Datasheet ADP5062ACPZ-1-R7 - Analog Devices Даташит BATT CHRGR, 6.7 В, LI-ION, 2.1 А, 20LFCSP — Даташит
Analog Devices ADP5062ACPZ-1-R7
Наименование модели: ADP5062ACPZ-1-R7
36 предложений от 17 поставщиков
Зарядное устройство, 1-элементная Li-Ion батарея, USB3.0/зарядка 1.2 , 6.7В вход, 2.1А зарядка
Рутоника
ADP5062ACPZ-1-R7
146 ₽
ADP5062ACPZ-1-R7
293 ₽
727GS
ADP5062ACPZ-1-R7
от 544 ₽
ТаймЧипс
ADP5062ACPZ-1-R7
Производитель: Analog Devices
Описание: BATT CHRGR, 6.7 В, LI-ION, 2.1 А, 20LFCSP
data sheetСкачать Data Sheet
Data Sheet
FEATURES
Linear Li-Ion Battery Charger with Power Path and USB Compatibility in LFCSP ADP5062
GENERAL DESCRIPTION
The ADP5062 charger is fully compliant with USB 3.0 and the USB Battery Charging Specification 1.2 and enables charging via the mini USB VBUS pin from a wall charger, car charger, or USB host port.
The ADP5062 operates from a 4 V to 6.7 V input voltage range but is tolerant of voltages up to 20 V thereby alleviating concerns about USB bus spikes during disconnect or connect scenarios. The ADP5062 features an internal FET between the linear charger output and the battery. This permits battery isolation and, hence, system powering under a dead battery or no battery scenario, which allows for immediate system function on connection to a USB power supply. Based on the type of USB source, which is detected by an external USB detection chip, the ADP5062 can be set to apply the correct current limit for optimal charging and USB compliance. The ADP5062 has three factory
  • Battery Type: Lithium Ion
  • Charge Current Max: 2.1 А
  • Number of Series Cells: 1
  • Влагостойкость: MSL 1 - Unlimited
  • Количество выводов: 20
  • Рабочий диапазон температрур: -40°C ... +125°C
  • RoHS: да
  • SVHC: No SVHC (18-Jun-2012)
ADP5062ACPZ1R7, ADP5062ACPZ 1 R7
На английском языке: Datasheet ADP5062ACPZ-1-R7 - Analog Devices BATT CHRGR, 6.7 V, LI-ION, 2.1 A, 20LFCSP
