Datasheet SD103AW-V-GS08 - Vishay Даташит Диод, Шоттки, 2 А, 40 В — Даташит
Наименование модели: SD103AW-V-GS08
6 предложений от 6 поставщиков Rectifier Diode Small Signal Schottky Si 40V 10ns Automotive 2-Pin SOD-123 T/R | |||
| SD103AW-V-GS08 | по запросу | ||
| SD103AW-V-GS08 Vishay | по запросу | ||
Производитель: Vishay
Описание: Диод, Шоттки, 2 А, 40 В
SD103AW-V/103BW-V/103CW-V
Vishay Semiconductors
Small Signal Schottky Diodes
Features
· The low forward voltage drop and fast switching make it ideal for protection of e3 MOS devices, steering, biasing, and coupling diodes for fast switching and low logic level applications.
· Other applications are click suppression, efficient full wave bridges in telephone subsets, and blocking diodes in rechargeable low voltage battery systems. · The SD103 series is a metal-on-silicon Schottky barrier device which is protected by a PN junction guard ring. · This diode is also available in the MiniMELF case with the type designations LL103A to LL103C, DO35 case with the type designations SD103A to SD103C and SOD323 case with type designations SD103AWS-V to SD103CWS-V. · For general purpose applications. · Lead (Pb)-free component · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC
- Diode Type: Schottky
- Forward Current If(AV): 200 мА
- Repetitive Reverse Voltage Vrrm Max: 40 В
- Forward Voltage VF Max: 600 мВ
- Reverse Recovery Time trr Max: 10 нс
- Forward Surge Current Ifsm Max: 2 А
- Тип корпуса: SOD-123
- Количество выводов: 2
- SVHC: No SVHC (20-Jun-2011)
- Current Ifsm: 2 А
- Температура перехода максимальная: 125°C
- Reverse Recovery Time trr Typ: 10 нс
- Способ монтажа: SMD
SD103AWVGS08, SD103AW V GS08
Купить SD103AW-V-GS08 на РадиоЛоцман.Цены
