Datasheet LM111H/NOPB - National Semiconductor Даташит ИС, компаратор, 1, 200 нс, TO-99 — Даташит
Наименование модели: LM111H/NOPB
![]() 40 предложений от 19 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LM111H/NOPB Analog Comparator, Rail to Rail, General Purpose, 1, 200ns, 5V to 36V, TO-99, 8Pins | |||
LM111H/NOPB Texas Instruments | 25 ₽ | ||
LM111H/NOPB Texas Instruments | 327 ₽ | ||
LM111H/NOPB Texas Instruments | от 1 324 ₽ | ||
LM111H/NOPB Texas Instruments | по запросу |
Описание: ИС, компаратор, 1, 200 нс, TO-99
LM111/LM211/LM311 Voltage Comparator
January 2001
1.0 General Description
The LM111, LM211 and LM311 are voltage comparators that have input currents nearly a thousand times lower than devices like the LM106 or LM710.
They are also designed to operate over a wider range of supply voltages: from standard ± 15V op amp supplies down to the single 5V supply used for IC logic. Their output is compatible with RTL, DTL and TTL as well as MOS circuits. Further, they can drive lamps or relays, switching voltages up to 50V at currents as high as 50 mA. Both the inputs and the outputs of the LM111, LM211 or the LM311 can be isolated from system ground, and the output can drive loads referred to ground, the positive supply or the negative supply. Offset balancing and strobe capability are provided and outputs can be wire OR'ed. Although slower than the LM106 and LM710 (200 ns response time vs 40 ns) the devices are also much less prone to spurious oscillation
- Output Compatibility: DTL, MOS, RTL, TTL
- Время отклика: 200 нс
- Диапазон напряжения питания: 5 В ... 36 В
- Количество компараторов: 1
- Тип выхода: Open Drain
- Тип компаратора: General Purpose
- Ток потребления: 5.1 мА
- RoHS: да
