Datasheet ATXMEGA32D4-MHR - Atmel Даташит Микроконтроллеры (MCU) 32 Кб FL 1 Кб EE 4K SRAM IND 1.6-3.6 В — Даташит
Наименование модели: ATXMEGA32D4-MHR
Купить ATXMEGA32D4-MHR на РадиоЛоцман.Цены — от 122 до 6 762 ₽ 17 предложений от 11 поставщиков AVR AVR® XMEGA® D4 Microcontroller IC 8/16-Bit 32MHz 32KB (16K x 16) FLASH 44-VQFN (7x7) | |||
ATXMEGA32D4-MHR Microchip | 122 ₽ | ||
ATXMEGA32D4-MHR Atmel | 239 ₽ | ||
ATXMEGA32D4-MHR Atmel | по запросу | ||
ATXMEGA32D4-MHR Microchip | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 32 Кб FL 1 Кб EE 4K SRAM IND 1.6-3.6 В
Features
· High-performance, Low-power 8/16-bit Atmel® AVR® XMEGA® Microcontroller · Non-volatile Program and Data Memories
16 KB - 128 KB of In-System Self-Programmable Flash 4 KB - 8 KB Boot Code Section with Independent Lock Bits 1 KB - 2 KB EEPROM 2 KB - 8 KB Internal SRAM Peripheral Features Four-channel Event System Four 16-bit Timer/Counters Three Timer/Counters with 4 Output Compare or Input Capture channels One Timer/Counter with 2 Output Compare or Input Capture channels High-Resolution Extensions on two Timer/Counters Advanced Waveform Extension on one Timer/Counter Two USARTs IrDA Extension on one USART Two Two-Wire Interfaces with dual address match (I2C and SMBus compatible) Two SPIs (Serial Peripheral Interfaces) peripherals 16-bit Real Time Counter with Separate Oscillator One Twelve-channel, 12-bit, 200 ksps Analog to Digital Converter Two Analog Comparators with Window compare function External Interrupts on all General Purpose I/O pins Pro
- Упаковка: Reel
- RoHS: да
ATXMEGA32D4MHR, ATXMEGA32D4 MHR
