Datasheet MAX4659EUA+ - Maxim Даташит ИС, аналоговый переключатель, одиночный, SPDT, µMAX-8 — Даташит
Maxim MAX4659EUA+
Наименование модели: MAX4659EUA+
39 предложений от 20 поставщиков
Микросхема Чип аналогового переключателя, MAXIM INTEGRATED PRODUCTS MAX4659EUA+T Analog Switch, High Current, SPDT, 1Channels, 50Ω, 9V to 40V, ± 4.5V to...
Рутоника
MAX4659EUA+T
Maxim
203 ₽
MAX4659EUA+
548 ₽
Элитан
MAX4659EUA+
709 ₽
MAX4659EUA+
Производитель: Maxim
Описание: ИС, аналоговый переключатель, одиночный, SPDT, µMAX-8
data sheetСкачать Data Sheet
19-2046; Rev 1; 1/07
High-Current, 25, SPDT, CMOS Analog Switches
General Description
The MAX4659/MAX4660 are medium voltage CMOS analog switches with a low on-resistance of 25 max specifically designed to handle large switch currents.
With a switch capability of up to 200mA peak current and 150mA continuous current (MAX4660), and up to 150mA peak current and 75mA continuous current (MAX4659), these parts can switch loads as low as 50. They can replace reed relays with a million times the speed and a virtually unlimited number of lifetime cycles. Normal power consumption is only 3mW, whether the switch is on or off. These parts are TTL/CMOS compatible and will switch any voltage within their power-supply range. The devices are single-pole/double-throw (SPDT) switches. The MAX4659/MAX4660 contain one normally closed (NC) switch and one normally open (NO) switch. The MAX4659/MAX4660s' power-supply range is from ±4.5V to ±20V for dual-supply operation and +9V to +40V for single-supply op
  • Analog Switch Type: SPDT
  • Количество каналов: 1
  • Полоса частот: 225 МГц
  • On State Resistance Max: 25 Ом
  • Диапазон напряжения питания: 9 В ... 40 В
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet MAX4659EUA+ - Maxim IC, ANALOG SWITCH, SINGLE, SPDT, µMAX-8
