Datasheet MCF51MM256VMLJ - Freescale Даташит Микроконтроллеры (MCU) 32 бит 256K FLASH — Даташит
Наименование модели: MCF51MM256VMLJ
32-bit Microcontrollers - MCU 32BIT 256K FLASH | |||
| MCF51MM256VMLJ | по запросу | ||
Производитель: Freescale
Описание: Микроконтроллеры (MCU) 32 бит 256K FLASH
Freescale Semiconductor Data Sheet: Technical Data
An Energy-Efficient Solution from Freescale
Document Number: MCF51MM256 Rev.
4, 10/2010
MCF51MM256/128
The MCF51MM256 series devices are members of the low-cost, low-power, high-performance ColdFire® V1 family of 32-bit microcontrollers (MCUs) designed for handheld metering devices. Not all features are available in all devices or packages; see Table 2 for a comparison of features by device. 32-Bit ColdFire V1 Central Processor Unit (CPU) · Up to 50.33-MHz ColdFire CPU above 2.4 V and 40 MHz CPU above 2.1 V and 20 MHz CPU above 1.8 V across temperature range of -40°C to 105°C. · ColdFire Instruction Set Revision C (ISA_C). · 32-bit multiply and accumulate (MAC) supports signed or unsigned integer or signed fractional inputs. On-Chip Memory · 256 K Flash comprised of two independent 128 K flash arrays; read/program/erase over full operating voltage and temperature; allows interrupt processing while programming. · 32 Kbytes System Rand
- Вид монтажа: SMD/SMT
- Высота: 0.8 мм
- Длина: 10 мм
- Размер памяти программ: 256 Кб
- Серия процессора: MCF51MM
- Тип корпуса: PBGA-B104
- Тип памяти программ: Flash
- Шина данных: 32 бит
- Ширина: 10 мм
- Ядро: ColdFire V1
- RoHS: да
