Datasheet Texas Instruments TAS5142DDV — Даташит
СерияTAS5142
МодельTAS5142DDV
Мощность цифрового стереоусилителя мощностью 100 Вт 44-HTSSOP от 0 до 70
Stereo Digital Amplifier Power Stage datasheet
PDF, 1.9 Мб, Версия: B, Файл опубликован: 18 май 2005
25 предложений от 17 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS TAS5142DDV Audio Power Amplifier, D, 2Channel, 100W, 0V to 34V, 10.8V to 13.2V, HTSSOP, 44Pins...
TAS5142DDV
314 ₽
TAS5142DDV
557 ₽
Элитан
TAS5142DDV
1 385 ₽
SUV System
TAS5142DDV
Pin44
Package TypeDDV
Industry STD TermHTSSOP
Package QTY35
МаркировкаTAS5142
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).635
Max Height (мм)1.2
Audio Input TypePWM
Control InterfaceHardware
Выходная мощность100 W
Power Stage Supply(Max)34 В
Power to Bridge Tied Load(Max)100 W
Power to Parallel Bridge Tied Load(Max)200 W
SNR102 дБ
Speaker Channels4 Max
THD + N @ 1 kHz0.1 %
  • Evaluation Modules & Boards: TAS5142DDV6EVM2
    TAS5142DDV6 Evaluation Module (EVM)
  • Evaluation Modules & Boards: TAS5504-5142V4EVM
    TAS5504-5142V4 Evaluation Module (EVM)
  • Evaluation Modules & Boards: TAS5086-5142V6EVM
    TAS5086-5142V6 Evaluation Module (EVM)
  • Evaluation Modules & Boards: TAS5508-5142K7EVM
    TAS5508-5142K7 Evaluation Module (EVM)
  • Power Supply Recommendations for DVD Receivers
    PDF, 153 Кб, Файл опубликован: 4 май 2005
    Selecting the optimal power supply for a non feed back digital amplifier can bechallenging. Music is dynamic, so the power consumption is changing dramatically,from almost zero to maximum within a few ms.Designing the power supply so powerful that it can deliver the total amplifier outputpower continuously is too costly and usually unnecessary.Designing the power supply too small gives p
  • Power Rating in Audio Amplifier (Rev. A)
    PDF, 514 Кб, Версия: A, Файл опубликован: 4 мар 2005
    Average consumers often weigh heavily on cost versus power rating of audio amplifiers as their basis for purchasing one. Depending on the marketing strategy, the powerrating methodology for audio amplifiers can vary from manufacturer to manufacturer.The purpose of this document is to clarify three commonly used power ratings: average power, peak power, and PMPO.The following Texas Instru
  • PSRR for Purepath Digital Audio Amplifiers
    PDF, 159 Кб, Файл опубликован: 15 апр 2005
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
  • Semiconductors > Audio > High-Power Audio Amplifiers (>50W) > PWM Input Class-D
На английском языке: Datasheet Texas Instruments TAS5142DDV
