Datasheet SM72238E/NOPB - National Semiconductor Даташит — Даташит
National Semiconductor SM72238E/NOPB
Наименование модели: SM72238E/NOPB
IC REG LINEAR 5V 100MA TO252-3. Linear Voltage Regulator IC 1 Output 100mA TO-252-3. PMIC - Voltage Regulators - Linear
SM72238E/NOPB
24 ₽
Рутоника
SM72238E/NOPB
SM72238E/NOPB
SM72238E/NOPB
data sheetСкачать Data Sheet
SM72238 SolarMagic Micropower Voltage Regulators
May 9, 2011
General Description
The SM72238 is a micropower voltage regulator with very low quiescent current (75A typ.) and very low dropout voltage (typ.
40mV at light loads and 380mV at 100mA). It is ideally suited for use in battery-powered systems. Furthermore, the quiescent current of the SM72238 increases only slightly in dropout, prolonging battery life. The SM72238 is available in the surface-mount D-Pak package. Careful design of the SM72238 has minimized all contributions to the error budget. This includes a tight initial tolerance (.5% typ.), extremely good load and line regulation (.05% typ.) and a very low output voltage temperature coefficient, making the part useful as a low-power voltage reference.
  • Входное напряжение минимальное: 30 В
  • Количество выходов: 1
  • Выходной ток: 100 мА
  • Количество выводов: 3
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Output Voltage Fixed: 5 В
  • Dropout Voltage Vdo: 450 мВ
На английском языке: Datasheet SM72238E/NOPB - National Semiconductor
