Datasheet AT89C52-20QC-5 - Atmel Даташит Микроконтроллеры (MCU) микроконтроллер — Даташит
Наименование модели: AT89C52-20QC-5
8-битные микроконтроллеры Microcontroller | |||
| AT89C52-20QC-5 Atmel | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) микроконтроллер
Features
Compatible with MCS-51TM Products 8K Bytes of In-System Reprogrammable Flash Memory Endurance: 1,000 Write/Erase Cycles Fully Static Operation: 0 Hz to 24 MHz Three-level Program Memory Lock 256 x 8-bit Internal RAM 32 Programmable I/O Lines Three 16-bit Timer/Counters Eight Interrupt Sources Programmable Serial Channel Low-power Idle and Power-down Modes
Description
The AT89C52 is a low-power, high-performance CMOS 8-bit microcomputer with 8K bytes of Flash programmable and erasable read only memory (PEROM).
The device is manufactured using Atmel's high-density nonvolatile memory technology and is compatible with the industry-standard 80C51 and 80C52 instruction set and pinout. The on-chip Flash allows the program memory to be reprogrammed in-system or by a conventional nonvolatile memory programmer. By combining a versatile 8-bit CPU with Flash on a monolithic chip, the Atmel AT89C52 is a powerful microcomputer which provides a highly-flexible and cost
- Шина данных: 8 бит
- RoHS: нет
AT89C5220QC5, AT89C52 20QC 5
