Datasheet Texas Instruments OPA2356AIDGKTG4 — Даташит
Серия | OPA2356 |
Модель | OPA2356AIDGKTG4 |
2,5 В, 200 МГц GBW, двойной КМОП-операционный усилитель 8-VSSOP от -40 до 125
OPA356, 2356: 200MHz, Video CMOS Operational Amplifier datasheet
PDF, 817 Кб, Версия: A, Файл опубликован: 7 ноя 2001
Купить OPA2356AIDGKTG4 на РадиоЛоцман.Цены — от 110 до 309 ₽ 13 предложений от 10 поставщиков 2.5V, 200MHz GBW, CMOS Dual Op Amp 8-VSSOP -40℃ to 125℃_x0000__x0000_ | |||
OPA2356AIDGKTG4 Texas Instruments | 110 ₽ | ||
OPA2356AIDGKTG4 Texas Instruments | 147 ₽ | ||
OPA2356AIDGKTG4 Texas Instruments | 213 ₽ | ||
OPA2356AIDGKTG4 Texas Instruments | по запросу |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | AYI |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
2nd Harmonic | 81 dBc |
3rd Harmonic | 93 dBc |
@ MHz | 1 |
Acl, min spec gain | 1 V/V |
Additional Features | Shutdown |
Архитектура | CMOS,Voltage FB |
BW @ Acl | 450 МГц |
CMRR(Min) | 66 дБ |
CMRR(Typ) | 80 дБ |
GBW(Typ) | 450 МГц |
Input Bias Current(Max) | 50 pA |
Iq per channel(Max) | 11 мА |
Iq per channel(Typ) | 8.3 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 7 uV/C |
Output Current(Typ) | 100 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 300 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.5 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 5.8 нВ/rtГц |
Vn at Flatband(Typ) | 5.8 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 9 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2356 (8)
- OPA2356AID OPA2356AIDG4 OPA2356AIDGKR OPA2356AIDGKRG4 OPA2356AIDGKT OPA2356AIDGKTG4 OPA2356AIDR OPA2356AIDRG4
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
