Datasheet ATMEGA8A-MN - Atmel Даташит Микроконтроллеры (MCU) AVR 8 Кб FLSH 512B EE 1 Кб SRAM-16MHz 105C — Даташит
Наименование модели: ATMEGA8A-MN
Купить ATMEGA8A-MN на РадиоЛоцман.Цены — от 53 до 555 ₽ 25 предложений от 15 поставщиков IC: микроконтроллер AVR; EEPROM: 512Б; SRAM: 1kБ; Flash: 8kБ; VQFN32 | |||
ATMEGA8A-MN Microchip | от 53 ₽ | ||
ATMEGA8A-MN Microchip | 128 ₽ | ||
ATMEGA8A-MN Atmel | 221 ₽ | ||
ATMEGA8A-MN Microchip | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 8 Кб FLSH 512B EE 1 Кб SRAM-16MHz 105C
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · Advanced RISC Architecture
130 Powerful Instructions Most Single-clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 16 MIPS Throughput at 16 MHz On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments 8K Bytes of In-System Self-programmable Flash program memory 512 Bytes EEPROM 1K Byte Internal SRAM Write/Erase Cycles: 10,000 Flash/100,000 EEPROM Data retention: 20 years at 85°C/100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits · In-System Programming by On-chip Boot Program · True Read-While-Write Operation Programming Lock for Software Security Peripheral Features Two 8-bit Timer/Counters with Separate Prescaler, one Compare Mode One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode Real Time Counter with Separate Oscillator Three PWM Channels 8-channel ADC in TQFP and QFN/ML
- Шина данных: 8 бит
- Ядро: AVR
- RoHS: да
ATMEGA8AMN, ATMEGA8A MN
