Еще 8 строк | |
IMPACT PUNCH DOWN TOOL 110 PUNC | 6 947 ₽ от 1 шт 21-42 дня склад 23 шт |
PWR ENT MOD RCPT IEC320-C14 PNL | 3 339 ₽ от 1 шт 21-42 дня склад 50 шт |
Еще 2 цен: … 2 059 ₽ | |
2 433 ₽ от 50 шт 21-42 дня склад 50 шт | |
2 059 ₽ от 100 шт 21-42 дня склад 50 шт | |
CONN PLUG 5POS IDC 18AWG GOLD | 1 517 ₽ от 1 шт 21-42 дня склад 11 шт |
Еще 4 цен: … 1 200 ₽ | |
1 371 ₽ от 10 шт 21-42 дня склад 11 шт | |
1 295 ₽ от 25 шт 21-42 дня склад 11 шт | |
1 264 ₽ от 50 шт 21-42 дня склад 11 шт | |
1 200 ₽ от 100 шт 21-42 дня склад 11 шт | |
CONN SOCKET 5POS IDC 18AWG GOLD | 1 785 ₽ от 1 шт 21-42 дня склад 98 шт |
Еще 4 цен: … 1 435 ₽ | |
1 606 ₽ от 10 шт 21-42 дня склад 98 шт | |
1 513 ₽ от 25 шт 21-42 дня склад 98 шт | |
1 474 ₽ от 50 шт 21-42 дня склад 98 шт | |
1 435 ₽ от 100 шт 21-42 дня склад 98 шт | |
CONN PLUG 5POS IDC 18AWG GOLD | 1 517 ₽ от 1 шт 21-42 дня склад 81 шт |
1 371 ₽ от 10 шт 21-42 дня склад 81 шт | |
1 295 ₽ от 25 шт 21-42 дня склад 81 шт | |
1 264 ₽ от 50 шт 21-42 дня склад 81 шт | |
1 200 ₽ от 100 шт 21-42 дня склад 81 шт | |
EXT O= .180,L= 1.00,W= .031 | 576 ₽ от 1 шт 21-42 дня склад 559 шт |
Еще 4 цен: … 431 ₽ | |
546 ₽ от 50 шт 21-42 дня склад 559 шт | |
517 ₽ от 150 шт 21-42 дня склад 559 шт | |
489 ₽ от 300 шт 21-42 дня склад 559 шт | |
431 ₽ от 500 шт 21-42 дня склад 559 шт | |
Диод: R-SCHOTTKY 10A 60V | 409 ₽ от 1 шт 21-42 дня склад 2309 шт |
Еще 4 цен: … 340 ₽ | |
390 ₽ от 10 шт 21-42 дня склад 2309 шт | |
368 ₽ от 20 шт 21-42 дня склад 2309 шт | |
348 ₽ от 50 шт 21-42 дня склад 2309 шт | |
340 ₽ от 100 шт 21-42 дня склад 2309 шт | |
LATCH LOCK FOR SIZE 5060 - 6080 | 5 172 ₽ от 1 шт 21-42 дня склад 6 шт |
26 ЭлектроПласт Санкт-Петербург Россия | |
80-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
Регистрация и накопление данных COUNTER / FREQUENCY INPUT MODULE | запрос 7-14 дней |
Дозаторы для жидкостей и бутылки 4 oz. Pure-Touch Dispenser Pump | запрос 7-14 дней |
Еще 17 строк | |
TUBEAXIAL | запрос 7-14 дней |
Crystals | запрос 7-14 дней |
Suitable for automobile, automation system,electronicequipment | запрос 7-14 дней |
8-Bit 40 MSPS/50 MSPS/80 MSPS Converter | запрос 7-14 дней |
BROADBAND ACCESS: xDSL, HPN, CMCs | запрос 7-14 дней |
Solid State Relays For Motor Control | запрос 7-14 дней |
Ultra Fast Recovery Epitaxial Diodes | запрос 7-14 дней |
Интегральные схемы (ИС) усилителей мощности 60-80VDC HI FREQ H-B RDG ... Далее HIP4080Интегральные схемы (ИС) усилителей мощности 60-80VDC HI FREQ H-B RDG DRVR W/ | запрос 7-14 дней |
Интегральные схемы (ИС) усилителей мощности 60-80 VDC HI FREQ H- BRDG ... Далее HIP4080AIB-TИнтегральные схемы (ИС) усилителей мощности 60-80 VDC HI FREQ H- BRDG DRIVER | запрос 7-14 дней |
