Datasheet Texas Instruments SN74LVCH16245ADGVR — Даташит
СерияSN74LVCH16245A
МодельSN74LVCH16245ADGVR
16-битный шинный трансивер с выходами с 3 состояниями 48-TVSOP от -40 до 125
SN74LVCH16245A 16-bit Bus Transceiver With 3-state Outputs datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 7 ноя 2013
13 предложений от 10 поставщиков
TEXAS INSTRUMENTS SN74LVCH16245ADGVR Transceiver, 74LVC16245, 2V to 3.6V, TVSOP-48
SN74LVCH16245ADGVR
34 ₽
T-electron
SN74LVCH16245ADGVR
49 ₽
SN74LVCH16245ADGVR
Flash-Turtle
SN74LVCH16245ADGVR
Электромеханические реле Hongfa – надежность и качество 19 января 2023
Pin48
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаLDH245A
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTVSOP
Package Size: mm2:W x L48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)7.1,4.5,4.7,4 нс
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVCH16245ADGVR
