Datasheet CYUSB3013-BZXC - Cypress Даташит ARM микроконтроллеры - микроконтроллер EZUSB SuperSpeedCtrl X16 256 Кб — Даташит
Наименование модели: CYUSB3013-BZXC
![]() 32 предложений от 16 поставщиков Интегральные микросхемы Встроенные микросхемы - Микроконтроллеры специального назначения | |||
CYUSB3013-BZXC Cypress | 160 ₽ | ||
CYUSB3013-BZXC Cypress | 1 038 ₽ | ||
CYUSB3013-BZXC Cypress | от 1 824 ₽ | ||
CYUSB3013-BZXC | 3 924 ₽ |
Производитель: Cypress
Описание: ARM микроконтроллеры - микроконтроллер EZUSB SuperSpeedCtrl X16 256 Кб
CYUSB301X
EZ-USB® FX3 SuperSpeed USB Controller
Features
Universal serial bus (USB) integration USB 3.0 and USB 2.0 peripherals compliant with USB 3.0 specification 1.0 5-Gbps USB 3.0 PHY compliant with PIPE 3.0 High-speed On-The-Go (HS-OTG) host and peripheral compliant with OTG Supplement Version 2.0 Thirty-two physical endpoints Support for battery charging Spec 1.1 and accessory charger adaptor (ACA) detection General Programmable Interface (GPIFTM II) Programmable 100-MHz GPIF II enables connectivity to a wide range of external devices 8-, 16-, and 32-bit data bus As many as16 configurable control signals Fully accessible 32-bit CPU ARM926EJ core with 200-MHz operation 512-KB or 256-KB embedded SRAM Additional connectivity to the following peripherals 2 I C master controller at 1 MHz 2 I S master (transmitter only) at sampling frequencies of 32 kHz, 44.1 kHz, and 48 kHz UART support of up to 4 Mbps SPI master at 33 MHz Selectable clock input frequencies 19.2,
- Упаковка: Tray
- RoHS: да
CYUSB3013BZXC, CYUSB3013 BZXC
