1 Flash-Turtle Китай Весь мир | |
8 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.138 ( ... Далее 1776099-88 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.138 (3.50mm) Vertical Through Hole | запрос 7 дней склад 10268 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.138 ( ... Далее 1776134-88 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.138 (3.50mm) 90°, Right Angle Through Hole | запрос 7 дней склад 10768 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.200 ( ... Далее 1776139-88 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.200 (5.08mm) Vertical Through Hole | запрос 7 дней склад 40341 шт |
Еще 14 строк | |
8 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.200 ( ... Далее 1776141-88 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.200 (5.08mm) 90°, Right Angle Through Hole | запрос 7 дней склад 41255 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.295 ( ... Далее 1776149-88 Position Terminal Block Header, Male Pins, Shrouded (2 Side) 0.295 (7.50mm) Vertical Through Hole | запрос 7 дней склад 37009 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.200 ( ... Далее 284008-88 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.200 (5.08mm) 90°, Right Angle Through Hole | запрос 7 дней склад 33045 шт |
8 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 ( ... Далее EDSTL950/88 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 (5.00mm) 90°, Right Angle Solder | запрос 7 дней склад 21992 шт |
16 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 ... Далее 1776166-816 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 (5.00mm) 90°, Right Angle Through Hole | запрос 7 дней склад 6483 шт |
96 Position Din Connector Plug, Male Pins Gold or Gold-Palladium ... Далее 8-1393644-796 Position Din Connector Plug, Male Pins Gold or Gold-Palladium Through Hole, Right Angle | запрос 7 дней склад 23851 шт |
96 Position Shroud for Male Pins Connector Gray Through Hole DIN 41612 ... Далее 533236-896 Position Shroud for Male Pins Connector Gray Through Hole DIN 41612, Type C, Type R | запрос 7 дней склад 28238 шт |
TE Connectivity Aerospace, Defense and Marine 66256-8 TE Connectivity Aerospace, Defense and Marine - 14 Мар 2024 10:03 Pin Contact Tin Crimp 12-16 AWG Power, Stamped | запрос 7 дней склад 16127 шт |
2 kOhms 0.75W, 3/4W PC Pins Through Hole Trimmer Potentiometer Cermet ... Далее TE Connectivity Passive Product 1623866-82 kOhms 0.75W, 3/4W PC Pins Through Hole Trimmer Potentiometer Cermet 15.0 Turn Side Adjustment | запрос 7 дней склад 21519 шт |
Contact Crimp Pin Tin-Lead | запрос 7 дней склад 32185 шт |
Pin Contact Silver 18.5-20 AWG Crimp Stamped | запрос 7 дней склад 19636 шт |
TE Connectivity Aerospace, Defense and Marine 5225550-8 TE Connectivity Aerospace, Defense and Marine - 14 Мар 2024 10:03 TNC Connector Plug, Male Pin | запрос 7 дней склад 7543 шт |
16 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.150 ... Далее EDSTLZ1570/816 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.150 (3.81mm) 90°, Right Angle Solder | запрос 7 дней склад 49661 шт |
16 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 ... Далее EDSTL971/816 Position Terminal Block Header, Male Pins, Shrouded (4 Side) 0.197 (5.00mm) 90°, Right Angle Solder | запрос 7 дней склад 8214 шт |
2 ChipWorker Китай Весь мир | |
192 ₽ 2-7 дней отгрузка со склада в Китае склад 50 шт | |
834 ₽ 2-7 дней отгрузка со склада в Китае склад 1641 шт | |
564 ₽ 2-7 дней отгрузка со склада в Китае склад 216 шт | |
3 AiPCBA Китай Весь мир | |
4 Akcel Китай Весь мир | |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC Tube | запрос от 1 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос от 1 шт |
Еще 162 строки | |
Power to the Board MATENLOK PIN | 34.9 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 29.3 ₽ | |
32.9 ₽ от 10 шт 5-7 дней склад 1 шт | |
31.1 ₽ от 100 шт 5-7 дней склад 1 шт | |
29.3 ₽ от 1000 шт 5-7 дней склад 1 шт | |
CONN HEADER PIN 10POS VERT GOLD | 1 620 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 1 360 ₽ | |
1 528 ₽ от 10 шт 5-7 дней склад 1 шт | |
1 442 ₽ от 100 шт 5-7 дней склад 1 шт | |
1 360 ₽ от 1000 шт 5-7 дней склад 1 шт | |
CONN PIN RCPT .034-.041 SOLDER | 68.9 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 57.9 ₽ | |
65.0 ₽ от 10 шт 5-7 дней склад 1 шт | |
61.3 ₽ от 100 шт 5-7 дней склад 1 шт | |
57.9 ₽ от 1000 шт 5-7 дней склад 1 шт | |
Headers & Wire Housings MINI BX PIN HDR ASY 110 POS RA | запрос от 1 шт |
High Speed / Modular Connectors HDI PIN ASSY 3 ROW 1 120 | запрос от 1 шт |
CONN HEADER PIN 18POS VERT GOLD | 1 718 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 1 442 ₽ | |
1 620 ₽ от 10 шт 5-7 дней склад 1 шт | |
1 529 ₽ от 100 шт 5-7 дней склад 1 шт | |
1 442 ₽ от 1000 шт 5-7 дней склад 1 шт | |
Headers & Wire Housings 08P AMPMODU II PIN HDR. | запрос от 1 шт |
D-Sub Contacts AMPLI PIN CONT SZ 22 | 768 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 645 ₽ | |
725 ₽ от 10 шт 5-7 дней склад 1 шт | |
684 ₽ от 100 шт 5-7 дней склад 1 шт | |
645 ₽ от 1000 шт 5-7 дней склад 1 шт | |
Standard Circular Contacts TYPE III + PIN 30-26 Reel of 1000 | запрос от 1 шт |
Standard Circular Contacts III+ PIN,24-20, Cut Strip of 100 | запрос от 1 шт |
Standard Circular Contacts PIN 18-14 BR/SN SIG Reel of 1000 | запрос от 1 шт |
Mechanical Encoder Rotary Incremental Flat Straight Quadrature Digital ... Далее 8-1879323-9Mechanical Encoder Rotary Incremental Flat Straight Quadrature Digital Square Wave 20PPR Through Hole PC Pin | запрос от 1 шт |
5 Utmel Китай Весь мир | |
... , 5 - 8 mm² Wire Size, Wire & Cable, Crimp, Power, Pin, AMP POWERBAND Далее 213841-8Power Contacts, Contact, 600 VAC, 600 VDC, Gold, 10 - 8 AWG Wire Size, 5 - 8 mm² Wire Size, Wire & Cable, Crimp, Power, Pin, AMP POWERBAND | запрос от 1 шт 5-7 дней склад 1161 шт |
8.0MM PIN CONTACT ASM 25MM2 | 2 371 ₽ от 1 шт 5-7 дней склад 4 шт |
Еще 3 цен: … 1 991 ₽ | |
2 237 ₽ от 10 шт 5-7 дней склад 4 шт | |
2 110 ₽ от 100 шт 5-7 дней склад 4 шт | |
1 991 ₽ от 1000 шт 5-7 дней склад 4 шт | |
8.0MM PIN INSULATION | 724 ₽ от 1 шт 5-7 дней склад 108 шт |
Еще 3 цен: … 608 ₽ | |
683 ₽ от 10 шт 5-7 дней склад 108 шт | |
644 ₽ от 100 шт 5-7 дней склад 108 шт | |
608 ₽ от 1000 шт 5-7 дней склад 108 шт | |
Еще 85 строк | |
8.0MM PIN CONTACT ASM 35MM2 | 2 371 ₽ от 1 шт 5-7 дней склад 15 шт |
2 237 ₽ от 10 шт 5-7 дней склад 15 шт | |
2 110 ₽ от 100 шт 5-7 дней склад 15 шт | |
1 991 ₽ от 1000 шт 5-7 дней склад 15 шт | |
8.0MM PIN CONTACT ASM 50MM2 | 2 371 ₽ от 1 шт 5-7 дней склад 9 шт |
2 237 ₽ от 10 шт 5-7 дней склад 9 шт | |
2 110 ₽ от 100 шт 5-7 дней склад 9 шт | |
1 991 ₽ от 1000 шт 5-7 дней склад 9 шт | |
Hall Effect Sensor 40mA Unipolar 1.8V/2.5V/3.3V/5V/9V/12V/15V/18V/24V ... Далее 103SR13A-8Hall Effect Sensor 40mA Unipolar 1.8V/2.5V/3.3V/5V/9V/12V/15V/18V/24V 3-Pin | запрос от 1 шт 5-7 дней склад 3265 шт |
PINCER GRAY 0.032 PIN | 713 ₽ от 1 шт 5-7 дней склад 56 шт |
Еще 3 цен: … 599 ₽ | |
673 ₽ от 10 шт 5-7 дней склад 56 шт | |
635 ₽ от 100 шт 5-7 дней склад 56 шт | |
599 ₽ от 1000 шт 5-7 дней склад 56 шт | |
Module DC-DC 4-OUT 12V/12V/12V/12V 0.7A/0.7A/0.7A/0.7A 35W 17-Pin | 12 588 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 10 569 ₽ | |
11 875 ₽ от 10 шт 5-7 дней склад 1 шт | |
11 203 ₽ от 100 шт 5-7 дней склад 1 шт | |
10 569 ₽ от 1000 шт 5-7 дней склад 1 шт | |
Mechanical Encoder Rotary Flat 16oz.in Straight BCD 8PPR Through Hole ... Далее 513360-8Mechanical Encoder Rotary Flat 16oz.in Straight BCD 8PPR Through Hole PC Pins | запрос от 1 шт 5-7 дней склад 3766 шт |
Crimp Wire Pins, Tabs & Ferrules, Ferrule, 14 AWG Wire Size, 2.5 mm² ... Далее 966289-8Crimp Wire Pins, Tabs & Ferrules, Ferrule, 14 AWG Wire Size, 2.5 mm² Wire Size, 2583 - 3257 CMA Wire Size, .164 in [4.2 mm] Barrel Inside ... | запрос от 1 шт 5-7 дней склад 6633 шт |
FFC Connectors, Header, Wire-to-Board, 14 Position, 2.54 mm [.1 in] ... Далее 1888292-8FFC Connectors, Header, Wire-to-Board, 14 Position, 2.54 mm [.1 in] Centerline, 2 Row, Right Angle, Pin, Package, Mating Retention | запрос от 1 шт 5-7 дней склад 1248 шт |
Barrier Strips, Dual Barrier, Printed Circuit Pin, Wire-to-Board, 4 ... Далее 796985-8Barrier Strips, Dual Barrier, Printed Circuit Pin, Wire-to-Board, 4 Position, 9.53 mm [.375 in] Centerline, 1 Row, 300 V / 600 V | запрос от 1 шт 5-7 дней склад 4264 шт |
Standard Circular Connectors, Stainless Steel, N Polarization Code, ... Далее FDBA 50-8 E1 PN 090 A838Standard Circular Connectors, Stainless Steel, N Polarization Code, Square Flange Receptacle, Pin, -55 - 200 °C, DEUTSCH FDBA | запрос от 1 шт 5-7 дней склад 2476 шт |
Pin Sockets, Socket Length 6.53 mm [.257 in], PCB Hole Diameter .062 ... Далее 5050864-8Pin Sockets, Socket Length 6.53 mm [.257 in], PCB Hole Diameter .062 in [1.57 mm], Open Bottom, .326 - .518 mm² Wire Size, 22 - 20 AWG Wire ... | запрос от 1 шт 5-7 дней склад 1473 шт |
Connector Contacts, Pin, Gold Flash, Gold Flash, 250 VAC, Locking ... Далее 207438-8Connector Contacts, Pin, Gold Flash, Gold Flash, 250 VAC, Locking Lance Contact Retention, Discrete Wire, 28 - 22 AWG Wire Size | запрос от 1 шт 5-7 дней склад 3659 шт |
Power Contacts, Contact, Gold, 32 AWG Wire Size, .03 mm² Wire Size, ... Далее 66460-8Power Contacts, Contact, Gold, 32 AWG Wire Size, .03 mm² Wire Size, Wire & Cable, Wire Wrap, Power & Signal, Pin, AMP Type III+ | запрос от 1 шт 5-7 дней склад 6270 шт |
Connector Contact, Pin, Wire-to-Board, Gold, Reel, Printed Circuit ... Далее 215345-8Connector Contact, Pin, Wire-to-Board, Gold, Reel, Printed Circuit Board, 3 A, Signal, Board Mount, -85 - 221 °F [-65 - 125 °C], ... | запрос от 1 шт 5-7 дней склад 3849 шт |
Automotive Terminals, Socket, Pin Diameter .051 in [1.3 mm], 20 - 22 ... Далее 770520-8Automotive Terminals, Socket, Pin Diameter .051 in [1.3 mm], 20 - 22 AWG Wire Size, .35 - .5 mm² Wire Size, Family Seal, Locking On the ... | запрос от 1 шт 5-7 дней склад 2233 шт |
Connector Contact, Pin, Tin-Lead, Straight, Printed Circuit Board, 5 A ... Далее 85842-8Connector Contact, Pin, Tin-Lead, Straight, Printed Circuit Board, 5 A, -65 - 60 °C, AMPMODU MOD 1 | запрос от 1 шт 5-7 дней склад 5226 шт |
Barrier Strips, Tri-Barrier, Printed Circuit Pin, Wire-to-Board, 20 ... Далее 8-1546158-0Barrier Strips, Tri-Barrier, Printed Circuit Pin, Wire-to-Board, 20 Position, 9.53 mm [.375 in] Centerline, 1 Row, 300 V / 600 V | запрос от 1 шт 5-7 дней склад 3179 шт |
6 ТМ Электроникс Санкт-Петербург Россия | |
Micro-MaTch; вилка; "папа"; PIN: 18; IDC; на шлейф; Конф: ... Далее 8-215083-8Micro-MaTch; вилка; "папа"; PIN: 18; IDC; на шлейф; Конф: 2x9; 1,27мм | 617 ₽ от 1 шт 5-10 дней склад 357 шт |
Еще 4 цен: … 343 ₽ | |
491 ₽ от 5 шт 5-10 дней склад 357 шт | |
443 ₽ от 20 шт 5-10 дней склад 357 шт | |
393 ₽ от 100 шт 5-10 дней склад 357 шт | |
343 ₽ от 250 шт 5-10 дней склад 357 шт | |
... -MaTch; гнездо; "мама"; PIN: 8; THT; на PCB; Конф: 2x4 ... Далее 2178710-8Micro-MaTch; гнездо; "мама"; PIN: 8; THT; на PCB; Конф: 2x4; прямой | 57.5 ₽ от 350 шт 5-10 дней склад 20000 шт |
Еще 3 цен: … 53.3 ₽ | |
55.1 ₽ от 1750 шт 5-10 дней склад 20000 шт | |
54.4 ₽ от 6650 шт 5-10 дней склад 20000 шт | |
53.3 ₽ от 12600 шт 5-10 дней склад 20000 шт | |
