1 Flash-Turtle Китай Весь мир | |
3.58 MHz Ceramic Resonator Built in Capacitor 15 pF ±0.2% 50 ... Далее CSTLS3M58G53-B03.58 MHz Ceramic Resonator Built in Capacitor 15 pF ±0.2% 50 Ohms -20℃ ~ 80℃ Through Hole | запрос 7 дней склад 32307 шт |
6 MHz Ceramic Resonator Built in Capacitor 39 pF ±0.2% 50 Ohms ... Далее CSTCR6M00G55-R06 MHz Ceramic Resonator Built in Capacitor 39 pF ±0.2% 50 Ohms -20℃ ~ 80℃ Surface Mount | запрос 7 дней склад 37164 шт |
6.29 MHz Ceramic Resonator Built in Capacitor 15 pF ±0.2% 50 ... Далее CSTCR6M29G53-R06.29 MHz Ceramic Resonator Built in Capacitor 15 pF ±0.2% 50 Ohms -20℃ ~ 80℃ Surface Mount | запрос 7 дней склад 49747 шт |
Еще 6 строк | |
6.75 MHz Ceramic Resonator Built in Capacitor 39 pF ±0.2% 50 ... Далее CSTCR6M75G55-R06.75 MHz Ceramic Resonator Built in Capacitor 39 pF ±0.2% 50 Ohms -20℃ ~ 80℃ Surface Mount | запрос 7 дней склад 28659 шт |
7.37 MHz Ceramic Resonator Built in Capacitor 15 pF ±0.2% 50 ... Далее CSTCR7M37G53-R07.37 MHz Ceramic Resonator Built in Capacitor 15 pF ±0.2% 50 Ohms -20℃ ~ 80℃ Surface Mount | запрос 7 дней склад 25923 шт |
16 MHz Ceramic Resonator Built in Capacitor 30 pF ±0.2% 50 Ohms ... Далее CSTLS16M0X55Z-A016 MHz Ceramic Resonator Built in Capacitor 30 pF ±0.2% 50 Ohms -20℃ ~ 80℃ Through Hole | запрос 7 дней склад 30827 шт |
16.934 MHz Ceramic Resonator Built in Capacitor 30 pF ±0.2% 50 ... Далее CSTLS16M9X55-A016.934 MHz Ceramic Resonator Built in Capacitor 30 pF ±0.2% 50 Ohms -20℃ ~ 80℃ Through Hole | запрос 7 дней склад 46768 шт |
5600 μF 80 V Aluminum Electrolytic Capacitors Radial, Can - Snap-In ... Далее ECO-S1KA562EA5600 μF 80 V Aluminum Electrolytic Capacitors Radial, Can - Snap-In 50mOhm @ 120Hz 3000 Hrs @ 105℃ | запрос 7 дней склад 7857 шт |
3300 μF 50 V Aluminum Electrolytic Capacitors Radial, Can - Snap-In ... Далее MAL205641332E33300 μF 50 V Aluminum Electrolytic Capacitors Radial, Can - Snap-In 80mOhm @ 100Hz 12000 Hrs @ 85℃ | запрос 7 дней склад 40006 шт |
2 Akcel Китай Весь мир | |
Constant Torque Hinge, Asymmetric, Forward Torque 9 N-m (80 in-lbf), ... Далее E6-10-680F-50Constant Torque Hinge, Asymmetric, Forward Torque 9 N-m (80 in-lbf), Reverse Torque 6.7 N-m (59.4 in-lbf), Heavy Duty Size, Aluminum Alloy, ... | запрос от 1 шт |
2.000 in X 2.250 in (50.80 Mm X 57.15 Mm) | запрос от 1 шт |
3/4 in X 2 in (19.00 Mm X 50.80 Mm) | запрос от 1 шт |
Еще 47 строк | |
Cap Aluminum Lytic 1200uF 450V 20% (50 X 80mm) Snap-In 10mm 0.152 Ohm ... Далее 383LX122M450B082VCap Aluminum Lytic 1200uF 450V 20% (50 X 80mm) Snap-In 10mm 0.152 Ohm 4700mA 3000h 105°C | запрос от 1 шт |
Cap Aluminum Lytic 1500uF 400V 20% (50 X 80mm) Snap-In 10mm 0.122 Ohm ... Далее 383LX152M400B082VCap Aluminum Lytic 1500uF 400V 20% (50 X 80mm) Snap-In 10mm 0.122 Ohm 5200mA 3000h 105°C | запрос от 1 шт |
964F# 3M(TM) Cloth Belt 964F_ 4 in x 91 in 80 YF-weight Top_ 50 per ... Далее 60600135671964F# 3M(TM) Cloth Belt 964F_ 4 in x 91 in 80 YF-weight Top_ 50 per case | запрос от 1 шт |
