Datasheet MAX4196ESA+ - Maxim Даташит ИС, INSTRUMENT усилитель, 34 кГц, 115 дБ, SOIC-8 — Даташит
Наименование модели: MAX4196ESA+
33 предложений от 19 поставщиков
MAX4196ESA+T
Maxim
от 317 ₽
727GS
MAX4196ESA+
Maxim
MAX4196ESA+T
MAX4196ESA-T
Maxim
Производитель: Maxim
Описание: ИС, INSTRUMENT усилитель, 34 кГц, 115 дБ, SOIC-8
data sheetСкачать Data Sheet
19-1468; Rev 1; 6/03
Micropower, Single-Supply, Rail-to-Rail, Precision Instrumentation Amplifiers
General Description
The MAX4194 is a variable-gain precision instrumentation amplifier that combines Rail-to-Rail® single-supply operation, outstanding precision specifications, and a high gain bandwidth.
This amplifier is also offered in three fixed-gain versions: the MAX4195 (G = +1V/V), the MAX4196 (G = +10V/V), and the MAX4197 (G = +100V/V). The fixed-gain instrumentation amplifiers feature a shutdown function that reduces the quiescent current to 8µA. A traditional three operational amplifier configuration is used to achieve maximum DC precision. The MAX4194­MAX4197 have rail-to-rail outputs and inputs that can swing to 200mV below the negative rail and to within 1.1V of the positive rail. All parts draw only 93µA and operate from a single +2.7V to +7.5V supply or from dual ±1.35V to ±3.75V supplies. These amplifiers are offered in 8-pin SO packages and are specified for the extende
На английском языке: Datasheet MAX4196ESA+ - Maxim IC, INSTRUMENT AMP, 34 kHz, 115 dB, SOIC-8
