Datasheet G6B2114PFDUS5DC - Omron Даташит Реле, SPST-NC+SPST-NO, 5 А, 5 В — Даташит
Наименование модели: G6B2114PFDUS5DC
![]() 8 предложений от 4 поставщиков Универсальное реле, серия G6B, силовое, без защелки, SPST-NO, SPST-NC, 5В DC, 5А | |||
G6B2114PFDUS5DC Omron | 448 ₽ | ||
G6B2114PFDUS5DC Omron | 507 ₽ | ||
G6B2114PFDUS5DC Omron | от 1 483 ₽ |
Производитель: Omron
Описание: Реле, SPST-NC+SPST-NO, 5 А, 5 В
G6B
PCB Power Relay
High Capacity and High Dielectric Strength Miniature Relay with Fully Sealed Construction in 5 A (8 A) SPST-NO (1a), SPST-NC (1b), DPST-NO (2a), DPST-NC (2b) Types
· High sensitive with operating power of 98 mW.
(G6B-1114P-US and G6B-1174P-US models) · High insulation with dielectric strength of 3,000VAC between coil and contacts (impulse withstand voltage of 6 kV). · Stick packing models are provided in consideration of compatibility to the automatic production line. · Standard model conforms to UL/CSA standards. Other SEV approved models are also available. · AgSnIn contacts suitable for loads that generate surge voltage such as inductive load and capacity load etc. are available for the whole product line. · Ultrasonically cleanable models is available. · Operation indicator & surge absorption diode are built-in for the whole product line. · Double-pole type is available for the whole product line.
RoHS Compliant
- Coil Current: 40 мА
- Coil Resistance: 125 Ом
- Coil Type: DC
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 5 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- External Depth: 20 мм
- Operating Power Nom: 200 мВт
- Внешняя ширина: 10 мм
- Габариты: высота: 10 мм
- Конфигурация контактов: SPST-NO / SPST-NC
- Способ монтажа: Through Hole
- Тип реле: Power
- RoHS: да