10 AMPERE DARLINGTON POWER TRANSISTORS COMPLEMENTARY SILICON 60.80 ... Далее MJ125010 AMPERE DARLINGTON POWER TRANSISTORS COMPLEMENTARY SILICON 60.80 VOLTS 150 WATTS | запрос 7-14 дней |
60 AMPERES COMPLEMENTARY SILICON POWER TRANSITORS 60-80 VOLTS 300 ... Далее MJ14001MJ1400360 AMPERES COMPLEMENTARY SILICON POWER TRANSITORS 60-80 VOLTS 300 WATTS | запрос 7-14 дней |
10 AMPERE DARLINGTON POWER TRANSISTORS COMPLEMENTARY SILICON 60.80 ... Далее MJ2500/DSI10 AMPERE DARLINGTON POWER TRANSISTORS COMPLEMENTARY SILICON 60.80 VOLTS 150 WATTS | запрос 7-14 дней |
27 МосЧип Москва Россия | |
Size C Aluminum Box With Cover | запрос 7-14 дней |
Поворотные переключатели 6 TAPS 50A/300VAC 20VDC | запрос 7-14 дней |
РЧ-соединители SSMCX Plug for RF178 | запрос 7-14 дней |
Еще 17 строк | |
SUPER FAST RECTIFIERS | запрос 7-14 дней |
Проводные клеммы и зажимы C-GRID 80 CKT SHROUD | запрос 7-14 дней |
40-716-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
5995-00-064-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
LTT-6080-115 24 Апр 2024 00:53 | запрос 7-14 дней |
CAP TANT 12UF 20V 5% AXIAL | запрос 7-14 дней |
30 mm Non-Illuminated Mushroom Momentary Metal Operator AMx | запрос 7-14 дней |
UV Power METERS | запрос 7-14 дней |
CK6080 24 Апр 2024 00:53 | запрос 7-14 дней |
ECG6080 24 Апр 2024 00:53 | запрос 7-14 дней |
MINIBRIDGE 25,40,50 and 60 AMPERE BRIDGE RECTIFIERS | запрос 7-14 дней |
12-bit, 60/80/105 Msps Analog-to-Digital Converter (ADC) Nyquist/high ... Далее TDA876912-bit, 60/80/105 Msps Analog-to-Digital Converter (ADC) Nyquist/high IF sampling | запрос 7-14 дней |
28 ТаймЧипс Санкт-Петербург Россия | |
Subminiature Fuse, 8.5 mm, Quick-Acting F, 250 VAC, 250 VDC | запрос 7-14 дней |
Еще 26 строк | |
CY4.6080 24 Апр 2024 00:53 | запрос 7-14 дней |
MULTIPLEXED TWO-WIRE HALL-EFFECT SENSOR ICs | запрос 7-14 дней |
Проводные клеммы и зажимы 5P IDC 3MM PANEL MNT PWR CLMP WIREMNT PLG | запрос 7-14 дней |
6080AP 24 Апр 2024 00:53 | запрос 7-14 дней |
6080JTX 24 Апр 2024 00:53 | запрос 7-14 дней |
6080SH 24 Апр 2024 00:53 | запрос 7-14 дней |
6080WASP 24 Апр 2024 00:53 | запрос 7-14 дней |
EV-PV6080 24 Апр 2024 00:53 | запрос 7-14 дней |
M55629/6-080 24 Апр 2024 00:53 | запрос 7-14 дней |
Интегральные схемы (ИС) усилителей мощности 60-80VDC HI FREQ H-B RDG ... Далее HIP4080AИнтегральные схемы (ИС) усилителей мощности 60-80VDC HI FREQ H-B RDG DRVR W/ | запрос 7-14 дней |
29 Океан Электроники Санкт-Петербург Россия | |
CYOSC4.6080 24 Апр 2024 00:53 | запрос 7-14 дней |
Проводные клеммы и зажимы KK 156 PCB Assy Top Assy Top 08 Ckt Tin | запрос 7-14 дней |
Еще 20 строк | |
