Datasheet ZEN056V130A24LS - TE Connectivity Даташит Диод, стабилитрон, 5.6 В, PROTECTED — Даташит
Наименование модели: ZEN056V130A24LS
Купить ZEN056V130A24LS на РадиоЛоцман.Цены — от 38 до 394 ₽14 предложений от 14 поставщиков Диоды подавления переходных скачков напряжения (TVS) PolyZen Micro-Assem on Test Board | |||
| ZEN056V130A24LS Littelfuse | 382 ₽ | ||
| ZEN056V130A24LS-TB TE Connectivity | 394 ₽ | ||
| ZEN056V130A24LS TE Connectivity | по запросу | ||
| ZEN056V130A24LS-TB TE Connectivity | по запросу | ||
Производитель: TE Connectivity
Описание: Диод, стабилитрон, 5.6 В, PROTECTED
PolyZen Devices-- Polymer Protected Zener Diode
PolyZen devices are polymer protected precision Zener diode micro-assemblies.
They offer resettable protection against multi-watt fault events while exhibiting only 0.7W power dissipation that requires no special heat sinking. The relatively flat voltage vs. current response of the PolyZen device helps clamp the output voltage, even when input voltage and source currents vary. An advanced feature of the PolyZen micro-assembly is that its Zener and follow-on electronics are additionally protected by a resistively non-linear, polymer PTC (positive temperature coefficient) layer. This PTC layer is fully integrated into the device, is thermally coupled to the diode, and is electrically in series between VIN and the diode clamped VOUT. This advanced PTC layer responds to either diode heating or overcurrent events by transitioning from a low to high resistance state, also known as "tripping" A tripped PTC will limit current and generate a volta
- Resistance Rz: 0.12 Ом
- Test Current: 100 мА
- Zener Current: 100 мА
- Zener Voltage Vz Typ: 5.6 В
- Количество выводов: 3
- Рабочий диапазон температрур: -40°C ... +85°C
- Рассеиваемая мощность максимальная: 700 мВт
- Рассеиваемая мощность: 700 мВт
- Способ монтажа: SMD
- Тип корпуса: SMD
- RoHS: Y-Ex
