Datasheet ADP5061ACBZ-4-R7 - Analog Devices Даташит BATT CHRGR, PROG I2C, 2.1 А, 20WLCSP — Даташит
Наименование модели: ADP5061ACBZ-4-R7
![]() 36 предложений от 15 поставщиков Микросхема Чип управления батареи, ANALOG DEVICES ADP5061ACBZ-4-R7 Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 6.7V input, 2.1A charge, WLCSP-20... | |||
ADP5061ACBZ-4-R7 Analog Devices | 22 ₽ | ||
ADP5061ACBZ-4-R7 Analog Devices | от 65 ₽ | ||
ADP5061ACBZ-4-R7 | 300 ₽ | ||
ADP5061ACBZ-4-R7 Analog Devices | по запросу |
Производитель: Analog Devices
Описание: BATT CHRGR, PROG I2C, 2.1 А, 20WLCSP
Tiny I2C Programmable Linear Battery Charger with Power Path and USB Mode Compatibility
Data Sheet
FEATURES
2.6 mm Ч 2 mm WLCSP package Fully programmable via I2C Flexible digital control inputs Up to 2.1 A current from an ac charger in LDO mode Operating input voltage from 4.0 V to 6.7 V Tolerant input voltage from -0.5 V to +20 V (USB VBUS) Fully compatible with USB 3.0 and USB Battery Charging Specification 1.2 Built-in current sensing and limiting As low as 30 m battery isolation FET between battery and charger output Thermal regulation prevents over heating Compliant with JEITA 1 and JEITA 2 Li-Ion battery charging temperature specifications SYS_EN flag permits the system to be disabled until battery is at minimum required level for guaranteed system start-up
AC OR USB
- Battery IC Case Style: WLCSP
- Battery Type: Lithium Ion, Lithium Polymer
- Charge Current Max: 2.1 А
- Number of Series Cells: 1
- Влагостойкость: MSL 1 - Unlimited
- Количество выводов: 20
- Рабочий диапазон температрур: -40°C ...
+125°C
- RoHS: да
- SVHC: No SVHC (18-Jun-2012)
ADP5061ACBZ4R7, ADP5061ACBZ 4 R7