ECX-6080-10.000M 24 Апр 2024 00:53 | запрос 7-14 дней |
37-608-0 24 Апр 2024 00:53 | запрос 7-14 дней |
60-80 24 Апр 2024 00:53 | запрос 7-14 дней |
SWITCH REED SPDT .5A 60-80 A/T | запрос 7-14 дней |
LED 7-SEG DISP CC RED RHDP .56 | запрос 7-14 дней |
12 AMPERE POWER TRANSISTORS COMPLEMENTARY SILICON 40,60,80 VOLTS 100 ... Далее 2M599112 AMPERE POWER TRANSISTORS COMPLEMENTARY SILICON 40,60,80 VOLTS 100 WATTS | запрос 7-14 дней |
Интегральные схемы (ИС) усилителей мощности 60-80 VDC HI FREQ H- BRDG ... Далее HIP4080AIB/IBИнтегральные схемы (ИС) усилителей мощности 60-80 VDC HI FREQ H- BRDG DRIVER | запрос 7-14 дней |
60 AMPERES COMPLEMENTARY SILICON POWER TRANSITORS 60-80 VOLTS 300 ... Далее MJ14001X60 AMPERES COMPLEMENTARY SILICON POWER TRANSITORS 60-80 VOLTS 300 WATTS | запрос 7-14 дней |
10 AMPERE DARLINGTON POWER TRANSISTORS COMPLEMENTARY SILICON 60.80 ... Далее MJ2500D10 AMPERE DARLINGTON POWER TRANSISTORS COMPLEMENTARY SILICON 60.80 VOLTS 150 WATTS | запрос 7-14 дней |
30 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
PLUG BANANA STD INSULATED RED | запрос 7-14 дней |
6080-119 24 Апр 2024 00:53 | запрос 7-14 дней |
Еще 32 строки | |
6080-F0186 24 Апр 2024 00:53 | запрос 7-14 дней |
Проводные клеммы и зажимы 2.54MM HDR RA 8P 052/120 SN | запрос 7-14 дней |
Проводные клеммы и зажимы 2.5 Spox Hdr WB Shrd ShrdStgF White 8Ckt | запрос 7-14 дней |
Проводные клеммы и зажимы KK 156 Hdr Assy FrLk FrLk Peg 08 Ckt Tin | запрос 7-14 дней |
DUAL-IN-LINE SOCKETS Right Angle Mount Closed Frame | запрос 7-14 дней |
HALL-EFFECT SWITCHES | запрос 7-14 дней |
IEC Appliance Outlet F, mates to Felcom | запрос 7-14 дней |
6080G 24 Апр 2024 00:53 | запрос 7-14 дней |
6080P 24 Апр 2024 00:53 | запрос 7-14 дней |
6080WA 24 Апр 2024 00:53 | запрос 7-14 дней |
6080Z 24 Апр 2024 00:53 | запрос 7-14 дней |
T-1 Subminiature Lamps | запрос 7-14 дней |
SINGLE PHASE 6.0/8.0/10.0 AMPS. GLASS PASSIVATED BRIDGE RECTIFIERS | запрос 7-14 дней |
31 T-electron Раменское, Московская обл. Россия и страны СНГ | |
запрос | |
6080 20 Ноя 2023 00:56 | 519 ₽ склад 112 шт |
Кварц Z 4, 6080 20 Ноя 2023 00:56 | 35.0 ₽ да |
Еще 15 строк | |
1 736 ₽ склад 242 шт | |
1 736 ₽ склад 269 шт | |
973 ₽ склад 479 шт | |
1 336 ₽ склад 349 шт | |
BWU6080 20 Ноя 2023 00:56 | 31 960 ₽ склад 6 шт |
CPE6080 20 Ноя 2023 00:56 | 145 ₽ склад 289 шт |
TEL6080 20 Ноя 2023 00:56 | 2 868 ₽ склад 4 шт |
NOS6080 20 Ноя 2023 00:56 | 1 798 ₽ склад 10 шт |
Платамакетная6080 20 Ноя 2023 00:56 | 101 ₽ склад 9 шт |
NTE6080 20 Ноя 2023 00:56 | 198 ₽ склад 1192 шт |
6080CS 20 Ноя 2023 00:56 | 253 ₽ склад 242 шт |
SF6080 20 Ноя 2023 00:56 | 14 015 761 ₽ по запросу |
запрос да | |
