Datasheet NCP348MTTBG - ON Semiconductor Даташит ИС, OVERVOLTAG защита контроллер — Даташит
Наименование модели: NCP348MTTBG
![]() 18 предложений от 17 поставщиков Чип контроля напряжения, Positive Overvoltage Protection Circuit with Internal Low Ron NMOS FET and Status Flag OVLO 6.4V, WDFN10, 2.5x2 mm,... | |||
NCP348MTTBG ON Semiconductor | 26 ₽ | ||
NCP348MTTBG ON Semiconductor | 75 ₽ | ||
NCP348MTTBG ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: ИС, OVERVOLTAG защита контроллер
NCP348, NCP348AE Positive Overvoltage Protection Controller with Internal Low RON NMOS FET and Status FLAG
The NCP348 is able to disconnect the systems from its output pin in case wrong input operating conditions are detected.
The system is positive overvoltage protected up to +28 V. Due to this device using internal NMOS, no external device is necessary, reducing the system cost and the PCB area of the application board. The NCP348 is able to instantaneously disconnect the output from the input, due to integrated Low RON Power NMOS (65 mW), if the input voltage exceeds the overvoltage threshold (OVLO) or undervoltage threshold (UVLO). At powerup (EN pin = low level), the Vout turns on 50 ms after the Vin exceeds the undervoltage threshold. The NCP348 provides a negative going flag (FLAG) output, which alerts the system that a fault has occurred. In addition, the device has ESD-protected input (15 kV Air) when bypassed with a 1.0 mF or larger capacitor.
Features http://onsemi.com MARKI
- Battery IC Case Style: WDFN
- Battery Protection: Over Voltage
- Battery Type: Lithium
- Number of Batteries: 1
- Входное напряжение максимальное: 28 В
- Диапазон напряжения питания: 1.2 В ... 28 В
- Количество выводов: 10
- Напряжения питания Vcc: 1.2 В
- Рабочий диапазон температрур: -40°C ... +85°C
- Семейство: 348
- Способ монтажа: SMD
- Тактовая частота: 200 кГц
- Тип корпуса: WDFN
- RoHS: да
- SVHC: No SVHC (18-Jun-2012)
