1 Flash-Turtle Китай Весь мир | |
8 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.138 ( ... Далее 1776099-88 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.138 (3.50mm) Vertical Through Hole | запрос 7 дней склад 10268 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.138 ( ... Далее 1776134-88 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.138 (3.50mm) 90°, Right Angle Through Hole | запрос 7 дней склад 10768 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.200 ( ... Далее 1776139-88 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.200 (5.08mm) Vertical Through Hole | запрос 7 дней склад 40341 шт |
Еще 14 строк | |
8 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.200 ( ... Далее 1776141-88 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.200 (5.08mm) 90°, Right Angle Through Hole | запрос 7 дней склад 41255 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.295 ( ... Далее 1776149-88 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.295 (7.50mm) Vertical Through Hole | запрос 7 дней склад 37009 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.200 ( ... Далее 284008-88 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.200 (5.08mm) 90°, Right Angle Through Hole | запрос 7 дней склад 33045 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 ( ... Далее EDSTL950/88 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 (5.00mm) 90°, Right Angle Solder | запрос 7 дней склад 21992 шт |
16 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 ... Далее 1776166-816 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 (5.00mm) 90°, Right Angle Through Hole | запрос 7 дней склад 6483 шт |
96 Position Din Connector Plug, Male Pins Gold or Gold-Palladium ... Далее 8-1393644-796 Position Din Connector Plug, Male Pins Gold or Gold-Palladium Through Hole, Right Angle | запрос 7 дней склад 23851 шт |
96 Position Shroud for Male Pins Connector Gray Through Hole DIN 41612 ... Далее 533236-896 Position Shroud for Male Pins Connector Gray Through Hole DIN 41612, Type C, Type R | запрос 7 дней склад 28238 шт |
TE Connectivity Aerospace, Defense and Marine 66256-8 TE Connectivity Aerospace, Defense and Marine - 14 Мар 2024 10:03 Pin Contact Tin Crimp 12-16 AWG Power, Stamped | запрос 7 дней склад 16127 шт |
2 kOhms 0.75W, 3/4W PC Pins Through Hole Trimmer Potentiometer Cermet ... Далее TE Connectivity Passive Product 1623866-82 kOhms 0.75W, 3/4W PC Pins Through Hole Trimmer Potentiometer Cermet 15.0 Turn Side Adjustment | запрос 7 дней склад 21519 шт |
Contact Crimp Pin Tin-Lead | запрос 7 дней склад 32185 шт |
Pin Contact Silver 18.5-20 AWG Crimp Stamped | запрос 7 дней склад 19636 шт |
TE Connectivity Aerospace, Defense and Marine 5225550-8 TE Connectivity Aerospace, Defense and Marine - 14 Мар 2024 10:03 TNC Connector Plug, Male Pin | запрос 7 дней склад 7543 шт |
16 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.150 ... Далее EDSTLZ1570/816 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.150 (3.81mm) 90°, Right Angle Solder | запрос 7 дней склад 49661 шт |
16 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 ... Далее EDSTL971/816 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 (5.00mm) 90°, Right Angle Solder | запрос 7 дней склад 8214 шт |
2 ChipWorker Китай Весь мир | |
192 ₽ 2-7 дней отгрузка со склада в Китае склад 50 шт | |
834 ₽ 2-7 дней отгрузка со склада в Китае склад 1641 шт | |
564 ₽ 2-7 дней отгрузка со склада в Китае склад 216 шт | |
3 AiPCBA Китай Весь мир | |
4 Akcel Китай Весь мир | |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос от 1 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC Tube | запрос от 1 шт |
Еще 162 строки | |
Power to the Board MATENLOK PIN | запрос от 1 шт |
CONN HEADER PIN 10POS VERT GOLD | 1 619 ₽ от 1 шт 5-7 дней склад 220 шт |
Еще 3 цен: … 1 359 ₽ | |
1 527 ₽ от 10 шт 5-7 дней склад 220 шт | |
1 440 ₽ от 100 шт 5-7 дней склад 220 шт | |
1 359 ₽ от 1000 шт 5-7 дней склад 220 шт | |
CONN PIN RCPT .034-.041 SOLDER | 68.9 ₽ от 1 шт 5-7 дней склад 19735 шт |
Еще 3 цен: … 57.8 ₽ | |
65.0 ₽ от 10 шт 5-7 дней склад 19735 шт | |
61.3 ₽ от 100 шт 5-7 дней склад 19735 шт | |
57.8 ₽ от 1000 шт 5-7 дней склад 19735 шт | |
High Speed / Modular Connectors HDI PIN ASSY 3 ROW 1 120 | запрос от 1 шт |
Headers & Wire Housings MINI BX PIN HDR ASY 110 POS RA | запрос от 1 шт |
CONN HEADER PIN 18POS VERT GOLD | запрос от 1 шт |
D-Sub Contacts AMPLI PIN CONT SZ 22 | 767 ₽ от 1 шт 5-7 дней склад 500 шт |
Еще 3 цен: … 644 ₽ | |
724 ₽ от 10 шт 5-7 дней склад 500 шт | |
683 ₽ от 100 шт 5-7 дней склад 500 шт | |
644 ₽ от 1000 шт 5-7 дней склад 500 шт | |
Headers & Wire Housings 08P AMPMODU II PIN HDR. | запрос от 1 шт |
Standard Circular Contacts TYPE III + PIN 30-26 Reel of 1000 | запрос от 1 шт |
Standard Circular Contacts III+ PIN,24-20, Cut Strip of 100 | запрос от 1 шт |
Standard Circular Contacts PIN 18-14 BR/SN SIG Reel of 1000 | запрос от 1 шт |
Mechanical Encoder Rotary Incremental Flat Straight Quadrature Digital ... Далее 8-1879323-9Mechanical Encoder Rotary Incremental Flat Straight Quadrature Digital Square Wave 20PPR Through Hole PC Pin | запрос от 1 шт |
5 Utmel Китай Весь мир | |
... , 5 - 8 mm² Wire Size, Wire & Cable, Crimp, Power, Pin, AMP POWERBAND Далее 213841-8Power Contacts, Contact, 600 VAC, 600 VDC, Gold, 10 - 8 AWG Wire Size, 5 - 8 mm² Wire Size, Wire & Cable, Crimp, Power, Pin, AMP POWERBAND | запрос от 1 шт 5-7 дней склад 1161 шт |
8.0MM PIN CONTACT ASM 25MM2 | 2 369 ₽ от 1 шт 5-7 дней склад 4 шт |
Еще 3 цен: … 1 989 ₽ | |
2 235 ₽ от 10 шт 5-7 дней склад 4 шт | |
2 108 ₽ от 100 шт 5-7 дней склад 4 шт | |
1 989 ₽ от 1000 шт 5-7 дней склад 4 шт | |
8.0MM PIN INSULATION | 723 ₽ от 1 шт 5-7 дней склад 108 шт |
Еще 3 цен: … 607 ₽ | |
682 ₽ от 10 шт 5-7 дней склад 108 шт | |
644 ₽ от 100 шт 5-7 дней склад 108 шт | |
607 ₽ от 1000 шт 5-7 дней склад 108 шт | |
Еще 96 строк | |
8.0MM PIN CONTACT ASM 35MM2 | 2 369 ₽ от 1 шт 5-7 дней склад 15 шт |
2 235 ₽ от 10 шт 5-7 дней склад 15 шт | |
2 108 ₽ от 100 шт 5-7 дней склад 15 шт | |
1 989 ₽ от 1000 шт 5-7 дней склад 15 шт | |
8.0MM PIN CONTACT ASM 50MM2 | 2 369 ₽ от 1 шт 5-7 дней склад 9 шт |
2 235 ₽ от 10 шт 5-7 дней склад 9 шт | |
2 108 ₽ от 100 шт 5-7 дней склад 9 шт | |
1 989 ₽ от 1000 шт 5-7 дней склад 9 шт | |
Hall Effect Sensor 40mA Unipolar 1.8V/2.5V/3.3V/5V/9V/12V/15V/18V/24V ... Далее 103SR13A-8Hall Effect Sensor 40mA Unipolar 1.8V/2.5V/3.3V/5V/9V/12V/15V/18V/24V 3-Pin | запрос от 1 шт 5-7 дней склад 3265 шт |
PINCER GRAY 0.032 PIN | 712 ₽ от 1 шт 5-7 дней склад 56 шт |
Еще 3 цен: … 598 ₽ | |
672 ₽ от 10 шт 5-7 дней склад 56 шт | |
634 ₽ от 100 шт 5-7 дней склад 56 шт | |
598 ₽ от 1000 шт 5-7 дней склад 56 шт | |
Module DC-DC 4-OUT 12V/12V/12V/12V 0.7A/0.7A/0.7A/0.7A 35W 17-Pin | 12 576 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 10 559 ₽ | |
11 864 ₽ от 10 шт 5-7 дней склад 1 шт | |
11 193 ₽ от 100 шт 5-7 дней склад 1 шт | |
10 559 ₽ от 1000 шт 5-7 дней склад 1 шт | |
Mechanical Encoder Rotary Flat 16oz.in Straight BCD 8PPR Through Hole ... Далее 513360-8Mechanical Encoder Rotary Flat 16oz.in Straight BCD 8PPR Through Hole PC Pins | запрос от 1 шт 5-7 дней склад 3766 шт |
Crimp Wire Pins, Tabs & Ferrules, Ferrule, 14 AWG Wire Size, 2.5 mm² ... Далее 966289-8Crimp Wire Pins, Tabs & Ferrules, Ferrule, 14 AWG Wire Size, 2.5 mm² Wire Size, 2583 - 3257 CMA Wire Size, .164 in [4.2 mm] Barrel Inside ... | запрос от 1 шт 5-7 дней склад 6633 шт |
FFC Connectors, Header, Wire-to-Board, 14 Position, 2.54 mm [.1 in] ... Далее 1888292-8FFC Connectors, Header, Wire-to-Board, 14 Position, 2.54 mm [.1 in] Centerline, 2 Row, Right Angle, Pin, Package, Mating Retention | запрос от 1 шт 5-7 дней склад 1248 шт |
Barrier Strips, Dual Barrier, Printed Circuit Pin, Wire-to-Board, 4 ... Далее 796985-8Barrier Strips, Dual Barrier, Printed Circuit Pin, Wire-to-Board, 4 Position, 9.53 mm [.375 in] Centerline, 1 Row, 300 V / 600 V | запрос от 1 шт 5-7 дней склад 4264 шт |
Standard Circular Connectors, Stainless Steel, N Polarization Code, ... Далее FDBA 50-8 E1 PN 090 A838Standard Circular Connectors, Stainless Steel, N Polarization Code, Square Flange Receptacle, Pin, -55 - 200 °C, DEUTSCH FDBA | запрос от 1 шт 5-7 дней склад 2476 шт |
Pin Sockets, Socket Length 6.53 mm [.257 in], PCB Hole Diameter .062 ... Далее 5050864-8Pin Sockets, Socket Length 6.53 mm [.257 in], PCB Hole Diameter .062 in [1.57 mm], Open Bottom, .326 - .518 mm² Wire Size, 22 - 20 AWG Wire ... | запрос от 1 шт 5-7 дней склад 1473 шт |
Connector Contacts, Pin, Gold Flash, Gold Flash, 250 VAC, Locking ... Далее 207438-8Connector Contacts, Pin, Gold Flash, Gold Flash, 250 VAC, Locking Lance Contact Retention, Discrete Wire, 28 - 22 AWG Wire Size | запрос от 1 шт 5-7 дней склад 3659 шт |
Power Contacts, Contact, Gold, 32 AWG Wire Size, .03 mm² Wire Size, ... Далее 66460-8Power Contacts, Contact, Gold, 32 AWG Wire Size, .03 mm² Wire Size, Wire & Cable, Wire Wrap, Power & Signal, Pin, AMP Type III+ | запрос от 1 шт 5-7 дней склад 6270 шт |
Connector Contact, Pin, Wire-to-Board, Gold, Reel, Printed Circuit ... Далее 215345-8Connector Contact, Pin, Wire-to-Board, Gold, Reel, Printed Circuit Board, 3 A, Signal, Board Mount, -85 - 221 °F [-65 - 125 °C], ... | запрос от 1 шт 5-7 дней склад 3849 шт |
Automotive Terminals, Socket, Pin Diameter .051 in [1.3 mm], 20 - 22 ... Далее 770520-8Automotive Terminals, Socket, Pin Diameter .051 in [1.3 mm], 20 - 22 AWG Wire Size, .35 - .5 mm² Wire Size, Family Seal, Locking On the ... | запрос от 1 шт 5-7 дней склад 2233 шт |
Connector Contact, Pin, Tin-Lead, Straight, Printed Circuit Board, 5 A ... Далее 85842-8Connector Contact, Pin, Tin-Lead, Straight, Printed Circuit Board, 5 A, -65 - 60 °C, AMPMODU MOD 1 | запрос от 1 шт 5-7 дней склад 5226 шт |
Barrier Strips, Tri-Barrier, Printed Circuit Pin, Wire-to-Board, 20 ... Далее 8-1546158-0Barrier Strips, Tri-Barrier, Printed Circuit Pin, Wire-to-Board, 20 Position, 9.53 mm [.375 in] Centerline, 1 Row, 300 V / 600 V | запрос от 1 шт 5-7 дней склад 3179 шт |
6 ТМ Электроникс Санкт-Петербург Россия | |
... -MaTch; гнездо; "мама"; PIN: 8; SMT; на PCB; Конф: 2x4 ... Далее 8-2823056-8Micro-MaTch; гнездо; "мама"; PIN: 8; SMT; на PCB; Конф: 2x4; прямой | 290 ₽ от 900 шт 5-10 дней склад 2700 шт |
279 ₽ от 2700 шт 5-10 дней склад 2700 шт | |
... -MaTch; гнездо; "мама"; PIN: 8; THT; на PCB; Конф: 2x4 ... Далее 2178710-8Micro-MaTch; гнездо; "мама"; PIN: 8; THT; на PCB; Конф: 2x4; прямой | 58.0 ₽ от 350 шт 5-10 дней склад 20000 шт |
Еще 3 цен: … 53.7 ₽ | |
55.6 ₽ от 1750 шт 5-10 дней склад 20000 шт | |
54.8 ₽ от 6650 шт 5-10 дней склад 20000 шт | |
53.7 ₽ от 12600 шт 5-10 дней склад 20000 шт | |
... -MaTch; гнездо; "мама"; PIN: 8; SMT; на PCB; Конф: 2x4 ... Далее 2178711-8Micro-MaTch; гнездо; "мама"; PIN: 8; SMT; на PCB; Конф: 2x4; прямой | 181 ₽ от 56 шт 5-10 дней склад 5595 шт |
Еще 2 цен: … 144 ₽ | |
154 ₽ от 2700 шт 5-10 дней склад 5595 шт | |
144 ₽ от 7200 шт 5-10 дней склад 5595 шт | |
Еще 132 строки | |
... -MaTch; вилка; "папа"; PIN: 8; IDC; на шлейф; Конф: 2x4 ... Далее 2178712-8Micro-MaTch; вилка; "папа"; PIN: 8; IDC; на шлейф; Конф: 2x4; 1,27мм | 67.5 ₽ от 2500 шт 5-10 дней склад 21278 шт |