63.0 ₽ до 5 дней | |
запрос склад 1 шт | |
32 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
MPP ARCA 6080 Монтажная панель перфорированная, оцинкованная сталь, для размера 600x800x300 - - 18 Апр 2024 04:45 108.18 | 149 ₽ Доставка: есть Самовывоз: есть на складе |
221 ₽ Доставка: есть Самовывоз: есть на складе | |
Заклепки пластиковые нейлоновые. Материал: нейлон PA66. Цвет: черный. ... Далее PR-6080-KЗаклепки пластиковые нейлоновые. Материал: нейлон PA66. Цвет: черный. D уст.отв = 6 мм, Толщина панели 4 - 5.5 мм. | 27 199 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 87 строк | |
Монтажная плата для Cubo N; материал: оцинкованная сталь; размеры: ... Далее NMP6080Монтажная плата для Cubo N; материал: оцинкованная сталь; размеры: 550x754x2 мм | 3 400 ₽ Доставка: есть Самовывоз: есть на складе |
Монтажная панель для Cubo N; материал: полиэстер; размеры: 556x754x4 ... Далее NGRMP6080Монтажная панель для Cubo N; материал: полиэстер; размеры: 556x754x4 мм | 5 875 ₽ Доставка: есть Самовывоз: есть на складе |
11 191 ₽ Доставка: есть Самовывоз: есть на складе | |
22 875 ₽ Доставка: есть Самовывоз: есть на складе | |
8 229 ₽ Доставка: есть Самовывоз: есть на складе | |
07-0660 | 55.0 ₽ Доставка: есть Самовывоз: есть на складе |
51 465 ₽ Доставка: есть Самовывоз: есть на складе | |
53 024 ₽ Доставка: есть Самовывоз: есть на складе | |
2 472 ₽ Доставка: есть Самовывоз: есть на складе | |
3 911 ₽ Доставка: есть Самовывоз: есть на складе | |
0.04кгаксиальное | 23.0 ₽ Доставка: есть Самовывоз: есть на складе |
0.22кгаксиалFORCEBERG диск | 1 905 ₽ Доставка: есть Самовывоз: есть на складе |
0.27кг-60~80Cаксиальное | 20.0 ₽ Доставка: есть Самовывоз: есть на складе |
12-6080 | 1 436 ₽ Доставка: есть Самовывоз: есть на складе |
Никелированный латунный кабельный ввод компрессионного типа, М16*1,5. ... Далее 1100.17.080Никелированный латунный кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, Диапазон кабеля 6,0~8,0мм ... | 322 ₽ Доставка: есть Самовывоз: есть на складе |
Никелированный латунный кабельный ввод компрессионного типа, М20*1,5. ... Далее 1100.20.080Никелированный латунный кабельный ввод компрессионного типа, М20*1,5. -40 +100С, IP68, IP69K, Ключ=24, H=21, L=10, Диапазон кабеля 6,0~8,0мм ... | 414 ₽ Доставка: есть Самовывоз: есть на складе |
-60~+80CГОСТ12172-74 Solins | 450 ₽ Доставка: есть Самовывоз: есть на складе |
33 ЗУМ-СМД Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 600 руб. | |
Светодиодные индикаторы / 1-разряд [FYS] 126.5mm OA Зелёный 30-60-80 ... Далее FYS-50011FUG-11Светодиодные индикаторы / 1-разряд [FYS] 126.5mm OA Зелёный 30-60-80 mcd 570nm | 65.3 ₽ от 600 ₽ склад 3 шт |