... -MaTch; гнездо; "мама"; PIN: 8; SMT; на PCB; Конф: 2x4 ... Далее 2178711-8Micro-MaTch; гнездо; "мама"; PIN: 8; SMT; на PCB; Конф: 2x4; прямой | 325 ₽ от 1 шт 5-10 дней склад 5595 шт |
Еще 3 цен: … 142 ₽ | |
179 ₽ от 56 шт 5-10 дней склад 5595 шт | |
153 ₽ от 2700 шт 5-10 дней склад 5595 шт | |
142 ₽ от 7200 шт 5-10 дней склад 5595 шт | |
Еще 130 строк | |
... -MaTch; вилка; "папа"; PIN: 8; IDC; на шлейф; Конф: 2x4 ... Далее 2178712-8Micro-MaTch; вилка; "папа"; PIN: 8; IDC; на шлейф; Конф: 2x4; 1,27мм | 142 ₽ от 1 шт 5-10 дней склад 28778 шт |
Еще 4 цен: … 60.7 ₽ | |
103 ₽ от 100 шт 5-10 дней склад 28778 шт | |
74.1 ₽ от 1000 шт 5-10 дней склад 28778 шт | |
64.9 ₽ от 5000 шт 5-10 дней склад 28778 шт | |
60.7 ₽ от 25000 шт 5-10 дней склад 28778 шт | |
Micro-MaTch; переходник; PIN: 8; IDC,THT; на PCB,на ... Далее 2178713-8Micro-MaTch; переходник; PIN: 8; IDC,THT; на PCB,на шлейф; 1,27мм | 49.9 ₽ от 179 шт 5-10 дней склад 14821 шт |
Еще 4 цен: … 42.5 ₽ | |
48.0 ₽ от 4000 шт 5-10 дней склад 14821 шт | |
45.9 ₽ от 8000 шт 5-10 дней склад 14821 шт | |
44.1 ₽ от 21000 шт 5-10 дней склад 14821 шт | |
42.5 ₽ от 64000 шт 5-10 дней склад 14821 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 10; THT; на PCB; Конф: 2x5 | 931 ₽ от 1 шт 5-10 дней склад 231 шт |
Еще 4 цен: … 393 ₽ | |
757 ₽ от 5 шт 5-10 дней склад 231 шт | |
559 ₽ от 20 шт 5-10 дней склад 231 шт | |
449 ₽ от 100 шт 5-10 дней склад 231 шт | |
393 ₽ от 250 шт 5-10 дней склад 231 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 14; THT; на PCB; Конф: 2x7 | 641 ₽ от 1 шт 5-10 дней склад 1563 шт |
Еще 4 цен: … 467 ₽ | |
572 ₽ от 10 шт 5-10 дней склад 1563 шт | |
517 ₽ от 100 шт 5-10 дней склад 1563 шт | |
514 ₽ от 250 шт 5-10 дней склад 1563 шт | |
467 ₽ от 500 шт 5-10 дней склад 1563 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 16; THT; на PCB; Конф: 2x8 ... Далее 8-215460-6Micro-MaTch; гнездо; "мама"; PIN: 16; THT; на PCB; Конф: 2x8; 1,27мм | 635 ₽ от 250 шт 5-10 дней склад 3910 шт |
Еще 4 цен: … 396 ₽ | |
587 ₽ от 500 шт 5-10 дней склад 3910 шт | |
485 ₽ от 1 шт 5-10 дней склад 3910 шт | |
445 ₽ от 10 шт 5-10 дней склад 3910 шт | |
396 ₽ от 100 шт 5-10 дней склад 3910 шт | |
Micro-MaTch; гнездо; "папа"; PIN: 10; THT; на PCB; 1,5А; ... Далее 8-215464-0Micro-MaTch; гнездо; "папа"; PIN: 10; THT; на PCB; 1,5А; Конф: 2x5 | 823 ₽ от 1 шт 5-10 дней склад 517 шт |
Еще 4 цен: … 364 ₽ | |
720 ₽ от 5 шт 5-10 дней склад 517 шт | |
530 ₽ от 20 шт 5-10 дней склад 517 шт | |
430 ₽ от 100 шт 5-10 дней склад 517 шт | |
364 ₽ от 250 шт 5-10 дней склад 517 шт | |
Micro-MaTch; гнездо; "папа"; PIN: 12; THT; на PCB; 1,5А; ... Далее 8-215464-2Micro-MaTch; гнездо; "папа"; PIN: 12; THT; на PCB; 1,5А; Конф: 2x6 | 654 ₽ от 1 шт 5-10 дней склад 1381 шт |
Еще 4 цен: … 290 ₽ | |
562 ₽ от 5 шт 5-10 дней склад 1381 шт | |
425 ₽ от 20 шт 5-10 дней склад 1381 шт | |
348 ₽ от 100 шт 5-10 дней склад 1381 шт | |
290 ₽ от 250 шт 5-10 дней склад 1381 шт | |
Micro-MaTch; гнездо; "папа"; PIN: 14; THT; на PCB; 1,5А; ... Далее 8-215464-4Micro-MaTch; гнездо; "папа"; PIN: 14; THT; на PCB; 1,5А; Конф: 2x7 | 594 ₽ от 1 шт 5-10 дней склад 1324 шт |
Еще 4 цен: … 453 ₽ | |
528 ₽ от 10 шт 5-10 дней склад 1324 шт | |
498 ₽ от 250 шт 5-10 дней склад 1324 шт | |
477 ₽ от 100 шт 5-10 дней склад 1324 шт | |
453 ₽ от 500 шт 5-10 дней склад 1324 шт | |
Micro-MaTch; гнездо; "папа"; PIN: 16; THT; на PCB; 1,5А; ... Далее 8-215464-6Micro-MaTch; гнездо; "папа"; PIN: 16; THT; на PCB; 1,5А; Конф: 2x8 | 617 ₽ от 1 шт 5-10 дней склад 1427 шт |
Еще 4 цен: … 449 ₽ | |
550 ₽ от 10 шт 5-10 дней склад 1427 шт | |
496 ₽ от 100 шт 5-10 дней склад 1427 шт | |
494 ₽ от 250 шт 5-10 дней склад 1427 шт | |
449 ₽ от 500 шт 5-10 дней склад 1427 шт | |
Micro-MaTch; переходник; PIN: 10; IDC,THT; на PCB,на шлейф; 1,27мм | 514 ₽ от 1 шт 5-10 дней склад 1025 шт |
Еще 4 цен: … 230 ₽ | |
446 ₽ от 5 шт 5-10 дней склад 1025 шт | |
332 ₽ от 20 шт 5-10 дней склад 1025 шт | |
269 ₽ от 100 шт 5-10 дней склад 1025 шт | |
230 ₽ от 250 шт 5-10 дней склад 1025 шт | |
Micro-MaTch; переходник; PIN: 12; IDC,THT; на PCB,на шлейф; 1,27мм | 533 ₽ от 1 шт 5-10 дней склад 294 шт |
Еще 4 цен: … 338 ₽ | |
485 ₽ от 5 шт 5-10 дней склад 294 шт | |
438 ₽ от 20 шт 5-10 дней склад 294 шт | |
385 ₽ от 100 шт 5-10 дней склад 294 шт | |
338 ₽ от 250 шт 5-10 дней склад 294 шт | |
Micro-MaTch; переходник; PIN: 14; IDC,THT; на PCB,на шлейф; 1,27мм | 691 ₽ от 1 шт 5-10 дней склад 1957 шт |
Еще 4 цен: … 556 ₽ | |
615 ₽ от 10 шт 5-10 дней склад 1957 шт | |
612 ₽ от 25 шт 5-10 дней склад 1957 шт | |
606 ₽ от 50 шт 5-10 дней склад 1957 шт | |
556 ₽ от 100 шт 5-10 дней склад 1957 шт | |
Micro-MaTch; переходник; PIN: 16; IDC,THT; на PCB,на шлейф; 1,27мм | 823 ₽ от 1 шт 5-10 дней склад 341 шт |
710 ₽ от 5 шт 5-10 дней склад 341 шт | |
528 ₽ от 20 шт 5-10 дней склад 341 шт | |
427 ₽ от 100 шт 5-10 дней склад 341 шт | |
364 ₽ от 250 шт 5-10 дней склад 341 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 12; THT; на PCB; Конф: 2x6 ... Далее 8-215079-2Micro-MaTch; гнездо; "мама"; PIN: 12; THT; на PCB; Конф: 2x6; прямой | 464 ₽ от 1 шт 5-10 дней склад 52 шт |
Еще 4 цен: … 339 ₽ | |
425 ₽ от 10 шт 5-10 дней склад 52 шт | |
379 ₽ от 100 шт 5-10 дней склад 52 шт | |
373 ₽ от 250 шт 5-10 дней склад 52 шт | |
339 ₽ от 500 шт 5-10 дней склад 52 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 16; THT; на PCB; Конф: 2x8 ... Далее 8-215079-6Micro-MaTch; гнездо; "мама"; PIN: 16; THT; на PCB; Конф: 2x8; прямой | 580 ₽ от 1 шт 5-10 дней склад 605 шт |
Еще 4 цен: … 423 ₽ | |
518 ₽ от 10 шт 5-10 дней склад 605 шт | |
468 ₽ от 100 шт 5-10 дней склад 605 шт | |
465 ₽ от 250 шт 5-10 дней склад 605 шт | |
423 ₽ от 500 шт 5-10 дней склад 605 шт | |
Micro-MaTch; гнездо; "мама"; PIN: 10; SMT; на PCB; Конф: 2x5 ... Далее 8-2823056-0Micro-MaTch; гнездо; "мама"; PIN: 10; SMT; на PCB; Конф: 2x5; прямой | 245 ₽ от 900 шт 5-10 дней склад 4500 шт |
Micro-MaTch; гнездо; "мама"; PIN: 12; SMT; на PCB; Конф: 2x6 ... Далее 8-2823056-2Micro-MaTch; гнездо; "мама"; PIN: 12; SMT; на PCB; Конф: 2x6; прямой | 219 ₽ от 900 шт 5-10 дней склад 1800 шт |
206 ₽ от 1800 шт 5-10 дней склад 1800 шт | |
7 ЭК ЗИП Москва Россия | |
Герметичные разъемы | 458 ₽ от 1 шт склад 490 шт |
316 ₽ от 4 шт склад 490 шт | |
300 ₽ от 32 шт склад 490 шт | |
8 Acme Chip Китай Весь мир | |
Current Mode PWM Controller 0V to 30V 200mA 500kHz 8-Pin SOIC T/R | запрос 7 дней склад 1663 шт |
Current Mode PWM Controller 0V to 30V 200mA 500kHz 8-Pin SOIC T/R | запрос 7 дней склад 2538 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 661 шт |
Еще 13 строк | |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC Tube | запрос 7 дней склад 2582 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 1783 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 409 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC Tube | запрос 7 дней склад 830 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 1365 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC Tube | запрос 7 дней склад 1870 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 1159 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 2489 шт |
Current Mode PWM Controller 0V to 30V 200mA 8-Pin SOIC T/R | запрос 7 дней склад 2398 шт |
DIP-8 | запрос 7 дней |
Transistor X Band, Gaas, N-channel, Rf Power, Mosfet, Hermetic Sealed, ... Далее TIM8596-8Transistor X Band, Gaas, N-channel, Rf Power, Mosfet, Hermetic Sealed, 2-11C1B, 2 Pin, Fet Rf Power | запрос 7 дней склад 5365 шт |
TRANSISTOR X BAND, GaAs, N-CHANNEL, RF POWER, MOSFET, HERMETIC SEALED, ... Далее TIM0910-8TRANSISTOR X BAND, GaAs, N-CHANNEL, RF POWER, MOSFET, HERMETIC SEALED, 2-11C1B, 2 PIN, FET RF Power | запрос 7 дней склад 2764 шт |
DRAM Chip Mobile SDRAM 256M-Bit 8Mx32 3.3V 90-Pin VFBGA Tray | запрос 7 дней склад 7664 шт |
9 Онлайн Компоненты Москва Россия | |
... CONNECTIVITY - 826629-8 - Pin Header, Board- ... ряд(-ов), 8 контакт(-ов), ... Далее 826629-8AMP - TE CONNECTIVITY - 826629-8 - Pin Header, Board-to-Board, 2.54 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Straight | 453 ₽ от 1 шт 5-12 дней склад 889 шт |
Еще 5 цен: … 241 ₽ | |
369 ₽ от 10 шт 5-12 дней склад 889 шт | |
326 ₽ от 100 шт 5-12 дней склад 889 шт | |
271 ₽ от 500 шт 5-12 дней склад 889 шт | |
246 ₽ от 1000 шт 5-12 дней склад 889 шт | |
241 ₽ от 2500 шт 5-12 дней склад 889 шт | |
AMP - TE CONNECTIVITY - 1586037-8 - Pin Header, вертикальный, Wire-to- ... Далее 1586037-8AMP - TE CONNECTIVITY - 1586037-8 - Pin Header, вертикальный, Wire-to-Board, 4.2 мм, 2 ряд(-ов), 8 контакт(-ов), Through Hole Straight | 144 ₽ от 10 шт 5-12 дней склад 3239 шт |
Еще 5 цен: … 89.3 ₽ | |
122 ₽ от 50 шт 5-12 дней склад 3239 шт | |
100 ₽ от 100 шт 5-12 дней склад 3239 шт | |
98.0 ₽ от 250 шт 5-12 дней склад 3239 шт | |
95.4 ₽ от 500 шт 5-12 дней склад 3239 шт | |
89.3 ₽ от 1500 шт 5-12 дней склад 3239 шт | |
... CONNECTIVITY - 292175-8 - Pin Header, Wire- ... ряд(-ов), 8 контакт(-ов), ... Далее 292175-8AMP - TE CONNECTIVITY - 292175-8 - Pin Header, Wire-to-Board, 2 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Straight, Серия AMP CT | 502 ₽ от 1 шт |
Еще 5 цен: … 277 ₽ | |
428 ₽ от 10 шт | |
373 ₽ от 100 шт | |
351 ₽ от 250 шт | |
326 ₽ от 500 шт | |
277 ₽ от 1000 шт | |
Еще 57 строк | |
AMP - TE CONNECTIVITY - 640457-8 - Pin Header, угловой, Wire-to-Board, ... Далее 640457-8AMP - TE CONNECTIVITY - 640457-8 - Pin Header, угловой, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Right Angle | 103 ₽ от 10 шт 5-12 дней склад 145 шт |
Еще 5 цен: … 82.0 ₽ | |
89.1 ₽ от 100 шт 5-12 дней склад 145 шт | |
87.2 ₽ от 250 шт 5-12 дней склад 145 шт | |
85.4 ₽ от 500 шт 5-12 дней склад 145 шт | |
83.8 ₽ от 1000 шт 5-12 дней склад 145 шт | |
82.0 ₽ от 2500 шт 5-12 дней склад 145 шт | |
... CONNECTIVITY - 825433-8 - Pin Header, Wire- ... ряд(-ов), 8 контакт(-ов), ... Далее 825433-8AMP - TE CONNECTIVITY - 825433-8 - Pin Header, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Straight | 519 ₽ от 1 шт 5-12 дней склад 1875 шт |
Еще 5 цен: … 296 ₽ | |
408 ₽ от 10 шт 5-12 дней склад 1875 шт | |
362 ₽ от 100 шт 5-12 дней склад 1875 шт | |
349 ₽ от 250 шт 5-12 дней склад 1875 шт | |
323 ₽ от 500 шт 5-12 дней склад 1875 шт | |
296 ₽ от 1000 шт 5-12 дней склад 1875 шт | |
AMP - TE CONNECTIVITY - 1241050-8 - Pin Header, Board-to-Board, 2. ... Далее 1241050-8AMP - TE CONNECTIVITY - 1241050-8 - Pin Header, Board-to-Board, 2.54 мм, 2 ряд(-ов), 16 контакт(-ов), Surface Mount Straight | 1 358 ₽ от 1 шт 5-12 дней склад 174 шт |
Еще 4 цен: … 948 ₽ | |
1 057 ₽ от 8 шт 5-12 дней склад 174 шт | |
1 055 ₽ от 26 шт 5-12 дней склад 174 шт | |
966 ₽ от 70 шт 5-12 дней склад 174 шт | |
948 ₽ от 175 шт 5-12 дней склад 174 шт | |
... CONNECTIVITY - 171826-8 - Pin Header, R/A ... ряд(-ов), 8 контакт(-ов), ... Далее 171826-8AMP - TE CONNECTIVITY - 171826-8 - Pin Header, R/A, Wire-to-Board, 2.5 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Right ... | 139 ₽ от 10 шт 5-12 дней склад 8028 шт |
Еще 5 цен: … 77.7 ₽ | |
97.0 ₽ от 100 шт 5-12 дней склад 8028 шт | |
92.0 ₽ от 250 шт 5-12 дней склад 8028 шт | |
87.0 ₽ от 500 шт 5-12 дней склад 8028 шт | |
79.7 ₽ от 1000 шт 5-12 дней склад 8028 шт | |
77.7 ₽ от 2500 шт 5-12 дней склад 8028 шт | |
AMP - TE CONNECTIVITY - 292230-8 - Pin Header, Wire-to-Board, 1. ... Далее 292230-8AMP - TE CONNECTIVITY - 292230-8 - Pin Header, Wire-to-Board, 1.5 мм, 1 ряд(-ов), 8 контакт(-ов), Поверхностный Монтаж | 151 ₽ от 10 шт 5-12 дней склад 1190 шт |
