Datasheet LPC1785FBD208,551 - NXP Даташит Микроконтроллеры (MCU) CORTEX-M3 256 Кб FL 80 Кб SRAM 4 Кб EE USB — Даташит
Наименование модели: LPC1785FBD208,551
![]() 13 предложений от 13 поставщиков IC MCU 32BIT 256KB FLASH 208LQFP. ARM® Cortex®-M3 LPC17xx Microcontroller IC 32-Bit 120MHz 256KB (256K x 8) FLASH 208-LQFP (28x28). Embedded... | |||
LPC1785FBD208,551 NXP | 515 ₽ | ||
LPC1785FBD208,551 NXP | по запросу | ||
Производитель: NXP
Описание: Микроконтроллеры (MCU) CORTEX-M3 256 Кб FL 80 Кб SRAM 4 Кб EE USB
LPC178x/7x
32-bit ARM Cortex-M3 microcontroller; up to 512 kB flash and 96 kB SRAM; USB Device/Host/OTG; Ethernet; LCD; EMC
Rev.
3 -- 27 December 2011 Objective data sheet
1. General description
The LPC178x/7x is an ARM Cortex-M3 based microcontroller for embedded applications requiring a high level of integration and low power dissipation. The Cortex-M3 is a next generation core that offers better performance than the ARM7 at the same clock rate and other system enhancements such as modernized debug features and a higher level of support block integration. The Cortex-M3 CPU incorporates a 3-stage pipeline and has a Harvard architecture with separate local instruction and data buses, as well as a third bus with slightly lower performance for peripherals. The Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branches. The LPC178x/7x adds a specialized flash memory accelerator to accomplish optimal performance when executing code from flash. The LPC178x/7x
- Упаковка: Tray
- RoHS: да
LPC1785FBD208551, LPC1785FBD208 551
