Datasheet Texas Instruments SN65HVD22DRG4 — Даташит
Серия | SN65HVD22 |
Модель | SN65HVD22DRG4 |
![Datasheet Texas Instruments SN65HVD22DRG4](http://www.ti.com/graphics/folders/partimages/SN65HVD22.jpg)
Расширенный синфазный трансивер RS-485 8-SOIC от -40 до 85
SN65HVD2x Extended Common-Mode RS-485 Transceivers datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 18 ноя 2016
![]() 12 предложений от 9 поставщиков Single Transmitter/Receiver RS-485 8Pin SOIC T/R | |||
SN65HVD22DRG4 Texas Instruments | от 74 ₽ | ||
SN65HVD22DRG4 Texas Instruments | 112 ₽ | ||
SN65HVD22DRG4 Texas Instruments | 223 ₽ | ||
SN65HVD22DRG4 Texas Instruments | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | VP22 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Common Mode Range | -20 to 25 |
Duplex | Half |
Fail Safe | Idle,Open,Short |
Fault Protection | -27 to 27 В |
HBM ESD | 16 kV |
ICC(Max) | 9 мА |
IEC 61000-4-2 Contact | N/A +/- kV |
Isolated | No |
No. of RX | 1 |
No. of TX | 1 |
Number of Nodes | 256 |
Package Group | SOIC |
Rating | Catalog |
Signaling Rate(Max) | 0.5 Mbps |
Supply Voltage(s)(Nom) | 5 В |
- Evaluation Modules & Boards: SN65HVD22EVM
SN65HVD22EVM Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: RS485-HF-DPLX-EVM
RS-485 Half-Duplex Evaluation Module
- RS-485 at 230-kbps Over Uncontrolled InterconnectPDF, 408 Кб, Файл опубликован: 12 апр 2004
This application report presents an evaluation of the SN65LBC184, SN65HVD22, and MAX487 transceivers in an uncontrolled impedance interconnection signaling at 230 kbps. The network used for the evaluation was identified as typical of that for building security. - RS-485 for Digital Motor Control ApplicationsPDF, 180 Кб, Файл опубликован: 12 май 2003
This application report focuses on the benefits of using RS-485 signaling for motor control and motion control applications. This technology has several benefits for these applications in terms of noise immunity, wide common-mode voltage range, adequate data rate, and multipoint capability. Other applications also use RS-485 signaling to take advantage of these same benefits. Applications such as - The RS-485 Unit Load and Maximum Number of Bus ConnectionsPDF, 197 Кб, Файл опубликован: 15 мар 2004
The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
Серия: SN65HVD22 (6)
- SN65HVD22D SN65HVD22DG4 SN65HVD22DR SN65HVD22DRG4 SN65HVD22P SN65HVD22PE4
- Semiconductors > Interface > RS-485/RS-422
