Datasheet Texas Instruments CD74HC4049NSRG4 — Даташит
Серия | CD74HC4049 |
Модель | CD74HC4049NSRG4 |
![Datasheet Texas Instruments CD74HC4049NSRG4](http://www.ti.com/graphics/folders/partimages/CD74HC4049.jpg)
Высокоскоростные шестнадцатеричные инвертирующие буферы КМОП-логики 16-SO от -55 до 125
CD54HC4049, CD74HC4049, CD54HC4050, CD74HC4050 datasheet
PDF, 649 Кб, Версия: I, Файл опубликован: 4 фев 2005
![]() 12 предложений от 9 поставщиков new in stock for immediate delivery | |||
CD74HC4049NSRG4 Texas Instruments | 9.30 ₽ | ||
CD74HC4049NSRG4 Texas Instruments | 9.51 ₽ | ||
CD74HC4049NSRG4 Texas Instruments | от 14 ₽ | ||
CD74HC4049NSRG4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | NS |
Industry STD Term | SOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | HC4049M |
Width (мм) | 5.3 |
Length (мм) | 10.3 |
Thickness (мм) | 1.95 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Bits | 6 |
F @ Nom Voltage(Max) | 28 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -4/4 мА |
Package Group | SO |
Package Size: mm2:W x L | 16SO: 80 mm2: 7.8 x 10.2(SO) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | HC |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 6 В |
tpd @ Nom Voltage(Max) | 18 нс |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD74HC4049 (14)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
