Datasheet Texas Instruments LM35DT/NOPB — Даташит
Серия | LM35 |
Модель | LM35DT/NOPB |
В±0.5В°C Temperature Sensor with Analog Output with 30V Capability 3-TO-220 0 to 100
Datasheet LM35
PDF, 1.7 Мб, Версия: G, Файл опубликован: 15 авг 2016, Страниц: 36
Precision Centigrade Temperature Sensors
Купить LM35DT/NOPB на РадиоЛоцман.Цены — от 56 до 986 ₽ 27 предложений от 18 поставщиков Датчик температуры Вых. по напряжению, +10мВ/°C, ±2°C, 0°С…+100°C Uпит=4...30В Iпот=141мкА | |||
LM35DT/NOPB Texas Instruments | 56 ₽ | ||
LM35DT/NOPB Texas Instruments | 104 ₽ | ||
LM35DTNOPB Texas Instruments | 234 ₽ | ||
LM35DTNOPB Texas Instruments | по запросу |
Pin | 3 |
Package Type | NEB |
Package QTY | 45 |
Carrier | TUBE |
Маркировка | LM35DT |
Interface | Analog Output |
Local Sensor Accuracy(Max) | 0.5 +/- C |
Рабочий диапазон температур | от -40 до 110,-55 до 150,0 до 100,0 до 70 C |
Package Group | TO |
Package Size: mm2:W x L | 3TO: 22 mm2: 4.699 x 4.699(TO) PKG |
Rating | Catalog |
Supply Current(Max) | 114 uA |
Supply Voltage(Max) | 30 В |
Supply Voltage(Min) | 4 В |
- High-Efficiency 3A Battery Chargers Use LM2576 Regulators (Rev. B)PDF, 187 Кб, Версия: B, Файл опубликован: 23 апр 2013
This application report describes two LM2576-based designs that provide up to 3A of current for batterycharging. - AN-460 LM34/LM35 Precision Monolithic Temperature Sensors (Rev. C)PDF, 495 Кб, Версия: C, Файл опубликован: 1 май 2013
This application report discusses the details and uses of the Texas Instruments LM34 and LM35 asprecision temperature sensors. - Thermocouple, Cold-Junction Compensation—Analog ApproachPDF, 614 Кб, Файл опубликован: 27 авг 2014
Temperature is the most commonly measured physical parameter in a variety of systems, including automotive, industrial, and consumer domains. There are various temperature transducers available to address the need of accurate temperature measurement. Thermocouples are widely popular because they are inexpensive, have a wide range, are small in size, and do not need excitation. This application not - TO-92 Packing Options / Ordering Instructions (Rev. A)PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
- AN-1852 Designing With pH Electrodes (Rev. A)PDF, 115 Кб, Версия: A, Файл опубликован: 1 май 2013
A pH electrode measures hydrogen ion (H+) activity and produces an electrical potential or voltage. Theoperation of the pH electrode is based on the principle that an electric potential develops when two liquidsof different pH come into contact at opposite sides of a thin glass membrane. This was originallydiscovered in 1906 by Max Cremer [1]. His discovery laid the foundation for Fritz Habe - Sensing and Monitoring for Control and Protection SeminarPDF, 245 Кб, Файл опубликован: 17 фев 2003
- AN-480 A 40 MHz Programmable Video Op AmpPDF, 218 Кб, Файл опубликован: 11 май 2004
Серия: LM35 (27)
- Semiconductors > Space & High Reliability > Sensors > Temperature Sensor