Еще 2 цен: … 63.8 ₽ | |
65.4 ₽ от 5000 шт 5-10 дней склад 21278 шт | |
63.8 ₽ от 10000 шт 5-10 дней склад 21278 шт | |
Micro-MaTch; переходник; PIN: 8; IDC,THT; на PCB,на ... Далее 2178713-8Micro-MaTch; переходник; PIN: 8; IDC,THT; на PCB,на шлейф; 1,27мм | 50.3 ₽ от 179 шт 5-10 дней склад 14821 шт |
Еще 4 цен: … 42.8 ₽ | |
48.4 ₽ от 4000 шт 5-10 дней склад 14821 шт | |
46.3 ₽ от 8000 шт 5-10 дней склад 14821 шт | |
44.4 ₽ от 21000 шт 5-10 дней склад 14821 шт | |
42.8 ₽ от 64000 шт 5-10 дней склад 14821 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 14; THT; на PCB; Конф: 2x7 | 646 ₽ от 1 шт 5-10 дней склад 1563 шт |
Еще 4 цен: … 471 ₽ | |
576 ₽ от 10 шт 5-10 дней склад 1563 шт | |
521 ₽ от 100 шт 5-10 дней склад 1563 шт | |
518 ₽ от 250 шт 5-10 дней склад 1563 шт | |
471 ₽ от 500 шт 5-10 дней склад 1563 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 16; THT; на PCB; Конф: 2x8 ... Далее 8-215460-6Micro-MaTch; гнездо; "мама"; PIN: 16; THT; на PCB; Конф: 2x8; 1,27мм | 640 ₽ от 250 шт 5-10 дней склад 3910 шт |
Еще 4 цен: … 399 ₽ | |
592 ₽ от 500 шт 5-10 дней склад 3910 шт | |
489 ₽ от 1 шт 5-10 дней склад 3910 шт | |
448 ₽ от 10 шт 5-10 дней склад 3910 шт | |
399 ₽ от 100 шт 5-10 дней склад 3910 шт | |
Micro-MaTch; гнездо; "папа"; PIN: 10; THT; на PCB; 1,5А; ... Далее 8-215464-0Micro-MaTch; гнездо; "папа"; PIN: 10; THT; на PCB; 1,5А; Конф: 2x5 | 816 ₽ от 1 шт 5-10 дней склад 517 шт |
Еще 4 цен: … 362 ₽ | |
715 ₽ от 5 шт 5-10 дней склад 517 шт | |
526 ₽ от 20 шт 5-10 дней склад 517 шт | |
428 ₽ от 100 шт 5-10 дней склад 517 шт | |
362 ₽ от 250 шт 5-10 дней склад 517 шт | |
Micro-MaTch; гнездо; "папа"; PIN: 12; THT; на PCB; 1,5А; ... Далее 8-215464-2Micro-MaTch; гнездо; "папа"; PIN: 12; THT; на PCB; 1,5А; Конф: 2x6 | 649 ₽ от 1 шт 5-10 дней склад 1381 шт |
Еще 4 цен: … 290 ₽ | |
558 ₽ от 5 шт 5-10 дней склад 1381 шт | |
423 ₽ от 20 шт 5-10 дней склад 1381 шт | |
346 ₽ от 100 шт 5-10 дней склад 1381 шт | |
290 ₽ от 250 шт 5-10 дней склад 1381 шт | |
Micro-MaTch; гнездо; "папа"; PIN: 14; THT; на PCB; 1,5А; ... Далее 8-215464-4Micro-MaTch; гнездо; "папа"; PIN: 14; THT; на PCB; 1,5А; Конф: 2x7 | 598 ₽ от 1 шт 5-10 дней склад 1324 шт |
Еще 4 цен: … 457 ₽ | |
532 ₽ от 10 шт 5-10 дней склад 1324 шт | |
502 ₽ от 250 шт 5-10 дней склад 1324 шт | |
481 ₽ от 100 шт 5-10 дней склад 1324 шт | |
457 ₽ от 500 шт 5-10 дней склад 1324 шт | |
Micro-MaTch; гнездо; "папа"; PIN: 16; THT; на PCB; 1,5А; ... Далее 8-215464-6Micro-MaTch; гнездо; "папа"; PIN: 16; THT; на PCB; 1,5А; Конф: 2x8 | 622 ₽ от 1 шт 5-10 дней склад 427 шт |
Еще 4 цен: … 453 ₽ | |
554 ₽ от 10 шт 5-10 дней склад 427 шт | |
500 ₽ от 100 шт 5-10 дней склад 427 шт | |
498 ₽ от 250 шт 5-10 дней склад 427 шт | |
453 ₽ от 500 шт 5-10 дней склад 427 шт | |
Micro-MaTch; переходник; PIN: 10; IDC,THT; на PCB,на шлейф; 1,27мм | 510 ₽ от 1 шт 5-10 дней склад 1025 шт |
Еще 4 цен: … 226 ₽ | |
441 ₽ от 5 шт 5-10 дней склад 1025 шт | |
330 ₽ от 20 шт 5-10 дней склад 1025 шт | |
266 ₽ от 100 шт 5-10 дней склад 1025 шт | |
226 ₽ от 250 шт 5-10 дней склад 1025 шт | |
Micro-MaTch; переходник; PIN: 12; IDC,THT; на PCB,на шлейф; 1,27мм | 529 ₽ от 1 шт 5-10 дней склад 294 шт |
Еще 4 цен: … 335 ₽ | |
481 ₽ от 5 шт 5-10 дней склад 294 шт | |
433 ₽ от 20 шт 5-10 дней склад 294 шт | |
383 ₽ от 100 шт 5-10 дней склад 294 шт | |
335 ₽ от 250 шт 5-10 дней склад 294 шт | |
Micro-MaTch; переходник; PIN: 14; IDC,THT; на PCB,на шлейф; 1,27мм | 697 ₽ от 1 шт 5-10 дней склад 1957 шт |
Еще 4 цен: … 560 ₽ | |
620 ₽ от 10 шт 5-10 дней склад 1957 шт | |
617 ₽ от 25 шт 5-10 дней склад 1957 шт | |
611 ₽ от 50 шт 5-10 дней склад 1957 шт | |
560 ₽ от 100 шт 5-10 дней склад 1957 шт | |
Micro-MaTch; переходник; PIN: 16; IDC,THT; на PCB,на шлейф; 1,27мм | 816 ₽ от 1 шт 5-10 дней склад 41 шт |
705 ₽ от 5 шт 5-10 дней склад 41 шт | |
524 ₽ от 20 шт 5-10 дней склад 41 шт | |
425 ₽ от 100 шт 5-10 дней склад 41 шт | |
362 ₽ от 250 шт 5-10 дней склад 41 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 12; THT; на PCB; Конф: 2x6 ... Далее 8-215079-2Micro-MaTch; гнездо; "мама"; PIN: 12; THT; на PCB; Конф: 2x6; прямой | 468 ₽ от 1 шт 5-10 дней склад 52 шт |
Еще 4 цен: … 342 ₽ | |
429 ₽ от 10 шт 5-10 дней склад 52 шт | |
382 ₽ от 100 шт 5-10 дней склад 52 шт | |
376 ₽ от 250 шт 5-10 дней склад 52 шт | |
342 ₽ от 500 шт 5-10 дней склад 52 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 16; THT; на PCB; Конф: 2x8 ... Далее 8-215079-6Micro-MaTch; гнездо; "мама"; PIN: 16; THT; на PCB; Конф: 2x8; прямой | 585 ₽ от 1 шт 5-10 дней склад 588 шт |
Еще 4 цен: … 427 ₽ | |
522 ₽ от 10 шт 5-10 дней склад 588 шт | |
472 ₽ от 100 шт 5-10 дней склад 588 шт | |
469 ₽ от 250 шт 5-10 дней склад 588 шт | |
427 ₽ от 500 шт 5-10 дней склад 588 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 10; SMT; на PCB; Конф: 2x5 ... Далее 8-2823056-0Micro-MaTch; гнездо; "мама"; PIN: 10; SMT; на PCB; Конф: 2x5; прямой | 247 ₽ от 900 шт 5-10 дней склад 4500 шт |
Micro-MaTch; гнездо; "мама"; PIN: 12; SMT; на PCB; Конф: 2x6 ... Далее 8-2823056-2Micro-MaTch; гнездо; "мама"; PIN: 12; SMT; на PCB; Конф: 2x6; прямой | 221 ₽ от 900 шт 5-10 дней склад 1800 шт |
207 ₽ от 1800 шт 5-10 дней склад 1800 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 6; SMT; на PCB; Конф: 2x3; ... Далее 8-2823056-6Micro-MaTch; гнездо; "мама"; PIN: 6; SMT; на PCB; Конф: 2x3; прямой | 399 ₽ от 900 шт 5-10 дней склад 1800 шт |
338 ₽ от 1800 шт 5-10 дней склад 1800 шт | |
7 Acme Chip Китай Весь мир | |
Current Mode PWM Controller 0V to 30V 200mA 500kHz 8-Pin SOIC T/R | запрос 7 дней склад 1663 шт |
Current Mode PWM Controller 0V to 30V 200mA 500kHz 8-Pin SOIC T/R | запрос 7 дней склад 2538 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 661 шт |
Еще 13 строк | |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC Tube | запрос 7 дней склад 2582 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 1783 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 409 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC Tube | запрос 7 дней склад 830 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 1365 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC Tube | запрос 7 дней склад 1870 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 1159 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 2489 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 2398 шт |
DIP-8 | запрос 7 дней |
Transistor X Band, Gaas, N-channel, Rf Power, Mosfet, Hermetic Sealed, ... Далее TIM8596-8Transistor X Band, Gaas, N-channel, Rf Power, Mosfet, Hermetic Sealed, 2-11C1B, 2 Pin, Fet Rf Power | запрос 7 дней склад 5365 шт |
TRANSISTOR X BAND, GaAs, N-CHANNEL, RF POWER, MOSFET, HERMETIC SEALED, ... Далее TIM0910-8TRANSISTOR X BAND, GaAs, N-CHANNEL, RF POWER, MOSFET, HERMETIC SEALED, 2-11C1B, 2 PIN, FET RF Power | запрос 7 дней склад 2764 шт |
DRAM Chip Mobile SDRAM 256M-Bit 8Mx32 3.3V 90-Pin VFBGA Tray | запрос 7 дней склад 7664 шт |
8 Онлайн Компоненты Москва Россия | |
... CONNECTIVITY - 826629-8 - Pin Header, Board- ... ряд(-ов), 8 контакт(-ов), ... Далее 826629-8AMP - TE CONNECTIVITY - 826629-8 - Pin Header, Board-to-Board, 2.54 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Straight | 374 ₽ от 1 шт 5-12 дней склад 875 шт |
Еще 5 цен: … 237 ₽ | |
328 ₽ от 10 шт 5-12 дней склад 875 шт | |
287 ₽ от 100 шт 5-12 дней склад 875 шт | |
251 ₽ от 500 шт 5-12 дней склад 875 шт | |
241 ₽ от 1000 шт 5-12 дней склад 875 шт | |
237 ₽ от 2500 шт 5-12 дней склад 875 шт | |
AMP - TE CONNECTIVITY - 1586037-8 - Pin Header, вертикальный, Wire-to- ... Далее 1586037-8AMP - TE CONNECTIVITY - 1586037-8 - Pin Header, вертикальный, Wire-to-Board, 4.2 мм, 2 ряд(-ов), 8 контакт(-ов), Through Hole Straight | 144 ₽ от 10 шт 5-12 дней склад 3239 шт |
Еще 5 цен: … 89.3 ₽ | |
122 ₽ от 50 шт 5-12 дней склад 3239 шт | |
100 ₽ от 100 шт 5-12 дней склад 3239 шт | |
98.0 ₽ от 250 шт 5-12 дней склад 3239 шт | |
95.4 ₽ от 500 шт 5-12 дней склад 3239 шт | |
89.3 ₽ от 1500 шт 5-12 дней склад 3239 шт | |
... CONNECTIVITY - 292175-8 - Pin Header, Wire- ... ряд(-ов), 8 контакт(-ов), ... Далее 292175-8AMP - TE CONNECTIVITY - 292175-8 - Pin Header, Wire-to-Board, 2 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Straight, Серия AMP CT | 502 ₽ от 1 шт |
Еще 5 цен: … 277 ₽ | |
428 ₽ от 10 шт | |
373 ₽ от 100 шт | |
351 ₽ от 250 шт | |
326 ₽ от 500 шт | |
277 ₽ от 1000 шт | |
Еще 57 строк | |
AMP - TE CONNECTIVITY - 640457-8 - Pin Header, угловой, Wire-to-Board, ... Далее 640457-8AMP - TE CONNECTIVITY - 640457-8 - Pin Header, угловой, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Right Angle | 92.0 ₽ от 10 шт 5-12 дней склад 135 шт |
Еще 5 цен: … 67.9 ₽ | |
74.3 ₽ от 100 шт 5-12 дней склад 135 шт | |
72.7 ₽ от 250 шт 5-12 дней склад 135 шт | |
71.1 ₽ от 500 шт 5-12 дней склад 135 шт | |
69.5 ₽ от 1000 шт 5-12 дней склад 135 шт | |
67.9 ₽ от 2500 шт 5-12 дней склад 135 шт | |
... CONNECTIVITY - 825433-8 - Pin Header, Wire- ... ряд(-ов), 8 контакт(-ов), ... Далее 825433-8AMP - TE CONNECTIVITY - 825433-8 - Pin Header, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Straight | 519 ₽ от 1 шт 5-12 дней склад 1845 шт |
Еще 5 цен: … 298 ₽ | |
412 ₽ от 10 шт 5-12 дней склад 1845 шт | |
374 ₽ от 100 шт 5-12 дней склад 1845 шт | |
364 ₽ от 250 шт 5-12 дней склад 1845 шт | |
323 ₽ от 500 шт 5-12 дней склад 1845 шт | |
298 ₽ от 1000 шт 5-12 дней склад 1845 шт | |
AMP - TE CONNECTIVITY - 1241050-8 - Pin Header, Board-to-Board, 2. ... Далее 1241050-8AMP - TE CONNECTIVITY - 1241050-8 - Pin Header, Board-to-Board, 2.54 мм, 2 ряд(-ов), 16 контакт(-ов), Surface Mount Straight | 1 358 ₽ от 1 шт 5-12 дней склад 174 шт |
Еще 4 цен: … 793 ₽ | |
943 ₽ от 8 шт 5-12 дней склад 174 шт | |
913 ₽ от 26 шт 5-12 дней склад 174 шт | |
809 ₽ от 70 шт 5-12 дней склад 174 шт | |
793 ₽ от 175 шт 5-12 дней склад 174 шт | |
... CONNECTIVITY - 171826-8 - Pin Header, R/A ... ряд(-ов), 8 контакт(-ов), ... Далее 171826-8AMP - TE CONNECTIVITY - 171826-8 - Pin Header, R/A, Wire-to-Board, 2.5 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Right ... | 143 ₽ от 10 шт 5-12 дней склад 8018 шт |
Еще 5 цен: … 77.7 ₽ | |
118 ₽ от 100 шт 5-12 дней склад 8018 шт | |
107 ₽ от 250 шт 5-12 дней склад 8018 шт | |
96.4 ₽ от 500 шт 5-12 дней склад 8018 шт | |
85.9 ₽ от 1000 шт 5-12 дней склад 8018 шт | |
77.7 ₽ от 2500 шт 5-12 дней склад 8018 шт | |
AMP - TE CONNECTIVITY - 292230-8 - Pin Header, Wire-to-Board, 1. ... Далее 292230-8AMP - TE CONNECTIVITY - 292230-8 - Pin Header, Wire-to-Board, 1.5 мм, 1 ряд(-ов), 8 контакт(-ов), Поверхностный Монтаж | 151 ₽ от 10 шт 5-12 дней склад 1190 шт |
Еще 5 цен: … 100 ₽ | |
135 ₽ от 50 шт 5-12 дней склад 1190 шт | |
120 ₽ от 100 шт 5-12 дней склад 1190 шт | |
114 ₽ от 250 шт 5-12 дней склад 1190 шт | |
108 ₽ от 500 шт 5-12 дней склад 1190 шт | |
100 ₽ от 1500 шт 5-12 дней склад 1190 шт | |
... - 640454-8 - Pin Header, вертикальный ... ряд(-ов), 8 контакт(-ов), ... Далее 640454-8AMP - TE CONNECTIVITY - 640454-8 - Pin Header, вертикальный, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Straight | 69.9 ₽ от 10 шт 5-12 дней склад 1657 шт |