34 Ресторан Комплект Люберцы, Московская обл. Россия | |
... для тележек WLBAKE PF 2/6080/2 (без пола) купить в ... Далее Расстоечный шкаф и камера для тележек WLBAKE PF 2/6080/2 (без пола)✔ Расстоечный шкаф и камера для тележек WLBAKE PF 2/6080/2 (без пола) купить в интернет-магазине Ресторан Комплект ✔ Цена, ... | 855 669 ₽ на складе |
✔ Камера расстоечная WLBAKE PF 4/6080/2 без пола купить в ... Далее Камера расстоечная WLBAKE PF 4/6080/2 без пола✔ Камера расстоечная WLBAKE PF 4/6080/2 без пола купить в интернет-магазине Ресторан Комплект ✔ Цена, ... | 926 945 ₽ на складе |
✔ Шкаф расстоечный POLAIR СRP1.6080.T1inox купить в интернет-магазине ... Далее Шкаф расстоечный POLAIR СRP1.6080.T1inox✔ Шкаф расстоечный POLAIR СRP1.6080.T1inox купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, ... | 558 783 ₽ на складе |
Еще 25 строк | |
✔ Шкаф расстоечный POLAIR СRP1.6080.T2 inox купить в интернет- ... Далее Шкаф расстоечный POLAIR СRP1.6080.T2 inox✔ Шкаф расстоечный POLAIR СRP1.6080.T2 inox купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, ... | 613 440 ₽ на складе |
✔ Шкаф расстоечный POLAIR СRP2.6080.T2 inox купить в интернет- ... Далее Шкаф расстоечный POLAIR СRP2.6080.T2 inox✔ Шкаф расстоечный POLAIR СRP2.6080.T2 inox купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, ... | 639 495 ₽ на складе |
✔ Шкаф расстоечный POLAIR СRP2.6080.T4 inox купить в интернет- ... Далее Шкаф расстоечный POLAIR СRP2.6080.T4 inox✔ Шкаф расстоечный POLAIR СRP2.6080.T4 inox купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, ... | 958 626 ₽ на складе |
✔ Шкаф расстоечный POLAIR СRP2.6080.T6 inox купить в интернет- ... Далее Шкаф расстоечный POLAIR СRP2.6080.T6 inox✔ Шкаф расстоечный POLAIR СRP2.6080.T6 inox купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, ... | 1 269 117 ₽ на складе |
... товарные СКЕЙЛ СКЕ-Н-500-6080 купить в интернет-магазине Ресторан ... Далее Весы товарные СКЕЙЛ СКЕ-Н-500-6080✔ Весы товарные СКЕЙЛ СКЕ-Н-500-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 78 654 ₽ на складе |
... товарные СКЕЙЛ СКЕ-Н-300-6080 купить в интернет-магазине Ресторан ... Далее Весы товарные СКЕЙЛ СКЕ-Н-300-6080✔ Весы товарные СКЕЙЛ СКЕ-Н-300-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 78 654 ₽ на складе |
... Весы напольные MAS PM1HWS-300-6080 купить в интернет-магазине Ресторан ... Далее Весы напольные MAS PM1HWS-300-6080✔ Весы напольные MAS PM1HWS-300-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 84 780 ₽ на складе |
... Весы напольные MAS PM1HWS-500-6080 купить в интернет-магазине Ресторан ... Далее Весы напольные MAS PM1HWS-500-6080✔ Весы напольные MAS PM1HWS-500-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 84 780 ₽ на складе |
