Datasheet Texas Instruments SN74AUCH16244DGVR — Даташит
Серия | SN74AUCH16244 |
Модель | SN74AUCH16244DGVR |
16-битный буфер/драйвер с выходами с 3 состояниями 48-TVSOP от -40 до 85
SN74AUCH16244 datasheet
PDF, 852 Кб, Версия: E, Файл опубликован: 1 ноя 2002
Купить SN74AUCH16244DGVR на РадиоЛоцман.Цены — от 90 до 193 ₽ 13 предложений от 10 поставщиков Buffer, Non-Inverting 4 Element 4 Bit per Element 3-State Output 48-TVSOP | |||
SN74AUCH16244DGVR Texas Instruments | 90 ₽ | ||
SN74AUCH16244DGVR Texas Instruments | 97 ₽ | ||
SN74AUCH16244DGVR Texas Instruments | 102 ₽ | ||
SN74AUCH16244DGVR Texas Instruments | по запросу |
Pin | 48 |
Package Type | DGV |
Industry STD Term | TVSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | MJ244 |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1.05 |
Pitch (мм) | .4 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 16 |
F @ Nom Voltage(Max) | 250 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -9/9 мА |
Package Group | TVSOP |
Package Size: mm2:W x L | 48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AUC |
VCC(Max) | 2.7 В |
VCC(Min) | 0.8 В |
Voltage(Nom) | 0.8,1.2,1.5,1.8,2.5 В |
tpd @ Nom Voltage(Max) | 5.4,2.8,1.9,1.8 нс |
- Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUCH16244 (4)
- SN74AUCH16244DGGR SN74AUCH16244DGVR SN74AUCH16244GQLR SN74AUCH16244ZQLR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