3M CUBITRON II CLOTH BELT 967F, 4 IN X 90 IN, 80+YF-WEIGHT, 50 PER ... Далее 70103090793M CUBITRON II CLOTH BELT 967F, 4 IN X 90 IN, 80+YF-WEIGHT, 50 PER CASE, UPC: ', 00051125125734 | запрос от 1 шт |
3M Roloc Disc, Tr, 361F, 3 In 80 Yf-Weight, 50 Per Inner 200 Per Case ... Далее 224043M Roloc Disc, Tr, 361F, 3 In 80 Yf-Weight, 50 Per Inner 200 Per Case /3M 22404 | запрос от 1 шт |
PCB Mount Receptacle, Vertical, Board-to-Board, 80 Position, 1.27 mm ... Далее 7-104744-4PCB Mount Receptacle, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Gold, Through Hole - Solder, Signal, AMPMODU ... | запрос от 1 шт |
PCB Mount Receptacle, Right Angle, Board-to-Board, 80 Position, 1.27 ... Далее 5-103911-6PCB Mount Receptacle, Right Angle, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Gold, Through Hole - Solder, Signal, AMPMODU ... | запрос от 1 шт |
3MTM RolocTMДалее 70000451003MTM RolocTM Disc 361F, 80 YF-weight, TR, 3 in, Die R300V, 50/Carton, 200ea/ ... | запрос от 1 шт |
3M⢠Clean Sanding Disc 735U, 5 in P80 C-weight, 50 per inner 250 per ... Далее 000511412090743M⢠Clean Sanding Disc 735U, 5 in P80 C-weight, 50 per inner 250 per case | запрос от 1 шт |
Relay SSR 50mA 1.5V DC-IN 1.25A 80V AC/DC-OUT 6-Pin SOP Tube | 260 ₽ от 1 шт 5-7 дней склад 9 шт |
Еще 3 цен: … 218 ₽ | |
245 ₽ от 10 шт 5-7 дней склад 9 шт | |
231 ₽ от 100 шт 5-7 дней склад 9 шт | |
218 ₽ от 1000 шт 5-7 дней склад 9 шт | |
Relay SSR 50mA 1.3V DC-IN 0.04A 80V 4-Pin SOP T/R | запрос от 1 шт |
Relay SSR 50mA 1.5V DC-IN 0.15A 80V AC/DC-OUT 4-Pin SOP T/R | 572 ₽ от 1 шт 5-7 дней склад 5013 шт |
Еще 3 цен: … 480 ₽ | |
540 ₽ от 10 шт 5-7 дней склад 5013 шт | |
509 ₽ от 100 шт 5-7 дней склад 5013 шт | |
480 ₽ от 1000 шт 5-7 дней склад 5013 шт | |
Relay SSR 50mA 1.5V DC-IN 0.07A 80V AC/DC-OUT 16-Pin SOP T/R | 519 ₽ от 1 шт 5-7 дней склад 4320 шт |
Еще 3 цен: … 436 ₽ | |
489 ₽ от 10 шт 5-7 дней склад 4320 шт | |
462 ₽ от 100 шт 5-7 дней склад 4320 шт | |
436 ₽ от 1000 шт 5-7 дней склад 4320 шт | |
Relay SSR 50mA 1.5V DC-IN 0.35A 80V AC/DC-OUT 4-Pin SOP T/R | 572 ₽ от 1 шт 5-7 дней склад 7878 шт |
540 ₽ от 10 шт 5-7 дней склад 7878 шт | |
509 ₽ от 100 шт 5-7 дней склад 7878 шт | |
480 ₽ от 1000 шт 5-7 дней склад 7878 шт | |
Cap Aluminum Lytic 4700uF 80V 20% (25 X 50mm) Snap-In 10mm 0.063 Ohm ... Далее ECO-S1KP472CACap Aluminum Lytic 4700uF 80V 20% (25 X 50mm) Snap-In 10mm 0.063 Ohm 4090mA 3000h 85C Bulk | запрос от 1 шт |
Relay SSR 50mA 1.5V DC-IN 0.15A 80V AC/DC-OUT 4-Pin SOP T/R | 572 ₽ от 1 шт 5-7 дней склад 1135 шт |
540 ₽ от 10 шт 5-7 дней склад 1135 шт | |
509 ₽ от 100 шт 5-7 дней склад 1135 шт | |
480 ₽ от 1000 шт 5-7 дней склад 1135 шт | |
Circuit Breakers Cir Brkr, Hyd Mag, 1 pl, 80VDC, 50A, plug in, aux sw, ... Далее LMLK1-1RLS4-29471-2Circuit Breakers Cir Brkr, Hyd Mag, 1 pl, 80VDC, 50A, plug in, aux sw, UL489, midtrip | запрос от 1 шт |
3 Utmel Китай Весь мир | |
3.000 IN X 2.000 IN (76.20 MM X 50.80 MM) ;ROHS COMPLIANT: YES | 59 869 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 50 267 ₽ | |
56 480 ₽ от 10 шт 5-7 дней склад 1 шт | |
53 283 ₽ от 100 шт 5-7 дней склад 1 шт | |
50 267 ₽ от 1000 шт 5-7 дней склад 1 шт | |
