Datasheet Texas Instruments SN74LVT162240DL — Даташит
Серия | SN74LVT162240 |
Модель | SN74LVT162240DL |
16-битные буферы/драйверы ABT 3,3 В с выходами с 3 состояниями 48-SSOP от -40 до 85
3.3-V ABT 16-Bit Buffers/Drivers With 3-State Outputs datasheet
PDF, 338 Кб, Версия: A, Файл опубликован: 28 ноя 2006
Купить SN74LVT162240DL на РадиоЛоцман.Цены — от 55 до 309 ₽ 15 предложений от 11 поставщиков Микросхема: IC BUFFER INVERT 3.6V 48SSOP | |||
SN74LVT162240DL Texas Instruments | 55 ₽ | ||
SN74LVT162240DL Texas Instruments | 71 ₽ | ||
SN74LVT162240DL Texas Instruments | 76 ₽ | ||
TPS65146RGE Texas Instruments | 309 ₽ |
Pin | 48 |
Package Type | DL |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | LVT162240 |
Width (мм) | 7.49 |
Length (мм) | 15.88 |
Thickness (мм) | 2.59 |
Pitch (мм) | .635 |
Max Height (мм) | 2.79 |
Mechanical Data | Скачать |
Bits | 16 |
F @ Nom Voltage(Max) | 160 Mhz |
ICC @ Nom Voltage(Max) | 0.005 мА |
Output Drive (IOL/IOH)(Max) | -12/12 мА |
Package Group | SSOP |
Package Size: mm2:W x L | 48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVT |
VCC(Max) | 3.6 В |
VCC(Min) | 2.7 В |
Voltage(Nom) | 3.3 В |
tpd @ Nom Voltage(Max) | 4.6 нс |
- LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT162240 (4)
- SN74LVT162240DGGR SN74LVT162240DGVR SN74LVT162240DL SN74LVT162240DLG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
