Datasheet LT1719IS8 - Linear Technology Даташит Компаратор, одиночный, 4.5 нс, SOIC-8 — Даташит
Linear Technology LT1719IS8
Наименование модели: LT1719IS8
43 предложений от 22 поставщиков
Микросхема Компаратор, LINEAR TECHNOLOGY LT1719IS8#PBF Analog Comparator, Single, High Speed, 1, 4.5ns, 2.7V to 10.5V, SOIC, 8Pins
LT1719IS8#PBF
149 ₽
Зенер
Россия и страны ТС
LT1719IS8#TRPBF
от 318 ₽
Microfind
LT1719IS8#PBF
664 ₽
LT1719IS8
Производитель: Linear Technology
Описание: Компаратор, одиночный, 4.5 нс, SOIC-8
data sheetСкачать Data Sheet
FEATURES
n n n n n n n
LT1719 4.5ns Single/Dual Supply 3V/5V Comparator with Rail-to-Rail Output DESCRIPTION
The LT ®1719 is an UltraFastTM comparator optimized for low voltage operation.
The input voltage range extends from 100mV below VEE to 1.2V below VCC. Internal hysteresis makes the LT1719 easy to use even with slow moving input signals. The rail-to-rail outputs directly interface to TTL and CMOS. Alternatively the symmetric output drive can be harnessed for analog applications or for easy translation to other single supply logic levels. A shutdown control allows for reduced power consumption and extended battery life in portable applications. The LT1719 is available in the SO-8 and 6-lead SOT-23 package. The SO-8 package has separate supplies which allow flexible operation, accomodating separate analog input ranges and output logic levels. For a dual/quad comparator with similar performance, see the LT1720/LT1721.
L, LT, LTC, LTM, Linear Technology and the Linear logo are regis
  • Output Compatibility: CMOS, TTL
  • Время отклика: 4.5 нс
  • Диапазон напряжения питания: 2.7 В ... 10.5 В
  • Количество выводов: 8
  • Количество компараторов: 1
  • Тип компаратора: High Speed
  • Тип корпуса: SOIC
На английском языке: Datasheet LT1719IS8 - Linear Technology COMPARATOR, SINGLE, 4.5 ns, SOIC-8
