Datasheet LPC1778FBD144,551 - NXP Даташит 8- бит микроконтроллеры (MCU) CORTEX-M3 512 Кб FL 96 Кб SRAM USB 2.0 — Даташит
NXP LPC1778FBD144,551
Наименование модели: LPC1778FBD144,551
33 предложений от 19 поставщиков
Микроконтроллер NXP 32-бит LPC1700 ядро ARM Cortex M3 RISC 512кБ Флэш-память 3.3В автомобильного применения
LPC1778FBD144,551
535 ₽
ICdarom.ru
LPC1778FBD144,551
от 732 ₽
LPC1778FBD144,551
от 736 ₽
LPC1778FBD144,551
Производитель: NXP
Описание: 8- бит микроконтроллеры (MCU) CORTEX-M3 512 Кб FL 96 Кб SRAM USB 2.0
data sheetСкачать Data Sheet
LPC178x/7x
32-bit ARM Cortex-M3 microcontroller; up to 512 kB flash and 96 kB SRAM; USB Device/Host/OTG; Ethernet; LCD; EMC
Rev.
3 -- 27 December 2011 Objective data sheet
1. General description
The LPC178x/7x is an ARM Cortex-M3 based microcontroller for embedded applications requiring a high level of integration and low power dissipation. The Cortex-M3 is a next generation core that offers better performance than the ARM7 at the same clock rate and other system enhancements such as modernized debug features and a higher level of support block integration. The Cortex-M3 CPU incorporates a 3-stage pipeline and has a Harvard architecture with separate local instruction and data buses, as well as a third bus with slightly lower performance for peripherals. The Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branches. The LPC178x/7x adds a specialized flash memory accelerator to accomplish optimal performance when executing code from flash. The LPC178x/7x
  • Supply Voltage - Max: 3.6 В
  • Упаковка: Tray
  • RoHS: да
LPC1778FBD144551, LPC1778FBD144 551
На английском языке: Datasheet LPC1778FBD144,551 - NXP 8- bit Microcontrollers (MCU) CORTEX-M3 512 Kb FL 96 Kb SRAM USB 2.0