Еще 5 цен: … 98.2 ₽ | |
120 ₽ от 100 шт 5-12 дней склад 1190 шт | |
114 ₽ от 250 шт 5-12 дней склад 1190 шт | |
108 ₽ от 500 шт 5-12 дней склад 1190 шт | |
100 ₽ от 1000 шт 5-12 дней склад 1190 шт | |
98.2 ₽ от 2500 шт 5-12 дней склад 1190 шт | |
... - 640454-8 - Pin Header, вертикальный ... ряд(-ов), 8 контакт(-ов), ... Далее 640454-8AMP - TE CONNECTIVITY - 640454-8 - Pin Header, вертикальный, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 8 контакт(-ов), Through Hole Straight | 82.2 ₽ от 10 шт 5-12 дней склад 1677 шт |
Еще 5 цен: … 49.2 ₽ | |
63.6 ₽ от 100 шт 5-12 дней склад 1677 шт | |
56.0 ₽ от 500 шт 5-12 дней склад 1677 шт | |
53.8 ₽ от 1000 шт 5-12 дней склад 1677 шт | |
51.5 ₽ от 2500 шт 5-12 дней склад 1677 шт | |
49.2 ₽ от 5000 шт 5-12 дней склад 1677 шт | |
AMP - TE CONNECTIVITY - 826632-8 - Pin Header, Board-to-Board, 2. ... Далее 826632-8AMP - TE CONNECTIVITY - 826632-8 - Pin Header, Board-to-Board, 2.54 мм, 2 ряд(-ов), 16 контакт(-ов), Through Hole Straight | 829 ₽ от 1 шт 5-12 дней склад 517 шт |
Еще 5 цен: … 431 ₽ | |
674 ₽ от 10 шт 5-12 дней склад 517 шт | |
592 ₽ от 100 шт 5-12 дней склад 517 шт | |
519 ₽ от 250 шт 5-12 дней склад 517 шт | |
503 ₽ от 500 шт 5-12 дней склад 517 шт | |
431 ₽ от 1000 шт 5-12 дней склад 517 шт | |
PIN POINT GLUE SYRINGES & TIPS | 2 057 ₽ от 1 шт 5-12 дней склад 8 шт |
1 911 ₽ от 5 шт 5-12 дней склад 8 шт | |
Клеммная Колодка, Штыревой Разъем, 3.81 мм, 2 вывод(-ов), 8 А, 160 В | 251 ₽ от 1 шт 5-12 дней склад 39 шт |
Еще 5 цен: … 203 ₽ | |
220 ₽ от 10 шт 5-12 дней склад 39 шт | |
216 ₽ от 100 шт 5-12 дней склад 39 шт | |
211 ₽ от 500 шт 5-12 дней склад 39 шт | |
207 ₽ от 1000 шт 5-12 дней склад 39 шт | |
203 ₽ от 2500 шт 5-12 дней склад 39 шт | |
AMP - TE CONNECTIVITY - 8-146274-6 - Pin Header, вертикальный, Board- ... Далее 8-146274-6AMP - TE CONNECTIVITY - 8-146274-6 - Pin Header, вертикальный, Board-to-Board, 2.54 мм, 1 ряд(- ... | 1 392 ₽ от 1 шт 5-12 дней склад 1322 шт |
Еще 5 цен: … 925 ₽ | |
1 096 ₽ от 10 шт 5-12 дней склад 1322 шт | |
970 ₽ от 100 шт 5-12 дней склад 1322 шт | |
957 ₽ от 250 шт 5-12 дней склад 1322 шт | |
943 ₽ от 500 шт 5-12 дней склад 1322 шт | |
925 ₽ от 1000 шт 5-12 дней склад 1322 шт | |
AMP - TE CONNECTIVITY - 8-103324-6 - Pin Header, угловой, Wire-to- ... Далее 8-103324-6AMP - TE CONNECTIVITY - 8-103324-6 - Pin Header, угловой, Wire-to-Board, 2.54 мм, 2 ряд(- ... | 2 656 ₽ от 1 шт 5-12 дней склад 106 шт |
Еще 5 цен: … 1 547 ₽ | |
2 235 ₽ от 10 шт 5-12 дней склад 106 шт | |
2 148 ₽ от 25 шт 5-12 дней склад 106 шт | |
1 836 ₽ от 100 шт 5-12 дней склад 106 шт | |
1 579 ₽ от 250 шт 5-12 дней склад 106 шт | |
1 547 ₽ от 500 шт 5-12 дней склад 106 шт | |
AMP - TE CONNECTIVITY - 8-215464-4 - Pin Header, Board-to-Board, 1. ... Далее 8-215464-4AMP - TE CONNECTIVITY - 8-215464-4 - Pin Header, Board-to-Board, 1.27 мм, 2 ряд(-ов), 14 контакт(-ов), Through Hole Straight | 540 ₽ от 1 шт 5-12 дней склад 1548 шт |
Еще 5 цен: … 312 ₽ | |
426 ₽ от 10 шт 5-12 дней склад 1548 шт | |
401 ₽ от 100 шт 5-12 дней склад 1548 шт | |
351 ₽ от 250 шт 5-12 дней склад 1548 шт | |
342 ₽ от 500 шт 5-12 дней склад 1548 шт | |
312 ₽ от 1000 шт 5-12 дней склад 1548 шт | |
AMP - TE CONNECTIVITY - 8-215464-0 - Pin Header, Board-to-Board, 1. ... Далее 8-215464-0AMP - TE CONNECTIVITY - 8-215464-0 - Pin Header, Board-to-Board, 1.27 мм, 2 ряд(-ов), 10 контакт(-ов), Through Hole Straight | 401 ₽ от 1 шт 5-12 дней склад 152 шт |
Еще 4 цен: … 222 ₽ | |
312 ₽ от 6 шт 5-12 дней склад 152 шт | |
269 ₽ от 18 шт 5-12 дней склад 152 шт | |
227 ₽ от 50 шт 5-12 дней склад 152 шт | |
222 ₽ от 125 шт 5-12 дней склад 152 шт | |
AMP - TE CONNECTIVITY - 8-215464-2 - Pin Header, Board-to-Board, 1. ... Далее 8-215464-2AMP - TE CONNECTIVITY - 8-215464-2 - Pin Header, Board-to-Board, 1.27 мм, 2 ряд(-ов), 12 контакт(-ов), Through Hole Straight | 408 ₽ от 1 шт 5-12 дней склад 430 шт |
Еще 4 цен: … 308 ₽ | |
351 ₽ от 6 шт 5-12 дней склад 430 шт | |
333 ₽ от 18 шт 5-12 дней склад 430 шт | |
314 ₽ от 50 шт 5-12 дней склад 430 шт | |
308 ₽ от 125 шт 5-12 дней склад 430 шт | |
AMP - TE CONNECTIVITY - 8-338728-2 - Pin Header, Board-to-Board, 1. ... Далее 8-338728-2AMP - TE CONNECTIVITY - 8-338728-2 - Pin Header, Board-to-Board, 1.27 мм, 2 ряд(-ов), ... | 424 ₽ от 1 шт 5-12 дней склад 178 шт |
Еще 4 цен: … 303 ₽ | |
383 ₽ от 37 шт 5-12 дней склад 178 шт | |
364 ₽ от 112 шт 5-12 дней склад 178 шт | |
346 ₽ от 300 шт 5-12 дней склад 178 шт | |
303 ₽ от 750 шт 5-12 дней склад 178 шт | |
Pin Header, вертикальный, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 3 ... Далее 8-102202-4Pin Header, вертикальный, Wire-to-Board, 2.54 мм, 1 ряд(-ов), 3 контакт(-ов), Through Hole Straight | 330 ₽ от 1 шт 5-12 дней склад 3349 шт |
Еще 5 цен: … 214 ₽ | |
280 ₽ от 10 шт 5-12 дней склад 3349 шт | |
235 ₽ от 100 шт 5-12 дней склад 3349 шт | |
226 ₽ от 250 шт 5-12 дней склад 3349 шт | |
218 ₽ от 500 шт 5-12 дней склад 3349 шт | |
214 ₽ от 1000 шт 5-12 дней склад 3349 шт | |
Лампа накаливания, 12 В, Bi-Pin, T-1 (3мм), 0.15, 16000 ч | 339 ₽ от 1 шт 5-12 дней склад 328 шт |
Еще 5 цен: … 172 ₽ | |
235 ₽ от 100 шт 5-12 дней склад 328 шт | |
186 ₽ от 500 шт 5-12 дней склад 328 шт | |
179 ₽ от 2000 шт 5-12 дней склад 328 шт | |
176 ₽ от 5000 шт 5-12 дней склад 328 шт | |
172 ₽ от 10000 шт 5-12 дней склад 328 шт | |
10 ЕКОМП Санкт-Петербург Россия | |
Штыри 1x8 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLS2-8) Connfly DS1025-01-1*8 P8BV1 - DS1025-01-1*8 P8BV1 Connfly 27 Мар 2024 02:10 Штыри однорядные 1x8 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 1x8 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLS2-8) Connfly DS1025-01-1*8 P8BV1 - DS1025-01-1*8 P8BV1Штыри однорядные 1x8 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 2.11 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Разъем "вилка" 8 конт. (2x4) шаг 2.00 мм, верт. на пл. (ан. BH2-8/ IDC2-08MS) Connfly DS1014-08 SF1B - DS1014-08 SF1B Connfly 27 Мар 2024 02:10 Разъем "вилка" 8 конт.(2x4) шаг 2.00 мм, вертик. на плату ( ... Далее Разъем "вилка" 8 конт. (2x4) шаг 2.00 мм, верт. на пл. (ан. BH2-8/ IDC2-08MS) Connfly DS1014-08 SF1B - DS1014-08 SF1BРазъем "вилка" 8 конт.(2x4) шаг 2.00 мм, вертик. на плату (ответн. часть к IDC) | 8.57 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x15 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-30) Connfly DS1025-05-2*15 P8BV1 - DS1025-05-2*15 P8BV1 Connfly 27 Мар 2024 02:10 Штыри двухрядные 2x15 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x15 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-30) Connfly DS1025-05-2*15 P8BV1 - DS1025-05-2*15 P8BV1Штыри двухрядные 2x15 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 8.48 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Еще 8 строк | |
Штыри 2x20 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-40) Connfly DS1025-05-2*20 P8BV1 - DS1025-05-2*20 P8BV1 Connfly 27 Мар 2024 02:10 Штыри двухрядные 2x20 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x20 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-40) Connfly DS1025-05-2*20 P8BV1 - DS1025-05-2*20 P8BV1Штыри двухрядные 2x20 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 10.1 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Разъем "вилка" 8 конт. (2x4) шаг 2.54 мм, верт. на плату (ан. BH-8/ IDC-08MS) Connfly DS1013-08 SSIB1 - DS1013-08 SSIB1 Connfly 27 Мар 2024 02:10 Разъем "вилка" 8 конт.(2x4) шаг 2.54 мм, вертик. на плату ( ... Далее Разъем "вилка" 8 конт. (2x4) шаг 2.54 мм, верт. на плату (ан. BH-8/ IDC-08MS) Connfly DS1013-08 SSIB1 - DS1013-08 SSIB1Разъем "вилка" 8 конт.(2x4) шаг 2.54 мм, вертик. на плату (ответн. часть к IDC) (DS1013-08SSIB1-B-0) | 3.89 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 1x7 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLS2-7) Connfly DS1025-01-1*7 P8BV1 - DS1025-01-1*7 P8BV1 Connfly 27 Мар 2024 02:10 Штыри однорядные 1x7 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 1x7 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLS2-7) Connfly DS1025-01-1*7 P8BV1 - DS1025-01-1*7 P8BV1Штыри однорядные 1x7 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 1.85 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x6 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-12) Connfly DS1025-05-2*6 P8BV1 - DS1025-05-2*6 P8BV1 Connfly 27 Мар 2024 02:10 Штыри двухрядные 2x6 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x6 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-12) Connfly DS1025-05-2*6 P8BV1 - DS1025-05-2*6 P8BV1Штыри двухрядные 2x6 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. (DS1025-05-2*6P8BV1-B) | 3.05 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x10 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-20) Connfly DS1025-05-2*10 P8BV1 - DS1025-05-2*10 P8BV1 Connfly 27 Мар 2024 02:10 Штыри двухрядные 2x10 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x10 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-20) Connfly DS1025-05-2*10 P8BV1 - DS1025-05-2*10 P8BV1Штыри двухрядные 2x10 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 5.12 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Разъем "вилка" 8 конт. (2x4) шаг 2.54 мм, SMT на плату (ан. BHS-8) Connfly DS1013-08 MSISR - DS1013-08 MSISR Connfly 27 Мар 2024 02:10 Разъем "вилка" 8 конт.(2x4) шаг 2.54 мм, поверхн. монтаж на ... Далее Разъем "вилка" 8 конт. (2x4) шаг 2.54 мм, SMT на плату (ан. BHS-8) Connfly DS1013-08 MSISR - DS1013-08 MSISRРазъем "вилка" 8 конт.(2x4) шаг 2.54 мм, поверхн. монтаж на плату (ответн. часть к IDC), с установ. крышкой (вид упак. "tape ... | 24.7 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x12 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-24) Connfly DS1025-05-2*12 P8BV1 - DS1025-05-2*12 P8BV1 Connfly 27 Мар 2024 02:10 Штыри двухрядные 2x12 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 ... Далее Штыри 2x12 конт. шаг 2.00 мм, верт. на пл. (2.8 мм/ 4.0 мм) (ан. PLD2-24) Connfly DS1025-05-2*12 P8BV1 - DS1025-05-2*12 P8BV1Штыри двухрядные 2x12 конт. шаг 2.00 мм, вертик. на плату (2.8 мм/ 4.0 мм), позол. | 5.98 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
Штыри 2x20 конт. шаг 2.00 мм, пр. угол на плату (2.8/ 4.0 мм) (ан. PLD2-40R*) Connfly DS1025-06-2*20 P8BR1-B - DS1025-06-2*20 P8BR1-B Connfly 27 Мар 2024 02:10 Штыри двухрядные 2x20 конт. шаг 2.00 мм, прямой угол на плату, ... Далее Штыри 2x20 конт. шаг 2.00 мм, пр. угол на плату (2.8/ 4.0 мм) (ан. PLD2-40R*) Connfly DS1025-06-2*20 P8BR1-B - DS1025-06-2*20 P8BR1-BШтыри двухрядные 2x20 конт. шаг 2.00 мм, прямой угол на плату, низкопрофил. (2.8 мм/ 4.0 мм), позол. (DS1025-06-2*20P8BR1-B) | 10.3 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет на складе |
11 ЭФО Санкт-Петербург Россия Филиалы: Москва Казань Екатеринбург Ростов-на-Дону Пермь Нижний Новгород Новосибирск | |
178964-8 КОРПУС D-3100D 20 Pin | запрос Цена рассчитана по курсу ЦБ РФ. Точную цену уточняйте у поставщика |
12 ЗУМ-СМД Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 600 руб. | |
DIP-8 | запрос от 600 ₽ от 7 дней склад 12596 шт |
DIP-8 | запрос от 600 ₽ от 7 дней склад 14590 шт |
13 РЕФРО Москва Россия | |
