Datasheet Texas Instruments UC3906QTR — Даташит
Серия | UC3906 |
Модель | UC3906QTR |
Зарядное устройство для линейных свинцово-кислотных аккумуляторов 20-PLCC от -20 до 70
Sealed Lead-Acid Battery Charger datasheet
PDF, 4.3 Мб, Версия: C, Файл опубликован: 23 май 2005
Купить UC3906QTR на РадиоЛоцман.Цены — от 71 до 946 ₽ 14 предложений от 12 поставщиков Микросхема: IC BATT CHG LEAD ACID 20PLCC | |||
UC3906QTR Texas Instruments | 71 ₽ | ||
UC3906QTR Texas Instruments | 336 ₽ | ||
UC3906QTR Texas Instruments | от 708 ₽ | ||
UC3906QTR Texas Instruments | по запросу |
Pin | 20 |
Package Type | FN |
Industry STD Term | PLCC |
JEDEC Code | S-PQCC-J |
Маркировка | UC3906Q |
Width (мм) | 8.96 |
Length (мм) | 8.96 |
Thickness (мм) | 4.06 |
Pitch (мм) | 1.27 |
Max Height (мм) | 4.57 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | UC2906DW |
Replacement Code | F |
Approx. Price (US$) | 2.75 | 1ku |
Cell Chemistry | Lead Acid |
Charge Current(Max)(A) | 2 |
Charging Control Topology | Linear Charger |
Control Interface | Standalone (RC-Settable) |
Package Group | PLCC |
Package Size(mm2=WxL) | 20PLCC: 98 mm2: 9.9 x 9.9 |
Vin(Max)(V) | 40 |
RoHS | Не совместим |
- U-104 Improved Charging Methods for Lead-Acid Batteries Using the UC3906PDF, 331 Кб, Файл опубликован: 5 сен 1999
This application note describes the operation and application of the UC3906 sealed lead-acid battery-charger IC. Several charging circuits using this IC are described, along with expected improvements in battery performance. This note also discusses uses for the many auxiliary functions of the part. - U-131 Simple Switchmode Lead-Acid Battery ChargerPDF, 206 Кб, Файл опубликован: 5 сен 1999
Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
Серия: UC3906 (10)
- Semiconductors > Power Management > Battery Management Products > Battery Charger IC
