Datasheet MAXQ3210-EJX - Maxim Даташит Микроконтроллеры (MCU) — Даташит
Наименование модели: MAXQ3210-EJX
![]() 11 предложений от 11 поставщиков MAXQ® Microcontroller IC 16-Bit 3.6MHz 2KB (1K x 16) EEPROM 24-TSSOP | |||
MAXQ3210-EJX+ Maxim | 532 ₽ | ||
MAXQ3210-EJX+ Maxim | по запросу | ||
MAXQ3210-EJX+ Analog Devices | по запросу | ||
MAXQ3210-EJX+ | по запросу |
Производитель: Maxim
Описание: Микроконтроллеры (MCU)
Rev 1; 5/06
KIT ATION EVALU BLE AVAILA
Microcontroller with Internal Voltage Regulator, Piezoelectric Horn Driver, and Comparator
General Description
The MAXQ3210 microcontroller is a low-power, 16-bit RISC device that incorporates a driver for a high-output piezoelectric horn/transducer, an analog comparator, and a high-current I/O pin that directly drives an LED.
The device is uniquely suited for cost-conscious applications such as chemical detectors, alarm systems, and white goods, but can be used in any application that requires high-performance and low-power operation. The high-performance 16-bit RISC core and 8-bit accumulators are complemented by standard amenities such as timers and digital I/O. The power consumption per MIPS ratio is among the best in the 16-bit microcontroller industry. The MAXQ3210 is powered directly from a 6V to 9.5V source, such as a battery, but an internal voltage regulator operates the core at 5V. The microcontroller also provides a flag if the input
MAXQ3210EJX, MAXQ3210 EJX
