Datasheet SD103A-T/R - Vishay Даташит Диод, Шоттки, 15 А, DO-204 — Даташит
Наименование модели: SD103A-T/R
Купить SD103A-T/R на РадиоЛоцман.Цены — от 4.01 до 11 ₽ 21 предложений от 13 поставщиков Диод Шоттки малого сигнала, Шоттки, Одиночный, 40 В, 600 мВ, 15 А, 125 °C | |||
SD103A-TR Vishay | 4.01 ₽ | ||
SD103A-T/R Vishay | 6.94 ₽ | ||
SD103A-TR Vishay | 11 ₽ | ||
SD103A-T/R Diodes | по запросу |
Производитель: Vishay
Описание: Диод, Шоттки, 15 А, DO-204
SD103A, SD103B, SD103C
Vishay Semiconductors
Small Signal Schottky Diodes
Features
· The SD103 series is a Metal-on-silicon Schottky barrier device which is protected by a PN junction guard ring.
· The low forward voltage drop and fast switching make it ideal for protection of MOS devices, steering, biasing and coupling diodes for fast switching and low logic level applications. · Other applications are click suppression, efficient full wave bridges in telephone subsets, and blocking diodes in rechargeable low voltage battery systems. · These diodes are also available in the SOD-123 and SOD-323 case with type designations SD103AW(S)-V...SD103CW(S)-V, and in the MiniMELF case with type designations LL103A thru LL103C. · For general purpose applications · AEC-Q101 qualified · Compliant to RoHS directive 2002/95/EC and in accordance to WEEE 2002/96/EC · Halogen-free according to IEC 61249-2-21 definition
- Diode Type: Schottky
- Repetitive Reverse Voltage Vrrm Max: 40 В
- Forward Voltage VF Max: 600 мВ
- Reverse Recovery Time trr Max: 10 нс
- Forward Surge Current Ifsm Max: 15 А
- Тип корпуса: DO-35
- Количество выводов: 2
- SVHC: No SVHC (18-Jun-2010)
- Current Ifsm: 15 А
- Температура перехода максимальная: 125°C
- Reverse Recovery Time trr Typ: 10 нс
- Способ монтажа: Axial Leaded
RoHS: Y-Ex
SD103AT/R, SD103A T/R
