Datasheet Texas Instruments TPA2005D1DGNR — Даташит
СерияTPA2005D1
МодельTPA2005D1DGNR
Моноусилитель звука класса D, 1,4 Вт (TPA2005) 8-MSOP-PowerPAD от -40 до 85
TPA2005D1 1.4-W MONO Filter-Free Class-D Audio Power Amplifier datasheet
PDF, 1.6 Мб, Версия: G, Файл опубликован: 27 окт 2015
58 предложений от 23 поставщиков
Микросхема Усилитель звуковой частоты, Audio Power Amplifier, D, 1Channel, 1.4W, 2.5V to 5.5V, MSOP, 8Pins
Microfind
TPA2005D1DGNR
39 ₽
Триема
TPA2005D1DGNR
62 ₽
Контест
TPA2005D1DGNR
221 ₽
TPA2005D1DGNR64
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
МаркировкаBAL
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
Analog Supply (V)5.5 Min
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceHardware
Iq per channel(Typ)2.8 мА
Iq(Max)4.5 мА
Iq(Typ)2.8 мА
Load(Min)8 ohms
Выходная мощность1.4 W
PSRR75 дБ
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Pin/Package15BGA MICROSTAR JUNIOR, 8MSOP-PowerPAD, 8SON
Shutdown Current (ISD)0.5 uA
Speaker ChannelsMono Max
THD + N @ 1 kHz0.2 %
  • Evaluation Modules & Boards: TPA2005D1EVM
    TPA2005D1 Evaluation Module (EVM)
  • Power Rating in Audio Amplifier (Rev. A)
    PDF, 514 Кб, Версия: A, Файл опубликован: 4 мар 2005
    Average consumers often weigh heavily on cost versus power rating of audio amplifiers as their basis for purchasing one. Depending on the marketing strategy, the powerrating methodology for audio amplifiers can vary from manufacturer to manufacturer.The purpose of this document is to clarify three commonly used power ratings: average power, peak power, and PMPO.The following Texas Instru
  • Measuring Class-D Amplifiers for Audio Speaker Overstress Testing
    PDF, 175 Кб, Файл опубликован: 28 окт 2005
    This application report presents the results of an experiment conducted to demonstrate how to address the two most common concerns regarding speaker damage using Class-D amplifiers.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2005D1DGNR
