Datasheet Texas Instruments OPA121KP — Даташит
Серия | OPA121 |
Модель | OPA121KP |
Недорогой прецизионный операционный усилитель Difet 8-PDIP
Low Cost Precision Difet® Operational Amplifier datasheet
PDF, 500 Кб, Файл опубликован: 27 сен 2000
13 предложений от 10 поставщиков Low Cost Precision Difet OPERATIONAL AMPLIFIER | |||
OPA121KP Texas Instruments | от 486 ₽ | ||
OPA121KP1 | по запросу | ||
OPA121KP Burr-Brown | по запросу | ||
OPA121KP(BX-13DIP) | по запросу |
Pin | 8 |
Package Type | P |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.35 |
Length (мм) | 9.81 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | OPA121KU |
Replacement Code | F |
Additional Features | Vos Adj Pin |
Approx. Price (US$) | 6.16 | 1ku |
Архитектура | FET |
CMRR(Min)(dB) | 82 |
CMRR(Typ)(dB) | 100 |
GBW(Typ)(MHz) | 2 |
Input Bias Current(Max)(pA) | 5 |
Iq per channel(Max)(mA) | 4 |
Iq per channel(Typ)(mA) | 2.5 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 3 |
Operating Temperature Range(C) | 0 to 70 |
Output Current(Typ)(mA) | 40 |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 2 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 36 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 10 |
Vn at 1kHz(Typ)(nV/rtHz) | 8 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 2 |
RoHS | Не совместим |
- Diode-Connected FET Protects Op AmpsPDF, 49 Кб, Файл опубликован: 2 окт 2000
Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step. - Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA121 (7)
- OPA121KM OPA121KM3 OPA121KP OPA121KP4 OPA121KU OPA121KU/2K5 OPA121KUE4