2.000 IN X 0.748 IN (50.80 MM X 19.00 MM) | 46 498 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 39 041 ₽ | |
43 867 ₽ от 10 шт 5-7 дней склад 1 шт | |
41 383 ₽ от 100 шт 5-7 дней склад 1 шт | |
39 041 ₽ от 1000 шт 5-7 дней склад 1 шт | |
2.250 IN X 2.000 IN(57.15 MM X 50.80 MM) | 34 153 ₽ от 1 шт 5-7 дней склад 18 шт |
Еще 3 цен: … 28 676 ₽ | |
32 220 ₽ от 10 шт 5-7 дней склад 18 шт | |
30 396 ₽ от 100 шт 5-7 дней склад 18 шт | |
28 676 ₽ от 1000 шт 5-7 дней склад 18 шт | |
Еще 54 строки | |
4.000 IN X 300 FT (50.80 MM X 91.44 M) 10K0684 | 44 170 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 37 086 ₽ | |
41 670 ₽ от 10 шт 5-7 дней склад 1 шт | |
39 311 ₽ от 100 шт 5-7 дней склад 1 шт | |
37 086 ₽ от 1000 шт 5-7 дней склад 1 шт | |
0.375 IN X 165 FT(9.53 MM X 50.80 M) | 26 415 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 22 178 ₽ | |
24 919 ₽ от 10 шт 5-7 дней склад 1 шт | |
23 509 ₽ от 100 шт 5-7 дней склад 1 шт | |
22 178 ₽ от 1000 шт 5-7 дней склад 1 шт | |
Standard Labels, UL Listed, Label Width 76.2 mm [3 in], Label Height 2 ... Далее 319-LEStandard Labels, UL Listed, Label Width 76.2 mm [3 in], Label Height 2 in [50.8 mm], White, Polyester, Label Thickness 80 Micron | запрос от 1 шт 5-7 дней склад 4747 шт |
Standard Labels, Label Width 80 mm [3.14 in], Label Height .314 in [8 ... Далее EET-0880P-9Standard Labels, Label Width 80 mm [3.14 in], Label Height .314 in [8 mm], White, Polyester, Label Thickness 50 Micron | запрос от 1 шт 5-7 дней склад 9622 шт |
PCB Mount Header, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 ... Далее 5-104655-9PCB Mount Header, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Fully Shrouded, Gold, Surface Mount, Black, AMPMODU 50 ... | 1 691 ₽ от 1 шт 5-7 дней склад 3 шт |
Еще 3 цен: … 1 419 ₽ | |
1 595 ₽ от 10 шт 5-7 дней склад 3 шт | |
1 505 ₽ от 100 шт 5-7 дней склад 3 шт | |
1 419 ₽ от 1000 шт 5-7 дней склад 3 шт | |
PCB Mount Receptacle, Vertical, Board-to-Board, 80 Position, 1.27 mm ... Далее 5-2267261-8PCB Mount Receptacle, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Gold, Through Hole - Solder, Signal, AMPMODU 50/50 ... | запрос от 1 шт 5-7 дней склад 4243 шт |
PCB Mount Header, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 ... Далее 5-1571424-9PCB Mount Header, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Fully Shrouded, Through Hole - Solder, AMPMODU 50/50 ... | запрос от 1 шт 5-7 дней склад 477 шт |
PCB Mount Header, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 ... Далее 104666-5PCB Mount Header, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Fully Shrouded, Gold, Through Hole - Solder, AMPMODU ... | запрос от 1 шт 5-7 дней склад 7765 шт |
PCB Mount Header, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 ... Далее 2-104666-5PCB Mount Header, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Fully Shrouded, Gold, Through Hole - Solder, AMPMODU ... | запрос от 1 шт 5-7 дней склад 8666 шт |
PCB Mount Receptacle, Vertical, Board-to-Board, 80 Position, 1.27 mm ... Далее 5-147378-7PCB Mount Receptacle, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Gold, Surface Mount, Signal, Black, AMPMODU System ... | запрос от 1 шт 5-7 дней склад 6959 шт |
