Клеммники KEEN SIDE
Datasheet VS-HFA30PB120PBF - Vishay Даташит Диод, мягкий RECOVERY, 30 А — Даташит
Vishay VS-HFA30PB120PBF
Наименование модели: VS-HFA30PB120PBF
13 предложений от 12 поставщиков
Выпрямительные диоды, VISHAY VS-HFA30PB120PBF Standard Power Diode, Single, 1.2kV, 30A, 5.7V, 170ns, 120A
727GS
VS-HFA30PB120PBF
от 103 ₽
VS-HFA30PB120PBF
799 ₽
VS-HFA30PB120PBF
VS-HFA30PB120PBF
Производитель: Vishay
Описание: Диод, мягкий RECOVERY, 30 А
data sheetСкачать Data Sheet
HFA30PB120PbF
Ultrafast, Soft Recovery Diode HEXFRED
TM
PD -95686A
International Rectifier's HFA16PB120 is a state of the art center tap ultra fast recovery diode.
Employing the latest in epitaxial construction and advanced processing techniques it features a superb combination of characteristics which result in performance which is unsurpassed by any rectifier previously available. With basic ratings of 1200 volts and 16 amps continuous current, the HFA16PB120 is especially well suited for use as the companion diode for IGBTs and MOSFETs. In addition to ultra fast recovery time, the HEXFRED product line features extremely low values of peak recovery current (IRRM) and does not exhibit any tendency to "snap-off" during the tb portion of recovery. The HEXFRED features combine to offer designers a rectifier with lower noise and significantly lower switching losses in both the diode and the switching transistor. These HEXFRED advantages can help to significantly reduce snubbing, compone
Данные для моделированияДанные для моделирования
  • Diode Type: Soft Recovery
  • Repetitive Reverse Voltage Vrrm Max: 1.2 кВ
  • Forward Current If(AV): 30 А
  • Forward Voltage VF Max: 3.93 В
  • Reverse Recovery Time trr Max: 135 нс
  • Forward Surge Current Ifsm Max: 120 А
  • Рабочий диапазон температрур: -55°C ... +150°C
  • Тип корпуса: TO-247AC
  • Количество выводов: 2
  • Current Ifsm: 120 А
  • Температура перехода максимальная: 150°C
  • Reverse Recovery Time trr Typ: 170 нс
  • Current Ifrm: 90 А
Дополнительные аксессуары:
  • Fischer Elektronik - FK 243 MI 247 H
  • Fischer Elektronik - FK 243 MI 247 O
  • Fischer Elektronik - SK 145/25 STS-220
  • Fischer Elektronik - WLK 5
VSHFA30PB120PBF, VS HFA30PB120PBF
На английском языке: Datasheet VS-HFA30PB120PBF - Vishay DIODE, SOFT RECOVERY, 30 A
