Datasheet NTE6072 - NTE Electronics Даташит STANDARD диод, 70 А, 1 кВ, DO-5 — Даташит
NTE Electronics NTE6072
Наименование модели: NTE6072
21 предложений от 13 поставщиков
Диод: выпрямительный; 1кВ; 1,25В; 70А; катод на корпусе; DO5
Зенер
Россия и страны ТС
NTE6072
от 2 441 ₽
Элитан
NTE6072
NTE Electronics
15 400 ₽
LifeElectronics
NTE6072.
NTE Electronics
NTE6072
Производитель: NTE Electronics
Описание: STANDARD диод, 70 А, 1 кВ, DO-5
data sheetСкачать Data Sheet
NTE6048 thru NTE6073 Industrial Silicon Rectifier 70 Amp, DO5
Description: The NTE6048 thru NTE6073 power rectifiers are stud mounted DO5 packages.
Because the silicon junction is carefully fitted within a glass-to-metal hermetically sealed case, reliable operation is assured, even with extreme humidity and under other severe environmental conditions. These power rectifiers are completely corrosion resistant. A double diffused, passivated junction technique is utilized to provide stable uniform electrical characteristics, Inherent in their design are very low leakage currents and excellent surge handling capability. These NTE power rectifiers are available in both anode-to-case and cathode-to-case polarity in offering extended application parameters. NTE silicon power rectifiers are ideal for a broad range of commercial uses including power supplies, ultrasonic systems, inverters, welders, emergency generators, battery chargers, DC motor, and motor controls. Electrical Ratings and Char
  • Diode Type: Standard Recovery
  • Repetitive Reverse Voltage Vrrm Max: 1 кВ
  • Forward Current If(AV): 70 А
  • Forward Voltage VF Max: 1.25 В
  • Forward Surge Current Ifsm Max: 1.2 кА
На английском языке: Datasheet NTE6072 - NTE Electronics STANDARD DIODE, 70 A, 1 kV, DO-5