PCB Mount Header, Vertical, Wire-to-Board / Board-to-Board, 80 ... Далее 147377-7PCB Mount Header, Vertical, Wire-to-Board / Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Fully Shrouded, Gold, AMPMODU System ... | запрос от 1 шт 5-7 дней склад 9871 шт |
PCB Mount Header, Right Angle, Board-to-Board, 80 Position, 1.27 mm [. ... Далее 8-104118-6PCB Mount Header, Right Angle, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Unshrouded, Gold, Through Hole - Solder, AMPMODU ... | запрос от 1 шт 5-7 дней склад 9097 шт |
PCB Mount Header, Right Angle, Board-to-Board, 80 Position, 1.27 mm [. ... Далее 6-104118-6PCB Mount Header, Right Angle, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Unshrouded, Gold, Through Hole - Solder, AMPMODU ... | запрос от 1 шт 5-7 дней склад 4111 шт |
PCB Mount Header, Vertical, Wire-to-Board / Board-to-Board, 80 ... Далее 5-1977590-9PCB Mount Header, Vertical, Wire-to-Board / Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Fully Shrouded, Gold, AMPMODU System ... | запрос от 1 шт 5-7 дней склад 9477 шт |
PCB Mount Receptacle, Vertical, Board-to-Board, 80 Position, 1.27 mm ... Далее 147378-7PCB Mount Receptacle, Vertical, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Gold, Surface Mount, Signal, Black, AMPMODU System ... | запрос от 1 шт 5-7 дней склад 9182 шт |
PCB Mount Header, Right Angle, Board-to-Board, 80 Position, 1.27 mm [. ... Далее 3-104118-6PCB Mount Header, Right Angle, Board-to-Board, 80 Position, 1.27 mm [.05 in] Centerline, Unshrouded, Gold, Through Hole - Solder, AMPMODU ... | запрос от 1 шт 5-7 дней склад 8646 шт |
2.000 IN X 7.000 IN(50.80 MM X 177.80MM) | 35 775 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 30 037 ₽ | |
33 750 ₽ от 10 шт 5-7 дней склад 1 шт | |
31 839 ₽ от 100 шт 5-7 дней склад 1 шт | |
30 037 ₽ от 1000 шт 5-7 дней склад 1 шт | |
4 TradeElectronics Москва Россия | |
EL160.80.50 24 Апр 2024 13:53 Ultra-Fast-Recovery Rectifier Diodes | запрос 7-14 дней |
Brushless DC Motor Driver Module in a Power Flatpack 80-200V, 50 Amp | запрос 7-14 дней |
5 МосЧип Москва Россия | |
EL160.80.50 (LF) 24 Апр 2024 13:53 Ultra-Fast-Recovery Rectifier Diodes | запрос 7-14 дней |
6 ЗУМ-СМД Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 600 руб. | |
Оптроны 80V 50mA CTR:200-400% DIP4 LTV817-C-IN LITEON, CT817C-H CT- ... Далее K10101CОптроны 80V 50mA CTR:200-400% DIP4 LTV817-C-IN LITEON, CT817C-H CT-micro, EL817(C)-F EVERLIGHT, CT817C CT-micro, H11A817C300 FAIR, BL817C ... | 0.40 ₽ от 600 ₽ склад 5046 шт |
7 Оптулс Москва Россия | |
274420 VETTER LER 22/1 Cable lead-in roller для duct-ID 22 mm. roller-D 80/30x38/50 mm VETTER - 28 Фев 2024 17:35 274420 VETTER LER 22/1 Cable lead-in roller для duct-ID 22 mm. roller- ... Далее 274420 VETTER LER 22/1 Cable lead-in roller для duct-ID 22 mm. roller-D 80/30x38/50 mm274420 VETTER LER 22/1 Cable lead-in roller для duct-ID 22 mm. roller-D 80/30x38/50 mm | 11 699 ₽ Розница, Скидки для Дилеров - |