✔ Весы напольные MAS PM1E-500-6080 RS-232 купить в интернет- ... Далее Весы напольные MAS PM1E-500-6080 RS-232✔ Весы напольные MAS PM1E-500-6080 RS-232 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, ... | 30 840 ₽ на складе |
✔ Весы напольные MAS PM1H-300-6080 купить в интернет-магазине Ресторан ... Далее Весы напольные MAS PM1H-300-6080✔ Весы напольные MAS PM1H-300-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 44 100 ₽ на складе |
✔ Весы напольные MAS PM1H-500-6080 купить в интернет-магазине Ресторан ... Далее Весы напольные MAS PM1H-500-6080✔ Весы напольные MAS PM1H-500-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 44 100 ₽ на складе |
✔ Весы напольные MAS PM1B-300-6080 купить в интернет-магазине Ресторан ... Далее Весы напольные MAS PM1B-300-6080✔ Весы напольные MAS PM1B-300-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 30 900 ₽ на складе |
✔ Весы напольные MAS PM1B-500-6080 купить в интернет-магазине Ресторан ... Далее Весы напольные MAS PM1B-500-6080✔ Весы напольные MAS PM1B-500-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 30 900 ₽ на складе |
✔ Весы напольные MAS PM1E-300-6080 купить в интернет-магазине Ресторан ... Далее Весы напольные MAS PM1E-300-6080✔ Весы напольные MAS PM1E-300-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 29 280 ₽ на складе |
✔ Весы напольные MAS PM1E-500-6080 купить в интернет-магазине Ресторан ... Далее Весы напольные MAS PM1E-500-6080✔ Весы напольные MAS PM1E-500-6080 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, ... | 29 280 ₽ на складе |
✔ Шкаф ротационный REAL FORNI Boss 60.80 купить в интернет-магазине ... Далее Шкаф ротационный REAL FORNI Boss 60.80✔ Шкаф ротационный REAL FORNI Boss 60.80 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, руководство. ... | 1 139 050 ₽ на складе |
✔ Шкаф ротационный REAL FORNI Boss 60.80 R купить в интернет-магазине ... Далее Шкаф ротационный REAL FORNI Boss 60.80 R✔ Шкаф ротационный REAL FORNI Boss 60.80 R купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, руководство ... | 1 934 587 ₽ на складе |
35 Кремний Санкт-Петербург Россия и страны СНГ | |
0034.6080 24 Апр 2024 00:53 | запрос 7-14 дней |
6080 ;TO263-5/A 24 Апр 2024 00:53 | запрос 7-14 дней |
Еще 16 строк | |
6080-0 24 Апр 2024 00:53 | запрос 7-14 дней |
6080-2 24 Апр 2024 00:53 | запрос 7-14 дней |
84854-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
PGC-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
22-28-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
22-43-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
35505-6080-A00 GF 24 Апр 2024 00:53 | запрос 7-14 дней |
