Datasheet AT89LV55-12AU - Atmel Даташит Микроконтроллеры (MCU) 16K FLASH 8051 микроконтроллер - 16K FLASH — Даташит
Atmel AT89LV55-12AU
Наименование модели: AT89LV55-12AU
8-битные микроконтроллеры 16K FLASH 8051 MCU - 16K FLASH
МосЧип
AT89LV55-12AU
Atmel
AT89LV55-12AU
Atmel
AT89LV55-12AU
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 16K FLASH 8051 микроконтроллер - 16K FLASH
data sheetСкачать Data Sheet
Features
· Compatible with MCS®-51 Products · 20K Bytes of Reprogrammable Flash Memory · · · · · · · ·
­ Endurance: 1,000 Write/Erase Cycles Fully Static Operation: 0 Hz to 12 MHz Three-level Program Memory Lock 256 x 8-bit Internal RAM 32 Programmable I/O Lines Three 16-bit Timer/Counters Eight Interrupt Sources Low-power Idle and Power-down Modes 2.7V to 6.0V Operating Range
1.
Description
The AT89LV55 is a low-voltage, low-power CMOS 8-bit microcontroller with 20K bytes of Flash programmable and erasable read-only memory. The device is manufactured using Atmel's high-density nonvolatile memory technology and is compatible with the industry-standard 80C51 instruction set and pinout. The on-chip Flash allows the program memory to be reprogrammed. By combining a versatile 8-bit CPU with Flash on a monolithic chip, the Atmel AT89LV55 is a powerful microcontroller which provides a highly-flexible and cost-effective solution to many embedded control applications. The AT89LV55 provides th
  • Вид монтажа: SMD/SMT
  • Тип корпуса: TQFP-44
  • Шина данных: 8 бит
  • RoHS: да
AT89LV5512AU, AT89LV55 12AU
На английском языке: Datasheet AT89LV55-12AU - Atmel Microcontrollers (MCU) 16K FLASH 8051 MCU - 16K FLASH
