Datasheet ATXMEGA192D3-MHR - Atmel Даташит Микроконтроллеры (MCU) 192 Кб FL 4 Кб EE 16K SRAM IND 1.6-3.6 В — Даташит
Наименование модели: ATXMEGA192D3-MHR
Купить ATXMEGA192D3-MHR на РадиоЛоцман.Цены — от 204 до 2 770 ₽ 15 предложений от 12 поставщиков AVR AVR® XMEGA® D3 Microcontroller IC 8/16-Bit 32MHz 192KB (96K x 16) FLASH 64-QFN (9x9) | |||
ATXMEGA192D3-MHR Microchip | 204 ₽ | ||
ATXMEGA192D3-MHR Microchip | 498 ₽ | ||
ATXMEGA192D3-MHR Atmel | 572 ₽ | ||
ATXMEGA192D3-MHR Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 192 Кб FL 4 Кб EE 16K SRAM IND 1.6-3.6 В
Features
· High-performance, Low-power 8/16-bit Atmel® AVR® XMEGATM Microcontroller · Non-volatile Program and Data Memories
64K - 256K Bytes of In-System Self-Programmable Flash 4K - 8K Bytes Boot Code Section with Independent Lock Bits 2K - 4K Bytes EEPROM 4K - 16K Bytes Internal SRAM Peripheral Features Four-channel Event System Five 16-bit Timer/Counters Four Timer/Counters with 4 Output Compare or Input Capture channels One Timer/Counters with 2 Output Compare or Input Capture channels High Resolution Extensions on two Timer/Counters Advanced Waveform Extension on one Timer/Counter Three USARTs IrDA Extension on 1 USART Two Two-Wire Interfaces with dual address match(I2C and SMBus compatible) Two SPI (Serial Peripheral Interfaces) 16-bit Real Time Counter with Separate Oscillator One Sixteen-channel, 12-bit, 200ksps Analog to Digital Converter Two Analog Comparators with Window compare function External Interrupts on all General Purpose I/O pins Program
- Упаковка: Reel
- RoHS: да
ATXMEGA192D3MHR, ATXMEGA192D3 MHR