... индукционной плиты HURAKAN 8 pin универсальнаяМодель: Плата генератора ... Далее Плата генератора для индукционной плиты HURAKAN 8 pin универсальная ... для индукционной плиты HURAKAN 8 pin универсальнаяМодель: Плата генератора для индукционной плиты 8 pin универсальнаяСтрана: Китай | 6 381 ₽ на складе |
14 Десси Москва Россия | |
Модуль кнопок 44 (8 pin) 26 Мар 2024 02:10 Модуль кнопок 44 (8 pin) | 100 ₽ |
... : Шлейф 8 pin и длиной 7 см ... 149; Шлейф 12 pin и длиной 10 см ... Далее GKFFCB-P0.5. Набор инверсных FFC шлейфов с шагом 0, 5 мм. 8 штук. ... : 4 мм; Тип шлейфа: Инверсный. Комплект поставки: Шлейф 8 pin и длиной 7 см (1 штука); Шлейф 12 ... | 395 ₽ |
... : Шлейф 8 pin и длиной 7 см ... 149; Шлейф 12 pin и длиной 10 см ... Далее GKFFCA-P0.5. Набор прямых FFC шлейфов с шагом 0, 5 мм. 8 штук. ... : 4 мм; Тип шлейфа: Прямой. Комплект поставки: Шлейф 8 pin и длиной 7 см (1 штука); Шлейф 12 ... | 395 ₽ |
Еще 6 строк | |
Комбинированный универсальный переходник - адаптер TQFP / QFP / LQFP / PLCC 32...100 pin/шаг 0, 5 мм и TQFP / QFP / LQFP / PLCC 32...64 pin/шаг 0, 8 мм. DIY - 26 Мар 2024 02:10 Назначение: Макетирование с применением микросхем в квадратных ... Далее Комбинированный универсальный переходник - адаптер TQFP / QFP / LQFP / PLCC 32...100 pin/шаг 0, 5 мм и TQFP / QFP / LQFP / PLCC 32...64 pin/шаг 0, 8 мм.Назначение: Макетирование с применением микросхем в квадратных корпусах с шагом выводов 0,5 мм и 0,8 мм.: Верхняя сторона А, Двухсторонней ... | 132 ₽ |
... ; Разъём: 4 pin (РLS-4R); ... : 38 х 16 х 8 мм; Масса ... Далее Модуль RF060. HC-05. Bluetooth модуль 4 pin N_B ... : Master и Slave; Интерфейс передачи: UART; Разъём: 4 pin (РLS-4R); Размеры модуля: 38 х 16 х ... | 665 ₽ |
Гнездо на плату, двухрядное, прямое. Количество рядов: 2 ... Далее Разъём PBD-08. Гнездо прямое на плату 2х4 pin 2, 54 мм. 10 штукГнездо на плату, двухрядное, прямое. Количество рядов: 2 Форма контактов: Прямые Шаг контактов: 2,54 мм; ... | 90.0 ₽ |
Количество в упаковке: 10 шт. Гнезда на плату, однорядные, прямые ... Далее Разъем PBS-8L. Гнездо на плату 1х8 pin 2.54 мм с длинными контактамиКоличество в упаковке: 10 шт. Гнезда на плату, однорядные, прямые удлиненные контакты. Серия: PBS Количество рядов: 1; Форма контактов: ... | 210 ₽ |
PBS-8 YELLOW (гнездо на плату 18pin 2.54мм жёлтый) (упак. 10шт) 26 Мар 2024 02:10 PBS-8 YELLOW (гнездо на плату 18pin 2.54мм жёлтый) (упак. 10шт) | 80.0 ₽ |
Серверный модуль памяти KVR667D2D8F5/2G 256M x 72-Bit PC2-5300 CL5 ECC 240-Pin FBDIMM 26 Мар 2024 02:10 SPECIFICATIONS · FBDIMM Module 240-pin · JEDEC Standard R/C B · Memory ... Далее Серверный модуль памяти KVR667D2D8F5/2G 256M x 72-Bit PC2-5300 CL5 ECC 240-Pin FBDIMMSPECIFICATIONS · FBDIMM Module 240-pin · JEDEC Standard R/C B · Memory Organization: 2 rank of x8 devices · DDR2 DRAM Interface: SSTL_18 · ... | 1 500 ₽ |
15 Умные Модули Санкт-Петербург Россия | |
Кнопка миниатюрная с фиксацией 8.5х8.5 мм (3 PIN) | 11.0 ₽ Наличный, безнал расчет.... Далее Наличный, безнал расчет. Отгрузка в день заказа! 1-10 дней на складе |
16 Холодильник.ру Москва Россия | |
Дата-кабель mObility USB - LIGHTNING (8 PIN), плоский, 2 метра, 3 А, белый mObility - 23 Мар 2024 16:17 Тип: датакабель
Для бренда: Apple
Разъемы (вход): USB 2.0
Разъемы ( ... Далее Дата-кабель mObility USB - LIGHTNING (8 PIN), плоский, 2 метра, 3 А, белыйТип: датакабель
Для бренда: Apple
Разъемы (выход): 8pin Lightning
Длина кабеля (м): 2
Страна-производитель: Китай | 189 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Тип: датакабель
Для бренда: универсальный
Разъемы (вход): Lightning
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 1м Blue-blackТип: датакабель
Разъемы (выход): USB
Длина кабеля (м): 1
Страна-производитель: Китай | 429 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
Разъемы (вход): USB
Разъемы ... Далее Дата-кабель Pero DC-03 8-pin Lightning 2А 2 м белыйТип: датакабель
Разъемы (вход): USB
Разъемы (выход): Lightning 8pin
Длина кабеля (м): 2
Страна-производитель: ... | 389 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Еще 22 строки | |
Тип: датакабель
... Далее Дата-кабель Pero DC-03 8-pin Lightning 2А 2м черныйТип: датакабель
Длина кабеля (м): 2
Страна-производитель: Китай | 389 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 2м Silver-blackТип: датакабель
Длина кабеля (м): 2
Страна-производитель: Китай | 529 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Дата-кабель MoreChoice USB 2.1A для Lightning 8-pin K21i ПВХ 1м (White) MoreChoice - 23 Мар 2024 16:17 Тип: кабель
Разъемы ... Далее Дата-кабель MoreChoice USB 2.1A для Lightning 8-pin K21i ПВХ 1м (White)Тип: кабель
Длина кабеля (м): 1
Страна-производитель: ... | 190 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
Разъемы (вход): USB
Разъемы ... Далее Дата-кабель Pero DC-03 8-pin Lightning 2А 1 м белыйТип: датакабель
Разъемы (вход): USB
Длина кабеля (м): 1
Страна-производитель: ... | 330 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Сетевое ЗУ MoreChoice 2USB 2.4A для Lightning 8-pin со встроенным кабелем и LED подсветкой NC48i (Black) MoreChoice - 23 Мар 2024 16:17 Тип устройства: сетевое з/у
Назначение: универсальное
Количество ... Далее Сетевое ЗУ MoreChoice 2USB 2.4A для Lightning 8-pin со встроенным кабелем и LED подсветкой NC48i (Black)Тип устройства: сетевое з/у
Количество разъемов на выход: 2
Разъем на конце кабеля: 8pin Lightning (Apple)
... | 149 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 2м Blue-blackТип: датакабель
Длина кабеля (м): 2
Страна-производитель: Китай | 423 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 1м Silver-blackТип: датакабель
Длина кабеля (м): 1
Страна-производитель: Китай | 343 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
Разъемы (вход): USB
Разъемы ... Далее Дата-кабель Pero DC-02 8-pin Lightning 2А 1 м черныйТип: датакабель
Разъемы (вход): USB
Длина кабеля (м): 1
Страна-производитель: ... | 287 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 2м Green-blackТип: датакабель
Длина кабеля (м): 2
Страна-производитель: Китай | 216 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
Разъемы (вход): USB
Разъемы ... Далее Дата-кабель Pero DC-02 8-pin Lightning 2А 1 м розовыйТип: датакабель
Разъемы (вход): USB
Длина кабеля (м): 1
Страна-производитель: Китай | 179 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
... Далее Дата-кабель Pero DC-04 8-pin Lightning 2А 2м Red-blackТип: датакабель
Длина кабеля (м): 2
Кабель для синхронизации и зарядки Canyon 8-pin Lightning - USB-Type C CFI-12 CNE-CFI12W Canyon 23 Мар 2024 16:17 Тип: кабель
Разъемы (вход): USBC
Разъемы ( ... Далее Кабель для синхронизации и зарядки Canyon 8-pin Lightning - USB-Type C CFI-12 CNE-CFI12WТип: кабель
Разъемы (выход): USB TypeC
Длина кабеля (м): 2
Страна-производитель: Китай | 479 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
Для бренда: Apple
Разъемы (вход): USB Type C
Разъемы ( ... Далее Дата-кабель TFN 8-pin TypeC MFI, 1 м, белыйТип: датакабель
Для бренда: Apple
Длина кабеля (м): 1
Страна-производитель: Китай | 799 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: датакабель
Для бренда: Apple
Разъемы (вход): 8pin Lightning
... Далее Кабель TFN 8-pin TypeC 2.0 м, белый (TFN-CLIGC2MTPEWH)Тип: датакабель
Для бренда: Apple
Длина кабеля (м): 2
Страна-производитель: Китай | 690 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: кабель
Для бренда: Apple
Разъемы ( ... Далее Кабель MoreChoice USB 2.0A для Lightning 8-pin K16i TPE 1м (Purple)Тип: кабель
Для бренда: Apple
Длина кабеля (м): 1
Страна-производитель: Китай | 122 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: адаптер
Для бренда: Apple
Разъемы ... Далее Адаптер Red Line Lightning на 8-pin/Jack 3.5 мм, черный УТ000016491Тип: адаптер
Для бренда: Apple
Разъемы (выход): 3.5 миниджек (аудио) / 8pin Lightning
Страна-производитель: ... | 321 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
Тип: кабель
Для бренда: Apple
Разъемы (вход): USB
Разъемы (выход): ... Далее Кабель Red Line USB-8-pin для Apple, 1.5A, 20 см, белыйТип: кабель
Для бренда: Apple
Разъемы (вход): USB
Длина кабеля (м): 0.2
Страна-производитель: Китай | 76.0 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ на складе |
17 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
18-0176 | 114 ₽ Доставка: есть Самовывоз: есть на складе |
М0040577 | 46.0 ₽ Доставка: есть Самовывоз: есть на складе |
М0040580 | 91.0 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 55 строк | |
М0040581 | 133 ₽ Доставка: есть Самовывоз: есть на складе |
М0040594 | 54.0 ₽ Доставка: есть Самовывоз: есть на складе |
Тензометрическое оборудование | 15 531 ₽ Доставка: есть Самовывоз: есть на складе |
Панелька for ICs 2, 54 mm 8 pin SCS-08 28 Мар 2024 04:37 Линейка 60 шт | 4.00 ₽ Доставка: есть Самовывоз: есть на складе |
Выключатели DIP | 72.0 ₽ Доставка: есть Самовывоз: есть на складе |
М0019041 | 7.00 ₽ Доставка: есть Самовывоз: есть на складе |
М0040589 | 52.0 ₽ Доставка: есть Самовывоз: есть на складе |
М0040593 | 65.0 ₽ Доставка: есть Самовывоз: есть на складе |
18-0179 | 219 ₽ Доставка: есть Самовывоз: есть на складе |
USB кабель 3 в 1 Lightning 8 pin/micro USB/USB Type-C черный текстиль, 1 метр REXANT - - 28 Мар 2024 04:37 18-7013 | 379 ₽ Доставка: есть Самовывоз: есть на складе |
кабель интерфейсный разборный DB9F-DB9M pin-to-pin 1.8м | 248 ₽ Доставка: есть Самовывоз: есть на складе |
Микрокнопка б.фиксации №57 PS580N 5, 8*5, 8 мм ручка = 5 мм 6 pin 28 Мар 2024 04:37 Микрокнопка без фиксации PS580N 5,8*5,8мм ручка=5мм 6pin | 5.00 ₽ Доставка: есть Самовывоз: есть на складе |
6х6mm Daier, шток 8,5мм | 9.00 ₽ Доставка: есть Самовывоз: есть на складе |
Переключатель 2 положения №71 8, 6*7мм, ручка 4мм, 6pin 28 Мар 2024 04:37 Переключатель на 2 положения 8,6*7мм, ручка 4мм, 6pin | 30.0 ₽ Доставка: есть Самовывоз: есть на складе |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В ... Далее TEN 8-2421WIПреобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В/-5В 0.8A/-0.8A 8Вт 9-Pin PDIP | 5 930 ₽ Доставка: есть Самовывоз: есть на складе |
14-pin | 41.0 ₽ Доставка: есть Самовывоз: есть на складе |
Переключатель 2 положения №63 8, 6*4, 4мм, ручка 4мм, 3pin угловые 28 Мар 2024 04:37 Переключатель на 2 положения 8,6*4,4мм, ручка 4мм, 3pin угловые | 33.0 ₽ Доставка: есть Самовывоз: есть на складе |
18 Амарид-Электро Санкт-Петербург Россия | |
X-COM-S-1L FEDERLEISTE 8 PIN, серый | 1 074 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
X-COM-S-1L FEDERLEISTE 8 PIN, серый | 1 072 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... PCBs) Straight solder pin 0.8 x 0.8 мм 3-полюс., чёрный Далее 714-133Male header (for PCBs) Straight solder pin 0.8 x 0.8 мм 3-полюс., чёрный | 137 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
Еще 8 строк | |