Еще 5 цен: … 49.2 ₽ | |
59.0 ₽ от 100 шт 5-12 дней склад 1657 шт | |
55.4 ₽ от 500 шт 5-12 дней склад 1657 шт | |
53.3 ₽ от 1000 шт 5-12 дней склад 1657 шт | |
51.3 ₽ от 2500 шт 5-12 дней склад 1657 шт | |
49.2 ₽ от 5000 шт 5-12 дней склад 1657 шт | |
AMP - TE CONNECTIVITY - 826632-8 - Pin Header, Board-to-Board, 2. ... Далее 826632-8AMP - TE CONNECTIVITY - 826632-8 - Pin Header, Board-to-Board, 2.54 мм, 2 ряд(-ов), 16 контакт(-ов), Through Hole Straight | 736 ₽ от 1 шт 5-12 дней склад 485 шт |
Еще 5 цен: … 435 ₽ | |
583 ₽ от 10 шт 5-12 дней склад 485 шт | |
567 ₽ от 100 шт 5-12 дней склад 485 шт | |
549 ₽ от 250 шт 5-12 дней склад 485 шт | |
474 ₽ от 500 шт 5-12 дней склад 485 шт | |
435 ₽ от 1000 шт 5-12 дней склад 485 шт | |
AMP - TE CONNECTIVITY - 8-146274-6 - Pin Header, вертикальный, Board- ... Далее 8-146274-6AMP - TE CONNECTIVITY - 8-146274-6 - Pin Header, вертикальный, Board-to-Board, 2.54 мм, 1 ряд(- ... | 1 323 ₽ от 1 шт 5-12 дней склад 722 шт |
Еще 5 цен: … 941 ₽ | |
1 077 ₽ от 10 шт 5-12 дней склад 722 шт | |
961 ₽ от 100 шт 5-12 дней склад 722 шт | |
952 ₽ от 250 шт 5-12 дней склад 722 шт | |
943 ₽ от 500 шт 5-12 дней склад 722 шт | |
941 ₽ от 1000 шт 5-12 дней склад 722 шт | |
AMP - TE CONNECTIVITY - 8-103324-6 - Pin Header, угловой, Wire-to- ... Далее 8-103324-6AMP - TE CONNECTIVITY - 8-103324-6 - Pin Header, угловой, Wire-to-Board, 2.54 мм, 2 ряд(- ... | 2 467 ₽ от 1 шт 5-12 дней склад 96 шт |
Еще 5 цен: … 1 558 ₽ | |
2 146 ₽ от 10 шт 5-12 дней склад 96 шт | |
1 838 ₽ от 25 шт 5-12 дней склад 96 шт | |
1 704 ₽ от 100 шт 5-12 дней склад 96 шт | |
1 590 ₽ от 250 шт 5-12 дней склад 96 шт | |
1 558 ₽ от 500 шт 5-12 дней склад 96 шт | |
AMP - TE CONNECTIVITY - 8-215464-4 - Pin Header, Board-to-Board, 1. ... Далее 8-215464-4AMP - TE CONNECTIVITY - 8-215464-4 - Pin Header, Board-to-Board, 1.27 мм, 2 ряд(-ов), 14 контакт(-ов), Through Hole Straight | 540 ₽ от 1 шт 5-12 дней склад 1548 шт |
Еще 5 цен: … 312 ₽ | |
403 ₽ от 10 шт 5-12 дней склад 1548 шт | |
369 ₽ от 100 шт 5-12 дней склад 1548 шт | |
330 ₽ от 250 шт 5-12 дней склад 1548 шт | |
321 ₽ от 500 шт 5-12 дней склад 1548 шт | |
312 ₽ от 1000 шт 5-12 дней склад 1548 шт | |
AMP - TE CONNECTIVITY - 8-215464-0 - Pin Header, Board-to-Board, 1. ... Далее 8-215464-0AMP - TE CONNECTIVITY - 8-215464-0 - Pin Header, Board-to-Board, 1.27 мм, 2 ряд(-ов), 10 контакт(-ов), Through Hole Straight | 401 ₽ от 1 шт 5-12 дней склад 151 шт |
Еще 4 цен: … 232 ₽ | |
312 ₽ от 6 шт 5-12 дней склад 151 шт | |
276 ₽ от 18 шт 5-12 дней склад 151 шт | |
237 ₽ от 50 шт 5-12 дней склад 151 шт | |
232 ₽ от 125 шт 5-12 дней склад 151 шт | |
AMP - TE CONNECTIVITY - 8-215464-2 - Pin Header, Board-to-Board, 1. ... Далее 8-215464-2AMP - TE CONNECTIVITY - 8-215464-2 - Pin Header, Board-to-Board, 1.27 мм, 2 ряд(-ов), 12 контакт(-ов), Through Hole Straight | 337 ₽ от 1 шт 5-12 дней склад 401 шт |
Еще 4 цен: … 262 ₽ | |
298 ₽ от 6 шт 5-12 дней склад 401 шт | |
282 ₽ от 18 шт 5-12 дней склад 401 шт | |
267 ₽ от 50 шт 5-12 дней склад 401 шт | |
262 ₽ от 125 шт 5-12 дней склад 401 шт | |
AMP - TE CONNECTIVITY - 8-338728-2 - Pin Header, Board-to-Board, 1. ... Далее 8-338728-2AMP - TE CONNECTIVITY - 8-338728-2 - Pin Header, Board-to-Board, 1.27 мм, 2 ряд(-ов), ... | 424 ₽ от 1 шт 5-12 дней склад 178 шт |
Еще 4 цен: … 303 ₽ | |
383 ₽ от 37 шт 5-12 дней склад 178 шт | |
364 ₽ от 112 шт 5-12 дней склад 178 шт | |
346 ₽ от 300 шт 5-12 дней склад 178 шт | |
303 ₽ от 750 шт 5-12 дней склад 178 шт | |
Клеммная Колодка, Штыревой Разъем, 3.81 мм, 2 вывод(-ов), 8 А, 160 В | 230 ₽ от 1 шт 5-12 дней склад 39 шт |
Еще 5 цен: … 185 ₽ | |
201 ₽ от 10 шт 5-12 дней склад 39 шт | |
197 ₽ от 100 шт 5-12 дней склад 39 шт | |
193 ₽ от 500 шт 5-12 дней склад 39 шт | |
189 ₽ от 1000 шт 5-12 дней склад 39 шт | |
185 ₽ от 2500 шт 5-12 дней склад 39 шт | |
PIN POINT GLUE SYRINGES & TIPS | 2 057 ₽ от 1 шт 5-12 дней склад 5 шт |
1 911 ₽ от 5 шт 5-12 дней склад 5 шт | |
Pin Header, вертикальный, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 3 ... Далее 8-102202-4Pin Header, вертикальный, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 3 контакт(-ов), Through Hole Straight | 330 ₽ от 1 шт 5-12 дней склад 6771 шт |
Еще 5 цен: … 214 ₽ | |
280 ₽ от 10 шт 5-12 дней склад 6771 шт | |
235 ₽ от 100 шт 5-12 дней склад 6771 шт | |
226 ₽ от 250 шт 5-12 дней склад 6771 шт | |
218 ₽ от 500 шт 5-12 дней склад 6771 шт | |
214 ₽ от 1000 шт 5-12 дней склад 6771 шт | |
Лампа накаливания, 12 В, Bi-Pin, T-1 (3мм), 0.15, 16000 ч | 339 ₽ от 1 шт 5-12 дней склад 325 шт |
Еще 5 цен: … 172 ₽ | |
235 ₽ от 100 шт 5-12 дней склад 325 шт | |
186 ₽ от 500 шт 5-12 дней склад 325 шт | |
179 ₽ от 2000 шт 5-12 дней склад 325 шт | |
176 ₽ от 5000 шт 5-12 дней склад 325 шт | |
172 ₽ от 10000 шт 5-12 дней склад 325 шт | |
9 ЕКОМП Санкт-Петербург Россия | |
Штыри 1x8 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLS2-8) Connfly DS1025-01-1*8 P8BV1 - DS1025-01-1*8 P8BV1 Connfly 24 Апр 2024 01:50 Штыри однорядные 1x8 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 1x8 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLS2-8) Connfly DS1025-01-1*8 P8BV1 - DS1025-01-1*8 P8BV1Штыри однорядные 1x8 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 2.12 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x15 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-30) Connfly DS1025-05-2*15 P8BV1 - DS1025-05-2*15 P8BV1 Connfly 24 Апр 2024 01:50 Штыри двухрядные 2x15 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x15 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-30) Connfly DS1025-05-2*15 P8BV1 - DS1025-05-2*15 P8BV1Штыри двухрядные 2x15 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 8.56 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x20 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-40) Connfly DS1025-05-2*20 P8BV1 - DS1025-05-2*20 P8BV1 Connfly 24 Апр 2024 01:50 Штыри двухрядные 2x20 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x20 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-40) Connfly DS1025-05-2*20 P8BV1 - DS1025-05-2*20 P8BV1Штыри двухрядные 2x20 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 10.2 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Еще 7 строк | |
Разъем "вилка" 8 конт. (2x4) шаг 2.54 мм, верт. на плату (ан. BH-8/ IDC-08MS) Connfly DS1013-08 SSIB1 - DS1013-08 SSIB1 Connfly 24 Апр 2024 01:50 Разъем "вилка" 8 конт.(2x4) шаг 2.54 мм, вертик. на плату ( ... Далее Разъем "вилка" 8 конт. (2x4) шаг 2.54 мм, верт. на плату (ан. BH-8/ IDC-08MS) Connfly DS1013-08 SSIB1 - DS1013-08 SSIB1Разъем "вилка" 8 конт.(2x4) шаг 2.54 мм, вертик. на плату (ответн. часть к IDC) (DS1013-08SSIB1-B-0) | 3.92 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 1x7 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLS2-7) Connfly DS1025-01-1*7 P8BV1 - DS1025-01-1*7 P8BV1 Connfly 24 Апр 2024 01:50 Штыри однорядные 1x7 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 1x7 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLS2-7) Connfly DS1025-01-1*7 P8BV1 - DS1025-01-1*7 P8BV1Штыри однорядные 1x7 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 1.86 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x6 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-12) Connfly DS1025-05-2*6 P8BV1 - DS1025-05-2*6 P8BV1 Connfly 24 Апр 2024 01:50 Штыри двухрядные 2x6 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x6 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-12) Connfly DS1025-05-2*6 P8BV1 - DS1025-05-2*6 P8BV1Штыри двухрядные 2x6 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. (DS1025-05-2*6P8BV1-B) | 3.07 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x10 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-20) Connfly DS1025-05-2*10 P8BV1 - DS1025-05-2*10 P8BV1 Connfly 24 Апр 2024 01:50 Штыри двухрядные 2x10 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x10 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-20) Connfly DS1025-05-2*10 P8BV1 - DS1025-05-2*10 P8BV1Штыри двухрядные 2x10 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 5.16 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Разъем "вилка" 8 конт. (2x4) шаг 2.54 мм, SMT на плату (ан. BHS-8) Connfly DS1013-08 MSISR - DS1013-08 MSISR Connfly 24 Апр 2024 01:50 Разъем "вилка" 8 конт.(2x4) шаг 2.54 мм, поверхн. монтаж на ... Далее Разъем "вилка" 8 конт. (2x4) шаг 2.54 мм, SMT на плату (ан. BHS-8) Connfly DS1013-08 MSISR - DS1013-08 MSISRРазъем "вилка" 8 конт.(2x4) шаг 2.54 мм, поверхн. монтаж на плату (ответн. часть к IDC), с установ. крышкой (вид упак. "tape ... | 24.8 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x12 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-24) Connfly DS1025-05-2*12 P8BV1 - DS1025-05-2*12 P8BV1 Connfly 24 Апр 2024 01:50 Штыри двухрядные 2x12 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x12 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-24) Connfly DS1025-05-2*12 P8BV1 - DS1025-05-2*12 P8BV1Штыри двухрядные 2x12 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 6.02 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x20 конт. шаг 2.00 мм, пр. угол на плату (2.8/ 4.0 мм) (ан. PLD2-40R*) Connfly DS1025-06-2*20 P8BR1-B - DS1025-06-2*20 P8BR1-B Connfly 24 Апр 2024 01:50 Штыри двухрядные 2x20 конт. шаг 2.00 мм, прямой угол на плату, ... Далее Штыри 2x20 конт. шаг 2.00 мм, пр. угол на плату (2.8/ 4.0 мм) (ан. PLD2-40R*) Connfly DS1025-06-2*20 P8BR1-B - DS1025-06-2*20 P8BR1-BШтыри двухрядные 2x20 конт. шаг 2.00 мм, прямой угол на плату, низкопрофил. (2.8 мм/ 4.0 мм), позол. (DS1025-06-2*20P8BR1-B) | 10.3 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
10 ЗУМ-СМД Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 600 руб. | |
DIP-8 | запрос от 600 ₽ от 7 дней склад 12596 шт |
DIP-8 | запрос от 600 ₽ от 7 дней склад 14590 шт |
11 РЕФРО Москва Россия | |
... индукционной плиты HURAKAN 8 pin универсальнаяМодель: Плата генератора ... Далее Плата генератора для индукционной плиты HURAKAN 8 pin универсальная ... для индукционной плиты HURAKAN 8 pin универсальнаяМодель: Плата генератора для индукционной плиты 8 pin универсальнаяСтрана: Китай | 6 509 ₽ на складе |
12 Десси Москва Россия | |
Модуль кнопок 44 (8 pin) 02 Апр 2024 09:03 Модуль кнопок 44 (8 pin) | 100 ₽ |
... : Шлейф 8 pin и длиной 7 см ... 149; Шлейф 12 pin и длиной 10 см ... Далее GKFFCB-P0.5. Набор инверсных FFC шлейфов с шагом 0, 5 мм. 8 штук. ... : 4 мм; Тип шлейфа: Инверсный. Комплект поставки: Шлейф 8 pin и длиной 7 см (1 штука); Шлейф 12 ... | 395 ₽ |
... : Шлейф 8 pin и длиной 7 см ... 149; Шлейф 12 pin и длиной 10 см ... Далее GKFFCA-P0.5. Набор прямых FFC шлейфов с шагом 0, 5 мм. 8 штук. ... : 4 мм; Тип шлейфа: Прямой. Комплект поставки: Шлейф 8 pin и длиной 7 см (1 штука); Шлейф 12 ... | 395 ₽ |
Еще 5 строк | |
Комбинированный универсальный переходник - адаптер TQFP / QFP / LQFP / PLCC 32...100 pin/шаг 0, 5 мм и TQFP / QFP / LQFP / PLCC 32...64 pin/шаг 0, 8 мм. DIY - 02 Апр 2024 09:03 Назначение: Макетирование с применением микросхем в квадратных ... Далее Комбинированный универсальный переходник - адаптер TQFP / QFP / LQFP / PLCC 32...100 pin/шаг 0, 5 мм и TQFP / QFP / LQFP / PLCC 32...64 pin/шаг 0, 8 мм.Назначение: Макетирование с применением микросхем в квадратных корпусах с шагом выводов 0,5 мм и 0,8 мм.: Верхняя сторона А, Двухсторонней ... | 132 ₽ |
