Datasheet Texas Instruments OPA121KU/2K5 — Даташит
Серия | OPA121 |
Модель | OPA121KU/2K5 |
Недорогой прецизионный операционный усилитель Difet 8-SOIC от 0 до 70
Low Cost Precision Difet® Operational Amplifier datasheet
PDF, 500 Кб, Файл опубликован: 27 сен 2000
Купить OPA121KU/2K5 на РадиоЛоцман.Цены — от 71 до 836 ₽ 17 предложений от 14 поставщиков General Purpose Amplifier 1 Circuit 8-SOIC | |||
OPA121KU/2K5E4 Texas Instruments | 71 ₽ | ||
OPA121KU/2K5 Texas Instruments | от 587 ₽ | ||
OPA121KU/2K5 Texas Instruments | 780 ₽ | ||
OPA121KU/2K5E4 Texas Instruments | по запросу |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | 121KU | OPA |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | N/A |
Архитектура | FET |
CMRR(Min) | 82 дБ |
CMRR(Typ) | 100 дБ |
GBW(Typ) | 2 МГц |
Input Bias Current(Max) | 5 pA |
Iq per channel(Max) | 4 мА |
Iq per channel(Typ) | 2.5 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 3 uV/C |
Рабочий диапазон температур | от 0 до 70 C |
Output Current(Typ) | 40 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ) | 2 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 10 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 8 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 2 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Diode-Connected FET Protects Op AmpsPDF, 49 Кб, Файл опубликован: 2 окт 2000
Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
