Datasheet LPC1787FBD208,551 - NXP Даташит 8- бит микроконтроллеры (MCU) CORTEX-M3 512 Кб FL 96 Кб SRAM 4 Кб EE USB — Даташит
Наименование модели: LPC1787FBD208,551
Купить LPC1787FBD208,551 на РадиоЛоцман.Цены — от 355 до 2 047 ₽31 предложений от 17 поставщиков IC MCU 32BIT 512KB FLASH 208LQFP. ARM® Cortex®-M3 LPC17xx Microcontroller IC 32-Bit 120MHz 512KB (512K x 8) FLASH 208-LQFP (28x28). Embedded... | |||
| LPC1787FBD208,551 NXP | 1 326 ₽ | ||
| LPC1787FBD208,551 NXP | 1 621 ₽ | ||
| LPC1787FBD208,551 Nexperia | от 2 047 ₽ | ||
| LPC1787FBD208,551 NXP | по запросу | ||
Производитель: NXP
Описание: 8- бит микроконтроллеры (MCU) CORTEX-M3 512 Кб FL 96 Кб SRAM 4 Кб EE USB
LPC178x/7x
32-bit ARM Cortex-M3 microcontroller; up to 512 kB flash and 96 kB SRAM; USB Device/Host/OTG; Ethernet; LCD; EMC
Rev.
3 -- 27 December 2011 Objective data sheet
1. General description
The LPC178x/7x is an ARM Cortex-M3 based microcontroller for embedded applications requiring a high level of integration and low power dissipation. The Cortex-M3 is a next generation core that offers better performance than the ARM7 at the same clock rate and other system enhancements such as modernized debug features and a higher level of support block integration. The Cortex-M3 CPU incorporates a 3-stage pipeline and has a Harvard architecture with separate local instruction and data buses, as well as a third bus with slightly lower performance for peripherals. The Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branches. The LPC178x/7x adds a specialized flash memory accelerator to accomplish optimal performance when executing code from flash. The LPC178x/7x
- Упаковка: Tray
- RoHS: да
LPC1787FBD208551, LPC1787FBD208 551