Вилка THT, 0.8 x 0.8 мм solder pin, прямые, Шаг контактов 3 ... Далее 714-134Вилка THT, 0.8 x 0.8 мм solder pin, прямые, Шаг контактов 3,5 мм, 4-пол., черные | 185 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... PCBs) Straight solder pin 0.8 x 0.8 мм 12-полюс., чёрный Далее 714-142Male header (for PCBs) Straight solder pin 0.8 x 0.8 мм 12-полюс., чёрный | 554 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... , 5- to 8-pole suitable for 5 мм pin spacing, light gray Далее 2092-1602/002-000Gripping plate sliding connector release, 5- to 8-pole suitable for 5 мм pin spacing, light gray | 80.6 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... 1.0 мм solder pin, угловые, Фиксирующий рычаг ... мм, 8-пол., светло-серые Далее 722-238/039-000 ... под пайку THT, 0.6 x 1.0 мм solder pin, угловые, Фиксирующий рычаг, 2,5 мм2, Шаг контактов 5 мм ... | 697 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... 1.0 мм solder pin, угловые, Проходной фланец ... 5 мм, 8-пол., светло-серые Далее 722-238/047-000 ... под пайку THT, 0.6 x 1.0 мм solder pin, угловые, Проходной фланец, 2,5 мм2, Шаг контактов 5 мм ... | 682 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... 1.0 мм solder pin, угловые, Фиксирующий рычаг ... мм, 8-пол., светло-серые Далее 722-838/039-000 ... под пайку THT, 0.6 x 1.0 мм solder pin, угловые, Фиксирующий рычаг, 2,5 мм2, Шаг контактов 7,5 ... | 739 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... x 1.0 мм solder pin, прямые, Шаг контактов 3,5 ... Далее 734-138/046-000Вилка THT, 1.0 x 1.0 мм solder pin, прямые, Шаг контактов 3,5 мм, 8-пол., светло-серые | 302 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
... x 1.0 мм solder pin, прямые, Шаг контактов 3,81 ... Далее 734-238/046-000Вилка THT, 1.0 x 1.0 мм solder pin, прямые, Шаг контактов 3,81 мм, 8-пол., оранжевые | 302 ₽ Счёт от 1000 ₽ Только... Далее Счёт от 1000 ₽ Только юр.лица. Самовывоз, доставка до ДЛ. до 52 недель заказ |
19 Оптулс Москва Россия | |
70090003 STAHLWILLE 109/3 1,8 pin punch | 1 270 ₽ Розница, Скидки для Дилеров - |
70090005 STAHLWILLE 109/5 2,8 pin punch | 1 270 ₽ Розница, Скидки для Дилеров - |
Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8) PRESSMASTER - 28 Фев 2024 17:35 ... KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 ... Далее Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8)Пресс-клещи Pressmaster KPB-6099L для обжима Turned Pin контактов 4.0 - 10 мм2 (AWG 12-8) | 41 013 ₽ Розница, Скидки для Дилеров - |
Еще 5 строк | |
70090008 STAHLWILLE 109/8 5,9 pin punch | 1 030 ₽ Розница, Скидки для Дилеров - |
70070006 STAHLWILLE 108/150 X 8 parallel pin punch, octogonal | 913 ₽ Розница, Скидки для Дилеров - |
70070008 STAHLWILLE 108/200 X 8 parallel pin punch, octogonal | 1 146 ₽ Розница, Скидки для Дилеров - |
96700711 STAHLWILLE 105-8/6 K set pin punches - centre punches | 4 396 ₽ Розница, Скидки для Дилеров - |
96838124 STAHLWILLE ES 102/105/108/8 set parallel pin punches | 7 683 ₽ Розница, Скидки для Дилеров - |
20 DIP8.RU Москва Россия и страны ТС | |
Разъем Micro-MaTch; вилка; папа; PIN: 18; IDC; н | 530 ₽ от 1 шт 42 дня склад 357 шт Внешний |
Еще 9 цен: … 254 ₽ | |
530 ₽ от 1 шт от 1 дня склад 82 шт Москва | |
411 ₽ от 5 шт 42 дня склад 357 шт Внешний | |
411 ₽ от 5 шт от 1 дня склад 82 шт Москва | |
362 ₽ от 20 шт 42 дня склад 357 шт Внешний | |
362 ₽ от 20 шт от 1 дня склад 82 шт Москва | |
305 ₽ от 100 шт 42 дня склад 357 шт Внешний | |
305 ₽ от 100 шт от 1 дня склад 82 шт Москва | |
254 ₽ от 250 шт 42 дня склад 357 шт Внешний | |
254 ₽ от 250 шт от 1 дня склад 82 шт Москва | |
Разъем прямоугольный, мама, CX, PIN 12(4+8), размер 104.27 | 6 100 ₽ от 1 шт 42 дня склад 51 шт Внешний |
Еще 7 цен: … 3 761 ₽ | |
6 100 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
5 124 ₽ от 5 шт 42 дня склад 51 шт Внешний | |
5 124 ₽ от 5 шт от 1 дня склад 3 шт Москва | |
4 532 ₽ от 20 шт от 1 дня склад 3 шт Москва | |
4 532 ₽ от 20 шт 42 дня склад 51 шт Внешний | |
3 761 ₽ от 100 шт 42 дня склад 51 шт Внешний | |
3 761 ₽ от 100 шт от 1 дня склад 3 шт Москва | |
Разъем прямоугольный, папа, CX, PIN 12(4+8), размер 104.27 | 5 620 ₽ от 1 шт 42 дня склад 24 шт Внешний |
Еще 7 цен: … 3 482 ₽ | |
5 620 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
4 744 ₽ от 5 шт 42 дня склад 24 шт Внешний | |
4 744 ₽ от 5 шт от 1 дня склад 3 шт Москва | |
4 195 ₽ от 20 шт от 1 дня склад 3 шт Москва | |
4 195 ₽ от 20 шт 42 дня склад 24 шт Внешний | |
3 482 ₽ от 100 шт 42 дня склад 24 шт Внешний | |
3 482 ₽ от 100 шт от 1 дня склад 3 шт Москва | |
Еще 4 строки | |
Вилка, провод-плата, мама, PIN 8, без контактов, 2,5мм, XH, ... Далее XHP-8Вилка, провод-плата, мама, PIN 8, без контактов, 2,5мм, XH, 250В | 3.00 ₽ от 1 шт склад 6440 шт Внешний |
Еще 9 цен: … 2.13 ₽ | |
3.00 ₽ от 1 шт от 1 дня склад 510 шт Москва | |
2.64 ₽ от 500 шт склад 6440 шт Внешний | |
2.64 ₽ от 500 шт от 1 дня склад 510 шт Москва | |
2.31 ₽ от 2700 шт склад 6440 шт Внешний | |
2.31 ₽ от 2700 шт от 1 дня склад 510 шт Москва | |
2.19 ₽ от 11400 шт склад 6440 шт Внешний | |
2.19 ₽ от 11400 шт от 1 дня склад 510 шт Москва | |
2.13 ₽ от 29400 шт склад 6440 шт Внешний | |
2.13 ₽ от 29400 шт от 1 дня склад 510 шт Москва | |
Гнездо, DIN, мама, PIN 8, конфигурация выводов 262°, угловые ... Далее MAB 8 SH SWГнездо, DIN, мама, PIN 8, конфигурация выводов 262°, угловые 90°, THT | 1 060 ₽ от 1 шт 42 дня склад 1787 шт Внешний |
Еще 7 цен: … 651 ₽ | |
1 060 ₽ от 1 шт от 1 дня склад 21 шт Москва | |
914 ₽ от 5 шт 42 дня склад 1787 шт Внешний | |
914 ₽ от 5 шт от 1 дня склад 21 шт Москва | |
788 ₽ от 20 шт от 1 дня склад 21 шт Москва | |
788 ₽ от 20 шт 42 дня склад 1787 шт Внешний | |
651 ₽ от 100 шт 42 дня склад 1787 шт Внешний | |
651 ₽ от 100 шт от 1 дня склад 21 шт Москва | |
Гнездо; Micro-MaTch; мама; PIN: 10; THT; на PCB; | 90.0 ₽ от 1 шт склад 180 шт Внешний |
Еще 9 цен: … 67.3 ₽ | |
90.0 ₽ от 1 шт от 1 дня склад 1 шт Москва | |
79.1 ₽ от 31 шт склад 180 шт Внешний | |
79.1 ₽ от 31 шт от 1 дня склад 1 шт Москва | |
74.0 ₽ от 62 шт склад 180 шт Внешний | |
74.0 ₽ от 62 шт от 1 дня склад 1 шт Москва | |
70.1 ₽ от 123 шт склад 180 шт Внешний | |
70.1 ₽ от 123 шт от 1 дня склад 1 шт Москва | |
67.3 ₽ от 250 шт склад 180 шт Внешний | |
67.3 ₽ от 250 шт от 1 дня склад 1 шт Москва | |
Разъем: M8, 0,5м, мама, PIN: 4, на панель,винтами, гнездо, E, 4А | 2 790 ₽ от 1 шт от 1 дня склад 2 шт Москва |
Еще 3 цен: … 1 746 ₽ | |
2 346 ₽ от 5 шт от 1 дня склад 2 шт Москва | |
2 067 ₽ от 20 шт от 1 дня склад 2 шт Москва | |
1 746 ₽ от 100 шт от 1 дня склад 2 шт Москва | |
21 T-electron Раменское, Московская обл. Россия и страны СНГ | |
запрос да | |
запрос да | |
запрос | |
Еще 7 строк | |
290 ₽ до 5 дней | |
35.0 ₽ до 5 дней | |
42.0 ₽ до 5 дней | |
Разъем USB-mini /гнездо 8 pin SMD 20 Ноя 2023 00:56 | 42.0 ₽ да |
запрос да | |
131 ₽ до 5 дней | |
68.0 ₽ до 5 дней | |
22 Контест Москва Россия | |
TUNER TDQ-38HS 8 PIN 28 Мар 2024 02:28 | 864 ₽ |
P-1118-8 PIN МИКРОФОННЫЙ РАЗЪЕМ, БЛОЧНЫЙ 28 Мар 2024 02:28 | 462 ₽ |
P-1120-8 PIN МИКРОФОННЫЙ РАЗЪЕМ, КАБЕЛЬНЫЙ 28 Мар 2024 02:28 | 382 ₽ |
Еще 3 строки | |
A/L UNIV HDR 50P ACT PIN | запрос склад 444 шт |
CONN D-CAP MALE PINS 96POS VERT | запрос склад 14 шт |
23 Элитан Ижевск Россия Безнал. расчет Филиалы: Москва Санкт-Петербург Екатеринбург Новосибирск | |
SCS-8 PIN 27 Мар 2024 02:40 | 58.9 ₽ |
823 ₽ | |
1 227 ₽ | |
Еще 3 строки | |
939 ₽ | |
21.5 ₽ упаковка 2500 шт | |
72.5 ₽ | |
24 PL-1 Москва Россия | |
2 790 ₽ от 1 шт нет | |
Еще 2 цен: … 2 536 ₽ | |
2 657 ₽ от 3000 ₽ нет | |
2 536 ₽ от 6000 ₽ нет | |
Лазерная головка | 1 770 ₽ от 1 шт нет |
Еще 2 цен: … 1 609 ₽ | |
1 686 ₽ от 3000 ₽ нет | |
1 609 ₽ от 6000 ₽ нет | |
25 ВсеИнструменты.ру Москва Россия | |
СЗУ More Choice 1USB 1.0A для Lightning 8-pin NC33ib | 312 ₽ на складе |
СЗУ More Choice 2USB 2.4A для Lightning 8-pin 1м NC46ibb | 388 ₽ на складе |
... 2USB 2.1A для Lightning 8-pin со встроенным кабелем и LED ... Далее Сзу для Lightning 8-pin More ChoiceСЗУ More Choice 2USB 2.1A для Lightning 8-pin со встроенным кабелем и LED подсветкой NC48iw | 351 ₽ на складе |
Еще 24 строки | |
... .0A QC3.0 для Lightning 8-pin быстрая зарядка NC52QCi Далее Сзу для Lightning 8-pin More ChoiceСЗУ More Choice 1USB 3.0A QC3.0 для Lightning 8-pin быстрая зарядка NC52QCi | 412 ₽ на складе |
... .0 быстрая зарядка для Lighting 8-pin NC55QCib Далее Быстрая сзу для Lighting 8-pin More ChoiceСЗУ More Choice Smart 2USB 3.0A QC3.0 быстрая зарядка для Lighting 8-pin NC55QCib | 479 ₽ на складе |
СЗУ More Choice 2USB 2.1A для Lightning 8-pin NC24i | 367 ₽ на складе |
СЗУ More Choice 2USB 2.4A для Lightning 8-pin NC22i | 335 ₽ на складе |
... USB 2.1A для Lightning 8-pin TPE 1м K13iw Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.1A для Lightning 8-pin TPE 1м K13iw | 239 ₽ на складе |
... PD30W быстрая зарядка для Lightning 8-pin Type-C K71Si TPE 2м Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A PD30W быстрая зарядка для Lightning 8-pin Type-C K71Si TPE 2м | 360 ₽ на складе |
... USB 2.4A для Lightning 8-pin ТРЕ 1м K42i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A для Lightning 8-pin ТРЕ 1м K42i | 232 ₽ на складе |
... USB 2.0A для Lightning 8-pin K14i TPE 0.25м Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.0A для Lightning 8-pin K14i TPE 0.25м | 239 ₽ на складе |
... USB 2.1A для Lightning 8-pin ПВХ 1м K21iw Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.1A для Lightning 8-pin ПВХ 1м K21iw | 199 ₽ на складе |
... USB 2.4A для Lightning 8-pin Magnetic нейлон 1м K61Sib Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A для Lightning 8-pin Magnetic нейлон 1м K61Sib | 429 ₽ на складе |
... , 2.4 A, для Lightning 8-pin AC22i Далее Азу для Lightning 8-pin More ChoiceАвтомобильное зарядное устройство More Choice 2USB, 2.4 A, для Lightning 8-pin AC22i | 450 ₽ на складе |
... USB 2.0A для Lightning 8-pin TPE 1м K16i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.0A для Lightning 8-pin TPE 1м K16i | 199 ₽ на складе |
... USB 2.0A для Lightning 8-pin нейлон 1м K11i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.0A для Lightning 8-pin нейлон 1м K11i | 200 ₽ на складе |
... PD30W быстрая зарядка для Lightning 8-pin Type-C K71Si TPE 1мw Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A PD30W быстрая зарядка для Lightning 8-pin Type-C K71Si TPE 1мw | 330 ₽ на складе |
... USB 2.1A для Lightning 8-pin нейлон 1м K27i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.1A для Lightning 8-pin нейлон 1м K27i | 232 ₽ на складе |
... USB 2.4A для Lightning 8-pin TPE 1м K22i Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice USB 2.4A для Lightning 8-pin TPE 1м K22i | 191 ₽ на складе |
... USB 2.4A для Lightning 8-pin нейлон 1м K41Si Newsb Далее Дата кабель для Lightning 8-pin More ChoiceДата-кабель More Choice Smart USB 2.4A для Lightning 8-pin нейлон 1м K41Si Newsb | 350 ₽ на складе |
26 Полигон Санкт-Петербург Россия | |
Колодка для реле 8 PIN | 809 ₽ Доставка: есть Самовывоз: есть |
Колодка для реле 8 PIN I/O | 728 ₽ Доставка: есть Самовывоз: есть |
Колодка для реле 8 PIN | 661 ₽ Доставка: есть Самовывоз: есть |
27 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
разъемы видео, ТВ | 134 ₽ от 5000 ₽ |
разъемы видео, ТВ | 169 ₽ от 5000 ₽ |
Еще 12 строк | |
разъемы видео, ТВ | 105 ₽ от 5000 ₽ |
Разъемы DIN | 17.6 ₽ от 5000 ₽ |
Зарядные устройства для сотовых телефонов | 123 ₽ от 5000 ₽ |
PL1358 (PL1359, PL1360, PL1361, PL1362, PL1363, PL1364, PL1365), Кабель USB-Lightning плоский для Apple Iphone 5, 6s, 7 8 pin, цветной, 1м Pro Legend - 17 Фев 2023 02:42 Зарядные устройства для сотовых телефонов | 146 ₽ от 5000 ₽ |
разъемы видео, ТВ | 39.1 ₽ от 5000 ₽ |
драйверы MOSFET и IGBT | 99.4 ₽ от 5000 ₽ |
разъемы видео, ТВ | 36.8 ₽ от 5000 ₽ |
источники опорного напряжения | 134 ₽ от 5000 ₽ |
разъемы видео, ТВ | 146 ₽ от 5000 ₽ |
Микросхемы для импульсных источников питания | 134 ₽ от 5000 ₽ |
