Datasheet HSMS-282Y-BLKG - Avago Technologies Даташит Диод, Шоттки, SOT-523 — Даташит
Наименование модели: HSMS-282Y-BLKG
7 предложений от 7 поставщиков RF Diode Schottky - Single 15V 1 A SOD-523 | |||
HSMS-282Y-BLKG | по запросу | ||
HSMS-282Y-BLKG Broadcom | по запросу | ||
Производитель: Avago Technologies
Описание: Диод, Шоттки, SOT-523
HSMS-282Y
RF Schottky Barrier Diodes In Surface Mount SOD-523 Package
Data Sheet
Description
The HSMS-282Y of Avago Technologies is a RF Schottky Barrier Diode, featuring low series resistance, low forward voltage at all current levels and good RF characteristics.
The device is housed in a miniature low cost surface mount SOD-523 package. This miniature package is particularly useful in the application where board space is the major concern.ApplicationsThe HSMS-282Y is specially designed for both analog and digital applications. The typical applications are mixing, detecting, switching, sampling, clamping and wave shaping. Table 1. Absolute Maximum Ratings [1] at Tc = +25°C Symbol IF PIV TJ TSTG qjb Parameter Forward Current (1 µs Pulse) Peak Inverse Voltage Junction Temperature Storage Temperature Thermal Resistance[2] Unit Amp V °C °C °C/W Max Rating 1 15 150 -65 to 150 175
- Diode Configuration: Single
- Прямой ток максимальный: 10 мА
- Capacitance Ct: 1 пФ
- Тип корпуса: SOD-523
- Количество выводов: 2
- SVHC: No SVHC (15-Dec-2010)
- Маркировка: Yx
- Diode Type: RF Schottky
- Forward Current If(AV): 1 А
- Forward Voltage: 500 мВ
- Температура перехода максимальная: 150°C
- Pin Configuration: Single
- Repetitive Reverse Voltage Vrrm Max: 15 В
- Reverse Voltage Vr Max: 15 В
- Способ монтажа: SMD
HSMS282YBLKG, HSMS 282Y BLKG
