Datasheet CY7C67300-100AXA - Cypress Даташит 16- бит микроконтроллеры - микроконтроллер MULTIPORT HOST/SLAVE — Даташит
Наименование модели: CY7C67300-100AXA
Купить CY7C67300-100AXA на РадиоЛоцман.Цены — от 72 до 989 ₽ 10 предложений от 10 поставщиков MCU 16-bit CY7C673xx CY16 RISC 4KB ROM 3.3V Automotive 100-Pin TQFP | |||
CY7C67300-100AXA Cypress | 72 ₽ | ||
CY7C67300-100AXA Intel | 930 ₽ | ||
CY7C67300-100AXA Intel | 989 ₽ | ||
CY7C67300-100AXA Infineon | по запросу |
Производитель: Cypress
Описание: 16- бит микроконтроллеры - микроконтроллер MULTIPORT HOST/SLAVE
CY7C67300
EZ-HostTM Programmable Embedded USB Host and Peripheral Controller with Automotive AEC Grade Support
EZ-Host Features
Single chip programmable USB dual-role (Host/Peripheral) controller with two configurable Serial Interface Engines (SIEs) and four USB ports Support for USB On-The-Go (OTG) protocol On-chip 48 MHz 16-bit processor with dynamically switchable clock speed Configurable IO block supporting a variety of IO options or up to 32 bits of General Purpose IO (GPIO) 4K x 16 internal masked ROM containing built in BIOS that supports a communication ready state with access to I2CTM EEPROM Interface, external ROM, UART, or USB 8K x 16 internal RAM for code and data buffering Extended memory interface port for external SRAM and ROM 16-bit parallel Host Port Interface (HPI) with a DMA/mailbox data path for an external processor to directly access all of the on-chip memory and control on-chip SIEs Fast serial port supports from 9600 baud to 2.0M baud SPI support in both mast
- Вид монтажа: SMD/SMT
- Рабочий диапазон температрур: - 40 C ...
+ 85 C
- Тип корпуса: TQFP-100
- Упаковка: Tray
- RoHS: да
CY7C67300100AXA, CY7C67300 100AXA
