Datasheet ATAM862P-TNQY3D - Atmel Даташит Микроконтроллеры (MCU) micrium Transm — Даташит
Наименование модели: ATAM862P-TNQY3D
Микросхема Микроконтроллер, IC MCU FLASH 4K TX 315MHz 24SSOP
ATAM862P-TNQY3D
Atmel
620 ₽
ATAM862P-TNQY3D
Atmel
Hi-Tech Circuit Group
ATAM862P-TNQY3D
ATAM862P-TNQY3D
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) micrium Transm.
315 МГц FLASH 125 C
data sheetСкачать Data Sheet
Features
Single Package Fully-integrated 4-bit Microcontroller with RF Transmitter Low Power Consumption in Sleep Mode (< 1 µA Typically) Flash Controller for Application Program Available Maximum Output Power with Low Supply Current 2.0V to 4.0V Operation Voltage for Single Li-cell Power Supply ­40°C to +125°C Operation Temperature SSO24 Package About Seven External Components
1. Description
The ATAM862-3 is a single package dual-chip circuit. It combines a UHF ASK/FSK transmitter with a 4-bit microcontroller. It supports highly integrated solutions in car access and tire-pressure monitoring applications, as well as manifold applications in the industrial and consumer segment. It is available for the transmitting frequency range of 310 MHz to 330 MHz with data rates up to 32 kbaud Manchester coded. For further frequency ranges such as 429 MHz to 439 MHz and 868 MHz to 928 MHz separate datasheets are available. The device contains a flash microcontroller. Figure 1-1. A
  • Вид монтажа: SMD/SMT
  • Высота: 1.3 мм
  • Длина: 8.05 мм
  • Серия процессора: ATAM862x
  • Тип корпуса: SSO-24
  • Шина данных: 4 бит
  • Ширина: 4.5 мм
  • Ядро: MARC4
  • RoHS: да
ATAM862PTNQY3D, ATAM862P TNQY3D
На английском языке: Datasheet ATAM862P-TNQY3D - Atmel Microcontrollers (MCU) micrium Transm