Гнездо на плату, двухрядное, прямое. Количество рядов: 2 ... Далее Разъём PBD-08. Гнездо прямое на плату 2х4 pin 2, 54 мм. 10 штукГнездо на плату, двухрядное, прямое. Количество рядов: 2 Форма контактов: Прямые Шаг контактов: 2,54 мм; ... | 90.0 ₽ |
Количество в упаковке: 10 шт. Гнезда на плату, однорядные, прямые ... Далее Разъем PBS-8L. Гнездо на плату 1х8 pin 2.54 мм с длинными контактамиКоличество в упаковке: 10 шт. Гнезда на плату, однорядные, прямые удлиненные контакты. Серия: PBS Количество рядов: 1; Форма контактов: ... | 210 ₽ |
PBS-8 YELLOW (гнездо на плату 18pin 2.54мм жёлтый) (упак. 10шт) 02 Апр 2024 09:03 PBS-8 YELLOW (гнездо на плату 18pin 2.54мм жёлтый) (упак. 10шт) | 80.0 ₽ |
Серверный модуль памяти KVR667D2D8F5/2G 256M x 72-Bit PC2-5300 CL5 ECC 240-Pin FBDIMM 02 Апр 2024 09:03 SPECIFICATIONS · FBDIMM Module 240-pin · JEDEC Standard R/C B · Memory ... Далее Серверный модуль памяти KVR667D2D8F5/2G 256M x 72-Bit PC2-5300 CL5 ECC 240-Pin FBDIMMSPECIFICATIONS · FBDIMM Module 240-pin · JEDEC Standard R/C B · Memory Organization: 2 rank of x8 devices · DDR2 DRAM Interface: SSTL_18 · ... | 1 500 ₽ |
13 Умные Модули Санкт-Петербург Россия | |
Кнопка миниатюрная с фиксацией 8.5х8.5 мм (3 PIN) | 11.0 ₽ Наличный, безнал расчет.... Далее Наличный, безнал расчет. Отгрузка в день заказа! 1-10 дней на складе |
14 ЭК ЗИП Москва Россия | |
Быстроразъемные | 361 ₽ от 1 шт склад 1966 шт |
Еще 2 цен: … 236 ₽ | |
249 ₽ от 5 шт склад 1966 шт | |
236 ₽ от 41 шт склад 1966 шт | |
Быстроразъемные | 491 ₽ от 1 шт склад 3063 шт |
Еще 2 цен: … 322 ₽ | |
339 ₽ от 3 шт склад 3063 шт | |
322 ₽ от 30 шт склад 3063 шт | |
Держатели sim и карт памяти | запрос |
Еще 6 строк | |
Коробки распределительные | запрос |
Держатели sim и карт памяти | 69.7 ₽ от 1 шт склад 1150 шт |
Еще 2 цен: … 45.7 ₽ | |
48.1 ₽ от 21 шт склад 1150 шт | |
45.7 ₽ от 208 шт склад 1150 шт | |
Герметичные разъемы | 904 ₽ от 1 шт склад 1273 шт |
Еще 2 цен: … 592 ₽ | |
624 ₽ от 2 шт склад 1273 шт | |
592 ₽ от 17 шт склад 1273 шт | |
15 Холодильник.ру Москва Россия | |
Тип: датакабель
Для бренда: универсальный
Разъемы (вход): Lightning
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 1м Green-blackТип: датакабель
Разъемы (выход): USB
Длина кабеля (м): 1
Страна-производитель: Китай | 429 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 1м Red-blackТип: датакабель
Длина кабеля (м): 1
Тип: датакабель
Разъемы (вход): USB
Разъемы ... Далее Дата-кабель Pero DC-03 8-pin Lightning 2А 2 м белыйТип: датакабель
Разъемы (вход): USB
Разъемы (выход): Lightning 8pin
Длина кабеля (м): 2
Страна-производитель: ... | 389 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Еще 22 строки | |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 2м Silver-blackТип: датакабель
Длина кабеля (м): 2
Страна-производитель: Китай | 529 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 2м Red-blackТип: датакабель
Длина кабеля (м): 2
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 1м Blue-blackТип: датакабель
Длина кабеля (м): 1
Тип: датакабель
Для бренда: Apple
Разъемы (вход): USB
Разъемы (выход): ... Далее Дата-кабель Pero DC-03 8-pin Lightning 2А 0.2 м черныйТип: датакабель
Для бренда: Apple
Разъемы (вход): USB
Длина кабеля (м): 0.2
Страна-производитель: Китай | 289 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 2м Blue-blackТип: датакабель
Длина кабеля (м): 2
Страна-производитель: Китай | 338 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 1м Silver-blackТип: датакабель
Длина кабеля (м): 1
Страна-производитель: Китай | 430 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Дата-кабель MoreChoice USB 2.1A для Lightning 8-pin K12i нейлон 1м (Red Black) MoreChoice - 20 Апр 2024 02:07 Тип: кабель
Для бренда: Apple
Разъемы (вход): USB 2.0
Разъемы (выход): ... Далее Дата-кабель MoreChoice USB 2.1A для Lightning 8-pin K12i нейлон 1м (Red Black)Тип: кабель
Для бренда: Apple
Разъемы (выход): 8pin Lightning
Длина кабеля (м): 1
Страна-производитель: Китай | 219 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-03 8-pin Lightning 2А 2м черныйТип: датакабель
Длина кабеля (м): 2
Страна-производитель: Китай | 389 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: кабель
Разъемы (вход): 8pin Lightning
... Далее Кабель TFN 8-pin FORZA, 1 м, черный (TFNTFN-CFZLIGUSB1MBK)Тип: кабель
Длина кабеля (м): 1
Страна-производитель: Китай | 490 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Кабель для синхронизации и зарядки Canyon 8-pin Lightning - USB-Type C CFI-12 CNE-CFI12W Canyon 20 Апр 2024 02:07 Тип: кабель
Разъемы (вход): USBC
Разъемы ( ... Далее Кабель для синхронизации и зарядки Canyon 8-pin Lightning - USB-Type C CFI-12 CNE-CFI12WТип: кабель
Разъемы (выход): USB TypeC
Длина кабеля (м): 2
Страна-производитель: Китай | 599 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: кабель
Для бренда: Apple
Разъемы ( ... Далее Кабель TFN USB 8-pin 2.0м. белый (TFNTFN-CLIGUSB2MWH)Тип: кабель
Для бренда: Apple
Длина кабеля (м): 2
Страна-производитель: Китай | 290 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: кабель
Для бренда: Apple
Разъемы ( ... Далее Кабель TFN 8-pin FORZA, 1 м, белый (TFNTFN-CFZLIGUSB1MWH)Тип: кабель
Для бренда: Apple
Длина кабеля (м): 1
Страна-производитель: Китай | 550 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Тип: кабель
Для бренда: Apple
Разъемы ( ... Далее Кабель TFN 8-pin FORZA, 1 м, серый (TFNTFN-CFZLIGUSB1MST)Тип: кабель
Для бренда: Apple
Длина кабеля (м): 1
Страна-производитель: Китай | 750 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Тип: кабель
Для бренда: Apple
Разъемы ( ... Далее Кабель TFN 8-pin FORZA, 1 м, графитовый (TFNTFN-CFZLIGUSB1MGR)Тип: кабель
Для бренда: Apple
Длина кабеля (м): 1
Тип: датакабель
Для бренда: Apple
... Далее Кабель TFN 8-pin TypeC 2.0 м, белый (TFN-CLIGC2MTPEWH)Тип: датакабель
Для бренда: Apple
Длина кабеля (м): 2
Страна-производитель: Китай | 690 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: кабель
Для бренда: Apple
Разъемы ( ... Далее Кабель MoreChoice USB 2.0A для Lightning 8-pin K16i TPE 1м (Purple)Тип: кабель
Для бренда: Apple
Длина кабеля (м): 1
Страна-производитель: Китай | 98.0 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: кабель
Для бренда: Apple
Разъемы (вход): USB
Разъемы (выход): ... Далее Кабель Red Line USB-8-pin для Apple, 1.5A, 20 см, белыйТип: кабель
Для бренда: Apple
Разъемы (вход): USB
Страна-производитель: Китай | 61.0 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
16 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
М0040577 | 46.0 ₽ Доставка: есть Самовывоз: есть на складе |
М0040580 | 91.0 ₽ Доставка: есть Самовывоз: есть на складе |
М0040581 | 133 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 53 строки | |
М0040594 | 54.0 ₽ Доставка: есть Самовывоз: есть на складе |
Тензометрическое оборудование | 15 531 ₽ Доставка: есть Самовывоз: есть на складе |
Панелька for ICs 2, 54 mm 8 pin SCS-08 25 Апр 2024 04:18 Линейка 60 шт | 4.00 ₽ Доставка: есть Самовывоз: есть на складе |
Выключатели DIP | 72.0 ₽ Доставка: есть Самовывоз: есть на складе |
М0019041 | 7.00 ₽ Доставка: есть Самовывоз: есть на складе |
М0040589 | 52.0 ₽ Доставка: есть Самовывоз: есть на складе |
М0040593 | 65.0 ₽ Доставка: есть Самовывоз: есть на складе |
М0941808 | 715 ₽ Доставка: есть Самовывоз: есть на складе |
18-0179 | 219 ₽ Доставка: есть Самовывоз: есть на складе |
USB кабель 3 в 1 Lightning 8 pin/micro USB/USB Type-C черный текстиль, 1 метр REXANT - - 25 Апр 2024 04:18 18-7013 | 379 ₽ Доставка: есть Самовывоз: есть на складе |
кабель интерфейсный разборный DB9F-DB9M pin-to-pin 1.8м | 248 ₽ Доставка: есть Самовывоз: есть на складе |
Микрокнопка б.фиксации №57 PS580N 5, 8*5, 8 мм ручка = 5 мм 6 pin 25 Апр 2024 04:18 Микрокнопка без фиксации PS580N 5,8*5,8мм ручка=5мм 6pin | 5.00 ₽ Доставка: есть Самовывоз: есть на складе |
6х6mm Daier, шток 8,5мм | 9.00 ₽ Доставка: есть Самовывоз: есть на складе |
Переключатель 2 положения №71 8, 6*7мм, ручка 4мм, 6pin 25 Апр 2024 04:18 Переключатель на 2 положения 8,6*7мм, ручка 4мм, 6pin | 30.0 ₽ Доставка: есть Самовывоз: есть на складе |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В ... Далее TEN 8-2421WIПреобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В/-5В 0.8A/-0.8A 8Вт 9-Pin PDIP | 5 930 ₽ Доставка: есть Самовывоз: есть на складе |
14-pin | 41.0 ₽ Доставка: есть Самовывоз: есть на складе |
Переключатель 2 положения №63 8, 6*4, 4мм, ручка 4мм, 3pin угловые 25 Апр 2024 04:18 Переключатель на 2 положения 8,6*4,4мм, ручка 4мм, 3pin угловые | 33.0 ₽ Доставка: есть Самовывоз: есть на складе |
17 Амарид-Электро Санкт-Петербург Россия | |
X-COM-S-1L FEDERLEISTE 8 PIN, серый | 1 074 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
X-COM-S-1L FEDERLEISTE 8 PIN, серый | 1 072 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... PCBs) Straight solder pin 0.8 x 0.8 мм 3-полюс., чёрный Далее 714-133Male header (for PCBs) Straight solder pin 0.8 x 0.8 мм 3-полюс., чёрный | 137 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
Еще 8 строк | |
Вилка THT, 0.8 x 0.8 мм solder pin, прямые, Шаг контактов 3 ... Далее 714-134Вилка THT, 0.8 x 0.8 мм solder pin, прямые, Шаг контактов 3,5 мм, 4-пол., черные | 185 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... PCBs) Straight solder pin 0.8 x 0.8 мм 12-полюс., чёрный Далее 714-142Male header (for PCBs) Straight solder pin 0.8 x 0.8 мм 12-полюс., чёрный | 554 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... , 5- to 8-pole suitable for 5 мм pin spacing, light gray Далее 2092-1602/002-000Gripping plate sliding connector release, 5- to 8-pole suitable for 5 мм pin spacing, light gray | 80.6 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... 1.0 мм solder pin, угловые, Фиксирующий рычаг ... мм, 8-пол., светло-серые Далее 722-238/039-000 ... под пайку THT, 0.6 x 1.0 мм solder pin, угловые, Фиксирующий рычаг, 2,5 мм2, Шаг контактов 5 мм ... | 697 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... 1.0 мм solder pin, угловые, Проходной фланец ... 5 мм, 8-пол., светло-серые Далее 722-238/047-000 ... под пайку THT, 0.6 x 1.0 мм solder pin, угловые, Проходной фланец, 2,5 мм2, Шаг контактов 5 мм ... | 682 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... 1.0 мм solder pin, угловые, Фиксирующий рычаг ... мм, 8-пол., светло-серые Далее 722-838/039-000 ... под пайку THT, 0.6 x 1.0 мм solder pin, угловые, Фиксирующий рычаг, 2,5 мм2, Шаг контактов 7,5 ... | 739 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... x 1.0 мм solder pin, прямые, Шаг контактов 3,5 ... Далее 734-138/046-000Вилка THT, 1.0 x 1.0 мм solder pin, прямые, Шаг контактов 3,5 мм, 8-пол., светло-серые | 302 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... x 1.0 мм solder pin, прямые, Шаг контактов 3,81 ... Далее 734-238/046-000Вилка THT, 1.0 x 1.0 мм solder pin, прямые, Шаг контактов 3,81 мм, 8-пол., оранжевые | 302 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