274430 VETTER LER 25/1 Cable lead-in roller для duct-ID 25 mm. roller-D 80/30x38/50 mm VETTER - 28 Фев 2024 17:35 274430 VETTER LER 25/1 Cable lead-in roller для duct-ID 25 mm. roller- ... Далее 274430 VETTER LER 25/1 Cable lead-in roller для duct-ID 25 mm. roller-D 80/30x38/50 mm274430 VETTER LER 25/1 Cable lead-in roller для duct-ID 25 mm. roller-D 80/30x38/50 mm | 12 054 ₽ Розница, Скидки для Дилеров - |
8 AMANA Москва Россия и страны СНГ | |
Пескоуловитель под мойку Alta Group S-IN 1.0-80. Применяется в ... Далее S-IN 1.0-80Пескоуловитель под мойку Alta Group S-IN 1.0-80. Применяется в производственных цехах и лабораториях предприятий пищевой промышленности и ... | 15 250 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
9 ЧипСити Москва Россия | |
S8JX-G05012CD 21 Апр 2024 02:14 Power Supply; AC-DC; 12V; 4.2A; 80-370V In; Enclosed; DIN Rail Mount; ... Далее S8JX-G05012CDPower Supply; AC-DC; 12V; 4.2A; 80-370V In; Enclosed; DIN Rail Mount; 50W; S8JX Series | 6 354 ₽ 3-7 дней склад 468 шт |
S8JX-G05024D 21 Апр 2024 02:14 Power Supply; AC-DC; 24V; 2.1A; 80-370V In; Open Frame; DIN; ... Далее S8JX-G05024DPower Supply; AC-DC; 24V; 2.1A; 80-370V In; Open Frame; DIN; Commercial; 50W; S8JX Series | 10 059 ₽ 3-7 дней склад 165 шт |
G3VM81G1 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.35A 80V AC-OUT 4Pin SOP | 588 ₽ 3-7 дней склад 1102 шт |
Еще 49 строк | |
G3VM81GR1 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.2A 80V AC-OUT 4Pin SOP | 456 ₽ 3-7 дней склад 1280 шт |
G3VM81HR 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.00125A 80V AC-DC-OUT 6Pin SOP | 871 ₽ 3-7 дней склад 1115 шт |
G3VM-81G1 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.35A 80V AC-OUT 4Pin SOP | 407 ₽ 3-7 дней склад 4021 шт |
G3VM-81LR-TR05 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.12A 80V AC-DC-OUT 4Pin SSOP T/R | 914 ₽ 3-7 дней склад 874 шт |
G3VM-81GR1 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.2A 80V AC-OUT 4Pin SOP | 716 ₽ 3-7 дней склад 18559 шт |
G3VM-81GR 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.04A 80V AC-OUT 4Pin SOP | 725 ₽ 3-7 дней склад 1280 шт |
G3VM-81GR1 (TR) 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.2A 80V AC-OUT 4Pin SOP T/R | 284 ₽ 3-7 дней склад 950 шт |
G3VM-81GR (TR) 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.04A 80V AC-OUT 4Pin SOP T/R | 397 ₽ 3-7 дней склад 988 шт |
G3VM-81LR (TR) 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.12A 80V AC-DC-OUT 4Pin SSOP T/R | 1 492 ₽ 3-7 дней склад 1144 шт |
G3VM-81HR (TR) 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.00125A 80V AC-DC-OUT 6Pin SOP T/R | 975 ₽ 3-7 дней склад 15459 шт |
G3VM-41LR3 (TR) 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 80A 40V AC-OUT 4Pin SSOP T/R | 1 428 ₽ 3-7 дней склад 1144 шт |
G3VM-81LR (TR05) 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.12A 80V AC-DC-OUT 4Pin SSOP T/R | 1 081 ₽ 3-7 дней склад 2490 шт |
G3VM-81HR 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.00125A 80V AC-DC-OUT 6Pin SOP | 355 ₽ 3-7 дней склад 1276 шт |