35805-6080-A00 GF 24 Апр 2024 00:53 | запрос 7-14 дней |
MLX22-28-6080 24 Апр 2024 00:53 | запрос 7-14 дней |
MMM35505-6080-A00 GF 24 Апр 2024 00:53 | запрос 7-14 дней |
MMM35805-6080-A00 GF 24 Апр 2024 00:53 | запрос 7-14 дней |
DRR-DTH 60-80 24 Апр 2024 00:53 | запрос 7-14 дней |
DRT-DTH 60-80 24 Апр 2024 00:53 | запрос 7-14 дней |
MAN6080 24 Апр 2024 00:53 | запрос 7-14 дней |
PD6080 24 Апр 2024 00:53 | запрос 7-14 дней |
SPC6080 24 Апр 2024 00:53 | запрос 7-14 дней |
36 Зенер Москва Россия и страны ТС | |
PLUG BANANA STD INSULATED RED | 618 ₽ от 1 шт 5-15 дней склад 560 шт |
Еще 6 цен: … 346 ₽ | |
543 ₽ от 25 шт 5-15 дней склад 560 шт | |
494 ₽ от 100 шт 5-15 дней склад 560 шт | |
475 ₽ от 250 шт 5-15 дней склад 560 шт | |
444 ₽ от 500 шт 5-15 дней склад 560 шт | |
376 ₽ от 1000 шт 5-15 дней склад 560 шт | |
346 ₽ от 2500 шт 5-15 дней склад 560 шт | |
2.92MM MALE TO SMP MALE ADAPTER, | запрос 5-15 дней склад 27 шт |
AUDIO PIEZO TRANSDUCER 50V CHAS | запрос 5-15 дней склад 720 шт |
Еще 16 строк | |
PWR ENT MOD RCPT IEC320-C14 PNL | запрос 5-15 дней |
CAP TANT 12UF 5% 20V AXIAL | запрос 5-15 дней |
CONN SKT 2.2-3MM CLEAR WIREMNT | запрос 5-15 дней склад 99 шт |
CONN SKT 2.2-3MM CLEAR | 701 ₽ от 1 шт 5-15 дней склад 9 шт |
Еще 8 цен: … 388 ₽ | |
634 ₽ от 10 шт 5-15 дней склад 9 шт | |
598 ₽ от 25 шт 5-15 дней склад 9 шт | |
584 ₽ от 50 шт 5-15 дней склад 9 шт | |
555 ₽ от 100 шт 5-15 дней склад 9 шт | |
496 ₽ от 250 шт 5-15 дней склад 9 шт | |
467 ₽ от 500 шт 5-15 дней склад 9 шт | |
409 ₽ от 1000 шт 5-15 дней склад 9 шт | |
388 ₽ от 2500 шт 5-15 дней склад 9 шт | |
CONN SKT 2.2-3MM CLEAR PNLMNT | запрос 5-15 дней склад 12 шт |
CONN HEADER 8POS 2.5MM VERT TIN | запрос 5-15 дней |
CBL GRP 6.0-8.0 CD NPT 1/2" | запрос 5-15 дней |
CBL GRP 6.0-8.0 CD NPT 3/8" | запрос 5-15 дней |
CBL GRP 6.0-8.0 CD PG 9 | запрос 5-15 дней |
CBL GRP 6.0-8.0 CD PG 13 | запрос 5-15 дней |
CBL GRP 6.0-8.0 CD PG 16 | запрос 5-15 дней |
CBL GRP 6.0-8.0 MM CD M16X1.5 | запрос 5-15 дней |
CBL GRP 6.0-8.0 MM CD M20X1.5 | запрос 5-15 дней |
CONN WIRE SEAL M12 6.0-8.0MM | запрос 5-15 дней |
37 ЭКиТ Москва Россия Только юр.лица Безнал. расчет Филиалы: Санкт-Петербург Ростов-на-Дону Челябинск | |
Заклепки пластиковые нейлоновые. Материал: нейлон PA66. Цвет: черный. ... Далее PR-6080-KЗаклепки пластиковые нейлоновые. Материал: нейлон PA66. Цвет: черный. D уст.отв = 6 мм, Толщина панели 4 - 5.5 мм. | 21 001 ₽ |
Никелированный латунный кабельный ввод компрессионного типа, М16*1,5. ... Далее 1100.17.080Никелированный латунный кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, Диапазон кабеля 6,0~8,0мм ... | 246 ₽ склад 66 шт |