18 Оптулс Москва Россия | |
70090003 STAHLWILLE 109/3 1,8 pin punch | 1 270 ₽ Розница, Скидки для Дилеров - |
70090005 STAHLWILLE 109/5 2,8 pin punch | 1 270 ₽ Розница, Скидки для Дилеров - |
Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8) PRESSMASTER - 28 Фев 2024 17:35 ... KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 ... Далее Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8)Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8) | 41 013 ₽ Розница, Скидки для Дилеров - |
Еще 5 строк | |
70090008 STAHLWILLE 109/8 5,9 pin punch | 1 030 ₽ Розница, Скидки для Дилеров - |
70070006 STAHLWILLE 108/150 X 8 parallel pin punch, octogonal | 913 ₽ Розница, Скидки для Дилеров - |
70070008 STAHLWILLE 108/200 X 8 parallel pin punch, octogonal | 1 146 ₽ Розница, Скидки для Дилеров - |
96700711 STAHLWILLE 105-8/6 K set pin punches - centre punches | 4 396 ₽ Розница, Скидки для Дилеров - |
96838124 STAHLWILLE ES 102/105/108/8 set parallel pin punches | 7 683 ₽ Розница, Скидки для Дилеров - |
19 DIP8.RU Москва Россия и страны ТС | |
Разъем Micro-MaTch; вилка; папа; PIN: 18; IDC; н | 570 ₽ от 1 шт 42 дня склад 222 шт Внешний |
Еще 9 цен: … 288 ₽ | |
570 ₽ от 1 шт от 1 дня склад 22 шт Москва | |
446 ₽ от 5 шт 42 дня склад 222 шт Внешний | |
446 ₽ от 5 шт от 1 дня склад 22 шт Москва | |
393 ₽ от 20 шт 42 дня склад 222 шт Внешний | |
393 ₽ от 20 шт от 1 дня склад 22 шт Москва | |
335 ₽ от 100 шт 42 дня склад 222 шт Внешний | |
335 ₽ от 100 шт от 1 дня склад 22 шт Москва | |
288 ₽ от 250 шт 42 дня склад 222 шт Внешний | |
288 ₽ от 250 шт от 1 дня склад 22 шт Москва | |
Разъем прямоугольный, мама, CX, PIN 12(4+8), размер 104.27 | 5 880 ₽ от 1 шт 42 дня склад 70 шт Внешний |
Еще 7 цен: … 3 778 ₽ | |
5 880 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
4 953 ₽ от 5 шт 42 дня склад 70 шт Внешний | |
4 953 ₽ от 5 шт от 1 дня склад 3 шт Москва | |
4 407 ₽ от 20 шт от 1 дня склад 3 шт Москва | |
4 407 ₽ от 20 шт 42 дня склад 70 шт Внешний | |
3 778 ₽ от 100 шт 42 дня склад 70 шт Внешний | |
3 778 ₽ от 100 шт от 1 дня склад 3 шт Москва | |
Разъем прямоугольный, папа, CX, PIN 12(4+8), размер 104.27 | 5 420 ₽ от 1 шт 42 дня склад 25 шт Внешний |
Еще 7 цен: … 3 497 ₽ | |
5 420 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
4 586 ₽ от 5 шт 42 дня склад 25 шт Внешний | |
4 586 ₽ от 5 шт от 1 дня склад 3 шт Москва | |
4 080 ₽ от 20 шт от 1 дня склад 3 шт Москва | |
4 080 ₽ от 20 шт 42 дня склад 25 шт Внешний | |
3 497 ₽ от 100 шт 42 дня склад 25 шт Внешний | |
3 497 ₽ от 100 шт от 1 дня склад 3 шт Москва | |
Еще 5 строк | |
Вилка, провод-плата, мама, PIN 8, без контактов, 2,5мм, XH, ... Далее XHP-8Вилка, провод-плата, мама, PIN 8, без контактов, 2,5мм, XH, 250В | 3.00 ₽ от 1 шт склад 6407 шт Внешний |
Еще 9 цен: … 2.21 ₽ | |
3.00 ₽ от 1 шт от 1 дня склад 470 шт Москва | |
2.74 ₽ от 500 шт склад 6407 шт Внешний | |
2.74 ₽ от 500 шт от 1 дня склад 470 шт Москва | |
2.41 ₽ от 2500 шт склад 6407 шт Внешний | |
2.41 ₽ от 2500 шт от 1 дня склад 470 шт Москва | |
2.29 ₽ от 10400 шт склад 6407 шт Внешний | |
2.29 ₽ от 10400 шт от 1 дня склад 470 шт Москва | |
2.21 ₽ от 26700 шт склад 6407 шт Внешний | |
2.21 ₽ от 26700 шт от 1 дня склад 470 шт Москва | |
Гнездо, DIN, мама, PIN 8, конфигурация выводов 262°, угловые ... Далее MAB 8 SH SWГнездо, DIN, мама, PIN 8, конфигурация выводов 262°, угловые 90°, THT | 1 020 ₽ от 1 шт 42 дня склад 2787 шт Внешний |
Еще 7 цен: … 652 ₽ | |
1 020 ₽ от 1 шт от 1 дня склад 21 шт Москва | |
881 ₽ от 5 шт 42 дня склад 2787 шт Внешний | |
881 ₽ от 5 шт от 1 дня склад 21 шт Москва | |
764 ₽ от 20 шт от 1 дня склад 21 шт Москва | |
764 ₽ от 20 шт 42 дня склад 2787 шт Внешний | |
652 ₽ от 100 шт 42 дня склад 2787 шт Внешний | |
652 ₽ от 100 шт от 1 дня склад 21 шт Москва | |
Гнездо; Micro-MaTch; мама; PIN: 10; THT; на PCB; | 90.0 ₽ от 1 шт склад 175 шт Внешний |
Еще 9 цен: … 69.8 ₽ | |
90.0 ₽ от 1 шт от 1 дня склад 1 шт Москва | |
81.9 ₽ от 25 шт склад 175 шт Внешний | |
81.9 ₽ от 25 шт от 1 дня склад 1 шт Москва | |
76.6 ₽ от 49 шт склад 175 шт Внешний | |
76.6 ₽ от 49 шт от 1 дня склад 1 шт Москва | |
72.7 ₽ от 97 шт склад 175 шт Внешний | |
72.7 ₽ от 97 шт от 1 дня склад 1 шт Москва | |
69.8 ₽ от 250 шт склад 175 шт Внешний | |
69.8 ₽ от 250 шт от 1 дня склад 1 шт Москва | |
Разъем: M8; 1м; мама; PIN: 4; прямой; с амортизатором,с проводами | 2 110 ₽ от 1 шт 42 дня склад 1 шт Внешний |
Еще 7 цен: … 1 267 ₽ | |
2 110 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
1 793 ₽ от 5 шт 42 дня склад 1 шт Внешний | |
1 793 ₽ от 5 шт от 1 дня склад 3 шт Москва | |
1 438 ₽ от 10 шт от 1 дня склад 3 шт Москва | |
1 438 ₽ от 10 шт 42 дня склад 1 шт Внешний | |
1 267 ₽ от 25 шт 42 дня склад 1 шт Внешний | |
1 267 ₽ от 25 шт от 1 дня склад 3 шт Москва | |
Разъем: M8, 0,5м, мама, PIN: 4, на панель,винтами, гнездо, E, 4А | 2 690 ₽ от 1 шт 42 дня склад 78 шт Внешний |
Еще 7 цен: … 1 747 ₽ | |
2 690 ₽ от 1 шт от 1 дня склад 2 шт Москва | |
2 260 ₽ от 5 шт 42 дня склад 78 шт Внешний | |
2 260 ₽ от 5 шт от 1 дня склад 2 шт Москва | |
2 003 ₽ от 20 шт от 1 дня склад 2 шт Москва | |
2 003 ₽ от 20 шт 42 дня склад 78 шт Внешний | |
1 747 ₽ от 100 шт 42 дня склад 78 шт Внешний | |
1 747 ₽ от 100 шт от 1 дня склад 2 шт Москва | |
20 T-electron Раменское, Московская обл. Россия и страны СНГ | |
запрос да | |
запрос да | |
запрос | |
Еще 7 строк | |
290 ₽ до 5 дней | |
35.0 ₽ до 5 дней | |
42.0 ₽ до 5 дней | |
Разъем USB-mini /гнездо 8 pin SMD 20 Ноя 2023 00:56 | 42.0 ₽ да |
запрос да | |
131 ₽ до 5 дней | |
68.0 ₽ до 5 дней | |
21 Контест Москва Россия | |
TUNER TDQ-38HS 8 PIN 25 Апр 2024 02:08 | 864 ₽ |
P-1118-8 PIN МИКРОФОННЫЙ РАЗЪЕМ, БЛОЧНЫЙ 25 Апр 2024 02:08 | 462 ₽ |
P-1120-8 PIN МИКРОФОННЫЙ РАЗЪЕМ, КАБЕЛЬНЫЙ 25 Апр 2024 02:08 | 382 ₽ |
Еще 3 строки | |
A/L UNIV HDR 50P ACT PIN | запрос склад 444 шт |
CONN D-CAP MALE PINS 96POS VERT | запрос склад 14 шт |
22 Элитан Ижевск Россия Безнал. расчет Филиалы: Москва Санкт-Петербург Екатеринбург Новосибирск | |
SCS-8 pin 19 Апр 2024 02:31 | 53.9 ₽ |
LTC2904ITS8#TRPBF (8-Pin TSOT-23) 19 Апр 2024 02:31 | 413 ₽ |
49.4 ₽ | |
23 PL-1 Москва Россия | |
2 790 ₽ от 1 шт нет | |
Еще 2 цен: … 2 536 ₽ | |
2 657 ₽ от 3000 ₽ нет | |
2 536 ₽ от 6000 ₽ нет | |
Лазерная головка | 1 770 ₽ от 1 шт нет |
Еще 2 цен: … 1 609 ₽ | |
1 686 ₽ от 3000 ₽ нет | |
1 609 ₽ от 6000 ₽ нет | |
24 ВсеИнструменты.ру Москва Россия | |
СЗУ More Choice 1USB 1.0A для Lightning 8-pin NC33ib | 312 ₽ на складе |
СЗУ More Choice 2USB 2.4A для Lightning 8-pin 1м NC46ibb | 388 ₽ на складе |
... 2USB 2.1A для Lightning 8-pin со встроенным кабелем и LED ... Далее Сзу для Lightning 8-pin More ChoiceСЗУ More Choice 2USB 2.1A для Lightning 8-pin со встроенным кабелем и LED подсветкой NC48iw | 351 ₽ на складе |
Еще 24 строки | |
... .0A QC3.0 для Lightning 8-pin быстрая зарядка NC52QCi Далее Сзу для Lightning 8-pin More ChoiceСЗУ More Choice 1USB 3.0A QC3.0 для Lightning 8-pin быстрая зарядка NC52QCi | 412 ₽ на складе |
... .0 быстрая зарядка для Lighting 8-pin NC55QCib Далее Быстрая сзу для Lighting 8-pin More ChoiceСЗУ More Choice Smart 2USB 3.0A QC3.0 быстрая зарядка для Lighting 8-pin NC55QCib | 479 ₽ на складе |
СЗУ More Choice 2USB 2.1A для Lightning 8-pin NC24i | 367 ₽ на складе |
СЗУ More Choice 2USB 2.4A для Lightning 8-pin NC22i | 335 ₽ на складе |
... USB 2.1A для Lightning 8-pin TPE 1м K13iw Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.1A для Lightning 8-pin TPE 1м K13iw | 239 ₽ на складе |
... PD30W быстрая зарядка для Lightning 8-pin Type-C K71Si TPE 2м Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A PD30W быстрая зарядка для Lightning 8-pin Type-C K71Si TPE 2м | 360 ₽ на складе |
... USB 2.4A для Lightning 8-pin ТРЕ 1м K42i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A для Lightning 8-pin ТРЕ 1м K42i | 232 ₽ на складе |
... USB 2.0A для Lightning 8-pin K14i TPE 0.25м Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.0A для Lightning 8-pin K14i TPE 0.25м | 239 ₽ на складе |
... USB 2.1A для Lightning 8-pin ПВХ 1м K21iw Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.1A для Lightning 8-pin ПВХ 1м K21iw | 199 ₽ на складе |
... USB 2.4A для Lightning 8-pin Magnetic нейлон 1м K61Sib Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A для Lightning 8-pin Magnetic нейлон 1м K61Sib | 429 ₽ на складе |
... , 2.4 A, для Lightning 8-pin AC22i Далее Азу для Lightning 8-pin More ChoiceАвтомобильное зарядное устройство More Choice 2USB, 2.4 A, для Lightning 8-pin AC22i | 450 ₽ на складе |
... USB 2.0A для Lightning 8-pin TPE 1м K16i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.0A для Lightning 8-pin TPE 1м K16i | 199 ₽ на складе |
... USB 2.0A для Lightning 8-pin нейлон 1м K11i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.0A для Lightning 8-pin нейлон 1м K11i | 200 ₽ на складе |
... PD30W быстрая зарядка для Lightning 8-pin Type-C K71Si TPE 1мw Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A PD30W быстрая зарядка для Lightning 8-pin Type-C K71Si TPE 1мw | 330 ₽ на складе |
... USB 2.1A для Lightning 8-pin нейлон 1м K27i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.1A для Lightning 8-pin нейлон 1м K27i | 232 ₽ на складе |
... USB 2.4A для Lightning 8-pin TPE 1м K22i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.4A для Lightning 8-pin TPE 1м K22i | 191 ₽ на складе |
... USB 2.4A для Lightning 8-pin нейлон 1м K41Si Newsb Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A для Lightning 8-pin нейлон 1м K41Si Newsb | 350 ₽ на складе |
25 Полигон Санкт-Петербург Россия | |
Колодка для реле 8 PIN | 798 ₽ Доставка: есть Самовывоз: есть |
Колодка для реле 8 PIN I/O | 718 ₽ Доставка: есть Самовывоз: есть |
Колодка для реле 8 PIN | 652 ₽ Доставка: есть Самовывоз: есть |
26 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
разъемы видео, ТВ | 134 ₽ от 5000 ₽ |
разъемы видео, ТВ | 169 ₽ от 5000 ₽ |
Еще 12 строк | |
разъемы видео, ТВ | 105 ₽ от 5000 ₽ |
Разъемы DIN | 17.6 ₽ от 5000 ₽ |
Зарядные устройства для сотовых телефонов | 123 ₽ от 5000 ₽ |
PL1358 (PL1359, PL1360, PL1361, PL1362, PL1363, PL1364, PL1365), Кабель USB-Lightning плоский для Apple Iphone 5, 6s, 7 8 pin, цветной, 1м Pro Legend - 17 Фев 2023 02:42 Зарядные устройства для сотовых телефонов | 146 ₽ от 5000 ₽ |
разъемы видео, ТВ | 39.1 ₽ от 5000 ₽ |
драйверы MOSFET и IGBT | 99.4 ₽ от 5000 ₽ |
разъемы видео, ТВ | 36.8 ₽ от 5000 ₽ |
источники опорного напряжения | 134 ₽ от 5000 ₽ |
разъемы видео, ТВ | 146 ₽ от 5000 ₽ |
Микросхемы для импульсных источников питания | 134 ₽ от 5000 ₽ |
27 ЭлектроПласт Санкт-Петербург Россия | |
ли 8+8 PIN DIL SOCKET 1.85mm HIGH T/R 25 Апр 2024 13:00 | запрос 7-14 дней |
ИС, компараторы Lo-Pwr Dual Voltage | запрос 7-14 дней |
28 LifeElectronics Санкт-Петербург Россия | |
MINIATURE FUSES - 5x15 mm | запрос 7-14 дней |
Усилители звука Dual Lo-Volt Pwr Amp | запрос 7-14 дней |
29 ТаймЧипс Санкт-Петербург Россия | |
Генераторы подкачки заряда 3.3VIn to Reg 5Vout Charge Pump | запрос 7-14 дней |
30 TradeElectronics Москва Россия | |
256-Bit Serial CMOS EEPROM (MICROWIRE?„? Synchronous Bus) | запрос 7-14 дней |
