Datasheet MURA210T3G - ON Semiconductor Даташит FAST RECOVERY диод, 2 А, 100 В, 403D — Даташит
ON Semiconductor MURA210T3G
Наименование модели: MURA210T3G
40 предложений от 15 поставщиков
Зенер
Россия и страны ТС
MURA210T3G
от 22 ₽
MURA210T3G
от 25 ₽
727GS
MURA210T3G
MURA210T3G
Производитель: ON Semiconductor
Описание: FAST RECOVERY диод, 2 А, 100 В, 403D
data sheetСкачать Data Sheet
MC34023, MC33023 High Speed Single-Ended PWM Controller
The MC34023 series are high speed, fixed frequency, single-ended pulse width modulator controllers optimized for high frequency operation.
They are specifically designed for Off-Line and DC-to-DC converter applications offering the designer a cost-effective solution with minimal external components. These integrated circuits feature an oscillator, a temperature compensated reference, a wide bandwidth error amplifier, a high speed current sensing comparator, and a high current totem pole output ideally suited for driving a power MOSFET. Also included are protective features consisting of input and reference undervoltage lockouts each with hysteresis, cycle-by-cycle current limiting, and a latch for single pulse metering. The flexibility of this series allows it to be easily configured for either current mode or voltage mode control.
Features
http://onsemi.com
16 1
Данные для моделированияДанные для моделирования
  • Diode Type: Fast Recovery
  • Repetitive Reverse Voltage Vrrm Max: 100 В
  • Forward Current If(AV): 2 А
  • Forward Voltage VF Max: 940 мВ
  • Reverse Recovery Time trr Max: 30 нс
  • Forward Surge Current Ifsm Max: 50 А
На английском языке: Datasheet MURA210T3G - ON Semiconductor FAST RECOVERY DIODE, 2 A, 100 V, 403D