Никелированный латунный кабельный ввод компрессионного типа, М20*1,5. ... Далее 1100.20.080Никелированный латунный кабельный ввод компрессионного типа, М20*1,5. -40 +100С, IP68, IP69K, Ключ=24, H=21, L=10, Диапазон кабеля 6,0~8,0мм ... | 318 ₽ склад 7 шт |
38 Десси Москва Россия | |
Для тех, кто записывает лекции, ведет заметки от руки, ведет записи на ... Далее MT6080 - Цифровая авторучкаДля тех, кто записывает лекции, ведет заметки от руки, ведет записи на переговорах и т.д.. Все, что Вы запишете на бумаге с помощью этой ... | 13 500 ₽ |
Драйвер для светодиодных светильников AC220V /60-80W/x2 с Bluetooth 02 Апр 2024 09:03 | 1 018 ₽ |
39 PL-1 Москва Россия | |
790 ₽ от 1 шт да | |
Еще 4 цен: … 645 ₽ | |
752 ₽ от 3000 ₽ да | |
718 ₽ от 6000 ₽ да | |
682 ₽ от 2 шт да | |
645 ₽ от 4 шт да | |
40 Берёзка Электронные Компоненты Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
SMD (7х5х2 мм) белая матовая; цвет - красный (660нм) / зелёный (570 нм ... Далее FYL-2519SGWSMD (7х5х2 мм) белая матовая; цвет - красный (660нм) / зелёный (570 нм), яркость 8/13 мкд; I прямой/макс. 25(30) мА / 150 мА, U прямое/макс. ... | 10.6 ₽ розница 1 рабочий день склад 1389 шт |
Еще 3 цен: … 8.88 ₽ | |
9.78 ₽ мелкий опт 1 рабочий день склад 1389 шт | |
9.18 ₽ средний опт 1 рабочий день склад 1389 шт | |
8.88 ₽ крупный опт 1 рабочий день склад 1389 шт | |
126.5mm OA Зелёный 30-60-80 mcd 570nm | 811 ₽ розница 2-3 рабочих дня склад 14 шт |
Еще 3 цен: … 737 ₽ | |
774 ₽ мелкий опт 2-3 рабочих дня склад 14 шт | |
750 ₽ средний опт 2-3 рабочих дня склад 14 шт | |
737 ₽ крупный опт 2-3 рабочих дня склад 14 шт | |
41 ICdarom.ru Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
SMD (7х5х2 мм) белая матовая; цвет - красный (660нм) / зелёный (570 нм ... Далее FYL-2519SGWSMD (7х5х2 мм) белая матовая; цвет - красный (660нм) / зелёный (570 нм), яркость 8/13 мкд; I прямой/макс. 25(30) мА / 150 мА, U прямое/макс. ... | 7.68 ₽ розница 1 рабочий день склад 1413 шт |
Еще 3 цен: … 6.96 ₽ | |
7.38 ₽ мелкий опт 1 рабочий день склад 1413 шт | |
7.08 ₽ средний опт 1 рабочий день склад 1413 шт | |
6.96 ₽ крупный опт 1 рабочий день склад 1413 шт | |
126.5mm OA Зелёный 30-60-80 mcd 570nm | 797 ₽ розница 2-3 рабочих дня склад 14 шт |
Еще 3 цен: … 725 ₽ | |
761 ₽ мелкий опт 2-3 рабочих дня склад 14 шт | |
737 ₽ средний опт 2-3 рабочих дня склад 14 шт | |
725 ₽ крупный опт 2-3 рабочих дня склад 14 шт | |
42 AliExpress Китай Весь мир | |
1 354 ₽ от 21 дня | |
1 356 ₽ от 21 дня | |
3 026 ₽ от 21 дня | |
Еще 3 строки | |
1 308 ₽ от 21 дня | |
17.3 ₽ от 21 дня |
Искать "6080" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 93.2519 |
EUR | 99.3648 |