31 МосЧип Москва Россия | |
Проводные клеммы и зажимы PIN ASSEMBLY 9P | запрос 7-14 дней |
Высокоскоростные/модульные разъемы PIN CONTACT .156 30 100000 | запрос 7-14 дней |
Bulk Metal Foil Technology 3 Pin Transistor Outline Hermetic Resistor ... Далее 140150/8Bulk Metal Foil Technology 3 Pin Transistor Outline Hermetic Resistor Network | запрос 7-14 дней |
Еще 38 строк | |
Bulk Metal?® Foil Technology 16 Pin Transistor Outline Hermetic ... Далее 1422578-8Bulk Metal?® Foil Technology 16 Pin Transistor Outline Hermetic Resistor Network | запрос 7-14 дней |
Alligator Clip To Pin Tip Jack With Flex Boot | запрос 7-14 дней |
1.57mm (.062) Diameter, Standard .062 Pin and Socket Crimp Terminal, ... Далее 1560205-81.57mm (.062) Diameter, Standard .062 Pin and Socket Crimp Terminal, Series 1560,Male, with Selective Gold (Au) Plated Brass Contact, Tin/ ... | запрос 7-14 дней |
Разъемы стоек и панелей A600 PIN CONT SZ 16 | запрос 7-14 дней |
Разъемы "штырь/гнездо" TYPIII PIN S-TAB BR/AU SIG | запрос 7-14 дней |
Контакты D-Sub PIN CONTACT | запрос 7-14 дней |
... Busbar,2Phase+1/2pole,18Sqmm,;PIN Type,8 Lugs,UL/cUL listed Далее 2P18U3H/8Принадлежности для автоматических выключателей Busbar,2Phase+1/2pole,18Sqmm,;PIN Type,8 Lugs,UL/cUL listed | запрос 7-14 дней |
... выключателей Busbar,2 Phase,18sqmm,PIN Type;8 Lugs, UL/cUL listed Далее 2P18U3S/8Принадлежности для автоматических выключателей Busbar,2 Phase,18sqmm,PIN Type;8 Lugs, UL/cUL listed | запрос 7-14 дней |
32 ЭИК Санкт-Петербург Россия | |
CONN PIN 20-24AWG GOLD CRIMP | 193 ₽ от 1 шт 21-42 дня склад 21848 шт |
Еще 4 цен: … 116 ₽ | |
176 ₽ от 25 шт 21-42 дня склад 21848 шт | |
151 ₽ от 100 шт 21-42 дня склад 21848 шт | |
138 ₽ от 500 шт 21-42 дня склад 21848 шт | |
116 ₽ от 4000 шт 21-42 дня склад 21848 шт | |
Соединитель: CONN PIN 16-18AWG GOLD CRIMP | 188 ₽ от 1 шт 21-42 дня склад 19809 шт |
Еще 4 цен: … 113 ₽ | |
172 ₽ от 25 шт 21-42 дня склад 19809 шт | |
148 ₽ от 100 шт 21-42 дня склад 19809 шт | |
135 ₽ от 500 шт 21-42 дня склад 19809 шт | |
113 ₽ от 4000 шт 21-42 дня склад 19809 шт | |
CONN PIN 20-24AWG GOLD CRIMP | 316 ₽ от 1 шт 21-42 дня склад 4028 шт |
Еще 4 цен: … 170 ₽ | |
295 ₽ от 10 шт 21-42 дня склад 4028 шт | |
254 ₽ от 100 шт 21-42 дня склад 4028 шт | |
201 ₽ от 1000 шт 21-42 дня склад 4028 шт | |
170 ₽ от 10000 шт 21-42 дня склад 4028 шт | |
Еще 55 строк | |
CONN PIN CONTACT SOLDER GOLD | 3 041 ₽ от 10 шт 21-42 дня склад 868 шт |
Еще 3 цен: … 2 813 ₽ | |
2 926 ₽ от 30 шт 21-42 дня склад 868 шт | |
2 872 ₽ от 150 шт 21-42 дня склад 868 шт | |
2 813 ₽ от 500 шт 21-42 дня склад 868 шт | |
CONN PIN 8-10AWG GOLD CRIMP | 2 950 ₽ от 1 шт 21-42 дня склад 74 шт |
Еще 4 цен: … 2 315 ₽ | |
2 668 ₽ от 10 шт 21-42 дня склад 74 шт | |
2 597 ₽ от 25 шт 21-42 дня склад 74 шт | |
2 498 ₽ от 50 шт 21-42 дня склад 74 шт | |
2 315 ₽ от 100 шт 21-42 дня склад 74 шт | |
CONN PIN 16-18AWG TIN CRIMP | 132 ₽ от 1 шт 21-42 дня склад 27059 шт |
Еще 4 цен: … 76.0 ₽ | |
128 ₽ от 25 шт 21-42 дня склад 27059 шт | |
104 ₽ от 100 шт 21-42 дня склад 27059 шт | |
92.0 ₽ от 500 шт 21-42 дня склад 27059 шт | |
76.0 ₽ от 2500 шт 21-42 дня склад 27059 шт | |
CONN PIN 20-24AWG GOLD CRIMP | 210 ₽ от 1 шт 21-42 дня склад 7602 шт |
Еще 4 цен: … 119 ₽ | |
191 ₽ от 25 шт 21-42 дня склад 7602 шт | |
164 ₽ от 100 шт 21-42 дня склад 7602 шт | |
149 ₽ от 500 шт 21-42 дня склад 7602 шт | |
119 ₽ от 4000 шт 21-42 дня склад 7602 шт | |
CONN PIN CONTACT BNC CRIMP GOLD | 418 ₽ от 1 шт 21-42 дня склад 455 шт |
Еще 4 цен: … 245 ₽ | |
382 ₽ от 10 шт 21-42 дня склад 455 шт | |
341 ₽ от 100 шт 21-42 дня склад 455 шт | |
273 ₽ от 1000 шт 21-42 дня склад 455 шт | |
245 ₽ от 5000 шт 21-42 дня склад 455 шт | |
CONN PIN 20-24AWG GOLD CRIMP | 229 ₽ от 1 шт 21-42 дня склад 36410 шт |
Еще 4 цен: … 163 ₽ | |
218 ₽ от 10 шт 21-42 дня склад 36410 шт | |
208 ₽ от 25 шт 21-42 дня склад 36410 шт | |
180 ₽ от 100 шт 21-42 дня склад 36410 шт | |
163 ₽ от 500 шт 21-42 дня склад 36410 шт | |
CONN D-SUB PIN 22-28AWG CRIMP | 355 ₽ от 1 шт 21-42 дня склад 5057 шт |
Еще 4 цен: … 275 ₽ | |
308 ₽ от 10 шт 21-42 дня склад 5057 шт | |
295 ₽ от 25 шт 21-42 дня склад 5057 шт | |
289 ₽ от 50 шт 21-42 дня склад 5057 шт | |
275 ₽ от 100 шт 21-42 дня склад 5057 шт | |
CONN GUIDE PIN CORNER 104CF POS | 4 910 ₽ от 1 шт 21-42 дня склад 11 шт |
Еще 4 цен: … 3 482 ₽ | |
4 053 ₽ от 10 шт 21-42 дня склад 11 шт | |
3 767 ₽ от 25 шт 21-42 дня склад 11 шт | |
3 560 ₽ от 50 шт 21-42 дня склад 11 шт | |
3 482 ₽ от 100 шт 21-42 дня склад 11 шт | |
CONN PIN 14-18AWG TIN CRIMP | 151 ₽ от 1 шт 21-42 дня склад 24961 шт |
Еще 4 цен: … 91.0 ₽ | |
146 ₽ от 25 шт 21-42 дня склад 24961 шт | |
118 ₽ от 100 шт 21-42 дня склад 24961 шт | |
105 ₽ от 500 шт 21-42 дня склад 24961 шт | |
91.0 ₽ от 4000 шт 21-42 дня склад 24961 шт | |
Соединитель: CONN PIN 14-18AWG TIN CRIMP | 169 ₽ от 1 шт 21-42 дня склад 25974 шт |
Еще 4 цен: … 97.0 ₽ | |
163 ₽ от 25 шт 21-42 дня склад 25974 шт | |
132 ₽ от 100 шт 21-42 дня склад 25974 шт | |
117 ₽ от 500 шт 21-42 дня склад 25974 шт | |
97.0 ₽ от 3000 шт 21-42 дня склад 25974 шт | |
CONN PIN 26-30AWG GOLD CRIMP | 216 ₽ от 1 шт 21-42 дня склад 7178 шт |
Еще 4 цен: … 134 ₽ | |
206 ₽ от 10 шт 21-42 дня склад 7178 шт | |
194 ₽ от 50 шт 21-42 дня склад 7178 шт | |
164 ₽ от 250 шт 21-42 дня склад 7178 шт | |
134 ₽ от 1000 шт 21-42 дня склад 7178 шт | |
CONN PIN 10AWG SILVER CRIMP | 928 ₽ от 1 шт 21-42 дня склад 3229 шт |
Еще 4 цен: … 743 ₽ | |
844 ₽ от 10 шт 21-42 дня склад 3229 шт | |
799 ₽ от 25 шт 21-42 дня склад 3229 шт | |
780 ₽ от 50 шт 21-42 дня склад 3229 шт | |
743 ₽ от 100 шт 21-42 дня склад 3229 шт | |
CONN PIN 12-16AWG SILVER CRIMP | 924 ₽ от 1 шт 21-42 дня склад 4188 шт |
Еще 4 цен: … 739 ₽ | |
839 ₽ от 10 шт 21-42 дня склад 4188 шт | |
794 ₽ от 25 шт 21-42 дня склад 4188 шт | |
776 ₽ от 50 шт 21-42 дня склад 4188 шт | |
739 ₽ от 100 шт 21-42 дня склад 4188 шт | |
CONN PIN 18AWG GOLD SOLDER CUP | 201 ₽ от 1 шт 21-42 дня склад 1259 шт |
Еще 2 цен: … 106 ₽ | |
157 ₽ от 100 шт 21-42 дня склад 1259 шт | |
106 ₽ от 5000 шт 21-42 дня склад 1259 шт | |
CONN PIN 24-26AWG GOLD CRIMP | 199 ₽ от 1 шт 21-42 дня склад 19411 шт |
Еще 4 цен: … 120 ₽ | |
182 ₽ от 25 шт 21-42 дня склад 19411 шт | |
157 ₽ от 100 шт 21-42 дня склад 19411 шт | |
142 ₽ от 500 шт 21-42 дня склад 19411 шт | |
120 ₽ от 4000 шт 21-42 дня склад 19411 шт | |
CONN PIN 26-30AWG GOLD CRIMP | 262 ₽ от 1 шт 21-42 дня склад 8576 шт |
Еще 4 цен: … 210 ₽ | |
244 ₽ от 10 шт 21-42 дня склад 8576 шт | |
235 ₽ от 25 шт 21-42 дня склад 8576 шт | |
233 ₽ от 50 шт 21-42 дня склад 8576 шт | |
210 ₽ от 100 шт 21-42 дня склад 8576 шт | |
CONN PIN GOLD SOLDER EYELET | 296 ₽ от 55 шт 21-42 дня склад 485 шт |
283 ₽ от 330 шт 21-42 дня склад 485 шт | |
33 Аудиомания Москва Россия, Беларусь, Казахстан | |
... -A Plug - Mini USB 5 pin), двойной экран, длина 1 ... Далее MUM8002 1.8 m ... - mini USB, позолоченные разъёмы (USB-A Plug - Mini USB 5 pin), двойной экран, длина 1,8 м | 99.0 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 300 ₽ Самовывоз: есть Точки продаж: есть на складе |
34 Промэлектроника Екатеринбург Россия и страны СНГ | |
Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-4811WIПреобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9-Pin PDIP | 5 478 ₽ от 1 шт от 2-10 дней склад 8 шт |
Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт ... Далее TEN 8-1212Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 3 844 ₽ от 1 шт от 2-10 дней склад 2 шт |
Преобразователь DC-DC на печатную плату вход 12В двуполярный выход & ... Далее TEN 8-1223Преобразователь DC-DC на печатную плату вход 12В двуполярный выход ±15В 0.265A/-0.265A 8Вт 9-Pin металлический DIP | 3 278 ₽ от 1 шт от 2-10 дней склад 6 шт |
Еще 12 строк | |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3. ... Далее TEN 8-2410Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3.3В 2A 8Вт 9-Pin металлический DIP | 4 349 ₽ от 1 шт от 2-10 дней склад 15 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9 ... Далее TEN 8-2410WIПреобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9-Pin PDIP | 5 011 ₽ от 1 шт от 2-10 дней склад 10 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-2411WIПреобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9-Pin PDIP | 5 009 ₽ от 1 шт от 2-10 дней склад 283 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт ... Далее TEN 8-2412Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 284 ₽ от 1 шт от 2-10 дней склад 17 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.666A 8Вт ... Далее TEN 8-2412WIПреобразователь DC-DC на печатную плату вход 24В выход 12В 0.666A 8Вт 9-Pin PDIP | 5 737 ₽ от 1 шт от 2-10 дней склад 1 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт ... Далее TEN 8-2413Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт 9-Pin металлический DIP | 3 890 ₽ от 1 шт от 2-10 дней склад 13 шт |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В ... Далее TEN 8-2422Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В/-12В 0.335A/-0.335A 8Вт 9-Pin металлический DIP | 3 834 ₽ от 1 шт от 2-10 дней склад 5 шт |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 15В ... Далее TEN 8-2423Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 15В/-15В 0.265A/-0.265A 8Вт 9-Pin металлический DIP | 3 867 ₽ от 1 шт от 2-10 дней склад 4 шт |
Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт ... Далее TEN 8-4812Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 428 ₽ от 1 шт от 2-10 дней склад 48 шт |
Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.666A 8Вт ... Далее TEN 8-4812WIПреобразователь DC-DC на печатную плату вход 48В выход 12В 0.666A 8Вт 9-Pin PDIP | 5 714 ₽ от 1 шт от 2-10 дней склад 18 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9- ... Далее TEN 8-2411Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9-Pin металлический DIP | 3 794 ₽ от 1 шт от 2-10 дней склад 129 шт |
Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-4811Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9-Pin PDIP | 3 910 ₽ от 1 шт от 2-10 дней склад 4 шт |
35 Industrial Module Москва Россия | |
PIN BUSBAR SHOCKHAZARD SAFETY, 16SQMM 1-PHASE+N, 12MW FULLY INSULATED | 2 176 ₽ 7-28 дней на складе |
8-Port Device Server, 10/100 Ethernet----------------Connectors RS-232 ... Далее NPort 5610-88-Port Device Server, 10/100 Ethernet----------------Connectors RS-232 RJ-45 8pin,------------- 15KV ESD, 110V * | запрос 7-28 дней на складе |
8-Port Device Server, 10/100 Ethernet----------------Connectors RS-232 ... Далее NPort 5610-88-Port Device Server, 10/100 Ethernet----------------Connectors RS-232 RJ-45 8pin,------------- 15KV ESD, 110V * | 68 639 ₽ 7-28 дней на складе |
36 Берёзка Электронные Компоненты Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В ... Далее TEN 8-2422Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В/-12В 0.335A/-0.335A 8Вт 9-Pin металлический DIP | 4 254 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 491 ₽ | |
3 883 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 652 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 491 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт ... Далее TEN 8-1212Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 164 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 415 ₽ | |