28 ЭлектроПласт Санкт-Петербург Россия | |
ли 8+8 PIN DIL SOCKET 1.85mm HIGH T/R 29 Мар 2024 02:00 | запрос 7-14 дней |
ИС, компараторы Lo-Pwr Dual Voltage | запрос 7-14 дней |
29 ТаймЧипс Санкт-Петербург Россия | |
Генераторы подкачки заряда 3.3VIn to Reg 5Vout Charge Pump | запрос 7-14 дней |
30 TradeElectronics Москва Россия | |
256-Bit Serial CMOS EEPROM (MICROWIRE?„? Synchronous Bus) | запрос 7-14 дней |
31 LifeElectronics Санкт-Петербург Россия | |
Усилители звука Dual Lo-Volt Pwr Amp | запрос 7-14 дней |
32 МосЧип Москва Россия | |
Проводные клеммы и зажимы PIN ASSEMBLY 9P | запрос 7-14 дней |
Высокоскоростные/модульные разъемы PIN CONTACT .156 30 100000 | запрос 7-14 дней |
Bulk Metal Foil Technology 3 Pin Transistor Outline Hermetic Resistor ... Далее 140150/8Bulk Metal Foil Technology 3 Pin Transistor Outline Hermetic Resistor Network | запрос 7-14 дней |
Еще 38 строк | |
Bulk Metal?® Foil Technology 16 Pin Transistor Outline Hermetic ... Далее 1422578-8Bulk Metal?® Foil Technology 16 Pin Transistor Outline Hermetic Resistor Network | запрос 7-14 дней |
Alligator Clip To Pin Tip Jack With Flex Boot | запрос 7-14 дней |
1.57mm (.062) Diameter, Standard .062 Pin and Socket Crimp Terminal, ... Далее 1560205-81.57mm (.062) Diameter, Standard .062 Pin and Socket Crimp Terminal, Series 1560,Male, with Selective Gold (Au) Plated Brass Contact, Tin/ ... | запрос 7-14 дней |
Разъемы стоек и панелей A600 PIN CONT SZ 16 | запрос 7-14 дней |
Разъемы "штырь/гнездо" TYPIII PIN S-TAB BR/AU SIG | запрос 7-14 дней |
Контакты D-Sub PIN CONTACT | запрос 7-14 дней |
... Busbar,2Phase+1/2pole,18Sqmm,;PIN Type,8 Lugs,UL/cUL listed Далее 2P18U3H/8Принадлежности для автоматических выключателей Busbar,2Phase+1/2pole,18Sqmm,;PIN Type,8 Lugs,UL/cUL listed | запрос 7-14 дней |
... выключателей Busbar,2 Phase,18sqmm,PIN Type;8 Lugs, UL/cUL listed Далее 2P18U3S/8Принадлежности для автоматических выключателей Busbar,2 Phase,18sqmm,PIN Type;8 Lugs, UL/cUL listed | запрос 7-14 дней |
33 ЭИК Санкт-Петербург Россия | |
CONN PIN CONTACT SOLDER GOLD | 2 993 ₽ от 10 шт 21-42 дня склад 868 шт |
Еще 3 цен: … 2 769 ₽ | |
2 880 ₽ от 30 шт 21-42 дня склад 868 шт | |
2 827 ₽ от 150 шт 21-42 дня склад 868 шт | |
2 769 ₽ от 500 шт 21-42 дня склад 868 шт | |
CONN PIN CONTACT BNC CRIMP GOLD | 411 ₽ от 1 шт 21-42 дня склад 455 шт |
Еще 4 цен: … 241 ₽ | |
376 ₽ от 10 шт 21-42 дня склад 455 шт | |
336 ₽ от 100 шт 21-42 дня склад 455 шт | |
269 ₽ от 1000 шт 21-42 дня склад 455 шт | |
241 ₽ от 5000 шт 21-42 дня склад 455 шт | |
CONN PIN 20-24AWG GOLD CRIMP | 190 ₽ от 1 шт 21-42 дня склад 22140 шт |
Еще 4 цен: … 114 ₽ | |
173 ₽ от 25 шт 21-42 дня склад 22140 шт | |
149 ₽ от 100 шт 21-42 дня склад 22140 шт | |
135 ₽ от 500 шт 21-42 дня склад 22140 шт | |
114 ₽ от 4000 шт 21-42 дня склад 22140 шт | |
Еще 58 строк | |
CONN PIN 16-18AWG GOLD CRIMP | 185 ₽ от 1 шт 21-42 дня склад 19809 шт |
Еще 4 цен: … 111 ₽ | |
169 ₽ от 25 шт 21-42 дня склад 19809 шт | |
146 ₽ от 100 шт 21-42 дня склад 19809 шт | |
133 ₽ от 500 шт 21-42 дня склад 19809 шт | |
111 ₽ от 4000 шт 21-42 дня склад 19809 шт | |
CONN PIN 16-18AWG TIN CRIMP | 130 ₽ от 1 шт 21-42 дня склад 27059 шт |
Еще 4 цен: … 75.0 ₽ | |
126 ₽ от 25 шт 21-42 дня склад 27059 шт | |
102 ₽ от 100 шт 21-42 дня склад 27059 шт | |
90.0 ₽ от 500 шт 21-42 дня склад 27059 шт | |
75.0 ₽ от 2500 шт 21-42 дня склад 27059 шт | |
CONN PIN 20-24AWG GOLD CRIMP | 226 ₽ от 1 шт 21-42 дня склад 8460 шт |
Еще 4 цен: … 161 ₽ | |
214 ₽ от 10 шт 21-42 дня склад 8460 шт | |
205 ₽ от 25 шт 21-42 дня склад 8460 шт | |
177 ₽ от 100 шт 21-42 дня склад 8460 шт | |
161 ₽ от 500 шт 21-42 дня склад 8460 шт | |
CONN PIN 20-24AWG GOLD CRIMP | 196 ₽ от 1 шт 21-42 дня склад 10512 шт |
Еще 4 цен: … 118 ₽ | |
179 ₽ от 25 шт 21-42 дня склад 10512 шт | |
154 ₽ от 100 шт 21-42 дня склад 10512 шт | |
140 ₽ от 500 шт 21-42 дня склад 10512 шт | |
118 ₽ от 4000 шт 21-42 дня склад 10512 шт | |
CONN PIN 20-24AWG GOLD CRIMP | 311 ₽ от 1 шт 21-42 дня склад 4028 шт |
Еще 4 цен: … 167 ₽ | |
291 ₽ от 10 шт 21-42 дня склад 4028 шт | |
250 ₽ от 100 шт 21-42 дня склад 4028 шт | |
197 ₽ от 1000 шт 21-42 дня склад 4028 шт | |
167 ₽ от 10000 шт 21-42 дня склад 4028 шт | |
CONN PIN 8-10AWG GOLD CRIMP | 2 903 ₽ от 1 шт 21-42 дня склад 74 шт |
Еще 4 цен: … 2 278 ₽ | |
2 626 ₽ от 10 шт 21-42 дня склад 74 шт | |
2 556 ₽ от 25 шт 21-42 дня склад 74 шт | |
2 459 ₽ от 50 шт 21-42 дня склад 74 шт | |
2 278 ₽ от 100 шт 21-42 дня склад 74 шт | |
CONN PIN 20-24AWG GOLD CRIMP | 627 ₽ от 1 шт 21-42 дня склад 429 шт |
Еще 4 цен: … 447 ₽ | |
529 ₽ от 125 шт 21-42 дня склад 429 шт | |
489 ₽ от 375 шт 21-42 дня склад 429 шт | |
456 ₽ от 1000 шт 21-42 дня склад 429 шт | |
447 ₽ от 2500 шт 21-42 дня склад 429 шт | |
CONN D-SUB PIN 22-28AWG CRIMP | 349 ₽ от 1 шт 21-42 дня склад 5067 шт |
Еще 4 цен: … 271 ₽ | |
303 ₽ от 10 шт 21-42 дня склад 5067 шт | |
290 ₽ от 25 шт 21-42 дня склад 5067 шт | |
284 ₽ от 50 шт 21-42 дня склад 5067 шт | |
271 ₽ от 100 шт 21-42 дня склад 5067 шт | |
CONN GUIDE PIN CORNER 104CF POS | 4 833 ₽ от 1 шт 21-42 дня склад 11 шт |
Еще 4 цен: … 3 427 ₽ | |
3 989 ₽ от 10 шт 21-42 дня склад 11 шт | |
3 708 ₽ от 25 шт 21-42 дня склад 11 шт | |
3 504 ₽ от 50 шт 21-42 дня склад 11 шт | |
3 427 ₽ от 100 шт 21-42 дня склад 11 шт | |
CONN PIN 14-18AWG TIN CRIMP | 149 ₽ от 1 шт 21-42 дня склад 25163 шт |
Еще 4 цен: … 90.0 ₽ | |
144 ₽ от 25 шт 21-42 дня склад 25163 шт | |
117 ₽ от 100 шт 21-42 дня склад 25163 шт | |
103 ₽ от 500 шт 21-42 дня склад 25163 шт | |
90.0 ₽ от 4000 шт 21-42 дня склад 25163 шт | |
CONN PIN 24-26AWG GOLD CRIMP | 196 ₽ от 1 шт 21-42 дня склад 19436 шт |
179 ₽ от 25 шт 21-42 дня склад 19436 шт | |
154 ₽ от 100 шт 21-42 дня склад 19436 шт | |
140 ₽ от 500 шт 21-42 дня склад 19436 шт | |
118 ₽ от 4000 шт 21-42 дня склад 19436 шт | |
CONN PIN 14-18AWG TIN CRIMP | 166 ₽ от 1 шт 21-42 дня склад 27549 шт |
Еще 4 цен: … 95.0 ₽ | |
160 ₽ от 25 шт 21-42 дня склад 27549 шт | |
130 ₽ от 100 шт 21-42 дня склад 27549 шт | |
115 ₽ от 500 шт 21-42 дня склад 27549 шт | |
95.0 ₽ от 3000 шт 21-42 дня склад 27549 шт | |
CONN PIN 26-30AWG GOLD CRIMP | 213 ₽ от 1 шт 21-42 дня склад 7188 шт |
Еще 4 цен: … 131 ₽ | |
203 ₽ от 10 шт 21-42 дня склад 7188 шт | |
191 ₽ от 50 шт 21-42 дня склад 7188 шт | |
161 ₽ от 250 шт 21-42 дня склад 7188 шт | |
131 ₽ от 1000 шт 21-42 дня склад 7188 шт | |
CONN PIN 26-30AWG GOLD CRIMP | 258 ₽ от 1 шт 21-42 дня склад 8726 шт |
Еще 4 цен: … 207 ₽ | |
240 ₽ от 10 шт 21-42 дня склад 8726 шт | |
231 ₽ от 25 шт 21-42 дня склад 8726 шт | |
229 ₽ от 50 шт 21-42 дня склад 8726 шт | |
207 ₽ от 100 шт 21-42 дня склад 8726 шт | |
CONN PIN GOLD SOLDER EYELET | 292 ₽ от 55 шт 21-42 дня склад 485 шт |
279 ₽ от 330 шт 21-42 дня склад 485 шт | |
CONN PIN 10AWG SILVER CRIMP | 914 ₽ от 1 шт 21-42 дня склад 3229 шт |
Еще 4 цен: … 731 ₽ | |
830 ₽ от 10 шт 21-42 дня склад 3229 шт | |
786 ₽ от 25 шт 21-42 дня склад 3229 шт | |
768 ₽ от 50 шт 21-42 дня склад 3229 шт | |
731 ₽ от 100 шт 21-42 дня склад 3229 шт | |
CONN PIN 12-16AWG SILVER CRIMP | 910 ₽ от 1 шт 21-42 дня склад 5033 шт |
Еще 4 цен: … 727 ₽ | |
825 ₽ от 10 шт 21-42 дня склад 5033 шт | |
782 ₽ от 25 шт 21-42 дня склад 5033 шт | |
763 ₽ от 50 шт 21-42 дня склад 5033 шт | |
727 ₽ от 100 шт 21-42 дня склад 5033 шт | |
34 Аудиомания Москва Россия, Беларусь, Казахстан | |
... -A Plug - Mini USB 5 pin), двойной экран, длина 1 ... Далее MUM8002 1.8 m ... - mini USB, позолоченные разъёмы (USB-A Plug - Mini USB 5 pin), двойной экран, длина 1,8 м | 238 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 300 ₽ Самовывоз: есть Точки продаж: есть на складе |
35 Industrial Module Москва Россия | |
PIN BUSBAR SHOCKHAZARD SAFETY, 16SQMM 1-PHASE+N, 12MW FULLY INSULATED | 2 206 ₽ 7-28 дней на складе |
8-Port Device Server, 10/100 Ethernet----------------Connectors RS-232 ... Далее NPort 5610-88-Port Device Server, 10/100 Ethernet----------------Connectors RS-232 RJ-45 8pin,------------- 15KV ESD, 110V * | запрос 7-28 дней на складе |
8-Port Device Server, 10/100 Ethernet----------------Connectors RS-232 ... Далее NPort 5610-88-Port Device Server, 10/100 Ethernet----------------Connectors RS-232 RJ-45 8pin,------------- 15KV ESD, 110V * | 68 703 ₽ 7-28 дней на складе |
36 Промэлектроника Екатеринбург Россия и страны СНГ | |
Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт ... Далее TEN 8-1212Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 3 579 ₽ от 1 шт от 2-10 дней склад 5 шт |
Преобразователь DC-DC на печатную плату вход 12В двуполярный выход & ... Далее TEN 8-1223Преобразователь DC-DC на печатную плату вход 12В двуполярный выход ±15В 0.265A/-0.265A 8Вт 9-Pin металлический DIP | 3 128 ₽ от 1 шт от 2-10 дней склад 6 шт |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3. ... Далее TEN 8-2410Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3.3В 2A 8Вт 9-Pin металлический DIP | 4 051 ₽ от 1 шт от 2-10 дней склад 10 шт |
Еще 11 строк | |
Преобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9 ... Далее TEN 8-2410WIПреобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9-Pin PDIP | 4 637 ₽ от 1 шт от 2-10 дней склад 10 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-2411WIПреобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9-Pin PDIP | 4 774 ₽ от 1 шт от 2-10 дней склад 95 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт ... Далее TEN 8-2412Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 088 ₽ от 1 шт от 2-10 дней склад 19 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.666A 8Вт ... Далее TEN 8-2412WIПреобразователь DC-DC на печатную плату вход 24В выход 12В 0.666A 8Вт 9-Pin PDIP | 5 474 ₽ от 1 шт от 2-10 дней склад 1 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт ... Далее TEN 8-2413Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт 9-Pin металлический DIP | 3 759 ₽ от 1 шт от 2-10 дней склад 6 шт |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В ... Далее TEN 8-2422Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В/-12В 0.335A/-0.335A 8Вт 9-Pin металлический DIP | 3 659 ₽ от 1 шт от 2-10 дней склад 5 шт |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 15В ... Далее TEN 8-2423Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 15В/-15В 0.265A/-0.265A 8Вт 9-Pin металлический DIP | 3 690 ₽ от 1 шт от 2-10 дней склад 17 шт |
Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-4811WIПреобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9-Pin PDIP | 4 991 ₽ от 1 шт от 2-10 дней склад 6 шт |
Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт ... Далее TEN 8-4812Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 225 ₽ от 1 шт от 2-10 дней склад 48 шт |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9- ... Далее TEN 8-2411Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9-Pin металлический DIP | 3 850 ₽ от 1 шт от 2-10 дней склад 80 шт |
Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-4811Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9-Pin PDIP | 3 731 ₽ от 1 шт от 2-10 дней склад 4 шт |
37 Берёзка Электронные Компоненты Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В ... Далее TEN 8-2422Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В/-12В 0.335A/-0.335A 8Вт 9-Pin металлический DIP | 4 254 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 491 ₽ | |
