Datasheet MAXQ610X-0000 - Maxim Даташит Микроконтроллеры (MCU) — Даташит
Наименование модели: MAXQ610X-0000
IC MCU 16BIT 64KB FLASH DIESALE. MAXQ20S MAXQ® Microcontroller IC 16-Bit 12MHz 64KB (64K x 8) FLASH Diesale. Embedded - Microcontrollers...
MAXQ610X-0000+
Maxim
63 ₽
Hi-Tech Circuit Group
MAXQ610X-0000+
MAXQ610X-0000+
Рутоника
MAXQ610X-0000+
Maxim
Производитель: Maxim
Описание: Микроконтроллеры (MCU)
data sheetСкачать Data Sheet
19-4715; Rev 6; 7/11
KIT ATION EVALU ABLE AVAIL
16-Bit Microcontroller with Infrared Module
General Description
The MAXQ610 is a low-power, 16-bit MAXQ® microcontroller designed for low-power applications including universal remote controls, consumer electronics, and white goods.
The MAXQ610 combines a powerful 16-bit RISC microcontroller and integrated peripherals including two USARTs and an SPITM master/slave communications port, along with an IR module with carrier frequency generation and flexible port I/O capable of multiplexed keypad control. The MAXQ610 includes 64KB of flash memory and 2KB of data SRAM. Intellectual property (IP) protection is provided by a secure MMU that supports multiple application privilege levels and protects code against copying and reverse engineering. Privilege levels enable vendors to provide libraries and applications to execute on the MAXQ610, while limiting access to only data and code allowed by their privilege level. For the ultimate in low-pow
MAXQ610X0000, MAXQ610X 0000
На английском языке: Datasheet MAXQ610X-0000 - Maxim Microcontrollers (MCU)