3 800 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 573 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 415 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 12В двуполярный выход & ... Далее TEN 8-1223Преобразователь DC-DC на печатную плату вход 12В двуполярный выход ±15В 0.265A/-0.265A 8Вт 9-Pin металлический DIP | 3 636 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 2 977 ₽ | |
3 317 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 116 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
2 977 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Еще 11 строк | |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3. ... Далее TEN 8-2410Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3.3В 2A 8Вт 9-Pin металлический DIP | 4 057 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 528 ₽ | |
3 775 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 596 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 528 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9 ... Далее TEN 8-2410WIПреобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9-Pin PDIP | 5 402 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 444 ₽ | |
4 937 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 646 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 444 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9- ... Далее TEN 8-2411Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9-Pin металлический DIP | 4 054 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 324 ₽ | |
3 700 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 478 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 324 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-2411WIПреобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9-Pin PDIP | 4 809 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 951 ₽ | |
4 392 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 132 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 951 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт ... Далее TEN 8-2412Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 489 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 685 ₽ | |
4 099 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 854 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 685 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.666A 8Вт ... Далее TEN 8-2412WIПреобразователь DC-DC на печатную плату вход 24В выход 12В 0.666A 8Вт 9-Pin PDIP | 5 378 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 424 ₽ | |
4 914 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 625 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 424 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт ... Далее TEN 8-2413Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт 9-Pin металлический DIP | 4 126 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 383 ₽ | |
3 765 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 540 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 383 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В ... Далее TEN 8-2421WIПреобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В/-5В 0.8A/-0.8A 8Вт 9-Pin PDIP | 5 881 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 843 ₽ | |
5 376 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
5 061 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 843 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-4811WIПреобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9-Pin PDIP | 5 817 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 790 ₽ | |
5 318 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
5 006 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 790 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт ... Далее TEN 8-4812Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 424 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 631 ₽ | |
4 039 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 798 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 631 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 110В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-7211WIПреобразователь DC-DC на печатную плату вход 110В выход 5В 1.6A 8Вт 9-Pin металлический DIP | 7 180 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 5 929 ₽ | |
6 571 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
6 192 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
5 929 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
37 ICdarom.ru Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт ... Далее TEN 8-1212Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 3 999 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 279 ₽ | |
3 650 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 431 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 279 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 12В двуполярный выход & ... Далее TEN 8-1223Преобразователь DC-DC на печатную плату вход 12В двуполярный выход ±15В 0.265A/-0.265A 8Вт 9-Pin металлический DIP | 3 492 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 2 859 ₽ | |
3 185 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
2 993 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
2 859 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3. ... Далее TEN 8-2410Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3.3В 2A 8Вт 9-Pin металлический DIP | 4 442 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 648 ₽ | |
4 056 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 815 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 648 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Еще 10 строк | |
Преобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9 ... Далее TEN 8-2410WIПреобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9-Pin PDIP | 5 189 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 268 ₽ | |
4 741 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 462 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 268 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9- ... Далее TEN 8-2411Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9-Pin металлический DIP | 3 893 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 193 ₽ | |
3 553 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 340 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 193 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-2411WIПреобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9-Pin PDIP | 4 618 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 794 ₽ | |
4 218 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 968 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 794 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт ... Далее TEN 8-2412Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 311 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 539 ₽ | |
3 936 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 702 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 539 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт ... Далее TEN 8-2413Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт 9-Pin металлический DIP | 3 962 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 249 ₽ | |
3 616 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 399 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 249 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В ... Далее TEN 8-2421WIПреобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В/-5В 0.8A/-0.8A 8Вт 9-Pin PDIP | 5 648 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 651 ₽ | |
5 163 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 861 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 651 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В ... Далее TEN 8-2422Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В/-12В 0.335A/-0.335A 8Вт 9-Pin металлический DIP | 4 085 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 353 ₽ | |
3 730 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 507 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 353 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-4811WIПреобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9-Pin PDIP | 5 587 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 600 ₽ | |
5 107 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 808 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 600 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт ... Далее TEN 8-4812Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 249 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 487 ₽ | |
3 879 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 648 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 487 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 110В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-7211WIПреобразователь DC-DC на печатную плату вход 110В выход 5В 1.6A 8Вт 9-Pin металлический DIP | 6 896 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 5 694 ₽ | |
6 311 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
5 946 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
5 694 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
38 ЧипСити Москва Россия | |
Conn Power PIN 8POS 4.2mm Solder RA Thru-Hole 8 Terminal 1Port Tray | 81.1 ₽ 3-7 дней склад 6369 шт |
Conn Power PIN 3POS 5mm Solder ST Thru-Hole 3 Terminal 1Port | 701 ₽ 3-7 дней склад 891 шт |
Conn Power PIN 4POS 5mm Solder ST Thru-Hole 4 Terminal 1Port | 583 ₽ 3-7 дней склад 696 шт |
Еще 136 строк | |
Socket; PIN:11; 10A; 250VAC; Mounting: DIN; Leads: screw; Series: MT | 1 042 ₽ 3-7 дней склад 2282 шт |
Conn Backplane PIN 240POS 2mm Press Fit ST Thru-Hole | 1 975 ₽ 3-7 дней склад 937 шт |
Conn Backplane PIN 168POS 2mm Solder RA Thru-Hole | 2 940 ₽ 3-7 дней склад 992 шт |
Stainless Steal 3mm 10AWG Crimp Pin Contact Drawer Connector | 871 ₽ 3-7 дней склад 3141 шт |
Connector Accessories Guide/Power Pin | 98.7 ₽ 3-7 дней склад 1047 шт |
Connector Accessories Guide/Power Pin | 142 ₽ 3-7 дней склад 1009 шт |
CONN PIN 26-30AWG GOLD CRIMP | 51.5 ₽ 3-7 дней склад 15928 шт |
Contact PIN Crimp ST Cable Mount Loose Piece | 633 ₽ 3-7 дней склад 810 шт |
CONN CONT PIN 12-16AWG TIN CRIMP | 118 ₽ 3-7 дней склад 992 шт |
Conn D-Subminiature PIN 9POS 2.74mm Solder RA Thru-Hole 9 Terminal ... Далее 8-1393480-5Conn D-Subminiature PIN 9POS 2.74mm Solder RA Thru-Hole 9 Terminal 1Port | 423 ₽ 3-7 дней склад 878 шт |
Conn D-Subminiature PIN 9POS Crimp ST Cable Mount 9 Terminal 1Port Kit | 932 ₽ 3-7 дней склад 1373 шт |
Conn D-Subminiature PIN 9POS 2.74mm Solder RA Thru-Hole 9 Terminal ... Далее 5745434-8Conn D-Subminiature PIN 9POS 2.74mm Solder RA Thru-Hole 9 Terminal 1Port | 1 245 ₽ 3-7 дней склад 1161 шт |
Conn D-Subminiature PIN 15POS 2.74mm Solder RA Thru-Hole 15 Terminal ... Далее 5745435-8Conn D-Subminiature PIN 15POS 2.74mm Solder RA Thru-Hole 15 Terminal 1Port | 2 695 ₽ 3-7 дней склад 531 шт |