3 883 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 652 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 491 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт ... Далее TEN 8-1212Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 164 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 415 ₽ | |
3 800 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 573 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 415 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 12В двуполярный выход & ... Далее TEN 8-1223Преобразователь DC-DC на печатную плату вход 12В двуполярный выход ±15В 0.265A/-0.265A 8Вт 9-Pin металлический DIP | 3 636 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 2 977 ₽ | |
3 317 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 116 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
2 977 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Еще 11 строк | |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3. ... Далее TEN 8-2410Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3.3В 2A 8Вт 9-Pin металлический DIP | 4 057 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 528 ₽ | |
3 775 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 596 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 528 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9 ... Далее TEN 8-2410WIПреобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9-Pin PDIP | 5 402 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 444 ₽ | |
4 937 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 646 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 444 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9- ... Далее TEN 8-2411Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9-Pin металлический DIP | 4 054 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 324 ₽ | |
3 700 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 478 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 324 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-2411WIПреобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9-Pin PDIP | 4 809 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 951 ₽ | |
4 392 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 132 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 951 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт ... Далее TEN 8-2412Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 489 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 685 ₽ | |
4 099 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 854 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 685 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.666A 8Вт ... Далее TEN 8-2412WIПреобразователь DC-DC на печатную плату вход 24В выход 12В 0.666A 8Вт 9-Pin PDIP | 5 378 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 424 ₽ | |
4 914 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 625 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 424 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт ... Далее TEN 8-2413Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт 9-Pin металлический DIP | 4 126 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 383 ₽ | |
3 765 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 540 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 383 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В ... Далее TEN 8-2421WIПреобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В/-5В 0.8A/-0.8A 8Вт 9-Pin PDIP | 5 881 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 843 ₽ | |
5 376 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
5 061 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 843 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-4811WIПреобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9-Pin PDIP | 5 817 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 790 ₽ | |
5 318 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
5 006 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 790 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт ... Далее TEN 8-4812Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 424 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 631 ₽ | |
4 039 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 798 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 631 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 110В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-7211WIПреобразователь DC-DC на печатную плату вход 110В выход 5В 1.6A 8Вт 9-Pin металлический DIP | 7 180 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 5 929 ₽ | |
6 571 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
6 192 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
5 929 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
38 ICdarom.ru Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт ... Далее TEN 8-1212Преобразователь DC-DC на печатную плату вход 12В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 3 999 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 279 ₽ | |
3 650 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 431 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 279 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 12В двуполярный выход & ... Далее TEN 8-1223Преобразователь DC-DC на печатную плату вход 12В двуполярный выход ±15В 0.265A/-0.265A 8Вт 9-Pin металлический DIP | 3 492 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 2 859 ₽ | |
3 185 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
2 993 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
2 859 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3. ... Далее TEN 8-2410Преобразователь DC-DC на печатную плату вход 24В однополярный выход 3.3В 2A 8Вт 9-Pin металлический DIP | 4 442 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 648 ₽ | |
4 056 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 815 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 648 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Еще 10 строк | |
Преобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9 ... Далее TEN 8-2410WIПреобразователь DC-DC на печатную плату вход 24В выход 3.3В 2.4A 8Вт 9-Pin PDIP | 5 189 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 268 ₽ | |
4 741 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 462 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 268 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9- ... Далее TEN 8-2411Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.5A 8Вт 9-Pin металлический DIP | 3 893 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 193 ₽ | |
3 553 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 340 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 193 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-2411WIПреобразователь DC-DC на печатную плату вход 24В выход 5В 1.6A 8Вт 9-Pin PDIP | 4 618 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 794 ₽ | |
4 218 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 968 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 794 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт ... Далее TEN 8-2412Преобразователь DC-DC на печатную плату вход 24В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 311 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 539 ₽ | |
3 936 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 702 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 539 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт ... Далее TEN 8-2413Преобразователь DC-DC на печатную плату вход 24В выход 15В 0.535A 8Вт 9-Pin металлический DIP | 3 962 ₽ розница 3-4 рабочих дня склад 5 шт |
Еще 3 цен: … 3 249 ₽ | |
3 616 ₽ мелкий опт 3-4 рабочих дня склад 5 шт | |
3 399 ₽ средний опт 3-4 рабочих дня склад 5 шт | |
3 249 ₽ крупный опт 3-4 рабочих дня склад 5 шт | |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В ... Далее TEN 8-2421WIПреобразователь DC-DC на печатную плату вход 24В двуполярный выход 5В/-5В 0.8A/-0.8A 8Вт 9-Pin PDIP | 5 648 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 651 ₽ | |
5 163 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 861 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 651 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В ... Далее TEN 8-2422Преобразователь DC-DC на печатную плату вход 24В двуполярный выход 12В/-12В 0.335A/-0.335A 8Вт 9-Pin металлический DIP | 4 085 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 353 ₽ | |
3 730 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 507 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 353 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-4811WIПреобразователь DC-DC на печатную плату вход 48В выход 5В 1.6A 8Вт 9-Pin PDIP | 5 587 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 4 600 ₽ | |
5 107 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
4 808 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
4 600 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт ... Далее TEN 8-4812Преобразователь DC-DC на печатную плату вход 48В выход 12В 0.665A 8Вт 9-Pin металлический DIP | 4 249 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 3 487 ₽ | |
3 879 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
3 648 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
3 487 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
Преобразователь DC-DC на печатную плату вход 110В выход 5В 1.6A 8Вт 9- ... Далее TEN 8-7211WIПреобразователь DC-DC на печатную плату вход 110В выход 5В 1.6A 8Вт 9-Pin металлический DIP | 6 896 ₽ розница 3-4 рабочих дня склад 4 шт |
Еще 3 цен: … 5 694 ₽ | |
6 311 ₽ мелкий опт 3-4 рабочих дня склад 4 шт | |
5 946 ₽ средний опт 3-4 рабочих дня склад 4 шт | |
5 694 ₽ крупный опт 3-4 рабочих дня склад 4 шт | |
39 ЧипСити Москва Россия | |
Conn Power PIN 8POS 4.2mm Solder RA Thru-Hole 8 Terminal 1Port Tray | 81.2 ₽ 3-7 дней склад 6369 шт |
Conn Power PIN 3POS 5mm Solder ST Thru-Hole 3 Terminal 1Port | 702 ₽ 3-7 дней склад 891 шт |
Conn Power PIN 4POS 5mm Solder ST Thru-Hole 4 Terminal 1Port | 583 ₽ 3-7 дней склад 696 шт |
Еще 136 строк | |
Socket; PIN:11; 10A; 250VAC; Mounting: DIN; Leads: screw; Series: MT | 1 043 ₽ 3-7 дней склад 2282 шт |
Conn Backplane PIN 240POS 2mm Press Fit ST Thru-Hole | 1 977 ₽ 3-7 дней склад 937 шт |
Conn Backplane PIN 168POS 2mm Solder RA Thru-Hole | 2 942 ₽ 3-7 дней склад 992 шт |
Stainless Steal 3mm 10AWG Crimp Pin Contact Drawer Connector | 872 ₽ 3-7 дней склад 3141 шт |
Connector Accessories Guide/Power Pin | 98.8 ₽ 3-7 дней склад 1047 шт |
Connector Accessories Guide/Power Pin | 143 ₽ 3-7 дней склад 1009 шт |
CONN PIN 26-30AWG GOLD CRIMP | 51.6 ₽ 3-7 дней склад 15928 шт |
Contact PIN Crimp ST Cable Mount Loose Piece | 634 ₽ 3-7 дней склад 810 шт |
CONN CONT PIN 12-16AWG TIN CRIMP | 118 ₽ 3-7 дней склад 992 шт |
Conn D-Subminiature PIN 9POS 2.74mm Solder RA Thru-Hole 9 Terminal ... Далее 8-1393480-5Conn D-Subminiature PIN 9POS 2.74mm Solder RA Thru-Hole 9 Terminal 1Port | 423 ₽ 3-7 дней склад 878 шт |
Conn D-Subminiature PIN 9POS Crimp ST Cable Mount 9 Terminal 1Port Kit | 933 ₽ 3-7 дней склад 1373 шт |
Conn D-Subminiature PIN 9POS 2.74mm Solder RA Thru-Hole 9 Terminal ... Далее 5745434-8Conn D-Subminiature PIN 9POS 2.74mm Solder RA Thru-Hole 9 Terminal 1Port | 1 246 ₽ 3-7 дней склад 1161 шт |
