Datasheet HSMP-3830-TR1G - Avago Technologies Даташит Диод, ВЧ — Даташит
Наименование модели: HSMP-3830-TR1G
Купить HSMP-3830-TR1G на РадиоЛоцман.Цены — от 31 до 38 ₽11 предложений от 11 поставщиков Диод RF, Diode PIN Attenuator/Switch 200V 3Pin SOT-23 T/R | |||
| HSMP-3830-TR1G Broadcom | 33 ₽ | ||
| HSMP-3830-TR1G Avago Technologies | 38 ₽ | ||
| HSMP-3830-TR1G Avago Technologies | по запросу | ||
| HSMP-3830-TR1G | по запросу | ||
Производитель: Avago Technologies
Описание: Диод, ВЧ
HSMP-383x
Surface Mount RF PIN Diodes
Data Sheet
Description/Applications
The HSMP-383x series of general purpose PIN diodes are designed for two classes of applications.
The first is attenuators where current consumption is the most importantdesignconsideration.Thesecondapplication for this series of diodes is in switches where low capacitanceisthedrivingissueforthedesigner. The HSMP-386x seriesTotal Capacitance (CT ) andTotal Resistance(RT )aretypicalspecifications.Forapplications that require guaranteed performance, the general purposeHSMP-383xseriesisrecommended. A SPICE model is not available for PIN diodes as SPICE does not provide for a key PIN diode characteristic, carrierlifetime.
- SVHC: No SVHC (15-Dec-2010)
- Breakdown Voltage: 200 В
- Capacitance Ct: 0.3 пФ
- Current If @ Rs: 100 мА
- Маркировка: K0
- Diode Series Resistance Rs: 1.5 Ом
- Diode Type: RF
- Количество выводов: 3
- Тип корпуса: SOT-23
- Reverse Recovery Time trr Typ: 80 нс
- Reverse Voltage Vr Max: 50 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Electrolube - SMA10SL
- LICEFA - V11-7
- Roth Elektronik - RE901
HSMP3830TR1G, HSMP 3830 TR1G