G3VM-81G1 (TR) 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.35A 80V AC-OUT 4Pin SOP T/R | 362 ₽ 3-7 дней склад 40695 шт |
G3VM81GR1TR 21 Апр 2024 02:14 Relay SSR 50mA 1.3V DC-IN 0.2A 80V AC-OUT 4Pin SOP T/R | 1 123 ₽ 3-7 дней склад 4888 шт |
Semiconductor Fuse Fast Acting 80A 700VAC 700VDC 200kAIRAC 50kAIRDC 0. ... Далее FWP-80BSemiconductor Fuse Fast Acting 80A 700VAC 700VDC 200kAIRAC 50kAIRDC 0.95in. Dia | 11 564 ₽ 3-7 дней склад 963 шт |
Semiconductor Fuse Fast Acting 80A 700VAC 500VDC 200kAIRAC 50kAIRDC 0. ... Далее FWP-80A22FSemiconductor Fuse Fast Acting 80A 700VAC 500VDC 200kAIRAC 50kAIRDC 0.87in. Dia | 9 619 ₽ 3-7 дней склад 337 шт |
10 ЭИК Санкт-Петербург Россия | |
5.0 X 8.0 IN. POLYMER THICK FILM | 19 466 ₽ от 3 шт 21-42 дня склад 4 шт |
11 Аудиомания Москва Россия, Беларусь, Казахстан | |
Кешбэк за покупку - 49000 руб.! Ваша суммарная выгода - 71900 руб.! ... Далее CS-100A (EL34) SilverКешбэк за покупку - 49000 руб.! Ваша суммарная выгода - 71900 руб.! Подробнее Интегральный усилитель на лампах, предварительная секция: 1 x ... | 279 000 ₽ Доставка: есть Самовывоз: есть на складе |
Кешбэк за покупку - 49000 руб.! Ваша суммарная выгода - 51900 руб.! ... Далее CS-100A (KT88) BlackКешбэк за покупку - 49000 руб.! Ваша суммарная выгода - 51900 руб.! Подробнее Интегральный усилитель на лампах, предварительная секция: 1 x ... | 299 000 ₽ Доставка: есть Самовывоз: есть на складе |
Интегральный усилитель на лампах, предварительная секция: 1 x 6SN7, 2 ... Далее CS-100A (KT88) SilverИнтегральный усилитель на лампах, предварительная секция: 1 x 6SN7, 2 x 12BH7EH, 2 x 12AU7EH, выходной каскад: 8 х KT88, AB-класс, мощность ... | 332 500 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 1 строка | |
Интегральный усилитель на лампах, предварительная секция: 1 x 6SN7, 2 ... Далее CS-100A (EL34) BlackИнтегральный усилитель на лампах, предварительная секция: 1 x 6SN7, 2 x 12BH7EH, 2 x 12AU7EH, выходной каскад: 8 х EL34, AB-класс, мощность ... | 301 900 ₽ Доставка: есть Самовывоз: есть на складе |
12 Industrial Module Москва Россия | |
POWER CABLE, SOLD BY THE METER 4 X 10 C, UL/CSA, DESINA MOTION-CONNECT ... Далее 6FX5008-1BB51-1JA0POWER CABLE, SOLD BY THE METER 4 X 10 C, UL/CSA, DESINA MOTION-CONNECT 500 DELIVERY FORM:TIL 49 M IN COILS FROM 50 M DRUM DMAX =20.0 MM, ... | запрос 7-28 дней на складе |
CONT. RELAY 80E DIN EN 50 011 8NO, PLUG-IN CONNECTION ALT. CURRENT ... Далее 3TH4280-3MG1CONT. RELAY 80E DIN EN 50 011 8NO, PLUG-IN CONNECTION ALT. CURRENT ACTUATING WITH INTEGR. VARISTOR 110 V AC 60 HZ/92 V AC 50 HZ | 7 168 ₽ 7-28 дней на складе |
13 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
80Vin, 50mA, LDO in MS8E | 1 580 ₽ Доставка: есть Самовывоз: есть на складе |
14 ТаймЧипс Санкт-Петербург Россия | |
15 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
16 ЭлектроПласт Санкт-Петербург Россия | |
17 Океан Электроники Санкт-Петербург Россия | |
18 LifeElectronics Санкт-Петербург Россия | |
Искать "EL160.80.50-IN" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 93.2918 |
EUR | 99.5609 |