Conn D-Subminiature PIN 15POS 2.74mm Solder RA Thru-Hole 15 Terminal ... Далее 5745435-8Conn D-Subminiature PIN 15POS 2.74mm Solder RA Thru-Hole 15 Terminal 1Port | 2 697 ₽ 3-7 дней склад 531 шт |
Conn D-Subminiature PIN 15POS 2.76mm IDT ST Panel Mount 15 Terminal ... Далее 747531-8Conn D-Subminiature PIN 15POS 2.76mm IDT ST Panel Mount 15 Terminal 1Port Package | 650 ₽ 3-7 дней склад 1229 шт |
Conn D-Subminiature PIN 25POS 2.77mm Crimp ST Cable Mount 25 Terminal ... Далее 745211-8Conn D-Subminiature PIN 25POS 2.77mm Crimp ST Cable Mount 25 Terminal 1Port | 1 291 ₽ 3-7 дней склад 1018 шт |
Conn D-Subminiature PIN 7Coaxial/17Signal POS Solder ST Thru-Hole 24 ... Далее 208743-8Conn D-Subminiature PIN 7Coaxial/17Signal POS Solder ST Thru-Hole 24 Terminal 1Port | 3 846 ₽ 3-7 дней склад 1064 шт |
Conn LGH PIN 7POS Crimp ST Cable Mount 7 Terminal 1Port | 9 659 ₽ 3-7 дней склад 117 шт |
40 РИВ Электроникс Москва Россия | |
microSD SMD 8pin 1.8H 08 Фев 2024 13:12 | 13.7 ₽ от 77 шт мин заказ 77 шт Да |
Еще 4 цен: | |
9.68 ₽ от 160 шт мин заказ 77 шт Да | |
7.21 ₽ от 4620 шт мин заказ 77 шт Да | |
7.10 ₽ от 7540 шт мин заказ 77 шт Да | |
запрос от 0 шт мин заказ 77 шт Да | |
8-pin SOP Минимум 3шт. | 223 ₽ от 3 шт мин заказ 3 шт Да |
Еще 7 цен: | |
178 ₽ от 5 шт мин заказ 3 шт Да | |
168 ₽ от 33 шт мин заказ 3 шт Да | |
160 ₽ от 98 шт мин заказ 3 шт Да | |
152 ₽ от 150 шт мин заказ 3 шт Да | |
140 ₽ от 300 шт мин заказ 3 шт Да | |
133 ₽ от 420 шт мин заказ 3 шт Да | |
запрос от 0 шт мин заказ 3 шт Да | |
8-pin SOICN Минимум 2шт. | 331 ₽ от 2 шт мин заказ 2 шт Да |
Еще 8 цен: | |
264 ₽ от 4 шт мин заказ 2 шт Да | |
248 ₽ от 14 шт мин заказ 2 шт Да | |
235 ₽ от 26 шт мин заказ 2 шт Да | |
226 ₽ от 50 шт мин заказ 2 шт Да | |
219 ₽ от 100 шт мин заказ 2 шт Да | |
202 ₽ от 129 шт мин заказ 2 шт Да | |
193 ₽ от 350 шт мин заказ 2 шт Да | |
41 Whitegoods Москва Россия Hurakan | |
Плата генератора Hurakan 8PIN универсальная для индукционной плиты ... Далее 8PIN универсальная - 374646Плата генератора Hurakan 8PIN универсальная для индукционной плиты Hurakan. Без микропроцессора, подходит для всех моделей. | 6 499 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
... -ICF35DX4, HKN-ICF35DX47. Особенности (8 pin.) Новая модель NS-935G с ... Далее LM73 - 374527 ... индукционной Hurakan модели HKN-ICF70D2V, HKN-ICF35DX4, HKN-ICF35DX47. Особенности (8 pin.) Новая модель NS-935G с апреля 2021. | 4 003 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
... Hurakan модели HKN-ICF35DX4. Особенности 8 pin). A-817 c 35А bridge ... Далее HKN-ICF35DX4 - 217861 ... -ICF35DX4 предназначена для плиты индукционной Hurakan модели HKN-ICF35DX4. Особенности 8 pin). A-817 c 35А bridge. | 6 499 ₽ Предоплата 100% для товаров от... Далее Предоплата 100% для товаров от 100000 ₽ Самовывоз: есть 1-3 дня - |
42 Romstore Москва Россия, Беларусь | |
Кнопка №8 4pin 6x6x7 SWT-6 28 Мар 2024 02:34 | 15.0 ₽ розница |
5.00 ₽ опт | |
Кнопка №6 4pin 4.5x4.5x3.8 28 Мар 2024 02:34 | 15.0 ₽ розница |
5.00 ₽ опт | |
Тест-клипса (прищепка) SOIC8 с кабелем 28 Мар 2024 02:34 DIP8 в SOIC8-150-170-200-208mil, pin-to-pin, = SA602A | 950 ₽ розница |
790 ₽ опт | |
Еще 3 строки | |
Tuner TDQ-38HS 8pin 28 Мар 2024 02:34 | 1 000 ₽ розница |
795 ₽ опт | |
74AC299PC 28 Мар 2024 02:34 8-input universal shift/storage register with common parallel I/O pins ... Далее 74AC299PC8-input universal shift/storage register with common parallel I/O pins, КР1554ИР24 | 25.0 ₽ розница |
18.0 ₽ опт | |
HMS8-W (DIP8-MSOP8) 28 Мар 2024 02:34 8pin MSOP 3x3мм, шаг 0,65мм, pin-to-pin, панель Wells, = AE-SP8U TSU- ... Далее HMS8-W (DIP8-MSOP8)8pin MSOP 3x3мм, шаг 0,65мм, pin-to-pin, панель Wells, = AE-SP8U TSU-D08/MS08-3x3 | 2 990 ₽ опт |
2 990 ₽ розница | |
43 Кремний Санкт-Петербург Россия и страны СНГ | |
запрос 7-14 дней | |
Разьем микрофонный круглый вилка кабельная 8 pin 29 Мар 2024 02:00 | запрос 2 недели |
Еще 8 строк | |
8-pin DIL IC sockets Black plastic high or low profile 29 Мар 2024 02:00 | запрос 2 недели |
8-PIN-SM 29 Мар 2024 02:00 | запрос 7-14 дней |
DIP SWITCH 8 PIN PIANO 29 Мар 2024 02:00 | запрос 7-14 дней |
IC SOCKET 8 PIN 29 Мар 2024 02:00 | запрос 7-14 дней |
IC SOCKET 8 PIN D/C98 29 Мар 2024 02:00 | запрос 7-14 дней |
IC SOCKET 8 PIN D/C99 29 Мар 2024 02:00 | запрос 7-14 дней |
OP07CS-SMD (8 PIN) D/C97 29 Мар 2024 02:00 | запрос 7-14 дней |
44 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
CONN PLUG 4 POS STRAIGHT W/PINS | запрос 7-14 дней |
... характеристики соединителя 4P Size 8 Pin Plug Strt Strain Relief Далее PT06A-8-4P-SRКруговой мил / технические характеристики соединителя 4P Size 8 Pin Plug Strt Strain Relief | запрос 7-14 дней |
... характеристики соединителя 2P Size 8 Pin Plug R/A Strain Relief Далее PT08E-8-2P-SRКруговой мил / технические характеристики соединителя 2P Size 8 Pin Plug R/A Strain Relief | запрос 7-14 дней |
Еще 363 строки | |
... / технические характеристики соединителя 3P Size 8 Straight Pin Plug Далее PT06E-8-3PКруговой мил / технические характеристики соединителя 3P Size 8 Straight Pin Plug | запрос 7-14 дней |
... характеристики соединителя 3P Size 8 Jam Nut Pin Receptacle Далее PT07A-8-3PКруговой мил / технические характеристики соединителя 3P Size 8 Jam Nut Pin Receptacle | запрос 7-14 дней |
... характеристики соединителя 4P Size 8 Jam Nut Pin Receptacle Далее PT07A-8-4P (023)Круговой мил / технические характеристики соединителя 4P Size 8 Jam Nut Pin Receptacle | запрос 7-14 дней |
CORD PATCH PIN TIP PLUG 8 BLACK | запрос 7-14 дней |
... Ethernet 6 TRMN BRD GRND PINS 8 PIN BLOCK INDUCTOR Далее RJ45-6LC2-BМодульные соединители / соединители Ethernet 6 TRMN BRD GRND PINS 8 PIN BLOCK INDUCTOR | запрос 7-14 дней |
8-BIT OTP/EPROM MCUs WITH ... SAFEGUARD, SAFE RESET AND 16 PINS | запрос 7-14 дней |
LOW VOLTAGE 8-BIT ROM MCUs WITH A/D CONVERTER,AND 16 PINS | запрос 7-14 дней |
8-BIT OTP/EPROM MCUs WITH ... SAFEGUARD, SAFE RESET AND 20 PINS | запрос 7-14 дней |
8-BIT OTP/EPROM MCUs WITH ... SAFEGUARD, SAFE RESET AND 28 PINS | запрос 7-14 дней |
45 Океан Электроники Санкт-Петербург Россия | |
8 PIN DIP HCMOS | запрос 7-14 дней |
SS-103-G-8 29 Мар 2024 02:00 Базовые выключатели / Выключатели мгновенного действия Pin plunger ... Далее SS-103-G-8Базовые выключатели / Выключатели мгновенного действия Pin plunger 150gf 10.1A SPDT Solder | запрос 7-14 дней |
Преобразователи постоянного тока в постоянный 18W 24V to 1.8V 10A NEG ... Далее UHE-1.8/10000-D24NR-CПреобразователи постоянного тока в постоянный 18W 24V to 1.8V 10A NEG POL SENSE PIN | запрос 7-14 дней |
Еще 316 строк | |
Преобразователи постоянного тока в постоянный 24Vin 12Vout 8A 96W w/ ... Далее UVQ-12/8-D24PB9-CПреобразователи постоянного тока в постоянный 24Vin 12Vout 8A 96W w/ baseplate Pin 9 | запрос 7-14 дней |
LOW VOLTAGE 8-BIT ROM MCUs WITH A/D CONVERTER AND 20 PINS | запрос 7-14 дней |
LOW VOLTAGE 8-BIT ROM MCUs WITH A/D CONVERTER AND 28 PINS | запрос 7-14 дней |
... SNGLE ROW 1X1 PORT 1.8 MM PINS DUST CVR Далее U77A11141D01Соединители для ввода/вывода SNGLE ROW 1X1 PORT 1.8 MM PINS DUST CVR | запрос 7-14 дней |
46 Зенер Москва Россия и страны ТС | |
CONN PIN CONTACT SOLDER GOLD | запрос 5-15 дней |
CONN CONT PIN 12-16AWG TIN CRIMP | запрос 5-15 дней |
PIN,.062 DIA,.045 SQ POST,LP | запрос 5-15 дней |
Еще 283 строки | |
CONTACT PIN 17-20AWG CRIMP GOLD | запрос 5-15 дней |
JT 6C 6#22D PIN PLUG | 5 844 ₽ от 5 шт |
Еще 7 цен: … 3 066 ₽ | |
4 969 ₽ от 10 шт | |
4 345 ₽ от 25 шт | |
3 887 ₽ от 50 шт | |
3 343 ₽ от 100 шт | |
3 112 ₽ от 250 шт | |
3 089 ₽ от 500 шт | |
3 066 ₽ от 1000 шт | |
JT 6C 6#22D PIN PLUG | запрос 5-15 дней |
JT 6C 6#22D PIN RECP | запрос 5-15 дней |
CONN PIN CONTACT BNC SOLDER GOLD | запрос 5-15 дней |
CONN PIN CONTACT BNC CRIMP GOLD | запрос 5-15 дней |
CONN PIN CONTACT BNC SOLDR SILVR | запрос 5-15 дней |
CONN PIN CONTACT BNC CRIMP GOLD | 235 ₽ от 1 шт 5-15 дней склад 546 шт |
Еще 8 цен: … 122 ₽ | |
205 ₽ от 10 шт 5-15 дней склад 546 шт | |
196 ₽ от 25 шт 5-15 дней склад 546 шт | |
191 ₽ от 50 шт 5-15 дней склад 546 шт | |
183 ₽ от 100 шт 5-15 дней склад 546 шт | |
165 ₽ от 250 шт 5-15 дней склад 546 шт | |
152 ₽ от 500 шт 5-15 дней склад 546 шт | |
131 ₽ от 1000 шт 5-15 дней склад 546 шт | |
122 ₽ от 2500 шт 5-15 дней склад 546 шт | |
CONTACT PIN COAX CABLE 316DS GLD | запрос 5-15 дней |
CONTACT PIN 10AWG CRIMP SILVER | запрос 5-15 дней |
CONN PIN 12-16 AWG SILVER CRIMP | запрос 5-15 дней склад 6150 шт |
CONN PIN 16-18AWG TIN CRIMP | 79.0 ₽ от 1 шт 5-15 дней склад 13272 шт |
Еще 10 цен: … 35.1 ₽ | |
69.2 ₽ от 10 шт 5-15 дней склад 13272 шт | |
63.2 ₽ от 25 шт 5-15 дней склад 13272 шт | |
59.5 ₽ от 50 шт 5-15 дней склад 13272 шт | |
57.0 ₽ от 100 шт 5-15 дней склад 13272 шт | |
52.1 ₽ от 250 шт 5-15 дней склад 13272 шт | |
49.6 ₽ от 500 шт 5-15 дней склад 13272 шт | |
40.9 ₽ от 1000 шт 5-15 дней склад 13272 шт | |
39.2 ₽ от 4000 шт 5-15 дней склад 13272 шт | |
35.9 ₽ от 8000 шт 5-15 дней склад 13272 шт | |
35.1 ₽ от 12000 шт 5-15 дней склад 13272 шт | |
CONN PIN 20-24AWG TIN CRIMP | 53.6 ₽ от 10 шт 5-15 дней склад 54211 шт |
Еще 5 цен: … 36.1 ₽ | |
47.9 ₽ от 100 шт 5-15 дней склад 54211 шт | |
46.2 ₽ от 250 шт 5-15 дней склад 54211 шт | |
44.5 ₽ от 500 шт 5-15 дней склад 54211 шт | |
38.7 ₽ от 1000 шт 5-15 дней склад 54211 шт | |
36.1 ₽ от 2500 шт 5-15 дней склад 54211 шт | |
CONN PIN .062 14-18AWG TIN CRIMP | 74.0 ₽ от 1 шт 5-15 дней склад 828 шт |
Еще 11 цен: … 32.2 ₽ | |
64.3 ₽ от 10 шт 5-15 дней склад 828 шт | |
58.8 ₽ от 25 шт 5-15 дней склад 828 шт | |
55.3 ₽ от 50 шт 5-15 дней склад 828 шт | |
53.0 ₽ от 100 шт 5-15 дней склад 828 шт | |
48.4 ₽ от 250 шт 5-15 дней склад 828 шт | |
46.1 ₽ от 500 шт 5-15 дней склад 828 шт | |
38.0 ₽ от 1000 шт 5-15 дней склад 828 шт | |
37.1 ₽ от 4000 шт 5-15 дней склад 828 шт | |
33.4 ₽ от 8000 шт 5-15 дней склад 828 шт | |
32.9 ₽ от 12000 шт 5-15 дней склад 828 шт | |
32.2 ₽ от 28000 шт 5-15 дней склад 828 шт | |
CONN PLUG 8 POS STRAIGHT W/PINS | 7 619 ₽ от 5 шт |
Еще 3 цен: … 5 944 ₽ | |
6 572 ₽ от 10 шт | |
6 279 ₽ от 25 шт | |
5 944 ₽ от 50 шт | |
47 СЭлКом Москва Россия и страны СНГ | |
Акция! / | 52.6 ₽ розница 1-7 дней склад 9 шт |
48 Onber.ru Москва Россия и страны СНГ | |
Кабель питания HPE DL380 Gen10 8-pin Cable Kit (for Q0V76A and ... Далее Кабель питания HP 871828-B21Кабель питания HPE DL380 Gen10 8-pin Cable Kit (for Q0V76A and Q0J62A) | запрос 100% предоплата. Минимальная... Далее 100% предоплата. Минимальная сумма заказа 5000 р. Самовывоз: есть под заказ |
Cable Network 1000 Base-T RJ45 8-pin | 327 ₽ 100% предоплата. Минимальная... Далее 100% предоплата. Минимальная сумма заказа 5000 р. Самовывоз: есть под заказ |
49 AliExpress Китай Весь мир | |
316 ₽ от 21 дня | |
324 ₽ от 21 дня | |
430 ₽ от 21 дня | |
Еще 19 строк | |
615 ₽ от 21 дня | |
819 ₽ от 21 дня | |
819 ₽ от 21 дня | |
60.5 ₽ от 10 шт 10 шт/лот от 21 дня | |
946 ₽ от 21 дня | |
75.7 ₽ от 5 шт 5 шт/лот от 21 дня | |
354 ₽ от 21 дня | |
354 ₽ от 21 дня | |
1 650 ₽ от 21 дня | |
359 ₽ от 21 дня | |
424 ₽ от 21 дня | |
230 ₽ от 6 шт 6 шт/лот от 21 дня | |
134 ₽ от 21 дня | |
16.2 ₽ от 1 шт от 21 дня | |
1.08 ₽ от 10 шт 10 шт/лот от 21 дня | |
3 577 ₽ от 21 дня | |
594 ₽ от 21 дня |
Искать "8-pin" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 92.5919 |
EUR | 100.270 |
