Datasheet BAT42W-V-GS18 - Vishay Даташит Диод, 30 В, SOD-123 — Даташит
Vishay BAT42W-V-GS18
Наименование модели: BAT42W-V-GS18
Rectifier Diode Small Signal Schottky 30V 0.2A 5ns Automotive 2-Pin SOD-123 T/R
BAT42W-V-GS18
BAT42W-V-GS18
Производитель: Vishay
Описание: Диод, 30 В, SOD-123
data sheetСкачать Data Sheet
BAT42W-V/BAT43W-V
Vishay Semiconductors
Small Signal Schottky Diodes
Features
· These diodes feature very low turn-on voltage and fast switching.
These devices are protected by a PN junction guard ring e3 against excessive voltage, such as electrostatic discharges · These diodes are also available in the DO35 case with the type designations BAT42 to BAT43 and in MiniMELF SOD80 case with the type designations LL42 to LL43 · For general purpose applications · Lead (Pb)-free component · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC
  • Diode Type: Schottky
  • Repetitive Reverse Voltage Vrrm Max: 30 В
  • Forward Current If(AV): 200 мА
  • Forward Voltage VF Max: 1 В
  • Reverse Recovery Time trr Max: 5 нс
  • Forward Surge Current Ifsm Max: 4 А
  • Рабочий диапазон температрур: -55°C ... +125°C
  • Тип корпуса: SOD-123
  • Количество выводов: 2
  • Current Ifsm: 4 А
  • Температура перехода максимальная: 125°C
  • Reverse Recovery Time trr Typ: 5 нс
  • Способ монтажа: SMD
BAT42WVGS18, BAT42W V GS18
На английском языке: Datasheet BAT42W-V-GS18 - Vishay DIODE, 30 V, SOD-123