Conn D-Subminiature PIN 15POS 2.76mm IDT ST Panel Mount 15 Terminal ... Далее 747531-8Conn D-Subminiature PIN 15POS 2.76mm IDT ST Panel Mount 15 Terminal 1Port Package | 650 ₽ 3-7 дней склад 1229 шт |
Conn D-Subminiature PIN 25POS 2.77mm Crimp ST Cable Mount 25 Terminal ... Далее 745211-8Conn D-Subminiature PIN 25POS 2.77mm Crimp ST Cable Mount 25 Terminal 1Port | 1 290 ₽ 3-7 дней склад 1018 шт |
Conn D-Subminiature PIN 7Coaxial/17Signal POS Solder ST Thru-Hole 24 ... Далее 208743-8Conn D-Subminiature PIN 7Coaxial/17Signal POS Solder ST Thru-Hole 24 Terminal 1Port | 3 842 ₽ 3-7 дней склад 1064 шт |
Conn LGH PIN 7POS Crimp ST Cable Mount 7 Terminal 1Port | 9 650 ₽ 3-7 дней склад 117 шт |
39 РИВ Электроникс Москва Россия | |
Минимум 5шт. | 17.1 ₽ от 5 шт мин заказ 5 шт Да |
Еще 6 цен: | |
13.0 ₽ от 92 шт мин заказ 5 шт Да | |
11.4 ₽ от 540 шт мин заказ 5 шт Да | |
10.0 ₽ от 2300 шт мин заказ 5 шт Да | |
9.68 ₽ от 5700 шт мин заказ 5 шт Да | |
8.98 ₽ от 12000 шт мин заказ 5 шт Да | |
запрос от 0 шт мин заказ 5 шт Да | |
40 Whitegoods Москва Россия Hurakan | |
Плата генератора Hurakan 8PIN универсальная для индукционной плиты ... Далее 8PIN универсальная - 374646Плата генератора Hurakan 8PIN универсальная для индукционной плиты Hurakan. Без микропроцессора, подходит для всех моделей. | 7 098 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
... -ICF35DX4, HKN-ICF35DX47. Особенности (8 pin.) Новая модель NS-935G с ... Далее LM73 - 374527 ... индукционной Hurakan модели HKN-ICF70D2V, HKN-ICF35DX4, HKN-ICF35DX47. Особенности (8 pin.) Новая модель NS-935G с апреля 2021. | 4 053 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
... Hurakan модели HKN-ICF35DX4. Особенности 8 pin). A-817 c 35А bridge ... Далее HKN-ICF35DX4 - 217861 ... -ICF35DX4 предназначена для плиты индукционной Hurakan модели HKN-ICF35DX4. Особенности 8 pin). A-817 c 35А bridge. | 7 098 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
41 Romstore Москва Россия, Беларусь | |
Кнопка №8 4pin 6x6x7 SWT-6 25 Апр 2024 02:14 | 15.0 ₽ розница |
5.00 ₽ опт | |
Кнопка №6 4pin 4.5x4.5x3.8 25 Апр 2024 02:14 | 15.0 ₽ розница |
5.00 ₽ опт | |
Тест-клипса (прищепка) SOIC8 с кабелем 25 Апр 2024 02:14 DIP8 в SOIC8-150-170-200-208mil, pin-to-pin, = SA602A | 950 ₽ розница |
790 ₽ опт | |
Еще 3 строки | |
Tuner TDQ-38HS 8pin 25 Апр 2024 02:14 | 1 000 ₽ розница |
795 ₽ опт | |
74AC299PC 25 Апр 2024 02:14 8-input universal shift/storage register with common parallel I/O pins ... Далее 74AC299PC8-input universal shift/storage register with common parallel I/O pins, КР1554ИР24 | 25.0 ₽ розница |
18.0 ₽ опт | |
HMS8-W (DIP8-MSOP8) 25 Апр 2024 02:14 8pin MSOP 3x3мм, шаг 0,65мм, pin-to-pin, панель Wells, = AE-SP8U TSU- ... Далее HMS8-W (DIP8-MSOP8)8pin MSOP 3x3мм, шаг 0,65мм, pin-to-pin, панель Wells, = AE-SP8U TSU-D08/MS08-3x3 | 2 990 ₽ опт |
2 990 ₽ розница | |
42 Кремний Санкт-Петербург Россия и страны СНГ | |
запрос 7-14 дней | |
Разьем микрофонный круглый вилка кабельная 8 pin 25 Апр 2024 13:00 | запрос 2 недели |
Еще 8 строк | |
8-pin DIL IC sockets Black plastic high or low profile 25 Апр 2024 13:00 | запрос 2 недели |
8-PIN-SM 25 Апр 2024 13:00 | запрос 7-14 дней |
DIP SWITCH 8 PIN PIANO 25 Апр 2024 13:00 | запрос 7-14 дней |
IC SOCKET 8 PIN 25 Апр 2024 13:00 | запрос 7-14 дней |
IC SOCKET 8 PIN D/C98 25 Апр 2024 13:00 | запрос 7-14 дней |
IC SOCKET 8 PIN D/C99 25 Апр 2024 13:00 | запрос 7-14 дней |
OP07CS-SMD (8 PIN) D/C97 25 Апр 2024 13:00 | запрос 7-14 дней |
43 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
CONN PLUG 4 POS STRAIGHT W/PINS | запрос 7-14 дней |
... характеристики соединителя 4P Size 8 Pin Plug Strt Strain Relief Далее PT06A-8-4P-SRКруговой мил / технические характеристики соединителя 4P Size 8 Pin Plug Strt Strain Relief | запрос 7-14 дней |
... характеристики соединителя 2P Size 8 Pin Plug R/A Strain Relief Далее PT08E-8-2P-SRКруговой мил / технические характеристики соединителя 2P Size 8 Pin Plug R/A Strain Relief | запрос 7-14 дней |
Еще 363 строки | |
... / технические характеристики соединителя 3P Size 8 Straight Pin Plug Далее PT06E-8-3PКруговой мил / технические характеристики соединителя 3P Size 8 Straight Pin Plug | запрос 7-14 дней |
... характеристики соединителя 3P Size 8 Jam Nut Pin Receptacle Далее PT07A-8-3PКруговой мил / технические характеристики соединителя 3P Size 8 Jam Nut Pin Receptacle | запрос 7-14 дней |
... характеристики соединителя 4P Size 8 Jam Nut Pin Receptacle Далее PT07A-8-4P (023)Круговой мил / технические характеристики соединителя 4P Size 8 Jam Nut Pin Receptacle | запрос 7-14 дней |
CORD PATCH PIN TIP PLUG 8 BLACK | запрос 7-14 дней |
... Ethernet 6 TRMN BRD GRND PINS 8 PIN BLOCK INDUCTOR Далее RJ45-6LC2-BМодульные соединители / соединители Ethernet 6 TRMN BRD GRND PINS 8 PIN BLOCK INDUCTOR | запрос 7-14 дней |
8-BIT OTP/EPROM MCUs WITH ... SAFEGUARD, SAFE RESET AND 16 PINS | запрос 7-14 дней |
LOW VOLTAGE 8-BIT ROM MCUs WITH A/D CONVERTER,AND 16 PINS | запрос 7-14 дней |
8-BIT OTP/EPROM MCUs WITH ... SAFEGUARD, SAFE RESET AND 20 PINS | запрос 7-14 дней |
8-BIT OTP/EPROM MCUs WITH ... SAFEGUARD, SAFE RESET AND 28 PINS | запрос 7-14 дней |
44 Океан Электроники Санкт-Петербург Россия | |
... технические характеристики соединителя 4P Size 8 Pin Plug Right Angle Далее PT08E-8-4P (SR)Круговой мил / технические характеристики соединителя 4P Size 8 Pin Plug Right Angle | запрос 7-14 дней |
8 PIN DIP HCMOS | запрос 7-14 дней |
... характеристики соединителя 3P Size 8 Jam Nut Pin Recpt Str Relief Далее PT07A-8-3P (SR)Круговой мил / технические характеристики соединителя 3P Size 8 Jam Nut Pin Recpt Str Relief | запрос 7-14 дней |
Еще 308 строк | |
... характеристики соединителя 4P Size 8 Jam Nut Pin Receptacle Далее PT07A-8-4P (424)Круговой мил / технические характеристики соединителя 4P Size 8 Jam Nut Pin Receptacle | запрос 7-14 дней |
... характеристики соединителя 2P Sz 8 Jam Nut Pin Recept Strain Relief Далее PT07E-8-2P (SR)Круговой мил / технические характеристики соединителя 2P Sz 8 Jam Nut Pin Recept Strain Relief | запрос 7-14 дней |
... характеристики соединителя 4P Sz 8 Jam Nut Pin Recept Strain Relief Далее PT07E-8-4P (SR)Круговой мил / технические характеристики соединителя 4P Sz 8 Jam Nut Pin Recept Strain Relief | запрос 7-14 дней |
... характеристики соединителя 3P Size 8 Recept Pin Thru Bulkhead Далее PTB-8-3PSКруговой мил / технические характеристики соединителя 3P Size 8 Recept Pin Thru Bulkhead | запрос 7-14 дней |
SS-103-G-8 25 Апр 2024 13:00 Базовые выключатели / Выключатели мгновенного действия Pin plunger ... Далее SS-103-G-8Базовые выключатели / Выключатели мгновенного действия Pin plunger 150gf 10.1A SPDT Solder | запрос 7-14 дней |
... / соединители Ethernet 8 TRMN BRD GRND PINS 8 PIN SLEEVE INDUCTR Далее RJ45-8LCT2-BМодульные соединители / соединители Ethernet 8 TRMN BRD GRND PINS 8 PIN SLEEVE INDUCTR | запрос 7-14 дней |
Реле общего назначения DPDT 8 A 24VDC PC PINS | запрос 7-14 дней |
LOW VOLTAGE 8-BIT ROM MCUs WITH A/D CONVERTER AND 20 PINS | запрос 7-14 дней |
45 Зенер Москва Россия и страны ТС | |
CONN PIN CONTACT SOLDER GOLD | запрос 5-15 дней |
CONN CONT PIN 12-16AWG TIN CRIMP | запрос 5-15 дней |
PIN,.062 DIA,.045 SQ POST,LP | запрос 5-15 дней |
Еще 283 строки | |
CONTACT PIN 17-20AWG CRIMP GOLD | запрос 5-15 дней |
JT 6C 6#22D PIN PLUG | 5 844 ₽ от 5 шт |
Еще 7 цен: … 3 066 ₽ | |
4 969 ₽ от 10 шт | |
4 345 ₽ от 25 шт | |
3 887 ₽ от 50 шт | |
3 343 ₽ от 100 шт | |
3 112 ₽ от 250 шт | |
3 089 ₽ от 500 шт | |
3 066 ₽ от 1000 шт | |
JT 6C 6#22D PIN PLUG | запрос 5-15 дней |
JT 6C 6#22D PIN RECP | запрос 5-15 дней |
CONN PIN CONTACT BNC SOLDER GOLD | запрос 5-15 дней |
CONN PIN CONTACT BNC CRIMP GOLD | запрос 5-15 дней |
CONN PIN CONTACT BNC SOLDR SILVR | запрос 5-15 дней |
CONN PIN CONTACT BNC CRIMP GOLD | 235 ₽ от 1 шт 5-15 дней склад 546 шт |
Еще 8 цен: … 122 ₽ | |
205 ₽ от 10 шт 5-15 дней склад 546 шт | |
196 ₽ от 25 шт 5-15 дней склад 546 шт | |
191 ₽ от 50 шт 5-15 дней склад 546 шт | |
183 ₽ от 100 шт 5-15 дней склад 546 шт | |
165 ₽ от 250 шт 5-15 дней склад 546 шт | |
152 ₽ от 500 шт 5-15 дней склад 546 шт | |
131 ₽ от 1000 шт 5-15 дней склад 546 шт | |
122 ₽ от 2500 шт 5-15 дней склад 546 шт | |
CONTACT PIN COAX CABLE 316DS GLD | запрос 5-15 дней |
CONTACT PIN 10AWG CRIMP SILVER | запрос 5-15 дней |
CONN PIN 12-16 AWG SILVER CRIMP | запрос 5-15 дней склад 6150 шт |
CONN PIN 16-18AWG TIN CRIMP | 79.0 ₽ от 1 шт 5-15 дней склад 13272 шт |
Еще 10 цен: … 35.1 ₽ | |
69.2 ₽ от 10 шт 5-15 дней склад 13272 шт | |
63.2 ₽ от 25 шт 5-15 дней склад 13272 шт | |
59.5 ₽ от 50 шт 5-15 дней склад 13272 шт | |
57.0 ₽ от 100 шт 5-15 дней склад 13272 шт | |
52.1 ₽ от 250 шт 5-15 дней склад 13272 шт | |
49.6 ₽ от 500 шт 5-15 дней склад 13272 шт | |
40.9 ₽ от 1000 шт 5-15 дней склад 13272 шт | |
39.2 ₽ от 4000 шт 5-15 дней склад 13272 шт | |
35.9 ₽ от 8000 шт 5-15 дней склад 13272 шт | |
35.1 ₽ от 12000 шт 5-15 дней склад 13272 шт | |
CONN PIN 20-24AWG TIN CRIMP | 53.6 ₽ от 10 шт 5-15 дней склад 54211 шт |
Еще 5 цен: … 36.1 ₽ | |
47.9 ₽ от 100 шт 5-15 дней склад 54211 шт | |
46.2 ₽ от 250 шт 5-15 дней склад 54211 шт | |
44.5 ₽ от 500 шт 5-15 дней склад 54211 шт | |
38.7 ₽ от 1000 шт 5-15 дней склад 54211 шт | |
36.1 ₽ от 2500 шт 5-15 дней склад 54211 шт | |
CONN PIN .062 14-18AWG TIN CRIMP | 74.0 ₽ от 1 шт 5-15 дней склад 828 шт |
Еще 11 цен: … 32.2 ₽ | |
64.3 ₽ от 10 шт 5-15 дней склад 828 шт | |
58.8 ₽ от 25 шт 5-15 дней склад 828 шт | |
55.3 ₽ от 50 шт 5-15 дней склад 828 шт | |
53.0 ₽ от 100 шт 5-15 дней склад 828 шт | |
48.4 ₽ от 250 шт 5-15 дней склад 828 шт | |
46.1 ₽ от 500 шт 5-15 дней склад 828 шт | |
38.0 ₽ от 1000 шт 5-15 дней склад 828 шт | |
37.1 ₽ от 4000 шт 5-15 дней склад 828 шт | |
33.4 ₽ от 8000 шт 5-15 дней склад 828 шт | |
32.9 ₽ от 12000 шт 5-15 дней склад 828 шт | |
32.2 ₽ от 28000 шт 5-15 дней склад 828 шт | |
CONN PLUG 8 POS STRAIGHT W/PINS | 7 619 ₽ от 5 шт |
Еще 3 цен: … 5 944 ₽ | |
6 572 ₽ от 10 шт | |
6 279 ₽ от 25 шт | |
5 944 ₽ от 50 шт | |
46 СЭлКом Москва Россия и страны СНГ | |
Акция! / | 48.9 ₽ розница 1-7 дней склад 9 шт |
47 Onber.ru Москва Россия и страны СНГ | |
Кабель питания HPE DL380 Gen10 8-pin Cable Kit (for Q0V76A and ... Далее Кабель питания HP 871828-B21Кабель питания HPE DL380 Gen10 8-pin Cable Kit (for Q0V76A and Q0J62A) | запрос 100% предоплата. Минимальная... Далее 100% предоплата. Минимальная сумма заказа 5000 р. Самовывоз: есть под заказ |
Cable Network 1000 Base-T RJ45 8-pin | 327 ₽ 100% предоплата. Минимальная... Далее 100% предоплата. Минимальная сумма заказа 5000 р. Самовывоз: есть под заказ |
48 AliExpress Китай Весь мир | |
86.5 ₽ от 21 дня | |
58.4 ₽ от 21 дня | |
48.6 ₽ от 21 дня | |
Еще 17 строк | |
324 ₽ от 21 дня | |
230 ₽ от 6 шт 6 шт/лот от 21 дня | |
16.2 ₽ от 1 шт от 21 дня | |
69.2 ₽ от 21 дня | |
15.1 ₽ от 1 шт от 21 дня | |
80.5 ₽ от 20 шт 20 шт/лот от 21 дня | |
134 ₽ от 21 дня | |
819 ₽ от 21 дня | |
819 ₽ от 21 дня | |
316 ₽ от 21 дня | |
91.6 ₽ от 5 шт 5 шт/лот от 21 дня | |
60.5 ₽ от 10 шт 10 шт/лот от 21 дня | |
307 ₽ от 21 дня | |
324 ₽ от 21 дня | |
1 728 ₽ от 21 дня | |
151 ₽ от 21 дня |
Искать "8-pin" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 92.5058 |
EUR | 98.9118 |
